HBL1221
HBL1221
    HUBBELL(哈伯尔公司)
HBL1221 数据手册
Switches Section C Switches Index Rating Features and Benefits 15A, 20A & 30A, 120-277V AC 15A & 20A, 120-277V AC 15A & 20A, 120-277V AC 15A, 20A & 30A, 120-277V AC 15A & 20A, 347V AC 15A & 20A, 120-277V AC 15A & 20A, 120-277V AC 15A & 20A, 120-277V AC 15A, 20A & 30A, 120-277V AC 30A, 40A & 60A, 600V AC 30A, 60A & 100A, 600V AC 30A & 60A, 600V AC Type Page Number Toggle Switch C-3 Industrial/Institutional Toggle and Lock Type C-4 Momentary Contact, Three Position, Two Circuit, Center Off C-4 Lighted Toggle C-5 Pilot Light Toggle C-5 Industrial/Institutional Toggle and Lock Type C-5 Construction and Commercial Toggle C-6 Style Line® Rocker, Lighted and Pilot Light C-7 ® Push Button PresSwitch Switches C-8 Maintained Contact Three Position, Two Circuit, Center Off C-9 Incandescent Dimmers and Fan Speed Controls C-10–11 Panel Mount Bat Handle Switches C-12–13 Push Button Stations C-14–16 Manual Motor Controllers and Enclosures C-17–19 UL Type 4X Unfused Disconnect Switch C-20 UL Type 4X Fused Disconnect Switch C-21–22 Accessories C-23–25 Switch Technical Information C-26 Manual Motor Controllers Technical Information C-27 UL, CSA & Fed. Spec. Listing Data C-28 Dimmer Ganging and Derating Chart C-29 Toggle Switch Wiring Diagrams C-30–31 Disconnect Switch Technical Information C-32 Index Dimensions in Inches (mm) www.hubbell-wiring.com Switches AC Switches Switches AC Toggle Switches Industrial/Institutional – Heavy Duty Features and Benefits Thread cleaning captive mounting screw. Steel, nickel plated bridge is corrosion resistant. Strip gauge for accurate wiring. Large silver cadmium oxide contacts reduce contact erosion providing long life. Prominent amperage marking allows easy identification of rating. Abuse resistant nylon toggle. Back wire entrance points for terminations accept two wires for feed thru capability, avoiding pigtailing. Color coded base identifies amperage when terminating connections, 15A-Blue, 20A-Red, 30A-Green. One piece rivetless copper alloy spring contact arm & terminal plate assures proper contact alignment providing long life. Large brass binding head screws with deep slots secure wire connections. One piece integral grounding terminal with #8 brass screw provides a low resistance ground path. Stainless steel automatic grounding clip assures grounding continuity between mounting strap and metal wall box. Thermoplastic elastomer rocker assures precise alignment of carbon steel coil compression spring. Permanently lubricated assembly provides long life and trouble free operation. Heavy duty nylon toggle resists abuse and chemical attack making it suitable for use in the toughest environments. One piece integral grounding terminal with #8 brass screw allows compliance to NEC® . Stainless steel automatic grounding clip assures grounding continuity between mounting strap and metal wall box. Steel nickel plated mounting strap provides a corrosion resistant finish. www.hubbell-wiring.com C-3 Features and Benefits Dimensions in Inches (mm) One piece rivetless copper alloy spring contact arm and terminal plate assures proper contact alignment reducing heat rise. Large silver cadmium oxide contacts reduce contact erosion and prevent welding, providing long life. Switches AC Switches 15, 20 and 30 Ampere, 120-277 Volts AC Industrial – Institutional, Heavy Duty Specification Grade Toggle and Lock Type AC Switches with Ground Screw F #6-32 TAP 3.28" (83.3) 2.38" (60.5) 2.28" (57.9) 1.05" (26.7) 1.0" (25.4) 1.25" (31.8) HBL1221 #6-32 TAP 3.28" 2.38" (83.3) (60.5) 2.28" (57.9) 1.05" (26.7) 1.0" (25.4) 1.25" (31.8) HBL1221L and Key #6-32 TAP 3.28" (83.3) 2.38" (60.5) 2.28" (57.9) 1.05" (26.7) 1.0" (25.4) 1.25" (31.8) HBL3031 Operates current style AC locking switches . e.g.: HBL1221L ACTUATE Operates old style AC locking switches. e.g.: 1221L (One key furnished with each lock switch.) IN SE Toggle and Lock RT HBL1209 #6-32 TAP 3.28" (83.3) 2.38" (60.5) 2.28" (57.9) 1.05" (26.7) 1.0" (25.4) 1.25" (31.8) HBL1557 C-4 Specification Grade AC Switches, Back and Side Wired 15A, 120-277V AC Description Brown nylon toggle. Ivory nylon toggle. Gray nylon toggle. White nylon toggle. Red nylon toggle. Lock type. Key for lock switches. Catalog Numbers Single Pole Double Pole HBL1201 HBL1202 HBL1201I HBL1202I HBL1201GY – HBL1201W – HBL1201R – HBL1201L** HBL1202L** HBL1209* Three Way HBL1203 HBL1203I HBL1203GY – – HBL1203L** Four Way HBL1204 HBL1204I HBL1204GY – – HBL1204L** Catalog Numbers Single Pole Double Pole HBL1221 HBL1222 HBL1221I HBL1222I HBL1221GY HBL1222GY HBL1221W HBL1222W HBL1221R HBL1222R HBL1221BK HBL1222BK HBL1221L** HBL1222L** HBL1209* Three Way HBL1223 HBL1223I HBL1223GY HBL1223W HBL1223R HBL1223BK HBL1223L** Four Way HBL1224 HBL1224I HBL1224GY HBL1224W HBL1224R HBL1224BK HBL1224L** 20A, 120-277V AC Description Brown nylon toggle. Ivory nylon toggle. Gray nylon toggle. White nylon toggle. Red nylon toggle. Black nylon toggle. Lock type. Key for lock switches. 30A, 120-277V AC Description Brown nylon toggle. Ivory nylon toggle. Catalog Numbers Single Pole Double Pole HBL3031 HBL3032 HBL3031I HBL3032I Three Way HBL3033 HBL3033I Momentary Contact, Specification Grade, Back and Side Wired Three Position, Two Circuit, Center Off. UL & CSA Only RT SE IN S Fed.Spec. Catalog Numbers Description 15A, 120-277V AC 20A, 120-277V AC Brown nylon toggle. HBL1556 HBL1557 Ivory nylon toggle. HBL1556I HBL1557I Gray nylon toggle. HBL1556GY HBL1557GY Red nylon toggle. HBL1556R – White nylon toggle. – HBL1557W Lock type. HBL1556L HBL1557L Key for lock switches. HBL1209* Notes: Keys are supplied with each lock switch. For extra keys order HBL1209. For technical data see page C-26. See Section K for wall plates. For accessories see pages C-23–C-25. See pages C-30 and C-31 for wiring diagrams. * Not UL Listed, CSA Certified ** Not Fed Spec HP Conversion Chart 15A 20A 30A 120V .5 HP 1 HP 2HP 208V 240V 1.5HP 2HP 2HP 2HP 2HP 2HP www.hubbell-wiring.com 277VAC 2HP 2HP 2HP Dimensions in Inches (mm) Switches AC Switches 15, 20 and 30 Ampere, 120-277 Volts AC Industrial – Institutional, Heavy Duty Specification Grade Toggle Type Lighted and Pilot Light AC Switches with Ground Screw F S Fed.Spec. #6-32 TAP Specification Grade, Lighted and Pilot Light Toggle Switches, Back and Side Wired Lighted Toggle (light on with load off) 3.28" (83.3) 2.38" (60.5) Catalog Numbers Rating Description Single Pole Double Pole 15A 120-277V AC Ivory nylon toggle. HBL1201IL – 20A 120-277V AC Ivory nylon toggle. HBL1221IL – 20A 120-277V AC Clear polycarbonate HBL1221ILC – toggle. 