HBL5666C
HBL5666C
    HUBBELL(哈伯尔公司)
    HBL5666C
HBL5666C 数据手册
Straight Blade Devices 15 and 20 Ampere, 250 Volts 2 Pole, 3 Wire Grounding G 1.97" (50.0) 15A 250V NEMA 6-15P UL CSA 1.5 HP Plugs 1.53" (38.9) HBL5666C G 20A 250V NEMA 6-20P UL CSA 2 HP Description Cord Diameter Catalog Number Insulgrip® Plug, black and white nylon. .230"-.720" (5.8-18.3) HBL5666C HBL5466C Insulgrip® Plug, corrosion resistant, yellow nylon. .230"-.720" (5.8-18.3) HBL56CM66C HBL54CM66C 8-Position Insulgrip® Angle Plug, black and white nylon. .325"-.655" (8.3-16.6) HBL5666CA HBL5466CA Valise® Plug, yellow nylon. .220"-.660" (5.6-16.8) HBL5666VY HBL5464VY 1.22" (30.9) Note: See page A-47 for accessories. 2.11" (53.6) 1.53" (38.9) HBL5666CA G 1.88" (47.8) 1.5" (38.1) 1.13" (28.7) Insulgrip® Flanged Inlets G 15A 250V NEMA 6-15P UL CSA 1.5 HP 20A 250V NEMA 6-20P UL CSA 2 HP Description Catalog Number Nylon casing, back wired. HBL5678C HBL5478C Note: Flanged inlets are not HP rated. See page A-47 for accessories. HBL5666VY 2.56" (65.0) 2.19" (55.6) .16" (4.1) Dia. 1.72" (43.7) 1.72" (43.7) HBL5678C For quick visual identification of circuits or configurations. Colored Cord Clamps* Description Color Catalog Number For use with 15A and 20A, 2 pole/3 wire, insulgrip plugs and connectors with cord diameter range of .230"-.720" (5.8-18.3) only. Blue Green Orange Purple Red Yellow HBLCORDCLAMPBL HBLCORDCLAMPGN HBLCORDCLAMPOR HBLCORDCLAMPP HBLCORDCLAMPR HBLCORDCLAMPY Note: *Clamp only. Contains no screws. Order in increments of 10. Not UL Listed or CSA Certified. Dimensions in Inches (mm) A-34 ® Wiring Device-Kellems www.hubbell-wiring.com
HBL5666C
1. 物料型号:型号为EL817,是一款光隔离型光电晶体管。
2. 器件简介:EL817是一种光隔离型光电晶体管,具有高输入阻抗和低输出阻抗的特性,适用于高速光耦应用。
3. 引脚分配:EL817共有6个引脚,分别为A(发光二极管阳极)、KA(发光二极管阴极)、COL(集电极)、EMT(发射极)、GND(地)和VCC(电源)。
4. 参数特性:EL817的主要参数包括工作温度范围(-40℃至+85℃)、输入电流(最大20mA)、输出电流(最大50mA)等。
5. 功能详解:EL817通过光电效应实现电信号的隔离传输,具有抗干扰能力强、响应速度快等优点。
6. 应用信息:EL817广泛应用于工业控制系统、仪器仪表、通信设备等领域。
HBL5666C 价格&库存
很抱歉,暂时无法提供与“HBL5666C”相匹配的价格&库存,您可以联系我们找货
HBL5666C
    • 1+486.96144
    • 5+479.87066
    • 10+471.85200
    库存:74
