HBL7464V
HBL7464V
    HUBBELL(哈伯尔公司)
HBL7464V 数据手册
Product Datasheet HBL7464V -- Twist-Lock Valise Connector Body 2P2W, 15A 125V, ML-1R, Black Nylon Product Specifications Product Type Product Item Plug Wiring Scheme 2-Pole, 2-Wire Non-Grounding Amperage 15A Voltage 125V AC NEMA Configuration ML-1P Item Style Valise Device Color Black Cord Dia. .218"-.375" (5.5-9.5) Housing Material Black nylon Terminal Clamp Material Cold rolled steel-nickel-plated Terminal Screw Material #8-32 Steel (copper flash, nickel plate & molykote) Cord Clamp Screw Material Steel - zinc plated Multi-drive Body Holding Screw Material Steel, zinc plated Multi-drive Ratings Molded In or Stamped On Catalog No Permanently ink marked on product Dielectric Voltage Withstand 2,000V minimum Current Interrupting Certified for current interrupting at full rated current Temperature Rise Max 30C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of .75. Cord Accommodation Round portable service cords of diameters commensurate with the device rating as defined in UL Standard 62, CSA C22.2 No. 49. Terminal Accommodation 15A #14 AWG Terminal Identification Terminals identified in accordance with UL 498 (X, Y, Z, White, Green) Flammability HB or better per UL 94 or CSA 22.2 No. 0.6 Operating Temperatures Maximum Continuous 75 C Minimum -40 C (w/o impact) Moisture Resistance IP20 Listings UL UPC Number 783585237251 Weight in LBs 0.05 Link to Drawing Library Click here for Library Link to PDF Catalog Click here for Catalog NEMA Configuration
HBL7464V 价格&库存
很抱歉,暂时无法提供与“HBL7464V”相匹配的价格&库存,您可以联系我们找货
