HBL5269C
HBL5269C
    HUBBELL(哈伯尔公司)
    HBL5269C
HBL5269C 数据手册
Hubbell Wiring Device-Kellems Entertainment Industry Products At Hubbell, We’re Never Satisfied, But Our Customers Always Are. Hubbell Wiring Device-Kellems products have long set the standard for innovation, performance, durability, safety and convenience. But, there’s an underlying secret to our continuing success. It’s our philosophy of never leaving well enough alone. We believe we can always make our products better – and the record shows we have. The dynamic environments the Entertainment Industry faces are unpredictable and therefore place high demands on all your equipment. Hubbell devices have the proven reliability to deliver secure connections that let you turn your attention to the critical details for a flawless show, no matter what the venue. We offer tailored products to the entertainment industry such as all black plugs and connectors that blend into the background, single pole devices with a double cam that stand up to repeated mating, angle plugs from 15 to 60 amps that fit into the tight spaces where cable management becomes a more critical issue, and the overall quality that can take on the harsh everyday abuse unique to producing a show. Safety is always a top priority, all Hubbell products are designed and manufactured with this in mind and exceed UL standards so the show can go on. Since our company was founded more than 115 years ago, Hubbell Wiring Devices has become the standard in the industry. We pride ourselves with the quality and the detail built into every product we make. We’ve put this brochure together so you can easily find in one place, all of the Hubbell devices that our experience tells us the Entertainment Industry needs to keep quality high and downtime low. Hubbell Advantage Hubbell First - Indicates a product that is the first in the industry to meet a new standard or solve key application needs. Labor Savings - Indicates a unique feature that greatly simplifies assembly or reduces installation time. Tips and Application Solutions Describes ways to use Hubbell products to address demanding applications. Entertainment Industry Products Table of Contents Page Straight Blade Plugs, Connectors, Receptacles and Inlets 2 Twist-Lock® Plugs, Connectors, Receptacles, Inlets, Outlets and Midget Twist-Lock 3 Single Pole Plugs, Receptacles, Caps, Tri-Tap, "T"s and Snap Back Covers 4, 5 Pin & Sleeve Plugs, Receptacles, Connectors, Inlets, Back Boxes, Low Profile and Short Pin & Sleeve 6, 7 Modular Cable Protection Systems TrukTrak®, TredTrak® and AccessTrak® Systems 8 Lock-Out Tag-Out PLUGOUT® and SWITCHOUT® Devices 9 Automatic and Manual Set Line Cords, Ground Fault Circuit Interrupter Portable Multiple Outlets and GFCI Devices Modules 10 30 Amp Ground Fault Devices Hard Wired and Portable GFCI 11 Electric Cord and Cable Reels Weatherproof Cable and Static Discharge Reels 12 Portable Outlet Boxes and Plates Boxes with Cord Strain Relief, Blank, Single and Duplex Plates 13 Spider® II 50 Amp and 60 Amp Temporary Power Distribution Systems 13 HI-Impact™ Industrial Ethernet Connectors, Patch Cords, Plugs, Wall Plates and Accessories 14 Voice, Data and Video Jacks, Multimedia Connectors, Plates, Frames and Modules 15 Convention Center Floor Box Floor Box with Provisions for Power, Datacom, Water and Compressed Air 16, 17 1 www.hubbellcatalog.com/wiring Entertainment Industry Products Straight Blade Hubbell Insulgrip plugs and connectors continue our long-standing tradition of leadership as well as innovative design. The tough nylon body provides impact and chemical resistance commonly needed in the Entertainment Industry. The durable and powerful offsetting cord grip clamps on individual conductors and outer cord jackets prevent strain on the terminals. It’s these and many other features that set Hubbell performance above all others. Insulgrip Heavy Duty Plugs 2 Pole, 3 Wire Grounding 15 and 20 Amp, 125 Volts NEMA 5-15P 15A 125V 0.5 HP NEMA 5-20P 20A 125V 1 HP Description Black and white nylon. Cord Dia. .230"-.720" (5.8-18.3) Catalog Numbers HBL5266C™ HBL5366C™ All black nylon. .230"-.720" (5.8-18.3) HBL5266CM2 HBL5366CM2 Corrosion resistant yellow nylon. .230"-.720" (5.8-18.3) HBL52CM66C HBL53CM66C 8-position angle plug, black & white nylon. .325"-.655" (8.3-16.6) HBL5266CA HBL5366CA 8-position angle plug, transparent enclosure. .325"-.655" (8.3-16.6) HBL5266CAT – Anchor lock, black and white nylon.