2.28" (57.9) 1.05" (26.7) 1.0" (25.4) Three Way HBL1203IL HBL1223IL HBL1223ILC 1.25" (31.8) HBL1221ILC Pilot Light (light on with load on) Rating Description 15A 120-277V AC Red polycarbonate toggle. 20A 120-277V AC Red polycarbonate toggle. 20A 120-277V AC Clear polycarbonate toggle. 20A 120-277V AC Green polycarbonate toggle. 30A 120-277V AC Red polycarbonate toggle. 15A, 347V AC HBL1221PL HBL1222PL HBL1223PL HBL1221PLC – HBL1223PLC HBL1221PLG – – 3.28" (83.3) 2.38" (60.5) 2.28" (57.9) 1.05" (26.7) 1.0" (25.4) 1.25" (31.8) HBL1221PL HBL3031PL HBL3032PL – 1.30" (33.0) only Catalog Numbers Description Single Pole Double Pole Three Way Four Way Brown nylon toggle. HBL18201CN – HBL18203CN – Ivory nylon toggle. HBL18201ICN – HBL18203ICN HBL18204ICN Lock type. HBL18201LCN – HBL18203LCN – Key for lock switches. HBL1209 20A, 347V AC #6-32 TAP 4.06" (103.1) 3.53" (90.0) 2.41" (61.2) 2.27" (57.7) 1.11" (28.2) only Catalog Numbers Single Pole Double Pole Three Way Four Way HBL18221CN – HBL18223CN – HBL18221ICN – HBL18223ICN – HBL18221CN Notes: Keys are supplied with each lock switch. For extra keys order HBL1209. For technical data see page C-26. See Section K for wallplates. For accessories see pages C-23 to C-25. See pages C-30 and C-31 for wiring diagrams. Operates current style AC locking switches RT SE IN ACTUATE Operates old style AC locking switches (One key furnished with each lock switch.) IN SE RT HBL1209 HP Conversion Chart 15A 20A 30A 120V .5 HP 1 HP 2HP 208V 240V 1.5HP 2HP 2HP 2HP 2HP 2HP Dimensions in Inches (mm) 277VAC 2HP 2HP 2HP www.hubbell-wiring.com C-5 Ligthed, Pilot Light and 347V AC Description Brown nylon toggle. Ivory nylon toggle. #6-32 TAP Catalog Numbers Single Pole Double Pole Three Way HBL1201PL – HBL1203PL Switches AC Switches 15 and 20 Ampere, 120-277 Volts AC Construction and Commercial Series Specification Grade AC Toggle Switches with Ground Screw 1.25" (31.8) #6-32 TAP F S Fed.Spec. 3.28" 2.38" (83.3) (60.5) 2.28" (57.9) 1.13" (28.7) 1.31" (33.2) CS1201I #6-32 TAP 1.25" (31.8) 3.28" 2.38" (83.3) (60.5) Description Brown toggle. Ivory toggle. Gray toggle. White toggle. Office white toggle. Catalog Numbers Single Pole Double Pole CS1201 – CS1201I – CS1201GY – CS1201W – CS1201OW – Three Way Four Way CS1203 – CS1203I – CS1203GY – CS1203W – CS1203OW – Catalog Numbers Single Pole Double Pole CS1221 CS1222 CS1221I CS1222I CS1221GY CS1222GY CS1221W CS1222W CS1221R CS1222R CS1221BK CS1222BK CS1221OW CS1222OW Three Way CS1223 CS1223I CS1223GY CS1223W CS1223R CS1223BK CS1223OW 20A, 120-277V AC 2.28" (57.9) 1.13" (28.7) 1.31" (33.2) CS1221 #6-32 TAP Construction Series Heavy Duty Specification Grade AC Toggle Switches, Back and Side Wired 15A, 120-277V AC 1.25" (31.8) Description Brown toggle. Ivory toggle. Gray toggle. White toggle. Red toggle. Black toggle. Office white toggle. Four Way CS1224 CS1224I CS1224GY CS1224W CS1224R CS1224BK CS1224OW Commercial Series Heavy Duty Specification Grade AC Toggle Switches, Side Wired Only. 15A, 120-277V AC Construction and Commercial Toggle 3.28" 2.38" (83.3) (60.5) 2.28" (57.9) 1.13" (28.7) 1.31" (33.2) Description Brown toggle. Catalog Numbers Single Pole Double Pole Three Way CS115 – CS315 Ivory toggle. Gray toggle. White toggle. Office white toggle. CS115I CS115GY CS115W CS115OW – – – – CS315I CS315GY CS315W CS315OW Four Way – – – – – CS115I #6-32 TAP 1.25" (31.8) 20A, 120-277V AC 1.31" (33.2) Catalog Numbers Description Single Pole Double Pole Three Way Four Way Brown toggle. CS120 – CS320 – Ivory toggle. CS120I – CS320I – Gray toggle. CS120GY – CS320GY – White toggle. CS120W – CS320W – Office white toggle. CS120OW – CS320OW – Notes: See Section K for wall plates. See page C-30 for wiring diagrams. For accessories see pages C-23–C-25. 3.28" 2.38" (83.3) (60.5) 2.28" (57.9) 1.13" (28.7) CS120 HP Conversion Chart 15A 20A 30A C-6 120V .5 HP 1 HP 2HP 208V 240V 1.5HP 2HP 2HP 2HP 2HP 2HP www.hubbell-wiring.com 277VAC 2HP 2HP 2HP Dimensions in Inches (mm) Switches AC Switches 15 and 20 Ampere, 120-277 Volt AC Style Line® Specification Grade Rocker Switches Style Line Specification Grade AC Rocker Switches, Back and Side Wired 15A, 120-277V AC Description Brown rocker. Ivory rocker. Gray rocker. White rocker. Black rocker. Office white rocker. Catalog Numbers Single Pole Double Pole HBL2101 – HBL2101I – HBL2101GY – HBL2101WA – HBL2101BK – HBL2101OW – Three Way HBL2103 HBL2103I HBL2103GY HBL2103WA HBL2103BK HBL2103OW Four Way – – – – – – Catalog Numbers Single Pole Double Pole HBL2121 HBL2122 HBL2121I HBL2122I HBL2121GY HBL2122GY HBL2121WA HBL2122WA HBL2121BK HBL2122BK HBL2121OW HBL2122OW Three Way HBL2123 HBL2123I HBL2123GY HBL2123WA HBL2123BK HBL2123OW Four Way HBL2124 HBL2124I HBL2124GY HBL2124WA HBL2124BK HBL2124OW Style Line Specification Grade Lighted and Pilot Light AC Rocker Switches, Back and Side Wired 20A, 120V AC Lighted Rocker (light on with load off) Description Ivory rocker. White rocker. Self Grounding Clip 3.81" (96.7) 3.28" (83.3) 20A, 120-277V AC Description Brown rocker. Ivory rocker. Gray rocker. White rocker. Black rocker. Office white rocker. #6-32 TAP Catalog Numbers Single Pole Double Pole HBL2121IL – HBL2121ILWA – Three Way Four Way HBL2123IL – HBL2123ILWA – 20A, 120V AC Pilot Light Rocker (light on with load on) 1.12" (28.4) 1.48" (37.6) HBL2121 #6-32 TAP Self Grounding Clip 3.81" (96.7) 3.28" (83.3) 2.78" (70.6) 1.12" (28.4) 1.48" (37.6) HBL2121IL Four Way – Style Line® Rocker Switches Catalog Numbers Description Single Pole Double Pole Three Way Ivory rocker. HBL2121PL – – Note: See Section K for wall plates. See pages C-30 for wiring diagrams. For accessories see pages C-23. 