HBL5679C
HBL5679C
    HUBBELL(哈伯尔公司)
HBL5679C 数据手册
Straight Blade Devices Straight Blade Devices 15 and 20 Ampere, 250 Volts 2 Pole, 3 Wire Grounding Insulgrip® and Valise® Connector Bodies and Flanged Receptacles G NEMA 6-15R 15A 250V UL CSA Connector Bodies G NEMA 6-20R 20A 250V UL Listed Insulgrip® 2.78" (70.6) Description Cord Diameter Catalog Numbers Insulgrip® Connector Body, black and white nylon, multiple drive screws. .230"-.720" (5.8-18.3) HBL5669C HBL5469C Valise® Connector Body, yellow nylon. .220"-.660" (5.6-16.8) HBL5669VY HBL5469VY 1.53" (38.9) 1.41" (35.8) HBL5669C Note: See page A-45 for accessories. 1.50" (38.1) 1.13" (28.7) HBL5669VY 2.56" (65.0) 2.19" (55.63) Flanged Receptacles .16" (4.1) Dia. Description Catalog Numbers Nylon casing, multiple drive screws. HBL5679C HBL5479C 1.72" (43.7) 1.72" (43.7) HBL5679C Stainless steel flange, brown phenolic HBL5656 – housing (mounting screws packaged separately). Notes: Connector bodies are not HP rated. *Watertight connectors IP55 suitability when closure plug inserted or when installed and used properly with mating Elastogrip watertight plug. See page A-45 for accessories. .20" Dia. (5.1) 1.47" (37.3) 2.06" (52.3) 1.09" (27.7) HBL5656 Dimensions in Inches (mm) www.hubbell-wiring.com A-31 15 and 20 Ampere, 250 Volts Connector Bodies & Flanged Receptacles 2.63" (66.88)
HBL5679C 价格&库存
很抱歉,暂时无法提供与“HBL5679C”相匹配的价格&库存,您可以联系我们找货
