HBL2311
HBL2311
    HUBBELL(哈伯尔公司)
HBL2311 数据手册
Twist-Lock® Devices 20A, 125V AC, 2 Pole, 3 Wire Grounding Insulgrip® Plug Features Ribbed nylon housing provides a secure grip and impact and chemical resistance. Superior cord grip design protects terminations from excess strain. Clear, funnel shaped wire entry for ease of termination. Integral dust shield protects wiring chamber from dust or contaminants. Ordering Information Description Black and white nylon. Cord Diameter .360"-.930" (9-24) UPC 783585037707 Catalog Number HBL2311 Listings Listed to UL 498 Fed.Spec. W-C-596 Certified to CSA C22.2 No.42 Specifications Housing / Cord Clamp Terminal Retainer Blades Terminal Screws Terminal Clamp Assembly Screws Nylon Clear polycarbonate Brass #10-32 Brass (Phillips / Slotted / Robertson) Cold rolled steel – nickel plated Steel - nickel plated Performance Electrical Current Interrupting Dielectric Voltage Certified for current interrupting at full rated current Withstands 2,000V minimum Mechanical Terminal Accommodation #16 AWG - #8 AWG stranded copper wire only. Accessories Terminal Identification Terminals identified in accordance with UL 498 Environmental Flammability Moisture Resistance Operating Temperatures HB or better per UL94 or CSA 22.2 No. 0.6 IP20 Suitability Maximum Continuous 75°C Minimum -40°C (w/o impact) Connector Single Receptacle Flanged Receptacle Weatherproof Boot Resources Customer Use Drawing eCatalog Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. HBL2313 HBL2310 HBL2316 HBL6031
HBL2311 价格&库存
很抱歉,暂时无法提供与“HBL2311”相匹配的价格&库存,您可以联系我们找货
HBL2311
    • 1+212.70665
    库存:3
    HBL2311
      • 1+426.74863
      • 5+420.50033
      • 10+413.66885
      库存:55