* .230"-.720" (5.8-18.3) HBL5280C – Anchor lock, corrosion resistant yellow nylon.* .230"-.720" (5.8-18.3) HBL52CM80C – Finger grip, black neoprene, combination screws. .312"-.468" (7.9-11.9) CSA only. HBL5921 – Fusible, black vinyl housing, slotted screws. CSA only. HBL5299 – * .296"-.625" (7.5-15.9) HBL5266C HBL5280C Component Insulgrip Heavy Duty Connector Bodies 2 Pole, 3 Wire Grounding 15 and 20 Amp, 125 Volts NEMA 5-15R 15A 125V NEMA 5-20R 20A 125V Description Black and white nylon. Cord Dia. .230"-.720" (5.8-18.3) Catalog Numbers HBL5269C™ HBL5369C™ All black nylon. .230"-.720" (5.8-18.3) HBL5269CM2 HBL5369CM2 Corrosion resistant yellow nylon. .230"-.720" (5.8-18.3) HBL52CM69C HBL53CM69C Heavy Duty, Specification Grade Duplex Receptacles NEMA 5-15R 15A 125V 0.5 HP NEMA 5-20R 20A 125V 1HP Description Flush, nylon face, back and side wired, multiple drive screws. Color Brown Ivory Gray Red White Black Catalog Numbers HBL5262 HBL5362 HBL5262I HBL5362I HBL5262GY HBL5362GY HBL5262R HBL5362R HBL5262W HBL5362W HBL5262BK HBL5362BK Corrosion resistant. Yellow Ivory HBL52CM62 HBL52CM62I On 4" (101.6) round cover. Brown HBL5282 Isolated ground. Orange Ivory Gray White Red IG5262 IG5262I IG5262GY – IG5262R Flanged Inlets and Receptacles Description Nylon casing, back wired. Weatherproof, gray nylon, w/lift cover & boot, multiple drive screws. Dimensions in Inches (mm) NEMA 5-15R 15A 125V NEMA 5-15R 15A 125V NEMA 5-20R 20A 125V – IG5362 IG5362I IG5362GY IG5362W IG5362R HBL5262 NEMA 5-20R 20A 125V Flanged Receptacle Catalog Numbers HBL5279C HBL5379C HBL61CM64 HBL61CM65 2 HBL5269C HBL53CM62 – Flanged Inlet Catalog Numbers HBL5278C HBL5378C – HBL5266A – HBL5278C Entertainment Industry Products Twist-Lock® Since 1929, when Harvey Hubbell obtained the first patents on Twist-Lock® devices and introduced them to the market, they have been the standard for the Entertainment Industry. Today, Hubbell Insulgrip Twist-Lock Devices continue to set the standard against which all quality industrial wiring devices are measured. The Insulgrip® line includes plugs, connectors, flanged inlets and outlets and flush mounting receptacles. With a single piece dust shield, tough nylon housing, visible identification and a roomy wiring chamber, these devices offer the most powerful cord grip in the industry. The unparalleled acceptance and success of the Twist-Lock line is a tribute to the quality of this long lasting design. When selecting premium plugs and connectors for the Entertainment Industry, the decision is Hubbell. Twist-Lock Devices Selection Chart NEMA Grounding Twist-Lock 15 20 2 3 30 20 3 4 30 20 4 5 30 Connector Body Inlet Outlet Insulgrip Nylon Nylon Single Receptacles Single IG Single NEMA AC HP Code No. Rating† Poles Wires Amps Volts 15 Plug 125 L5-15 0.5 HBL4720C 250 L6-15 1.5 HBL4570C HBL4720CBK HBL4729C HBL4729CBK HBL4716C HBL4715C HBL4710 IG4710 HBL4579C 277AC L7-15 2 HBL4770C HBL4779C 125 L5-20 1 HBL2311 HBL2311BK HBL2313 HBL2313BK HBL2315 HBL2316 HBL2310 IG2310 250 L6-20 2 HBL2321 HBL2321BK HBL2323 HBL2323BK HBL2325 HBL2326 HBL2320 IG2320 277AC L7-20 2 HBL2331 HBL2333 HBL2335 HBL2336 HBL2330 480AC L8-20 3 HBL2341 HBL2343 HBL2345 HBL2346 HBL2340 IG2340 600AC L9-20 HBL2351 HBL2353 HBL2355 HBL2356 HBL2350 125 L5-30 2 HBL2611 HBL2611BK HBL2613 HBL2613BK HBL2615 HBL2616 HBL2610 IG2610 250 L6-30 2 HBL2621 HBL2621BK HBL2623 HBL2623BK HBL2625 HBL2626 HBL2620 IG2620 277AC L7-30 3 HBL2631 HBL2633 HBL2635 HBL2636 HBL2630 480AC L8-30 5 HBL2641 HBL2643 HBL2645 HBL2646 HBL2640 600AC L9-30 HBL2651 HBL2653 HBL2655 HBL2656 HBL2650 125/250 L14-20 2 (1) HBL2411 HBL2415 HBL2416 HBL2410 IG2410 3Ø250AC L15-20 3 HBL2421 HBL2423 HBL2425 HBL2426 HBL2420 IG2420 3Ø480AC L16-20 5 HBL2431 HBL2433 HBL2435 HBL2436 HBL2430 125/250 L14-30 2 HBL2711 HBL2715 HBL2716 HBL2710 IG2710 3Ø250AC L15-30 3 HBL2721 HBL2723 HBL2725 HBL2726 HBL2720 IG2720 3Ø480AC L16-30 10 HBL2731 HBL2733 HBL2735 HBL2736 HBL2730 3Ø600AC L17-30 HBL2741 HBL2743 HBL2745 HBL2746 HBL2740 3ØY120/208AC L21-20 2 HBL2511 HBL2515 HBL2516 HBL2510 IG2510 3ØY277/480AC L22-20 5 HBL2521 HBL2523 HBL2525 HBL2526 HBL2520 3ØY347/600AC L23-20 HBL2531 HBL2533 HBL2535 HBL2536 HBL2530 3ØY120/208AC L21-30 3 HBL2811 HBL2815 HBL2816 HBL2810 IG2810 3ØY277/480AC L22-30 10 HBL2821 HBL2823 HBL2825 HBL2826 HBL2820 3ØY347/600AC L23-30 HBL2831 HBL2833 HBL2835 HBL2836 HBL2830 HBL2411BK HBL2711BK HBL2511BK HBL2811BK