HBL2621
HBL2621
    HUBBELL(哈伯尔公司)
HBL2621 数据手册
Twist-Lock® Devices 30 Ampere, 125, 250 Volts and 277 Volts AC 2 Pole, 3 Wire Grounding X W G G Y 30A 125V NEMA L5-30P UL/CSA 2 HP Plugs Watertight Safety-Shroud® 2.78" (70.6) 4.50" (114.3) HBL2611SW IP66 SUITABILITY Description Cord Dia. Catalog Number Black Valox® housing, white Valox® clamps. .325"-.930" (9-24) HBL2611SW Safety-Shroud® Description 2.26" (57.4) 2.04" (51.8) 30A 250V NEMA L6-30P UL/CSA 2 HP IP20 Cord Dia. Black and white nylon body, .360"-.930" white Valox® shroud. Can be used (9-24) with the Insulgrip Connector Bodies. 30A 277V AC NEMA L7-30P UL/CSA 3 HP UL Type 4x, 12 HBL2621SW – HBL2621S – SUITABILITY Catalog Number HBL2611S Note: See page B-40 for accessories. Insulgrip® 3.97" (100.8) HBL2621S 2.75" (69.9) 2.26" (57.4) 1.97" (50.0) HBL2621 IP20 SUITABILITY Description Cord Dia. Catalog Number Black and white nylon. .360"-.930" (9-24) HBL2611 HBL2621 Heat stabilized, gray nylon, 220° F (104° C). .360"-.930" (9-24) HBL2611F HBL2621F – Corrosion resistant, yellow nylon. .360"-.930" (9-24) HBL26CM11 HBL26CM21 – All black nylon. .360"-.930" (9-24) HBL2611BK HBL2621BK – Description Cord Dia. Catalog Number Yellow nylon. .590"-.930" (15.0-23.6) HBL2611VY Corrosion resistant, yellow nylon. .590"-.930" (15.0-23.6) HBL26CM11V Black nylon. .590"-.930" (15.0-23.6) HBL2611VBK HBL2631 Note: See page B-51 for accessories. Valise® 2.50" (63.5) 1.78" (45.2) HBL2611VY IP20 SUITABILITY HBL2621VY – – – HBL2621VBK – Note: See page B-51 for accessories. 2.28" (57.9) Flanged Inlets Watertight Safety-Shroud® 3.75" (95.3) 1.63" (41.4) 3.75" (95.3) Gray Valox® housing and flange. HBL2615SW Reverse service, gray Valox® housing and flange (use with HBL2613SR), (Not shown). HBL2615SWR Insulgrip® 2.88" (73.2) 120° 1.25" R. (31.8) 2.09" (53.1) Catalog Number UL Type 4x, 12 HBL2625SW – – – Note: See page B-54 for accessories. HBL2615SW .19" (4.8) 120° DIA. IP66 SUITABILITY Description IP20 SUITABILITY Description Catalog Number Nylon casing, back wired. HBL2615 HBL2625 Heat stabilized, gray nylon, 220° F (104° C). HBL2615F HBL2625F – Nylon casing, weather protective, die cast aluminum, back wired, self closing lift cover. HBL2615M3 – – HBL2635 Note: See page B-50 for accessories. See pages B-69 and B-70 for technical information on Twist-Lock and Watertight Safety-Shroud devices. See page B-74 for technical information on Valise plugs and connectors. 2.04" (51.8) HBL2625 Dimensions in Inches (mm) B-26 Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. ® Wiring Device-Kellems www.hubbell-wiring.com
HBL2621 价格&库存
很抱歉,暂时无法提供与“HBL2621”相匹配的价格&库存,您可以联系我们找货
