HBL4715
HBL4715
    HUBBELL(哈伯尔公司)
HBL4715 数据手册
Twist-Lock® Devices 15 Ampere, 125, 250 Volts and 277 Volts AC 2 Pole, 3 Wire Grounding G W X G IP20 SUITABILITY Connector Bodies 15A 125V NEMA L5-15R UL/CSA Cord Dia. Catalog Number Insulgrip connector body, black and white nylon. Multiple drive screws. All black nylon. .230"-.720" (5.8-18.3) .230"-.720" (5.8-18.3) .325"-.655" (8.3-16.6) HBL4729C Valise® connector body, black nylon. 2.78" (70.6) Y Description Insulgrip connector body, 8 position angle, black and white nylon. Multiple drive screws. Insulgrip connector body, corrosion resistant, yellow and white nylon. Multiple drive screws. Elastogrip connector body, yellow elastomer, dust tight. Elastogrip® connector body, yellow elastomer, water/dust tight. Valise® connector body, yellow nylon. W G 15A 277V AC NEMA L7-15R UL/CSA 15A 250V NEMA L6-15R UL/CSA 1.53" (38.9) 1.41" (35.8) HBL4579C HBL4779C HBL4729CBK – – HBL4729CA – – HBL4729C 1.75" (44.5) .230"-.720" (5.8-18.3) HBL47CM29C HBL45CM79C HBL47CM79C .300"-.655" (7.6-16.6) .300"-.655" (7.6-16.6) .220"-.660" (5.6-16.8) .220"-.660" (5.6-16.8) HBL2547 – – HBL25W47** – – 4.00" (101.6) HBL25W47 HBL4729VY HBL4579VY 2.59" (65.8) HBL4779VY HBL4729VBK HBL4579VBK HBL4779VBK 1.50" (38.1) Note: See page B-49 for accessories. Receptacles Description Catalog Number Duplex, flush, brown RTP face, back and side wired. Duplex, flush, ivory RTP face, back and side wired. Duplex, ring terminal connection. Duplex, isolated ground, flush, orange RTP face, back and side wired. Duplex, corrosion resistant, yellow RTP face, back and side wired. Single, flush, black nylon face, back and side wired. Same as HBL4760 without mounting screws, ears. Terminal screws backed out, back and side wired. Single, ring terminal connection. Single, isolated ground, flush, orange nylon face, back and side wired. Single, black nylon face mounted on a 4" (101.6) round box cover, back and side wired. Single, panel mount, black nylon face, side wired only, 1.75" or 1.937" (44.5 or 49.2) mounting centers. HBL4700* HBL4700I* HBL4700RT* IG4700A* HBL47CM00* HBL4729VY HBL4550* – HBL4550RT* IG4550A* HBL4750* – – – – – HBL4710 – HBL4560 – HBL4760 HBL4760C HBL4710RT IG4710 HBL4560RT IG4560 1.70" (43.2) 3.28" (83.3) – – 2.74" (69.5) 1.17" (29.7) HBL4700 HBL4711 – HBL4761 HBL4713 HBL4563 HBL4763 1.27" (32.3) Note: See pages B-48 and B-49 for accessories. 2.38" (60.5) 1.38" (35.1) Flanged Receptacles Description Catalog Number Insulgrip flanged receptacle, nylon casing, back wired. Stainless steel casing, brown phenolic. Corrosion resistant, stainless steel casing, yellow melamine. HBL4715C HBL4585C HBL4785C HBL4715 HBL47CM15 HBL4585 – HBL4785 – Note: See pages B-48 and B-49 for accessories. HP ratings are AC only. RTP is an abbreviation for reinforced thermoplastic polyester. See section M for additional information on isolated ground devices. *Supplied with break-off tabs for split circuit wiring. **Watertight connector body IP55 suitability when closure plug is inserted or when installed and used properly with watertight plug. HBL4710 2.56" (65.0) 2.19" (55.6) 1.36" (34.5) 1.75" (44.5) 2.31" (58.7) 3.28" (83.3) 1.50" (38.1) 1.94" (49.3) .16" (4.1) DIA. 1.69" (42.9) .16" (4.1) DIA. HBL4715 1.72" (43.7) HBL4715C Dimensions in Inches (mm) www.hubbell-wiring.com ® Wiring Device-Kellems B-11
HBL4715 价格&库存
很抱歉,暂时无法提供与“HBL4715”相匹配的价格&库存,您可以联系我们找货