2.78" (70.6) HP Conversion Chart 15A 20A 30A 120V .5 HP 1 HP 2HP 208V 240V 1.5HP 2HP 2HP 2HP 2HP 2HP Dimensions in Inches (mm) 277VAC 2HP 2HP 2HP www.hubbell-wiring.com C-7 Switches AC Switches 20 Ampere, 120-277 Volts AC PresSwitch® Push Button Switches 1.50" (38.1) 3.28" (83.3) 2.38" (60.5) .94" (23.9) .97" (24.6) 2.44" (62.0) #6-32 TAP HBL1281 Specification Grade, Side Wired Only Standard Type 20A, 120-277V AC Description Brown nylon actuator. Ivory nylon actuator. Catalog Numbers Single Pole Double Pole Three Way Four Way HBL1281 HBL1282 HBL1283* HBL1284* HBL1281I HBL1282I HBL1283I* HBL1284I* Momentary Type 20A, 120-277V AC Description Circuit normally closed, brown. Circuit normally open, brown. Catalog Numbers Single Pole Double Pole Three Way Four Way HBL1281MC* – – – HBL1281MO* – – – Lighted and Pilot Light PresSwitches, 120V AC Lighted Actuator (light on with load off) Description 15A, ivory nylon actuator. 20A, ivory nylon actuator. 1.50" (38.1) Catalog Numbers Single Pole Double Pole Three Way Four Way – – – HBL1259I* HBL1287I – HBL1288I* – .94" (23.9) .97" (24.6) 20A, 120V AC Pilot Light Actuator (light on with load on) 3.28" (83.3) 2.38" (60.5) 2.44" (62.0) #6-32 TAP Push Button PresSwitch® HBL1297 Catalog Numbers Description Single Pole Double Pole Three Way Four Way Red nylon actuator. HBL1297 – HBL1298* – Notes: See Section K for wallplates. See pages C-30 and C-31 for wiring diagrams. For accessories see pages C-23–C-25. *Not Listed by UL or CSA. HP Conversion Chart 15A 20A 30A C-8 120V .5 HP 1 HP 2HP 208V 240V 1.5HP 2HP 2HP 2HP 2HP 2HP www.hubbell-wiring.com 277VAC 2HP 2HP 2HP Dimensions in Inches (mm) Switches AC Switches 15, 20 and 30 Ampere, 120-277 Volts AC Industrial – Institutional, Heavy Duty Specification Grade Three Position, Two Circuit, Center Off, Maintained Contact Switches 1.31 (33.2) 1.25 (31.8) #6-32 TAP Maintained Contact, Specification Grade, Back and Side Wired, Three Position, Two Circuit, Center Off Single Pole, Double Throw Description Brown nylon toggle. Ivory nylon toggle. White nylon toggle. Catalog Numbers 15A 120-277V AC HBL1381 HBL1381I – 20A 120-277V AC HBL1385 HBL1385I HBL1385W 30A 120-277V AC – – – 2.37 (60.2) 3.28 (83.3) HBL1381 Double Pole, Double Throw Catalog Numbers 15A 20A 30A Description 120-277V AC 120-277V AC 120-277V AC Brown nylon toggle. HBL1382 HBL1386 HBL1388 Ivory nylon toggle. HBL1382I HBL1386I HBL1388I Lock type. – HBL1386L – Key for lock switches. HBL1209 Notes: Keys supplied with each lock switch. For extra keys order HBL1209. See page C-31 for wiring diagrams. For accessories see pages C-23–C-25. For technical data see page C-26. #6-32 TAP 1.31 (33.2) 1.25 (31.8) 2.37 (60.2) 3.28 (83.3) HBL1386I AC Three Position, 2 Circuit Center Off Toggle Dimensions in Inches (mm) www.hubbell-wiring.com C-9 Switches AC Dimmers 600 to 2000 Watts, 120 Volts AC 60 Hz 2.75" (70.0) Architectural Grade Preset Slide Control 4.50" (114.3) 600 and 1000W Dimmer Fits Single-Gang Wall Boxes. AS63 and AS103 4.50" (114.3) 4.50" (114.3) Rating/Description Color Catalog Numbers Incandescent 600W, 120V AC, 60 Hz, White AS63 Control Single pole/three way - preset. 1000W, 120V AC, 60 Hz, White AS103 Single pole/three way - preset. 1500W, 120V AC, 60 Hz, White AS153 Single pole/three way - preset. 2000W, 120V AC, 60 Hz, White AS203 Single pole/three way - preset. Accessories Small plate kit for 600W Ivory AS1I and 1000W models. Includes White AS1W non-metallic trimplate and slide. Large plate kit for 1500W Ivory AS2I and 2000W models. Includes White AS2W non-metallic trimplate and slide. Note: The dimmers listed above can be wired for single pole or three way applications. 1500 and 2000W Dimmer Fits Single-Gang Wall Boxes. AS153 and AS203 2.75" (70.0) Architectural Grade Rotary Models 4.50" (114.3) 600 and 1000W Dimmer Fits Single-Gang Wall Boxes. AR61 and AR101 4.50" (114.3) AC Dimmers 4.50" (114.3) Rating/Description Incandescent 600W, 120V AC, 60 Hz. Control Single pole - push on/off. Three way - push on/off. 1000W, 120V AC, 60 Hz. Single pole - push on/off. Three way - push on/off. 1500W, 120V AC, 60 Hz, Single pole, rotary on/off. 2000W, 120V AC, 60 Hz, Single pole, rotary on/off. Accessories Small plate kit for 600W and 1000W models. Includes non-metallic trimplate and knob. Large plate kit for 1500W and 2000W models. Includes non-metallic trimplate and knob. Note: See page C-29 for ganging and derating. Color Catalog Numbers Beige Beige AR61 AR63 Beige Beige Beige AR101 AR103 AR151 Beige AR201 Beige White AR1BE AR1W Beige White AR2BE AR2W 1500 and 2000W Dimmer Fits Single-Gang Wall Boxes. AR151 and AR201 C-10 www.hubbell-wiring.com Dimensions in Inches (mm) Switches AC Dimmers 600 to 1000 Watts, 120 Volts AC 60 Hz 120V AC 60 Hz Fan Control Specification Grade Preset Slide Control Rating/Description Incandescent 600W 120V AC, 60 Hz, Control Single pole - preset. 600W 120V AC, 60 Hz, Three way - preset. 1000W 120V AC, 60 Hz, Single pole - preset. Color Catalog Numbers Ivory S61I White S61W Ivory S63I White S63W Brown S11BR Ivory S11I White S11W Gray S11GY Black S11BL 1000W 120V AC, 60 Hz, Ivory S13I Three way - preset. White S13W Gray S13GY Notes: Use Style Line® wall plates with preset slide control dimmers. See page C-29 for ganging and derating. 2.13" (54.1) 4.13" (104.9) 600 and 1000W Dimmer Fits Single-Gang Wall Boxes. S61I and S11I Rotary Model Rating/Description Color Catalog Numbers Incandescent 600W 120V AC, 60 Hz. Control Single pole - push on/off. Ivory R61I Three way - push on/off. Ivory R63I Fan Speed 5A, 120V AC, 60 Hz, Ivory RF5I Control Single pole. Accessories Replacement knob. Ivory RKI Replacement knob. White RKW Notes: Use standard toggle switch wall plates with rotary dimmers. See page C-29 for ganging and derating. 1.31" (33) 2.13" (54.1) 1.31" (33) 4.13" (104.9) 600W Dimmer Fits Single-Gang Wall Boxes. R61I AC Dimmers Dimensions in Inches (mm) www.hubbell-wiring.com C-11 Switches Switches Heavy Duty Panel Mount Bat Handle Switches 10A 250V AC 20A 125V AC Horsepower Rated 3/4 HP, 125-250V AC Description Single pole/ single throw. Terminal Screw Spade Catalog Numbers HBL11 HBL11SP OF .61" (15.5) F 1.13" (28.7) ON HBL11 .56" (14.2) Screw Terminal Shown Single pole/ single throw momentary. Screw Spade HBL11M HBL11SPM OF .61" (15.5) F 1.13" (28.7) ry nta me Mo ON .56" (14.2) Screw Terminal Shown Single pole/ double throw. Screw Spade HBL12 HBL12SP .61" (15.5) ON 1.13" (28.7) ON .56" (14.2) Screw Terminal Shown HBL123SP Single pole/ double throw 3-position center off. Screw Spade HBL123 HBL123SP .61" (15.5) ON 1.13" (28.7) OFF ON .56" (14.2) Screw Terminal Shown Specifications Impact Resistant Thermoplastic Body. Fine Silver Contacts. Knurled Nut, Hex Nut And Strap All Nickel Plated. Keyed