HBL1281
HBL1281
    HUBBELL(哈伯尔公司)
HBL1281 数据手册
Switches, Single Pole 20A, 120-277V AC PresSwitch® Features Large brass binding head screws with deep slots Thread cleaning captive mounting screw Strip gauge for accurate wiring Ordering Information Description Nylon actuator, side wired only Toggle Color Brown UPC 783585016818 Catalog Number HBL1281 Listings UL Listed CSA Certified Specifications Top Material Base Material Toggle Material Contacts Terminal Screws Ground Screw Thermoset Thermoset Nylon Silver Alloy Brass Brass (Green) Performance Electrical Dielectric Voltage Max. Continuous Current Max. Working Voltage Overload Temperature Rise Withstands 1500V AC minimum for 1 minute 20A 277V AC Minimum 4.8 times rated current for 100 cycles 30°C maximum at rated current Mechanical Terminal Accommodations #14 AWG min. - #10 AWG max. solid and stranded copper wire only Environmental Flammability Operating Temperature UL 94V-2 Max. continuous: 75°C; Min. continuous: -40°C without impact Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. Online Resources Customer Use Drawing eCatalog
HBL1281 价格&库存
很抱歉,暂时无法提供与“HBL1281”相匹配的价格&库存,您可以联系我们找货