HBL2413 HBL2713 HBL2513 HBL2813 HBL4586C HBL4585C HBL4560 IG4560 HBL4786C HBL4785C HBL4760 HBL2413BK HBL2713BK HBL2513BK HBL2813BK Flat Cable Cable Cord Cord Clamp Clamp Devices Devices Flat 4 5 20 3ØY120/208AC L21-20 2 HBL2511FC HBL2513FC 30 3ØY120/208AC L21-30 3 HBL2811FC HBL2813FC Plug Midget Twist-Lock Poles Wires Amps Volts Plug Insulation Displacement Connector Connector Insulation Displacement Nylon Inlet Stainless Steel Inlet Nylon Outlet Stainless Steel Outlet NEMA Code No. 2 2 15 125 ML-1 HBL7465V HBL7467 HBL7468 2 3 15 125 ML-2 HBL7494 HBL7494V HBL7464V HBL7593 HBL7593V HBL7595N HBL7595 HBL7596N HBL7596 3 3 15 125/250 ML-3 HBL7485 HBL7485V HBL7484 HBL7484V HBL7486N HBL7486 HBL7487N HBL7487 †The Horsepower Ratings are the Phase Values. The Values in Parentheses are Phase to Neutral. Note: Horsepower Ratings are Applicable to Plugs and Receptacles Only and Do Not Apply to Connectors, Flanged Inlets and Outlets. 3 www.hubbellcatalog.com/wiring Entertainment Industry Products Single Pole Hubbell’s new Single Pole connectors are made from a specially formulated thermoset rubber that resists cracking in cold, hot or oily conditions as well as any other harmful environments that may be found within the Entertainment Industry. The connectors have been designed so they are easy to assemble, requiring no special tools. A high strength, non-conductive retaining screw will securely lock the contacts to the insulated sleeves. These Single Pole connectors are completely interchangeable with other manufacturers single pole products. The product is UL Enclosure Type 3R, 4X and 12K Rated. Plugs Amp 300 300 300 300 300 300 300 300 Color Black White Red Blue Green Yellow Orange Brown Cable Size #4 - 2/0 #4 - 2/0 #4 - 2/0 #4 - 2/0 #4 - 2/0 #4 - 2/0 #4 - 2/0 #4 - 2/0 Male Plug HBL300MBK HBL300MW HBL300MR HBL300MBL HBL300MGN HBL300MY HBL300MO HBL300MBN Female Plug HBL300FBK HBL300FW HBL300FR HBL300FBL HBL300FGN HBL300FY HBL300FO HBL300FBN 400 400 400 400 400 400 400 400 Black White Red Blue Green Yellow Orange Brown 2/0 - 4/0 2/0 - 4/0 2/0 - 4/0 2/0 - 4/0 2/0 - 4/0 2/0 - 4/0 2/0 - 4/0 2/0 - 4/0 HBL400MBK HBL400MW HBL400MR HBL400MBL HBL400MGN HBL400MY HBL400MO HBL400MBN HBL400FBK HBL400FW HBL400FR HBL400FBL HBL400FGN HBL400FY HBL400FO HBL400FBN Male Plug HBLMRSBK HBLMRSW HBLMRSR HBLMRSBL HBLMRSGN HBLMRSY HBLMRSO HBLMRSBN Female Plug HBLFRSBK HBLFRSW HBLFRSR HBLFRSBL HBLFRSGN HBLFRSY HBLFRSO HBLFRSBN Panel Mount Receptacles; Stud Type Amp 400 400 400 400 400 400 400 400 Color Black White Red Blue Green Yellow Orange Brown HBL400MBK HBL400FBK HBLMRSR HBLFRSBL Panel Mount Receptacles; Double Set Screw Amp 400 400 400 400 400 400 400 400 Color Black White Red Blue Green Yellow Orange Brown Cable Size #4 - 4/0 #4 - 4/0 #4 - 4/0 #4 - 4/0 #4 - 4/0 #4 - 4/0 #4 - 4/0 #4 - 4/0 Male Plug HBLMRBK HBLMRW HBLMRR HBLMRBL HBLMRGN HBLMRY HBLMRO HBLMRBN Female Plug HBLFRBK HBLFRW HBLFRR HBLFRBL HBLFRGN HBLFRY HBLFRO HBLFRBN Fits Male Devices HBLMCAPBK HBLMCAPW HBLMCAPR HBLMCAPBL HBLMCAPGN HBLMCAPY HBLMCAPO HBLMCAPBN Fits Female Devices HBLFCAPBK HBLFCAPW HBLFCAPR HBLFCAPBL HBLFCAPGN HBLFCAPY HBLFCAPO HBLFCAPB Protective Caps Color Black White Red Blue Green Yellow Orange Brown 4 HBLMRBK HBLFRO HBLFCAPBK HBLMCAPBK Entertainment Industry Products Single Pole Tapping and Paralleling “T” Color Black White Red Blue Green Yellow Orange Brown Tapping "T" (Female-Female-Male) Catalog Numbers HBLTBK HBLTW HBLTR HBLTBL HBLTGN HBLTY HBLTO HBLTBN Paralleling "T" (Female-Male-Male) Catalog Numbers HBLPTBK HBLPTW HBLPTR HBLPTBL HBLPTGN HBLPTY HBLPTO HBLPTBN Male-Female-Female-Female Catalog Numbers HBLM3FBK HBLM3FW HBLM3FR HBLM3FBL HBLM3FGN HBLM3FY HBLM3FO HBLM3FBN Female-Male-Male-Male Catalog Numbers HBLF3MBK HBLF3MW HBLF3MR HBLF3MBL HBLF3MGN HBLF3MY HBLF3MO HBLF3MBN HBLTBN HBLPTY HBLM3FBK HBLF3MR Tri-Tap Color Black White Red Blue Green Yellow Orange Brown Double Male (Male-Male) Color Black White Red Blue Green Yellow Orange Brown Catalog Numbers HBLDMBK HBLDMW HBLDMR HBLDMBL HBLDMGN HBLDMY HBLDMO HBLDMBN HBLDMBL Double Female (Female-Female) Color Black White Red Blue Green Yellow Orange Brown Catalog Numbers HBLDFBK HBLDFW HBLDFR HBLDFBL HBLDFGN HBLDFY HBLDFO HBLDFBN HBLDFBK Snap Back Cover Color Black White Red Blue Green Yellow Orange Brown Catalog Numbers HBLSCBK HBLSCW HBLSCR HBLSCBL HBLSCGN HBLSCY HBLSCO HBLSCBN 5 HBLSCW www.hubbellcatalog.com/wiring Entertainment Industry