Brass Bushing Nickel Plated. Brass Toggle Nickel Plated. Choice of Terminal Design: .250” (6.3) Male Tab Spade Type or 6/32 Screw Type. UL Recognized. .61" M Single pole/ Screw ON oment (15.5) ary double throw Spade 1.13" OFF (28.7) 3-position y tar center off ONomen M Screw Terminal Shown momentary. Note: All threaded stems 15 /32”–32 thread. HBL123MM HBL123SPMM .56" (14.2) 10A 240V AC 15A 120V AC Description Single pole/ single throw. Terminal Screw ON OF Catalog Number HBL118 F 0.62" (15.7) 1.78" 0.48" (12.2) (45.2) 0.31" (7.9) 0.37" (9.4) 0.56" (14.2) 0.67" (17.0) Note: 15 /32”–32 thread. Panel Mount Switches 4A 250V 8A 125V 10A 120V AC 1/3 HP 120V AC Description Single pole/ single throw. Terminal #18 Std AWG Copper Wire Leads 105° C Black. Catalog Number HBL11WL 0.56" (14.2) OFF 15/32-32 THRD Keyway .080 x .035 0.25" (6.4) 0.98" (24.9) 6.00" (152.4) 0.50" (12.7) 0.64" (16.3) Note: 15/32”–32 thread, keyway .080x.035. C-12 www.hubbell-wiring.com Dimensions in Inches (mm) Switches Switches Heavy Duty Panel Mount Bat Handle Switches 10A 250V AC 20A 125V AC Horsepower Rated 11/2 HP, 125-250V AC Description Double pole/ single throw. Terminal Screw .75" (19.1) Spade .47" (11.9) .80" (20.3) ON Catalog Numbers HBL21 HBL21SP 1.30" (33.0) Spade Terminal Shown Double pole/ double throw. Screw Spade HBL21 F OF .75" (19.1) .80" (20.3) ON HBL22 HBL22SP 1.30" (33.0) ON Screw Terminal Shown Double pole/ double throw 3 position center off. Screw Spade .75" (19.1) .80" (20.3) ON HBL223 HBL223SP 1.30" (33.0) OFF ON HBL223 Screw Terminal Shown Double pole/ double throw 3 position center off momentary. Screw Spade .75" (19.1) .80" (20.3) Mo ON me nta ry 1.30" (33.0) OFF ON Screw Terminal Shown HBL223MM HBL223SPMM y r nta me Mo Silicone SSB1 rubber boot. Notes: All threaded stems 15 /32”–32 thread. For information on 12V DC tapered handle switches see Section V, Marine Electrical Products. SSB1 4A 250V 8A 125V 10A 120V AC 1/3 HP 120V AC Description Single pole/ single throw. Terminal #18 Std AWG Copper Wire Leads 105° C Black. Catalog No. HBL11PBWL { { HBL11PBWL Panel Mount Switches Note: 15 /32”–32 thread, keyway .080 x .034. Dimensions in Inches (mm) www.hubbell-wiring.com C-13 Switches Switches Pendant Pushbutton Stations IP44 SUITABILITY PBS-Series Heavy Duty Pendant Pushbutton Stations NEMA 3R Description 2 button, single speed. 2 button, two speed. 4 button, single speed. 4 button, two speed. 6 button, single speed. 6 button, two speed. 8 button, single speed. 8 button, two speed. Product Dimensions, PBS Series PBS6 Style A 2 button 7.88” (200.0) 4 button 13.69” (347.6) 6 button 18.0” (457.2) 8 button 22.31” (566.7) Housing: Yellow vinyl rubber. Cable Entrance Threaded 1" NPT I.D. (25.4) 1.125" O.D. (28.6) A Catalog Numbers PBS2 PBS4 PBS6 PBS8 Two-Speed Single Break AC 35% PF DC IND Voltage 120V 240V 125V 250V Current 6A 3A .4A .2A Single-Speed Double Break AC 35% PF DC Voltage 120V 240V 125V Current 6A 3A 1.1A IND 250V .55A Pendent Pushbutton Stations 0.88" (22.4) Approx. Wt. Assembled 2.5 lbs 4.5 lbs 5.5 lbs 7.5 lbs Contact Interrupting Ratings, PBS Series 3.50" (88.9) 3.25" (82.6) Catalog Numbers PBS2 PBS22 PBS4 PBS42 PBS6 PBS62 PBS8 PBS82 C-14 www.hubbell-wiring.com Dimensions in Inches (mm) Switches Switches Pendant Pushbutton Stations PBS Series Parts and Accessories Replacement Inserts When the insert switches are in need of replacement, simply unplug the old insert and plug in a new one. Description Single speed insert momentary N.O. and N.C. On-Off insert (no mechanical interlock) Momentary, start-stop, reset-stop. 3 speed insert, momentary. Used to a maximum of 3 speed points. For five speed applications replace an existing terminal board with the TB5 terminal board and replace an existing insert with the five speed (MS5) insert. 5 speed insert, momentary. Used to a maximum of 5 speed points. Catalog Numbers PG2 PG6 PG2 PG6 MS2 MS5 MS2 MS5 Conversion Inserts In addition to single speed and two speed applications, preassembled units can be adapted to handle other applications. TB2 Description Catalog Numbers Terminal board Catalog No. TB2 is required for TB2 each insert switch PG2, PG6 and MS2. Terminal board Catalog No. TB5 is required for insert switch MS5. TB5 Accessories TB5 Description Catalog Numbers Indicator labels for replacement package contains 1 each: PBSLP hoist, trolley, bridge, forward-reverse, raise-lower, in-out, right left, east-west, north-south, reset-stop, start-stop, power, main hoist, aux. hoist, on-off, up-down. Rubber button cover for replacement purposes. PBSBC 120V red pilot light for 4, 6, and 8 button units only. PBSPL1* *Each pendant station can accommodate one of the pilot light in the 1.20” (30.6) diameter mounting hole. PBSBC PBSLP Pendent Pushbutton Station Accessories Kellems® Deluxe Aluminum Cord Fitting Outdoor or indoors where subject to moisture, splash or submersion. Kellems grips provide strain relief for multi-conductor cable. Description Cord Range Catalog Numbers Kellems grip. Kellems grip. .750-.875” (19 to 22.2) .875-1.00” (22.2 to 25.4) 07401023 07401025 PBSPL1 07401023 Dimensions in Inches (mm) www.hubbell-wiring.com C-15 Switches Switches Pendant Pushbutton Stations IP55 1.06" (26.9) SUITABILITY Compact Pendant Stations, CPB2 Series NEMA 4X Two Button Description Catalog Numbers Single-speed normally open-normally closed CPB20 without mechanical interlock. Single-speed with mechanical interlock between pushbuttons. CPB21 Two-speed with mechanical interlock between pushbuttons. CPB22 Included with product: nylon cord grip and sealing washer (must be installed to achieve NEMA 4X rating). Indication label pack. Cord dia. range .375”-.625” (9.5 - 15.9). Ambient temperatures: 25°F - 140°F (32°C-60°C). Typical applications: Package electric motor hoists. Remote control of machinery. 9.13" (231.9) 2.38" (60.5) CPB21 Contact Ratings, CPB2 Series Wiring Diagram CPB2 Series N.O.1 Com.1 Bott. N.O.2 Top TAB Two Speed* CPB22 N.C.1 N.O.1 Voltage 120V 240V 125V 250V Current 6A 3A 1.1A .55A Two-Speed AC 35% PF Voltage 120V 240V Current 3A 1.5A Bott. Top Single Speed* CPB21 Com.1 Bott. N.O.1 Ctr. Top Ctr. Monmentary (On / Off) CPB20 Single Speed AC 35% PF DC IND N.O.2 Ctr. Compact Pendent Pushbutton Stations * Mechanical “floating ball” interlock prevents activating both Pushbuttons simultaneously. C-16 www.hubbell-wiring.com Dimensions in Inches (mm) Switches AC Switches 30 Ampere, 600 Volts AC Industrial – Heavy Duty AC Manual Motor Controllers, Double and Three Pole (Without Overload Protection) and Enclosures IP44* 2.25" (57.1) 1.12" (28.4) SUITABILITY 30A 600V AC Manual Motor Controllers Double Pole Description 30A, double pole, single throw, AC manual motor controller, black nylon handle, side wired. 