HBLDS3
HBLDS3
    HUBBELL(哈伯尔公司)
HBLDS3 数据手册
HUBBELL WIRING DEVICE-KELLEMS HUBBELL Circuit-Lock® Non-Metallic Disconnects Now Labelless  Same Catalog Number  New Permanent Markings  Same Great Features Same Great Hubbell Device Without the Label Hubbell’s Circuit-Lock® non-metallic disconnects are frequently used in harsh environments. Frequent wash down, hot and high pressure water, caustic cleaning agents and UV light are common place. Hubbell’s new laser marked covers ensure that ratings are now permanently marked. FEATURES  Permanent Labelless Marking  IP69k and Type 4X,12 Water Ingress Protection  Certified by NSF for hygiene in Food Processing applications  Molded in corrosion and impact resistant material that is UV stabilized  SCCR rating of 65kA when protected by Class J fuses  Highly visible red handle which meets OSHA LO/TO capabilities  Cover cannot be removed with switch in the “On” position  Accepts Up to 2 Auxiliary Contacts  Available in Variable Frequency Drive (VFD) and MotorQuick Versions Non-Metallic Disconnects Joins the Family of Labelless Disconnects Available in: 30Amp 60 Amp 100 Amp VFD Motor-Quick® Non-Metallic Square Top Stainless Steel www.hubbell-wiring.com Sloped Top Stainless Steel HUBBELL WIRING DEVICE-KELLEMS Rating Information IP69k Water & Dust Ingress Protection: IP69k Water Test Extremely Hot (176˚) and High Pressure Water (1450 psi) sprayed from various angles. IP69k Dust Test Device is placed in a dust chamber for 8 hours while a vacuum tries to pull dust into the sealed device. National Sanitation Foundation (NSF) Known as The Most Trusted Name in Food Safety™, NSF International has been helping businesses in the agriculture, processing, food equipment, restaurant and retail industries to navigate the food safety and regulatory environment for nearly 70 years. © 2014 NSF International. All rights reserved. Ordering Information Labelless 30, 60 and 100 Amp Unfused Disconnect Switches Description Non-Metallic Stainless Steel Square Top Stainless Steel Sloped Top 30A disconnect switch 30A disconnect switch with HBLAC1 auxiliary contact 30A disconnect switch for use with variable frequency drives 60A disconnect switch 60A disconnect switch with HBLAC1 auxiliary contact 60A disconnect switch for use with variable frequency drives 100A disconnect switch 100A disconnect switch with HBLAC1 auxiliary contact 100A disconnect switch for use with variable frequency drives HBLDS3 HBLDS3AC HBLDS3VFD HBLDS6 HBLDS6AC HBLDS6VFD HBLDS10 HBLDS10AC HBLDS10VFD HBLDS3SS HBLDS3SSAC HBLDS3SSVFD HBLDS6SS HBLDS6SSAC HBLDS6SSVFD HBLDS10SS HBLDS10SSAC HBLDS10SSVFD HBLDS3SSR HBLDS3SSRAC HBLDS3SSRVFD HBLDS6SSR HBLDS6SSRAC HBLDS6SSRVFD HBLDS10SSR HBLDS10SSRAC HBLDS10SSRVFD Description Non-Metallic Stainless Steel Square Top Stainless Steel Sloped Top Disconnect switch with one pre-wired LINKOSITY® female receptacle (load side) HBLDS3MQR HBLDS3SSMQR HBLDS3SSRMQR Disconnect switch with 5 foot pre-wired LINKOSITY® female cable (load side) HBLDS3MQ5 HBLDS3SSMQ5 HBLDS3SSRMQ5 Disconnect switch with one pre-wired LINKOSITY® male receptacle (line side) and one pre-wired LINKOSITY® female receptacle (load side) HBLDS3MQR2 HBLDS3SSMQR2 HBLDS3SSRMQR2 Non-Metallic* Stainless Steel Square Top Stainless Steel Sloped Top 30A MotorQuick® Unfused Disconnect Switches UL Type 4X, 12 and IP69k Labelless Replacement Covers Description For 30A switches HBLDS3RC HBLDS3SSRC HBLDS3SSRRC For 60A switches HBLDS6RC HBLDS6SSRC HBLDS6SSRRC For 100A switches HBLDS10RC HBLDS10SSRC HBLDS10SSRRC *Laser Marked www.hubbell-wiring.com Hubbell Wiring Systems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 • Phone (800) 288-6000 • FAX (800) 255-1031 Printed in U.S.A. Specifications subject to change without notice. WLFSD006 2/15
HBLDS3 价格&库存
很抱歉,暂时无法提供与“HBLDS3”相匹配的价格&库存,您可以联系我们找货