Products Pin & Sleeve Go ahead and dish it out. Immerse it in water, grind it with dirt or put it to the test on the longest cable runs. Run over it, bake it or freeze it. Hubbell Pin & Sleeve is designed and built for the most demanding Entertainment Industry applications. All of these Pin & Sleeve devices are designed to be safe, easy to use and reliable in any environment. These UL Listed and CSA Certified devices will interface with any Pin & Sleeve meeting International Standard IEC 60309-1 and IEC 60309-2. Watertight Devices IP67 Poles and Amps Wires 16 2P 3W 2P 3W 3P 4W 4P 5W 20 2P 3W 2P 3W 2P 3W 3P 4W 3P 4W 3P 4W 3P 4W 4P 5W 4P 5W 4P 5W 30 2P 3W 2P 3W 2P 3W 3P 4W 3P 4W 3P 4W 3P 4W 4P 5W 4P 5W 4P 5W 32 2P 3W 2P 3W 3P 4W 3P 4W 4P 5W Configuration Recep./ Plug/ Conn. Inlet Voltage 100-130 220-240 380-415 220/380 240/415 125 250 480 125/250 3Ø250 3Ø480 3Ø600 3ØY120/208 3ØY277/480 3ØY347/600 125 250 480 125/250 3Ø250 3Ø480 3Ø600 3ØY120/208 3ØY277/480 3ØY347/600 100-130 220-240 380-415 380V 50Hz 440V 60Hz 240/415 220/380 Back Boxes Receptacle Plug Connector HBL316R4W HBL316P4W HBL316C4W HBL316B4W† BB2030N Inlet Nonmetallic Metallic HBL316R6W HBL316P6W HBL316C6W HBL316B6W HBL416R6W HBL416P6W HBL416C6W HBL416B6W† BB2030N HBL516R6W HBL516P6W HBL516C6W HBL516B6W BB2030N HBL320R4W HBL320P4W HBL320C4W HBL320B4W BB2030N HBL320R6W HBL320P6W HBL320C6W HBL320B6W BB2030N HBL320R7W HBL320P7W HBL320C7W HBL320B7W BB2030N BB2030N HBL420R12W HBL420P12W HBL420C12W HBL420B12W BB2030N HBL420R9W HBL420P9W HBL420C9W HBL420B9W BB2030N HBL420R7W HBL420P7W HBL420C7W HBL420B7W BB2030N HBL420R5W HBL420P5W HBL420C5W HBL420B5W BB2030N HBL520R9W HBL520P9W HBL520C9W HBL520B9W BB2030N HBL520R7W HBL520P7W HBL520C7W HBL520B7W BB2030N HBL520R5W HBL520P5W HBL520C5W HBL520B5W BB2030N HBL330R4W HBL330P4W HBL330C4W HBL330B4W BB2030N HBL330R6W HBL330P6W HBL330C6W HBL330B6W BB2030N HBL330R7W HBL330P7W HBL330C7W HBL330B7W BB2030N HBL430R12W HBL430P12W HBL430C12W HBL430B12W BB2030N HBL430R9W HBL430P9W HBL430C9W HBL430B9W BB2030N HBL430R7W HBL430P7W HBL430C7W HBL430B7W BB2030N HBL430R5W HBL430P5W HBL430C5W HBL430B5W BB2030N HBL530R9W HBL530P9W HBL530C9W HBL530B9W BB2030N HBL530R7W HBL530P7W HBL530C7W HBL530B7W BB2030N HBL530R5W HBL530P5W HBL530C5W HBL530B5W BB2030N HBL332R4W† HBL332P4W† HBL332C4W† HBL332B4W† BB2030N HBL332R6W HBL332P6W HBL332C6W HBL332B6W BB2030N HBL432R6W HBL432P6W HBL432C6W HBL432B6W BB2030N HBL432R3W HBL432P3W HBL432C3W – BB2030N HBL532R6W HBL532P6W HBL532C6W HBL532B6W BB2030N † Consult factory. 6 BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W BB201W BB301W Replacement Interior Kits Conn. Plugs Recep. Inlets IN320BF IN320BM IN320BF IN320BM IN420DF IN420DM IN520EF† IN520EM IN320AF IN320AM IN320BF IN320BM IN320BF IN320BM IN420CF IN420CM IN420DF IN420DM IN420DF IN420DM IN420DF IN420DM IN520EF† IN520EM IN520EF† IN520EM IN520EF† IN520EM IN330AF IN330AM IN330BF IN330BM IN330BF IN330BM IN430CF IN430CM IN430DF IN430DM IN430DF IN430DM IN430DF IN430DM IN530EF IN530EM IN530EF IN530EM IN530EF IN530EM IN330BF IN330BM IN330BF IN330BM IN430DF IN430DM IN430DF IN430DM IN530EF IN530EM Entertainment Industry Products Pin & Sleeve Watertight Devices Poles Configuration and Recep./ Plug/ Amps Wires Conn. Inlet 60 2P 3W 2P 3W 2P 3W 3P 4W 3P 4W 3P 4W 3P 4W 4P 5W 4P 5W 4P 5W 63 2P 3W 3P 4W 4P 5W 100 2P 3W 2P 3W 2P 3W 3P 4W 3P 4W 3P 4W 3P 4W 4P 5W 4P 5W 4P 5W 125 2P 3W 3P 4W 4P 5W IP67 Voltage 125 250 480 125/250 3Ø250 3Ø480 3Ø600 3ØY120/208 3ØY277/480 3ØY347/600 220-240 380-415 220/380 240/415 125 250 480 125/250 3Ø250 3Ø480 3Ø600 3ØY120/208 3ØY277/480 3ØY347/600 220-240 380-145 220/380 240/415 Watertight Devices Back Boxes Receptacle HBL360R4W Plug HBL360P4W Connector HBL360C4W Inlet HBL360B4W HBL360R6W HBL360P6W HBL360C6W HBL360B6W HBL360R7W HBL360P7W HBL360C7W HBL360B7W HBL460R12W HBL460P12W HBL460C12W HBL460B12W HBL460R9W HBL460P9W HBL460C9W HBL460B9W HBL460R7W HBL460P7W HBL460C7W HBL460B7W HBL460R5W HBL460P5W HBL460C5W HBL460B5W HBL560R9W HBL560P9W HBL560C9W HBL560B9W HBL560R7W HBL560P7W HBL560C7W HBL560B7W HBL560R5W HBL560P5W HBL560C5W HBL560B5W HBL363R6W HBL363P6W HBL363C6W HBL363B6W HBL463R6W HBL463P6W HBL463C6W HBL463B6W HBL563R6W HBL563P6W HBL563C6W HBL563B6W HBL3100R4W HBL3100P4W HBL3100C4W HBL3100B4W HBL3100R6W HBL3100P6W HBL3100C6W HBL3100B6W HBL3100R7W HBL3100P7W HBL3100C7W HBL3100B7W HBL4100R12W HBL4100P12W HBL4100C12W HBL4100B12W HBL4100R9W HBL4100P9W HBL4100C9W HBL4100B9W