HBL4729C
HBL4729C
    HUBBELL(哈伯尔公司)
HBL4729C 数据手册
Twist-Lock® Devices 15A, 125V, 2 Pole, 3 Wire Grounding Insulgrip® Connector Features Ribbed nylon housing provides secure, impact and chemical resistant grip Superior cord grip design protects terminations from excess strain Integral VARI-SIZE insert accomodates a wide range of cord diameters Ordering Information Description Black and white nylon. Cord Diameter .230"-.720" (5.8-18.3) UPC 783585171357 Catalog Number HBL4729C Listings Listed to UL 498 Fed.Spec. W-C-596 Certified to CSA C22.2 No.42 Specifications Housing / Cord Clamp Terminal Retainer Contacts Terminal Screws Terminal Clamp Assembly Screws Nylon Clear polycarbonate Brass #8-32 Brass (Phillips / Slotted / Robertson) Cold rolled steel – nickel plated Steel - nickel plated Performance Electrical Current Interrupting Dielectric Voltage Certified for current interrupting at full rated current Withstands 2,000V minimum Mechanical Terminal Accommodation #18 - #10 AWG stranded copper wire only. Terminal Identification Environmental Flammability Moisture Resistance Operating Temperatures Terminals identified in accordance with UL 498 Accessories HB or better per UL94/CSA 22.2 No.0.17 IP20 Suitability Maximum Continuous 75°C; Minimum -40°C (w/o impact) Plug Weatherproof Boot Flanged Inlet Weatherproof Boot Resources Customer Use Drawing eCatalog Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. HBL4720C HBL6024 HBL4716C HBL6023
HBL4729C 价格&库存
很抱歉,暂时无法提供与“HBL4729C”相匹配的价格&库存,您可以联系我们找货
