HBL9965C
HBL9965C
    HUBBELL(哈伯尔公司)
HBL9965C 数据手册
Non-NEMA Twist-Lock® Devices 20 Ampere, 250, 125/250 Volts and 3ØY 120/208 Volts AC Insulgrip® Plugs, Flanged Inlets, Connector Bodies and Receptacles 3P 3W 2P 3W Y For Replacement Use Only 2.75"(69.9) 2.26" (57.4) 1.97" (50.0) HBL9965C IP20 GR W CU SUITABILITY X 20A 250V Non-NEMA Not UL Listed Plugs Description Cord Dia. Catalog Number Black and white nylon. .360"-.930" (9-24) HBL9965GCB Corrosion resistant, yellow nylon. .360"-.930" (9-24) – 20A 125/250V Non-NEMA Not UL Listed HBL9965C HBL99CM65C Note: See page B-51 for accessories. 1.25" R. (31.8) .19" (4.8) DIA. 2.09" (53.1) 120° 2.04" (51.8) 2.88" (73.2) Flanged Inlets Description Catalog Number – Nylon casing, back wired. HBL3325C Note: See page B-50 for accessories. 120° HBL3325C 3P 4W For Replacement Use Only IP20 W X SUITABILITY Z Z X Y 2.75"(69.9) Y 2.33" (59.2) 2.21" (56.1) 4P 4W GR 20A 3Ø 250V AC Non-NEMA Not UL Listed Plugs Description Cord Dia. Catalog Number Black and white nylon. .350"-1.150" (9-29) HBL7411GCB HBL7411C 20A 3Ø Y 120/208V AC Non-NEMA Not UL Listed HBL7411C Note: See page B-53 for accessories. 1.34" R. (34.0) .19" (4.8) DIA. 2.27" (57.7) Flanged Inlets Description Catalog Number – Nylon casing, back wired. 120° 2.23" (56.6) 3.06" (77.7) HBL7408C Note: See page B-52 for accessories. See page B-69 for technical information. The devices shown on this page are not listed by Underwriters Laboratories Inc. and are for replacement use only in existing installations. 120° HBL7408C Dimensions in Inches (mm) B-42 CAUTION: To avoid electrical shock, review premises carefully and do not use if slot or blade configuration (design) is already in a circuit having a rating differing from the rating of this device. ® Wiring Device-Kellems www.hubbell-wiring.com
HBL9965C 价格&库存
很抱歉,暂时无法提供与“HBL9965C”相匹配的价格&库存,您可以联系我们找货
