H-MoSS
H-MOSS® Occupancy Sensors
Hubbell Motion Sensing Switches
Control Units - CU300AU Universal Control Unit
H-MoSS
Hu
bbe
ll M
otion Sensing Switc
he s
The CU300AU Universal Control Unit automatically
detects the line voltage input within the 120-277V
range, eliminating the need for voltage specific
control units. It contains an internal relay for the
control of an external lighting load and is designed
for use with low voltage 24V DC occupancy
sensors. This control unit features Zero Arc Point
Switching, which minimizes relay-contact wear
from high inrush loads, and is capable of switching
20A loads. The CU300AU can power 1-4 sensors
or 3 sensors and 1 AAR (Add-A-Relay) for multiple
circuits. It is plenum rated and mounts inside
or outside a junction box or inside a fluorescent
fixture ballast cavity.
Key Features
• Universal Voltage- 120V-277V AC, 50/60Hz
• Regulated 24V DC, 150mA Output Current
Short Circuit Protected
• Zero Arc Point Switching
• Plenum Rated
• Works with Complete Line of Hubbell H-MOSS®
Ceiling and Wall Mount Sensors
• UL and cUL Listed
• 5 Year Limited Warranty
Features and Benefits
Features
Benefits
Universal Voltage- 120-277V AC
One control unit for all your needs. Allows you to service multiple
applications with one control unit.
Automatic Voltage Detection
Eliminates the need for specialized wiring, wiring is the same for all
applications. The CU300AU automatically detects which voltage is being
used.
Minimizes relay contact wear associated with high inrush loads.
Plenum Rated
Complies with requirements for use in a compartment handling conditioned
air (plenum).
Mounting Options
Easily mounts inside or outside a junction box or inside a fluorescent fixture
ballast cavity.
www.hubbell-wiring.com
Control Units
Hubbell CU300AU provides a 24V DC power supply for 1 to 4 sensors or sensor/
Add-A-Relay combinations. The control unit contains an internal relay for the control
of an external lighting load. Control unit is plenum rated.
Description
120-277V AC, 50/60 Hz for use with ATD, ATU & ATP series ceiling
sensors and wall mount sensors
Catalog Number
CU300AU
CU300AU
Specifications
Power Requirements
Output
Relay Contact Rating
Plenum Rated
Construction
Operating Environment
Size
Color
Certifications
Warranty
100-277V AC, 50/60Hz
24V DC, 150mA nominal, isolated and regulated
20A, 120V AC incandescent: 0 to 1800 watts;
20A, 120V AC ballast: 0 to 2400 watts;
277V AC ballast: 0 to 5540 watts;
1HP, 120 or 277V AC motor load
Complies with requirements for use in a compartment handling conditioned air (plenum)
Plenum rated for external junction box mounting
High impact, UL 94-5V plastic
Indoor use only
Operating temperature: 32º - 104ºF (0º - 40ºC);
0% to 95% relative humidity, non-condensing
3.69"L x 2.33"W x 1.36"H (93.7mm x 59.2mm x 34.5mm)
Black
UL and cUL Listed
5 year limited
Wiring Diagram
Single Circuit:
1 to 4 sensors or 3 sensors and 1 AAR.
Ground
Lighting
Load
Neutral
Hot
Override Off Switch
(optional)
Control Unit rated for
20 Amps
Red
Red
Black
White
Red (+24VDC @ 150mA)
Red
Black (common)
Black
Blue (control)
Blue
CU300AU Control Unit
For use with ATD, ATU and ATP Series ceiling and wall mount sensors.
Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 185 Plains Road • Milford, CT 06461-2420
Phone (800) 288-6000 • FAX (800) 255-1031 • Website: www.hubbell-wiring.com
Printed in U.S.A. Specifications subject to change without notice. H-MOSS® is a registered trademark of Hubbell Incorporated.
WLDSHM006 8/09
很抱歉,暂时无法提供与“CU300AU”相匹配的价格&库存,您可以联系我们找货
