Product Datasheet
HBL2725 -- Twist-Lock Flanged Inlet
3P4W, 30A 3PH 250V, L15-30P, White Nylon
Product Specifications
Product Type
Product Item
Flanged Inlet
Wiring Scheme
3-Pole, 4-Wire Grounding
Amperage
30A
Voltage
3 Phase 250V AC
NEMA Configuration
L15-30P
Item Style
Standard
Device Color
White
Terminal Retainer Material
Clear polycarbonate
Blade Material
Brass
Terminal Clamp Material
.08" (2) steel-nickel plated
Terminal Screw Material
#10-32 Brass (white finish on neutral screw when used) Multi-drive
Ground Screw Material
#10-32 Brass (green finish) Multi-drive
Body Holding Screw Material
Steel, zinc plated Multi-drive
Body Contact Carrier Material Natural White Nylon
Flanged Casing Material
Natural White Nylon
Mounting Screw Material
Nickel-plated Brass Round head screws
Ratings
Molded In or Stamped On
Catalog No
Permanently ink marked on product
Dielectric Voltage Withstand
2,000V minimum
Current Interrupting
Certified for current interrupting at full rated current
Temperature Rise
Max 30C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of .75.
Terminal Accommodation
30A #10 AWG
Terminal Identification
Terminals identified in accordance with UL 498 (X, Y, Z, White, Green)
Flammability
HB or better per UL 94 or CSA 22.2 No. 0.6
Operating Temperatures
Maximum Continuous 75 C Minimum -40 C (w/o impact)
Listings
FED SPEC UL/CSA
UPC Number
783585039282
Weight in LBs
0.2
Link to Drawing Library
Click here for Library
Link to PDF Catalog
Click here for Catalog
NEMA Configuration
很抱歉,暂时无法提供与“HBL2725”相匹配的价格&库存,您可以联系我们找货