30A, double pole, single throw, AC manual motor controller, black nylon handle, back wired. HBL7832BW in HBL1390 Type 1 enclosure with non-metallic cover, 1 /2 ” and 3/4” knockouts on top, bottom and back of steel frame. HBL7832BW in HBL1370 metal Type 1 enclosure. HBL7832BW in HBL13R90 metal Type 3R enclosure. Catalog Numbers HBL7832 HBL7832BW 3.28" (83.3) 2.38" (60.5) 3.78" (96.0) (2) .20 Dia. HBL1392BW HBL7810BW HBL1372BW HBL13R92BW Catalog Numbers HBL7810UD HBL7810BW HBL1389BW 3.28" (83.3) 2.38" (60.5) 3.78" (96.0) HBL1379BW HBL13R89BW Description Type 1 enclosure for 30A switch with non metallic cover (without switch) with 1 /2 ” and 3/4” knockouts on top, bottom and back of steel frame. Type 1 enclosure for 30A switch with metallic cover (without switch) with 1 /2 ” and 3/4” knockouts on top, bottom and back of steel frame. Type 3R metal enclosure without switch. (2) .20 Dia. 4.72" (119.9) HBL13R90 Motor Rating 120V AC 240V AC 480V AC 2HP 5HP 10 HP 15HP 3HP 71 /2 HP 2.04" (51.8) 2.75" (69.9) 2.37" (60.2) SIDE VIEW HBL13R89BW / HBL13R90 HBL13R92BW 1.50" (38.1) 4 Knockouts .50'' (12.7) Type Noted ''B'' B 1.25" (31.8) 2.00" (50.8) 3.97" (100.8) 4.52" (114.8) B 2.00" (50.8) 3.00" (76.2) 3.31" (84.1) 2.62" (66.5) 1.06" (26.9) Mounting Surface HBL1389BW END VIEW HBL13R89BW / HBL13R90 HBL13R92BW (2) .13" (3.3) Dia.Holes .68" (17.3) 4.40" (111.8) 5.52" (140.2) 2.41" (61.2) .91" (23.1) (2) .27" (6.9) Dia. Holes BACK VIEW HBL1370/HBL1372BW/HBL1379BW Dimensions in Inches (mm) Phase 1 3 4.40" (111.8) 3 Mounting Feet with .25" (6.4) Dia. Hole BACK VIEW HBL13R89BW / HBL13R90 HBL13R92BW 2.44" (62.0) 2.75" (69.9) (2) .50'' & .75" Knockouts 600V AC 15HP 20HP Mounting Surface .19" (4.8) 2.41" (61.2) HBL1379BW .50'' x .75'' Knockout Each End 3.00" (76.2) HBL13R89BW END VIEW HBL1370/HBL1372BW/HBL1379BW www.hubbell-wiring.com C-17 Manual Motor Controllers and Enclosures Notes:* Enclosure rating. For technical data see page C-32 .09" (2.3) Mtg. Holes 3.20" (81.3) Catalog Numbers HBL1390 HBL1370 (4) #6-32 TAP HBL7810UD Enclosures 30A Double Pole 30A Three Pole Mtg. Holes 2.25" (57.1) 1.12" (28.4) Three Pole Description 30A, three pole, single throw, AC manual motor controller, black nylon handle, side wired. 30A, three pole, single throw, AC manual motor controller, black nylon handle, back wired. HBL7810BW in HBL1390 Type 1 enclosure with non-metallic cover, 1 /2 ” and 3/4” knockouts on top, bottom and back of steel frame. HBL7810BW in HBL1370 metal Type 1 enclosure. HBL7810BW in HBL13R90 metal Type 3R enclosure. (4) #6-32 TAP Switches Switches AC Switches 30 Ampere, 600 Volts AC Heavy Duty Manual Motor Controllers “Suitable as Motor Disconnect”* 30A 600V AC Double Pole Description 30A, double pole, single throw, AC manual motor controller, black nylon handle, side wired. HBL7832FWMD in HBL13R90MD Type 3R Enclosure. Catalog Numbers HBL7832FWMD HBL13R92MD 30A 600V AC Three Pole Description 30A, three pole, single throw, AC manual motor controller, black nylon handle, side wired. HBL7832FWMD in HBL13R90MD Type 3R Enclosure. Note: for technical data, see page C-27 * When protected by 30A max RK5 fuses. .09" (2.3) 2.04" (51.8) 2.75" (69.9) 6.50" (165.1) 2.37" (60.2) SIDE VIEW HBL13R92MD / HBL13R89MD Manual Motor Controllers and Enclosures C-18 4 Knockouts .50'' (12.7) Type Noted ''B'' 4.40" (111.8) B 1.25" (31.8) 480V AC 10HP 15HP B 2.00" (50.8) 2.00" (50.8) BACK VIEW HBL13R92MD / HBL13R89MD Motor Rating 120V AC 240V AC 2HP 5HP 3HP 71 /2 HP www.hubbell-wiring.com 3 Mounting Feet with .25" (6.4) Dia. Hole 3.00" (76.2) 3.31" (84.1) 1.06" (26.9) Mounting Surface END VIEW HBL13R92MD / HBL13R89MD 600V AC 15HP 20HP Phase 1 3 Dimensions in Inches (mm) Manual Motor Controllers and Enclosures 30A Double Pole 30A Three Pole HBL13R89MD Mounting Surface .19" (4.8) Product Catalog Numbers HBL7810FWMD Switches AC Switches 40 and 60 Ampere, 600 Volts AC Industrial – Heavy Duty AC Manual Motor Controllers, Double and Three Pole (Without Overload Protection) and Enclosures 3.38" (85.9) IP44* SUITABILITY 40A 600V AC Manual Motor Controllers Description Catalog Numbers 40A, double pole, single throw, AC manual motor controller, black nylon handle, side wired. HBL7842 40A, three pole, single throw, AC manual motor controller, black nylon handle, side wired. HBL7843 Note: Catalog numbers HBL7842 & HBL7843 dimensions are the same as HBL7810BW shown on C-17. .40" #10 (10.2) -32 TAP 3.28" (83.3) 2.38" 3.78" (96.0) (60.5) 2.82" (71.6) 2.31" (58.7) .20" DIA (5.1) 1.5" (38.1) 1.75" (44.5) HBL7862 60A 600V AC Manual Motor Controllers Description 60A, double pole, single throw, AC manual motor controller, black nylon handle, back wired. Same as HBL7862 except front wired. HBL7862FW in Type 3R enclosure. 60A, three pole, single throw, AC manual motor controller, black nylon handle, back wired. Same as HBL7863 except front wired. HBL7863FW in a Type 3R enclosure. Note: For technical data, see page C-27. 3.38" (85.9) Catalog Numbers HBL7862 HBL7862FW HBL16R92 HBL7863 HBL7863FW HBL16R93 .40" (10.2) 3.28" (83.3) 2.38" 3.78" (96.0) (60.5) 2.82" (71.6) 2.31" (58.7) .20" DIA (5.1) 1.5" (38.1) 4.40" (111.8) Description Catalog Number Type 3R metal enclosure without switch. HBL16R90 Note: 40 and 60A manual motor controllers are suitable for use with enclosure cat. no. HBL16R90. * Enclosure rating. Motor Rating 40A Double Pole 40A Three Pole 60A Double Pole 60A Three Pole 120V AC 2HP 3HP - 240V AC 5HP 71 /2 HP 10HP 10HP 480V AC 10HP 15HP 15HP 25HP 600V AC 15HP 20HP 20HP 30HP 10.11" (256.8) Phase 1 3 1 3 HBL16R93 3 Mounting Feet with .25" (6.4) Dia. Hole .09" (2.3) .19" (4.8) 4.40" (111.8) 2.75" (69.9) A 4 Knockouts .75'' x 1'' Typ. Noted ''A'' A A A 1.70" (43.2) 3.00" (76.2) 2.00" (50.8) 3.31" (84.1) 10.11" (256.8) 3.00" (76.2) 1.52" (38.6) Mounting Surface 2.00" (50.8) BACK VIEW HBL16R90/HBL16R92/HBL16R93 Dimensions in Inches (mm) END VIEW HBL16R90/HBL16R92/HBL16R93 www.hubbell-wiring.com