HBL4100R7W HBL4100P7W HBL4100C7W HBL4100B7W HBL4100R5W HBL4100P5W HBL4100C5W HBL4100B5W HBL5100R9W HBL5100P9W HBL5100C9W HBL5100B9W HBL5100R7W HBL5100P7W HBL5100C7W HBL5100B7W HBL5100R5W HBL5100P5W HBL5100C5W HBL5100B5W HBL3125R6W HBL3125P6W HBL3125C6W HBL3125B6W HBL4125R6W HBL4125P6W HBL4125C6W HBL4125B6W HBL5125R6W HBL5125P6W HBL5125C6W HBL5125B6W Nonmetallic Metallic BB60N BB601W BB602W BB60N BB601W B602W BB60N BB601W BB602W BB60N BB601W BB602W BB60N BB601W BB602W BB60N BB601W BB602W BB60N BB601W BB602W BB60N BB601W BB602W BB60N BB601W BB602W BB60N BB601W BB602W BB60N BB601W BB602W BB60N BB601W BB602W BB60N BB601W BB602W BB100N BB1001W BB1002W BB100N BB1001W BB1002W BB100N BB1001W BB1002W BB100N BB1001W BB1002W BB100N BB1001W BB1002W BB100N BB1001W BB1002W BB100N BB1001W BB1002W BB100N BB1001W BB1002W BB100N BB1001W BB1002W BB100N BB1001W BB1002W BB100N BB1001W BB1002W BB100N BB1001W BB1002W BB100N BB1001W BB1002W Replacement Interior Kits Conn. Plugs Recep. Inlets IN360AF IN360AM IN360BF N360BM† IN360BF N360BM† IN460CF IN460CM IN460DF IN460DM IN460DF IN460DM IN460DF IN460DM IN560EF N560EM† IN560EF N560EM† IN560EF N560EM† IN360BFS IN360BMS† IN460DFS IN460DMS IN560EFS† IN560EMS IN3100AF IN3100AM IN3100BF IN3100BM† IN3100BF IN3100BM† IN4100CF† IN4100CM IN4100DF IN4100DM IN4100DF IN4100DM IN4100DF IN4100DM IN5100EF IN5100EM IN5100EF IN5100EM IN5100EF IN5100EM IN3100BFS IN3100BMS † † IN4100DFS IN4100DMS IN5100EFS IN5100EMS † Consult factory. Short Pin & Sleeve Plug Low Profile Devices Configuration Poles Recep./ Plug/ Amps & Wires Conn. Inlet 20 3P 4W 30 3P 4W 3P 4W 60 3P 4W 60 4P 5W Voltage 3Ø250 125/250 3Ø250 3Ø250 3ØY 120/208 Plug L420P9 Receptacle L420R9 L430P12 L430R12 L430P9 L430R9 A460P9 A460R9 A560P9 — Cord Diameter Min. Max. .350”-.710” (8.3-15.9) .390”-.775” (9.9-19.7) .390” -.775” (9.9-19.7) Configuration Poles Recep./ Amps & Wires Conn. 100 4P 5W Plug/ Inlet Voltage Plug 3ØY 120/208 HBL5100P9WSH .75”-1.25” (19.0- 31.8) 7 www.hubbellcatalog.com/wiring Entertainment Industry Products Modular Cable Protection Systems The Entertainment Industry is an ideal application for this Modular Cable Protection System. These products are designed to safeguard electrical cables and cords from vehicle and pedestrian traffic. This product line comes in three versions: • TredTrak® System - comes as a 5-channel track that will protect cable diameters up to 1.28". • TrukTrak® System - comes with 5 channels and will protect cables up to 3.25" in diameter. • AccessTrak® System - comes with 5 channels and will protect cables up to 1.31" in diameter. Enables users to be ADAAG (American Disabilities Act Accessibility Guidelines) compliant. TrukTrak® System Description 5-Channel blue & yellow. 5-Channel end caps (pair only), yellow. 5-Channel 45° right turn blue & yellow. 5-Channel 45° left turn blue & yellow. 3-Channel, blue & yellow. 3-Channel end caps (pair only), yellow. Catalog Numbers HBLTT5B HBLTT5ECB (Female) (Male) HBLTT545RB Width B 20" (508) Height C 2.31" (58.7) Channel Width Height D E 1.25" (31.8) 1.25" (31.8) 7.5" (190.5) 20" (508) 5.25" (133.3) 20" (508) 25" (635) 20" (508) 2.31" (58.7) 2.31" (58.7) 2.31" (58.7) 1.25" (31.8) 1.25" (31.8) 1.25" (31.8) 1.25" (31.8) 1.25" (31.8) 1.25" (31.8) HBLTT545LB 25" (635) 20" (508) 2.31" (58.7) 1.25" (31.8) 1.25" (31.8) 36" (914.4) 20" (508) 3.05" (77.5) 2.25" (57.2) 2.25" (57.2) 8.25" (209.6) 20" (508) 6.38" (161.9) 20" (508) 36" (914.1) 22" (558.8) 3.05" (77.5) 2.25" (57.2) 3.05" (77.5) 2.25" (57.2) 4.13" (104.9) 3.25" (82.6) 2.25" (57.2) 2.25" (57.2) 3.25" (82.6) Length A 36" (914.1) Width B 17.5" (445) Height C 1.95" (50) Channel Width Height D E 1.30" (33) 1.30" (33) 5.5" (138) 5.5" (138) 5.5" (138) 17.5" (445) 17.5" (445) 17.5" (445) 1.95" (50) 1.95" (50) 1.95" (50) 1.30" (33) 1.30" (33) 1.30" (33) 1.30" (33) 1.30" (33) 1.30" (33) 17.5" (445) 17.5" (445) 1.95" (50) 1.30" (33) 1.30" (33) 17.5" (445) 17.5" (445) 1.95" (50) 1.30" (33) 1.30" (33) Length A 36" (914.4) HBLTT3B HBLTT3ECB (Female) (Male) 2-Channel, blue & yellow. HBLTT2B ® TredTrak Right turn 45 Female end Female End A A B Male end Male End D E System Catalog Description Numbers 5-Channel blue & yellow. HBLTRED5B 5-Channel end caps HBLTRED5ECB (pair only), yellow. (Female) (Male) 5-Channel female HBLTRED5ECFB end caps (2 females), yellow. 5-Channel “X" fitting, HBLTRED5XB blue & yellow. 