HBL5362SA
HBL5362SA
    HUBBELL(哈伯尔公司)
HBL5362SA 数据手册
SPIKESHIELD® Power Quality Products Power Quality Products TVSS Products Straight Blade, 2 Pole, 3 Wire Grounding 15 and 20 Ampere, 125 Volts AC 60 Hz Specification Grade and Hospital Grade Surge Suppression Duplex and 4-PLEX® Receptacles Description Surge suppression receptacles with light, 240 joules/15000A per mode. Surge suppression receptacles with light and alarm, 240 joules/15000A per mode. Isolated ground, surge suppression receptacles with light and alarm, 240 joules/15000A per mode. 4-PLEX surge suppression receptacles with lights. 80 joules/6500A per mode. Color Blue Ivory Office White Blue Ivory Gray White Office White Blue Ivory Gray White Orange Office White Blue Ivory NEMA 5-15R 15A 125V UL CSA NEMA 5-20R 20A 125V UL CSA Catalog Numbers HBL5260SA HBL5360SA HBL5260ISA HBL5360ISA HBL5260OWSA HBL5360OWSA HBL5262SA HBL5362SA HBL5262ISA HBL5362ISA HBL5262GYSA HBL5362GYSA HBL5262WSA HBL5362WSA HBL5262OWSA HBL5362OWSA IG5262SA IG5362SA IG5262ISA IG5362ISA IG5262GYSA IG5362GYSA IG5262WSA IG5362WSA IG5262OSA IG5362OSA IG5262OWSA IG5362OWSA HBL415S HBL420S HBL415IS HBL420IS Circuit Guard, Hospital Grade Duplex Receptacles Description Surge suppression receptacles with light and alarm, 240 joules/15000A per mode. Isolated ground, surge suppression receptacles with light and alarm, 240 joules/15000A per mode. 4-PLEX surge suppression receptacles with lights, 80 joules/6500A per mode. 1.23” (31.2) W W Circuit Guard®, Specification Grade Duplex Receptacles 1.30” (33.0) G G Color Blue Ivory Gray White Red Blue Ivory Gray White Orange Red Blue Ivory Catalog Numbers HBL8262SA HBL8362SA HBL8262ISA HBL8362ISA HBL8262GYSA HBL8362GYSA HBL8262WSA HBL8362WSA HBL8262RSA HBL8362RSA IG8262SA IG8362SA IG8262ISA IG8362ISA IG8262GYSA IG8362GYSA IG8262WSA IG8362WSA IG8262OSA IG8362OSA IG8262RSA IG8362RSA – HBL420HS – HBL420HIS Color Blue Ivory Ivory Catalog Numbers HBL4APBL HBL4API HBL4PBI 3.28” 2.62” (83.3) (66.5) 1.13” (28.7) 1.75” (44.5) HBL5262GYSA 1.30” (33.0) 1.23” (31.2) 3.28” 2.62” (83.3) (66.5) 1.13” (28.7) 1.75” (44.5) IG5362SA 1.30” (33.0) 1.23” (31.2) 4-PLEX Accessories Description 4-PLEX adapter plates for 1 and 2 gang, and 4” (101.6) square device boxes. 4-PLEX portable box. Portable 4” (101.6) square box with cord grip. Accepts up to .66” (16.8) diameter cord. Note: 4-PLEX box is not UL Listed. 3.28” 2.62” (83.3) (66.5) 1.13” (28.7) 1.75” (44.5) Wall Plates Dimensions in Inches (mm) www.hubbell-wiring.com HBL8362ISA .92" (23.4) .1" (2.5) TVSS Products High-Impact Nylon Stainless Steel (S/S) Configuration Color Standard Mid-Size Plated Steel Brass Blue – SPJ26C* Chrome CH26 Smooth S/S S26 Blue – SPJ26 Brass BP26 Smooth S/S SJ26Ž Ivory – PJ26C* Smooth Brass B26 Ivory HPS1I PJ26 Gray HPS1GY PJ26G White HPS1WA PJ26W O White HPS1OW – 1-gang Orange IGHPS1** – Red HPS1R PJ26R Notes: *Premarked “COMPUTER ONLY.” Lettering is block 1 /4” high. **Premarked “ISOLATED GROUND.” Lettering is block 1 /4” high. ŽJumbo size plate. See Section A for technical data for 4-PLEX devices. For technical information, see page J-19. 4.30" sq. (109.2) 3.02" (76.7) 3.38" (85.9) HBL415S J-15
HBL5362SA 价格&库存
很抱歉,暂时无法提供与“HBL5362SA”相匹配的价格&库存,您可以联系我们找货
