HBL2316
HBL2316
    HUBBELL(哈伯尔公司)
HBL2316 数据手册
Product Datasheet HBL2316 -- Twist-Lock Flanged Receptacle 2P3W, 20A 125V, L5-20R, White Nylon Product Specifications Product Type Product Item Flanged Receptacle Wiring Scheme 2-Pole, 3-Wire Grounding Amperage 20A Voltage 125V AC NEMA Configuration L5-20R Item Style Standard Device Color White Horsepower 1 Terminal Retainer Material Clear polycarbonate Terminal Clamp Material .08" (2) steel-nickel plated Terminal Screw Material #10-32 Brass (white finish on neutral screw when used) Multi-drive Ground Screw Material #10-32 Brass (green finish) Multi-drive Body Holding Screw Material Steel, zinc plated Multi-drive Body Contact Carrier Material Natural White Nylon Contact Spring Material Brass Spring Binding Plate Material Brass Flanged Casing Material Natural White Nylon Mounting Screw Material Nickel-plated Brass Round head screws Ground Contact Material .031" (.8) Brass Ratings Molded In or Stamped On Catalog No Permanently ink marked on product Dielectric Voltage Withstand 2,000V minimum Current Interrupting Certified for current interrupting at full rated current Temperature Rise Max 30C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of .75. Terminal Accommodation 20A #12 AWG Terminal Identification Terminals identified in accordance with UL 498 (X, Y, Z, White, Green) Flammability UL 94 VO for Receptacles and Inlets. HB or better for Plugs and Connectors. Operating Temperatures Maximum Continuous 75 C Minimum -40 C (w/o impact) Listings FED SPEC UL/CSA UPC Number 783585037806 Weight in LBs 0.25 Link to Drawing Library Click here for Library Link to PDF Catalog Click here for Catalog NEMA Configuration
HBL2316 价格&库存
很抱歉,暂时无法提供与“HBL2316”相匹配的价格&库存,您可以联系我们找货