5-Channel “Y" fitting, HBLTRED5YB blue & yellow. ® AccessTrak Y-Fitting System Channel Catalog Length Width Height Width Description Numbers A B C D AccessTrak Kit* HBLAT5KIT 41.06" (1043) 42.90" (1090) 4.00" (102) 1.34" (34) Trough HBLAT5 36.00" (914) 13.34 (339) 1.94" (49) 1.34" (34) Trough End Rails (set) HBLAT5ER 16.03" (407) — 4.00" (102) — Ramps (set) HBLAT5RAMP 36.00" (965) — 1.94" (49) — Ramp End Rails (set) HBLAT5RAMPER — 14.75" (375) 4.00" (102) — *Consists of (1) HBLAT5, (1 set) HBLAT5ER, (1 set) HBLAT5RAMP and (2 sets) HBLAT5RAMPER Height E 1.31" (33) 1.31" (33) — — — Ramp Top View Trough 14.75" (375) 36.00" (914) B Trough Rails 4.00" (102) 13.28" (337) Ramp Side View 1.88" (48) Dimensions in Inches (mm) Assembled Kit 14.50" (368) A Trough Height X-Fitting Ramp End Rails B .25" (6.35) Left turn 45 41.06" (1043) 4.00" (102) 8 42.90" (1090) C Entertainment Industry Products Lock-Out Tag-Out All Hubbell Wiring Device-Kellems Lock-Out products comply with OSHA Lock-Out/Tag-Out Regulation 29CFR 1910.1478. The PlugOut product line accommodates the broadest range of plugs in the market place today from 15A convenience plugs all the way up to and including 60A Pin & Sleeve devices. Use these devices below to work safe during set-ups or breakdowns by insuring circuits are not energized. Lockout Devices For Electrical Safety PLUGOUT®, Keyed PLUGOUT®, and SWITCHOUT™ safety devices provide an approved method of complying with OSHA Lockout/Tagout regulation 29CFR 1910.147. PLUGOUT Devices Description Typical Devices Accommodated Catalog Numbers Small yellow lockout device. 15 and 20A molded on plugs. HLDMP Twist-Lock® plugs. HLD Medium yellow lockout device. 20 and 30A Large yellow lockout device. 20, 30 and 60A metallic and non-metallic Pin & Sleeve, Hubbellock® & 50A Twist-Lock plugs. HLD2 Description Yellow keyed PLUGOUT, keyed differently. Typical Devices Accommodated 15 and 20A, 125V straight blade plugs with holes in blades. Catalog Numbers HKLD Yellow keyed PLUGOUT, keyed alike. 15 and 20A, 125V straight blade plugs with holes in blades. HKLDPK2* HLDMP *Two devices per package. HLD SWITCHOUT Lockout Devices Description Yellow SWITCHOUT device. Typical Devices Accommodated Toggle switch. Catalog Numbers HSLDPK2* Includes HLDMP, HSLDPK2, HLD and HLD2. Catalog Numbers HLDKIT *Two devices per package. Lockout Device Kit Description Yellow lockout kit. HSLDPK2 Dimensions in Inches (mm) 9 HLD2 HKLDPK2 www.hubbellcatalog.com/wiring Entertainment Industry Products GFCI All Hubbell GFCI products are built for quality, designed for easy installation and packaged for convenience. The portable GFCI line cords provide ground fault protection both indoors and out. They are offered with an Automatic or Manual Set feature to meet all applications in the Entertainment Industry. Circuit Guard® Automatic Set Portable GFCI Line Cords Automatically energizes or sets the GFCI for use upon plug in and after the loss of primary power (power failure or unplugging the device). After a ground fault condition, unit must be reset by pushing the reset button. This feature eliminates the need for unit to be reset each time it is plugged in or powered up. Ideal for equipment intended for continuous use where a temporary power failure is likely and undesirable. Examples are pumps, pressure washers, portable signs or lighting and engine heaters. 15A 120V AC Description Catalog Numbers 18" (45.7 cm) GFCI line cord. 6’ (182.9 cm) GFCI line cord. 25’ (762 cm) GFCI line cord. 15’ (457.2 cm) GFCI power supply cord with stripped leads. GFP4C15A GFP6C15A GFP25C15A GFPOEMA* GFP4C15A Circuit Guard® Manual Set Portable GFCI Line Cords Requires the GFCI to be manually set for use by pressing the reset button upon plug in and after loss of primary power (power failure or unplugging the device). Must be manually reset after a ground fault condition. Ideal for applications where operator injury might occur if equipment were to restart after a power failure. Typical equipment includes power drills, saws, lathes and grinders. 15A 120V AC GFP3C20M 20A 120V AC Description Catalog Numbers 18" (45.7 cm) GFCI line cord. GFP4C15M – 3’ (91.4 cm) GFCI line cord. – GFP3C20M 6’ (182.9 cm) GFCI line cord. GFP6C15M – 25’ (762 cm) GFCI line cord. GFP25C15M – 15’ (457.2 cm) GFCI power supply cord with stripped leads. GFPOEMM* – 50’ (1524 cm) GFCI power supply with Elastogrip® GFP50C15WM – watertight straight blade. 