SIDE VIEW HBL16R90/HBL16R92/HBL16R93 C-19 Manual Motor Controllers and Enclosures Product 3.25" (82.6) 1.75" (44.5) HBL7862FW Enclosure Only 4.75" (120.7) #10 -32 TAP Switches AC Switches Switched Enclosures Circuit-Lock® 30, 60, and 100 Ampere Unfused Disconnect Switch “Suitable as Motor Disconnect” UL Listed, CSA Certified TYPE 4, 4X and 12K Enclosure Rating IP67 Adjustable mounting feet. SUITABILITY Stainless steel hardware for corrosion resistance. Non-metallic enclosure – nonconducting. Internal frame automatically bonds all grounds. Lockable handle to meet OSHA Lockout Tagout regulations. The Circuit-Lock Disconnect Switch meets NEC Article 430 requirements for a separate disconnect means within sight of all motor loads. In addition, the enclosure offers the ability to lock directly wired motor loads in the “OFF” position to comply with OSHA Lockout/Tagout regulations. This safety enclosure is Type 4X (Washdown, Corrosion resistant) and is also suitable for use with metallic conduit. The switch is mounted on an internal frame that is integral with the enclosure and bonds all grounds, and it accepts auxiliary contacts that can be used to signal PLC controllers. Circuit-Lock Unfused Disconnect Switch Dimensions Ordering Information 30A, 60A and 100A Description 30A Circuit-Lock disconnect switch. 30A Circuit-Lock disconnect switch with aux. contact.* 60A Circuit-Lock disconnect switch. 60A Circuit-Lock disconnect switch with aux. contact.* 100A Circuit-Lock disconnect switch. 100A Circuit-Lock disconnect switch with aux. contact.* Catalog Numbers HBLDS3 HBLDS3AC HBLDS6 HBLDS6AC HBLDS10 HBLDS10AC A B C .87" (22.1) G ON D OFF E F Auxiliary Contacts for 30A, 60A & 100A switch, A600 pilot duty Description Break before break. Break after break. Catalog Numbers HBLAC1 HBLAC2 Unfused Disconnect Switches Ground Block Description For 30A switch. For 60 & 100A switch. Catalog Numbers HBL30RGB HBL60100RGB Neutral Block Description For 30A switch. For 60A switch. For 100A switch. Catalog Numbers HBL30RNB HBL60RNB HBL100RNB Replacement Switch Description For 30A switch. For 60 & 100A switch. Notes: * Supplied with one HBLAC1 30A Units come with 3/4” NPT Hub 60A & 100A Units come with 1 1/4” NPT Hub C-20 Catalog Numbers HBLDS3RS HBL60100RS www.hubbell-wiring.com Key A B C D E F G 30A inch 6.00 5.12 4.12 6.62 7.62 8.50 4.12 mm 152 130 105 168 194 216 105 60A/100A inch mm 7.75 197 6.87 175 4.75 121 8.00 203 9.95 253 11.00 279 5.94 151 Horsepower Ratings 30A 60A 100A Voltage 120V AC 1Ø 1 7.5 7.5 208V AC 1Ø 208-240V AC 1Ø 3 15 15 240-277V AC 1Ø 480V AC 1Ø 5 30 30 208V AC 3Ø 208-240V AC 3Ø 7.5 30 30 240V AC 3Ø 480V AC 3Ø 15 50 50 600V AC 3Ø 15 50 50 Note: See page C-30 for technical data. Dimensions in Inches (mm) Switches Safety Devices Switched Enclosures Circuit-Lock® 30 and 60 Ampere Fused Disconnect Switch “Suitable as Motor Disconnect” Stainless steel hardware. Adjustable mounting feet. Non-metallic enclosure – safer - nonconducting. Fused disconnect switch accepts Class “J” fuses. Safety interlocked fuse access door. Removable door for easier wiring. Lockable high visibility red handle to meet OSHA Lockout/Tagout. Circuit-Lock Fused Disconnect Switch The Circuit-Lock Fused Disconnect Switch provides fused switched control of a directly wired load. The switch cannot be turned “ON” unless the enclosure cover is closed. The fuses cannot be accessed until the switch is turned “OFF”. The fuse holder accepts Class “J” fuses. This enclosure is non-metallic and is listed for Outdoor/Indoor (Type 4X Washdown, Corrosion resistant). The handle can be locked in the “OFF” position to comply with OSHA Lockout/Tagout regulations. Dimensions 7.27" (184.7) 15.03" (381.8) 11.46" (291.6) 3.60" (91.4) 10.18" (258.6) 9.31" (236.5) 7.19" (182.6) 12.37" (314.2) 14.48" (367.8) 15.36" (390.1) Dimensions in Inches (mm) www.hubbell-wiring.com C-21 Fused Disconnect Switches 8.43" (214.1) Switches Safety Devices Switched Safety Enclosures Circuit-Lock® 30 and 60 Ampere Fused Disconnect Switch UL Listed, CSA Certified TYPE 4, 4X and 12 Enclosure Rating IP67 SUITABILITY Ordering Information 30A & 60A Ratings 30A 600V AC Max. Volts 120V AC 208-240V AC 240V AC 3Ø 480V AC 3Ø 600V AC 3Ø 120/208V AC 3Ø Y 277/480V AC 3Ø Y 347/600V AC 3Ø Y 60A 120V AC 600V AC 208-240V AC Max. 240V AC 3Ø 480V AC 3Ø 600V AC 3Ø 120/208V AC 3Ø Y 277/480V AC 3Ø Y 347/600V AC 3Ø Y *Requires time delay fuses. Std. HP 0.5 1.5 3.0 5.0 7.5 3.0 5.0 7.5 1.5 3.0 7.5 15.0 15.0 7.5 15.0 15.0 Max. HP* 2.0 3.0 7.5 15.0 20.0 5.0 15.0 20.0 3.0 7.5 15.0 30.0 40.0 15.0 30.0 40.0 Catalog Numbers FDS30 FDS60 Auxiliary Contacts Description Auxiliary contact normally open, A600 pilot duty. Auxiliary contact normally closed, A600 pilot duty. Catalog Numbers ACFSNO ACFSNC Fuse & Short Circuit Information The starting current of motors of more than the standard horsepower rating may require the use of fuses with appropriate time-delay characteristics. Short Circuit Withstand Rating Suitable for use on a circuit capable of delivering not more than 100,000 RMS symmetrical amperes at the voltage rating of receptacle when protected by Class “J” fuses. Replacement fused switch must be the same type Hubbell switch as original and have equal or greater short circuit current withstand rating. Note: See page C-32 for technical data. Fused Disconnect Switches Horsepower Ratings C-22 www.hubbell-wiring.com Dimensions in Inches (mm) Switches AC Switches Accessories Nylon and Metal Wall Plates Standard Size, Smooth Nylon Switch Plates Gangs Brown Ivory Gray White Red Black Office White 1 2 3 P1X P2X P3X P1 P2 P3 P1G P2G P3G P1W P2W P3W P1R P2R P3R P1B P2B P3B P1OW P2OW P3OW One-gang 1 toggle switch Standard Size, Smooth Nylon Style Line® Switch Plates Gangs 1 2 3 Brown HPS1 HPS2 HPS3 Ivory HPS1I HPS2I HPS3I Gray HPS1GY HPS2GY HPS3GY White HPS1WA HPS2WA HPS3WA Red HPS1R HPS2R – Black HPS1B HPS2B HPS3B Office White HPS1OW HPS2OW HPS3OW Two-gang 2 toggle switches Standard Size, Smooth Metal Switch Plates Gangs 1 2 3 Stainless Steel S1 S2 S3 Brass B1 B2 B3 Aluminum A1 A2 * Three-gang 3 toggle switches Standard Size, Smooth Metal, Style Line Switch Plates Gangs Stainless Steel Brass 1 S26 B26 2 S262 B262 3 S263 B263 Note: See Section K for full line of wall plates. * Available as a custom metal wall plate, see page K-29 Aluminum * * * One-gang Two-gang Three-gang Accessories Dimensions in Inches (mm) www.hubbell-wiring.com C-23 Switches AC Switches Accessories Red Neon Pilot Light and Brass Locking Attachment and Lockout Devices for Toggle Switches Pilot Light, 120-277V AC Description Red neon pilot light, back & side wired, fits standard switch plate. Catalog Number HBL1220RJ HBL1220RJ Brass Locking Attachment for Switches Available in Master Keying and Straight Keying Systems HBL96061 shown with wallplate and switch HSLDPK2 Description Catalog Numbers Straight keying (all locks alike). Appropriate for most applications. HBL96061* Straight cylinder type lock, each HBL96061 ordered operates on the same key. All locks are keyed alike. Straight keying (individual). Straight cylinder type lock, each HBL96062 HBL96062 ordered operates on a different key. All locks are keyed differently and individually. This type cannot be master keyed. Master keying (individual). Cylinder type lock for master keying, HBL96060 each lock keyed individually with a master key to operate all locks. Notes: *Also available in dull chrome finish to match stainless steel. Add “DCH” suffix to catalog number. SWITCHOUT™ Lockout Device Description Catalog Number Yellow nylon, toggle switch lockout device. HSLDPK2**+ Notes: For more information on safety lockout devices, see Section U. + Two devices per package. **Not UL or CSA Listed. Accessories HSLDPK2 C-24 www.hubbell-wiring.com Dimensions in Inches (mm) Switches AC Switches Accessories Weatherproof Switch Plates IP44 1.88" (47.8) .94" (23.9) SUITABILITY Weatherproof Plates Description Clear bubble plate, silicone rubber for use with all general purpose AC toggle and PresSwitches® switches. Fits both FS/FD and standard boxes. Catalog Number HBL1795 4.63" (117.6) 3.25" (82.6) 2.38" (60.5) 2.94" (74.7) HBL1795 Weatherproof Plates Description Gray neoprene PresSwitch plate. Fits FS/FD and standard boxes. Same as above except yellow. Note: *Not listed by Underwriter’s Laboratories Inc. 1.88" (47.8) .94" (23.9) Catalog Numbers HBL1750* HBL17CM50* 4.63" (117.6) 2.38" (60.5) 3.25" (82.6) 2.94" (74.7) HBL1750 Weatherproof Plates Description Gray neoprene PresSwitch plate with 125V red pilot light. Fits only FS/FD boxes. Same as above except yellow. Note: *Not listed by Underwriter’s Laboratories Inc. .94" (23.9) Catalog Numbers HBL1785* 1.88" (47.8) 4.63" (117.6) 2.38" (60.5) HBL17CM85* 3.25" (82.6) 2.94" (74.7) HBL1785 Weatherproof Plates Description Cast aluminum lift cover plate with fiber shield. For standard toggle and PresSwitches. Fits only FS/FD boxes. Note: See Section K for full line of wall plates. 2.84 (72.1) Catalog Number HBL7420 3.25" 4.56" (82.6) (115.8) Accessories .19 dia. 4 holes (4.8) 1.89 (48.0) HBL7420 Dimensions in Inches (mm) www.hubbell-wiring.com C-25 Switches AC Switches Technical Information Industrial Heavy Duty Specification Grade Switches SP, DP, 3-Way, 4-Way Specifications Listings UL Listed CSA Certified Verified to Fed. Spec. W-S-896, SP, DP, 3-way and 4-way Component Base Top Toggle Terminals Terminal Screws Mounting Bridge Contacts Moveable Contact Arm Rocker Ground Terminal Ground Screw Automatic Grounding Clip Material Thermoset, Color Coded by Amperage Thermoset, Gray Nylon Brass Brass Nickel Plated Steel Silver Cadmium Oxide Copper Alloy Thermoplastic Elastomer Nickel-Plated Steel Brass Stainless Steel Performance Data Electrical Dielectric Voltage Max. Working Voltage Overload Temperature Rise Max. Continuous Current Endurance Mechanical Terminal Accommodations #14 AWG min. - #10 AWG max. solid and stranded wire. UL 94V-2. Max. continuous: 75° C; Min. continuous: -40° C w/o impact. Switch Technical Information Environmental Flammability Operating Temperature Withstands 1500V AC minimum for 1 minute. 277V AC Minimum 4.8 times rated current for 100 cycles. 30° C maximum at rated current. 15A, 20A, 30A. 50,000 cycles min., tungsten filament lamp load Fed. Spec. #WS896, SP, DP, 3-way and 4-way. C-26 www.hubbell-wiring.com Dimensions in Inches (mm) Switches AC Switches Technical Information Heavy Duty Manual Motor Controllers 30, 40 & 60A, Double Pole and Three Pole Specifications Listings UL Listed 508 Industrial Control Equipment CSA-C22.2 No. 14 Industrial Control Equipment 30A Suitable as Motor Disconnect UL File E70402 CSA File LR-46186 Component Base Cover Yoke Toggle Terminal Screws Contact Blades Contacts Brush Lifter Material Thermoset Thermoset Zinc Plated Steel Nylon Brass Brass Silver Cadmium Oxide Polycarbonate Performance Data Electrical Dielectric Voltage Electrical Life (Minimum) Working Voltage Short Circuit Withstand Rating (Motor Disconnect) Operating Temperature Mechanical Life (minimum) Terminal Torque (30A, 40A) Terminal Torque (60A) Mechanical Terminal Accommodations 2,200V AC max for 1 minute. 6,000 cycles at rated switch parameters. 600V AC RMS. 5,000 and 10,000 RMS with RK5 fuses at rated switch value. Min. continuous: -40° C w/o impact.. 10,000 Cycles. 20 inch pounds. 25 inch pounds. 30A #14 AWG min. - #10 AWG max. solid and stranded wire. 40A #14 AWG min. - #8 AWG max. solid and stranded wire.* 60A #14 AWG min. - #4 AWG max. solid and stranded wire Note: *Use listed/certified ring terminal. Switch Technical Information ????? Dimensions in Inches (mm) www.hubbell-wiring.com C-27 Switches AC Switches Listing Chart UL, CSA, and Fed. Spec. Listing Data Certification Chart Catalog Numbers CS115 CS315 CS120 CS320 CS1201 CS1203 CS1221 CS1222 CS1223 CS1224 HBL1201 HBL1202 HBL1203 HBL1204 HBL1201IL HBL1203IL HBL1201PL HBL1203PL HBL1201L HBL1202L HBL1203L HBL1204L HBL1221 HBL1222 HBL1223 HBL1224 HBL1221L HBL1222L HBL1223L HBL1224L HBL1221IL HBL1222I HBL1223IL HBL1221PL HBL1222PL HBL1223PL HBL1259I HBL1281 HBL1282 HBL1283 C-28 C-26 Federal Spec. WS896 Listed No No No No Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes No No No No UL Listed UL20 Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes No Yes Yes No CSA Certified Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes Yes No Yes Yes No Catalog Federal Spec. UL Listed CSA Numbers WS896 Listed UL20 Certified HBL1284 No No No HBL1287I No Yes Yes HBL1288I No No No HBL1281MO No No No HBL1281MC No No No HBL1297 No Yes Yes HBL1298 No No No HBL1381 No Yes Yes HBL1382 No Yes Yes HBL1385 No Yes Yes HBL1386 No Yes Yes HBL1386L No Yes Yes HBL1388 No Yes Yes HBL1556 No Yes Yes HBL1557 No Yes Yes HBL1556L No Yes Yes HBL1557L No Yes Yes HBL3031 Yes Yes Yes HBL3032 Yes Yes Yes HBL3033 Yes Yes Yes HBL3031PL Yes Yes Yes HBL3032PL Yes Yes Yes HBL2101 No Yes Yes HBL2103 No Yes Yes HBL2121 No Yes Yes HBL2122 No Yes Yes HBL2123 No Yes Yes HBL2124 No Yes Yes HBL2123IL No Yes Yes HBL2121PL No Yes Yes HBL7832 No Yes* Yes HBL7832BW No Yes* Yes HBL7810UD No Yes* Yes HBL7810BW No Yes* Yes HBL7842 No Yes* Yes HBL7843 No Yes* Yes HBL7862 No Yes* Yes HBL7862FW No Yes* Yes HBL7863 No Yes* Yes HBL7863FW No Yes* Yes Notes: Catalog numbers above represent all colors and variations. * Motor starting switches are listed to UL508. www.hubbell-wiring.com Dimensions in Inches (mm) Switches AC Dimmers Technical Data Dimmer – Ganging and Derating Architectural Grade Slide and Rotary Series Switchboxes Required: Side Sections Intact Number of Small Controls (600W & 1000W) 0 1 2 3 4 5 6 Number of 0 0 1 1+1 4 1+4 7 1+7 Large Controls 1 1 3 5 6 8 9 11 (1500W & 2000W) 2 4 6 7 9 10 12 13 3 6 8 10 11 13 14 16 4 9 11 12 14 15 17 18 Note: When ganging an even number of small controls with no side sections removed (plus numbers in chart), use gangable switchboxes with tapped ears as shown below. Do not use plaster rings or gangbox covers. Space an additional switchbox 3/4” apart from the other switchbox(es). A 3/4” close nipple is recommended as a spacer between the switchboxes. Example of four-gang installation Three small dimmers in this box. Four-Gang Gangable Switchbox One small dimmer in this box. Single-Gang Gangable Switchbox 3/4 Space (Use Close Nipple) Switchboxes Required: Side Sections Removed Number of Small Controls (600W & 1000W) 0 1 2 3 4 5 6 Number of 0 0 1 2 3 4 5 6 Large Controls 1 1 3 4 5 6 7 8 (1500W & 2000W) 2 3 5 6 7 8 9 10 3 5 7 8 9 10 11 12 4 7 9 10 11 12 13 14 Note: When removing side sections, remove only inner side sections. Do not remove side sections on outer ends of gang. Same installation rules apply to rotary dimmers (not shown). Remove All Inner Side Sections (Shaded) Do Not Remove Outer Side Sections Derating Chart Dimmer Ganging and De-rating Chart No side One side Both side sections removed section removed sections removed 600W 600W 500W 1000W 900W 700W 1500W 1250W 1000W 2000W 1800W 1500W Note: When ganging any combination of small and large controls, place a small control on one extreme end of the gang, and a large control at the other end of the gang. When ganging with side sections intact, use offset mounting holes. When ganging with side sections removed, use center mounting holes. Allow a 1/32” gap (space) between controls for ease in attaching the faceplate. Specification Grade Slide and Rotary Series Switchboxes Required: Side Sections Removed. Derating Chart 1 dimmer in wall box 600W 1000W 5A fan speed Dimensions in Inches (mm) 2 dimmers in wall box 500W 800W 4A 3 or more dimmers in wall box 400W 650W 3A www.hubbell-wiring.com C-29 Switches AC Switches Toggle Switch Wiring Diagrams Standard Toggle Type Switches SINGLE POLE 2 POLE 3 WAY TO 3 WAY 3 WAY 4 WAY 3 WAY L L L L LINE BLACK LINE NEUTRAL WHITE NEUTRAL Lighted Switches (light on with load off) SINGLE POLE LIGHTED 3 WAY LIGHTED L L L L LINE BLACK NEUTRAL WHITE Pilot Light Switches (light on with load on) SINGLE POLE PILOT DOUBLE POLE PILOT M L L Switch Wiring Diagrams L C-30 LINE BLACK NEUTRAL WHITE www.hubbell-wiring.com Dimensions in Inches (mm) Switches Switches AC Switches Toggle Switch Wiring Diagrams Three Way Pilot Switches B L K B L K B W H T LINE 1 B W H T BLACK L O A D NEUTRAL WHITE LINE 2 RED Three Position Switches, Momentary and Maintained DPDT CENTER OFF L-2 B-1 B-2 A-1 A-2 STRIP GAGE STRIP GAGE SPDT CENTER OFF M L-1 L L LINE 1 M BLACK NEUTRAL WHITE LINE 2 RED Switch Wiring Diagrams ????? Dimensions in Inches (mm) www.hubbell-wiring.com C-31 Switches AC Switches Technical Information Switched Safety Enclosures Circuit-Lock® Unfused Disconnect Switch Specifications Moisture Resistance Flammability Operating Temperature UV Resistance Dielectric Voltage Max. Working Voltage Current Interrupting Short Circuit Withstand Rating (Motor Disconnect) Terminal Identification Product Identification Mounting Impact Resistance Outdoor – Type 4X (Washdown, Corrosion resistant), IP 66 suitability; Indoor – 30A Type 12K (Dust-tight, Falling Dirt, Noncorrosive Liquids with Knockout). 60 and 100A Type 12 (Dust-tight, Falling Dirt, Noncorrosive Liquids). UL94-5VA and V0 Classification. Maximum Continuous +75°C; Minimum Continuous -40°C. All materials are UV stabilized. Withstands 3000V AC minimum. 600V AC RMS. Certified for current interrupting at full rated current and voltage. Suitable for use on a circuit capable of delivering not more than 10,000 RMS symmetrical amperes, 600V AC max. In accordance with UL, CSA and international conventions. Identification and ratings are part of external label. External fully adjustable feet. In accordance with UL 746C. Circuit-Lock Fused Disconnect Switch Specifications Moisture Resistance Switched Enclosure Technical Information Flammability Operating Temperature UV Resistance Dielectric Voltage Max. Working Voltage Impact Resistance Terminal Identification Product Identification Mounting Fuse Types Outdoor – Type 4X (Washdown, Corrosion resistant), IP 66 suitability; Indoor - Type 12 (Dust-tight, Falling Dirt, Noncorrosive Liquids). UL94-5VA and V0 Classification. Maximum Continuous +75°C; Minimum Continuous -40°C. All materials are UV stabilized. Withstands 3000V AC minimum. 600V AC RMS. In accordance with UL 746C. In accordance with UL, CSA and international conventions. Identification and ratings are part of external label. External fully adjustable feet. UL Listed, Class “J”; CSA Certified, HRCI-J. Circuit-Lock Unfused and Fused Disconnect Switch Materials Part Material Base Valox® Top Valox Handle Valox Conduit Hub Zinc Watertight 30A Unfused - 3 /4”, 30A Fused - 1”, 60/100A Unfused - 1 1 /4” Enclosure Gasket Neoprene Shaft (Unfused) Valox Shaft (Fused) Brass Shaft Seal Molded Neoprene Frame Galvanized Steel Ground Plate (Fused) Galvanized Steel Enclosure Screws Stainless Steel 300 Series  Valox is a registered trademark of General Electric Company. C-32 www.hubbell-wiring.com Dimensions in Inches (mm)
HBL1221 价格&库存
很抱歉,暂时无法提供与“HBL1221”相匹配的价格&库存,您可以联系我们找货