100’ (3048 cm) GFCI power supply with Elastogrip GFP100C15WM – watertight straight blade. *Total length is 15’ 4.5" (468.6 cm) including leads: green 4.5" (114.3), black and white 3.5" (88.9). Each prestripped .375" (9.5). GFPOEMM Circuit Guard® Manual Set Twist-Lock® Portable GFCI Line Cords Description 3’ (91.4 cm) GFCI line cord. 15A 120V AC 20A 120V AC Catalog Numbers GFP3C15MTL GFP3C20MTL Plug NEMA 5-15P NEMA 5-20P Catalog Numbers GFP15M GFP20M GFP3C20MTL Multiple Outlet Portable GFCI Description 4 outlet, yellow. 4 outlet, yellow. Rating 15A, 120V AC 20A, 120V AC Receptacles 2-Duplex 5-15R 2-Duplex 5-20R GFP15M GFCI Module Description GFCI module, manual set, yellow. Rating 20A, 120V AC, 60 Hz Dimensions in Inches (mm) Catalog Number GFM20 10 GFM20 Entertainment Industry Products GFCI 30A Ground Fault Products The GFCI offering consists of 30 hard-wired units that may be either surface or panel mounted. All models are available in 120, 240, 120/240V AC, 3Ø250V AC and 3Ø120/208V AC configurations and come in either automatic or manual reset. Hardwired units are available with or without an audible alarm and may also be ordered with either a line voltage or low voltage output signal. All portables are also 30 amp max rated and come with pigtails on both the line and the load sides so that the end-user may install any plug and connector they may choose. Circuit Guard Hard Wired 30A GFCI Description Hard wired, manual set and automatic set GFCIs. Voltage 120V AC 120V AC 240V AC 240V AC 120/240V AC 3Ø250V AC 3Ø120/208V AC Note: All units above are stock items. Alarm None Audible None Audible Audible Audible Audible Manual Set GFHW13005 GFHW13015 GFHW23005 GFHW23015 GFHW33015 GFHW530 GFHW430 Automatic Set GFHW13105 GFHW13115 GFHW23105 GFHW23115 GFHW33115 GFHW531 GFHW431 Automatic Reset GFCI Build Your Own Catalog Number Catalog Number Configurator: Example: Catalog Number: GFHW23015 GF HW 2 Voltage Ground HardFault Wired 1-120 V AC 2- 240 V AC 3-120/240V AC 4-3Ø120/208V AC 5-3Ø250V AC 3 0 Amperage 3 - 30 Amp 1 5 Reset Type Output Signal Mounting Style 0 - Manual 1 - Automatic 0 1 2 3 4 5 - Panel Mount/ Surface Mount - none Audible Alarm Line Voltage 24 Volt DC 12 Volt DC Manual Reset GFCI Note: 2 to 3 week lead time for all “build your own" catalog numbers. Circuit Guard Portable 30A GFCI Description Portable, manual set and automatic set GFCIs. Cord Length 2 Foot 25 Feet 2 Foot 25 Feet 6 Feet 6 Feet 6 Feet Note: All units above are stock items. Voltage 120V AC 120V AC 240V AC 240V AC 120/240V AC 3Ø250V AC 3Ø120/208V AC Manual Set GFP1301 GFP1302 GFP2301 GFP2302 GFP3305 GFP5305 GFP4305 Automatic Set GFP1311 GFP1312 GFP2311 GFP2312 GFP3315 GFP5315 GFP4315 GFP1311 Dimensional Drawing Catalog Number Configurator: Example: Catalog Number: GFHW23015 GF P 2 Voltage Ground PortFault able 1-120 V AC 2- 240 V AC 3-120/240V AC 4-3Ø120/208V AC 5-3Ø250V AC 3 Amperage 3 - 30 Amp 1 1 Reset Type Cord Length 0 - Manual 1 - Automatic 1 2 3 4 5 - 2 Feet 25 Feet 50 Feet 100 Feet 6 Feet Note: 2 to 3 week lead time for all “build your own" catalog numbers. Dimensions in Inches (mm) 11 www.hubbellcatalog.com/wiring Entertainment Industry Products Electric Cord and Cable Reels Our cord and cable reels are an ideal addition for the Entertainment Industry. These reels will minimize unmanaged cords and cables, which can cause trip hazards or electric shock due to damaged wire insulation. They offer quick, convenient cord deployment and the reels provide a safe and effective wire management system for any location or facility. Weatherproof Cable Reels are made for the most abusive and demanding environments. These reels feature a solid steel construction, a 600V rating with SOW - A type cable and Type 4X enclosure rating. They are designed for use with 15 & 20 amp industrial products such as portable outlet boxes, Insulgrip® and Twist-Lock® devices and pendant push-button stations. Weatherproof Cable & Static Discharge Reels Description 14" weatherproof reel. 16" weatherproof reel. 16" weatherproof reel. 16" weatherproof reel. 16" weatherproof reel. Static discharge reel. Static discharge reel. 14" pivot base. 16" pivot base. Catalog Numbers HBL501431W* HBL501232W* HBL501242W* HBL501032W* HBL501042W* HBL50SD Cable Length Feet Meters 50 15.2 50 15.2 50 15.2 50 15.2 50 15.2 50 15.2 HBL50YSD HBL14PB HBL16PB 50 – – † 15.2 – – Notes: * All weatherproof cable reels are supplied with wire leads. † Volts 600 600 600 600 600 – Cable Type 14/3 SOW-A 12/3 SOW-A 12/4 SOW-A 10/3 SOW-A 10/4 SOW-A Single 3/32" Steel – – – Dual (Y) 3/32" Steel – – Amps 15 20 16 25 20 – – – – Weight lbs. kg 55 24 80 36.3 86 38.7 86 38.7 92 41.1 12 5.4 13 5 13 5.9 2.27 5.9 35ft./10.6m + Dual 15ft./4.5m for “Y". Power supply cable not supplied. Industrial Cord Reels are built to provide safe, convenient power and lighting for demanding entertainment applications and environments. The industrial reels are all steel construction, have a 300V rating with SJ cord and can be ceiling, wall or bench mounted. They are available with fluorescent or incandescent hand lamps as well as a HBL5269C connector body or portable outlet box versions. Industrial Cord Reels Description Reel with HBL5269C connector. Reel with portable outlet box. Reel with incandescent hand lamp. Reel with fluorescent hand lamp. Pivot Base Catalog Numbers HBL45123C Cable Length Feet Meters Volts 45 13.7 125 Cable Type 12/3 SJEO Amps 15 Weight lbs. kg 23 10.4 Watts (Max) 1875 HBL45123R 45 13.7 125 12/3 SJEO 15 23 10.4 1875 HBL50163IN 50 15.2 125 16/3 SJT 0.8 21 9.5 100 HBL50162FL 50 15.2 120V AC 16/2 SJT 0.3 21 9.5 13 HBL340PB – – – – 5 2.26 – – Note: Supplied with 5ft. power supply cord with HBL5266C, 15A straight blade plug. Commercial Cord Reels are designed for the less demanding requirements of lighter duty environments. The commercial reels feature steel construction and have a 125V rating with SJT type cord. These reels are UL Listed and provide power and lighting for all your needs. Commercial Cord Reels Catalog Description Numbers Reel with fluorescent HBLC25163FL hand lamp & inline receptacle. Reel with fluorescent HBLC25162AFL hand lamp & automatic shut off switch. Reel with non-metallic HBLC25163AIN incandescent hand lamp & automatic shut off switch. Reel with metallic HBLC25143IN incandescent hand lamp with receptacle & circuit breaker. Reel with wire leads. HBLC25163 Reel with a Hubbell HBLC25163C HBL5969VBLK connector. Cable Length Feet Meters 25 7.62 Volts 120V AC Cable Type 16/3 SJT Amps 10 Weight lbs. kg 9 4.1 Watts (Max) 1200 25 7.62 120V AC 16/2 SJT 0.3 8.2 3.7 13 25 7.62 125 16/3 SJT 0.6 9 4.1 75 25 7.62 125 14/3 SJT 13 9.5 4.3 1625 25 25 7.62 7.62 125 125 16/3 SJT 16/3 SJT 10 10 8.5 8.5 3.9 3.9 1250 1250 Note: Reels supplied with 2ft. power supply cord and molded on straight blade 15A plug. 12 Entertainment Industry Products Portable Outlet Box and Spider® II Portable Outlet Box Our portable outlet boxes were designed to provide a rugged enclosure for a variety of wiring devices. Their non-metallic construction is impactresistant, non-conductive and corrosion-resistant. The boxes are field wired and are offered in a high visibility yellow color. Not only are these boxes easy to install anywhere but they are also highly durable. Portable Outlet Boxes and Plates Description Box with cord strain relief, with one blank cover plate. Box with cord strain relief, with two duplex (indoor) cover plates. Blank, non-metallic FS cover plate with foam gasket, gray. Duplex, non-metallic FS cover plate, gray. Single receptacle (1.39"), non-metallic FS cover plate, gray. Single receptacle (1.56"), non-metallic FS cover plate, gray. Rectangular opening, non-metallic FS cover plate, gray. Catalog Numbers HBLPOB1 HBLPOB1D HBLP14FS HBLP8FS HBLP7FS HBLP720FS HBLP26FS Spider® II Hubbell’s new Spider II temporary power distribution system sets a new safety and performance standard for your temporary power needs. Outdoor events, unconditional venues and modern convenience place more demands on electrical power than ever before. Hubbell’s new and improved Spider box steps up to this challenge by offering advanced electrical and safety features. The Spider II box incorporates the most advanced ground fault module technology available in the industry today ensuring safe and reliable distribution of electrical power. With the constant need for temporary power applications, this is one product the Entertainment Industry should not be without. Spider® II Boxes Rating 50A, 120/240V AC (max.) Type Straight Blade Twist-Lock® Twist-Lock (Inlet) Twist-Lock (Outlet) 50A, 120/240V Straight Blade AC (max.) Twist-Lock Twist-Lock (Inlet) Twist-Lock (Outlet) 50A, 120/240V Twist-Lock AC (max.) Twist-Lock Twist-Lock (Inlet) Twist-Lock (Outlet) 50A, 120/240V Twist-Lock AC (max.) Twist-Lock Twist-Lock (Inlet) Twist-Lock (Outlet) 60A, 3Ø 120/208V Twist-Lock AC (max.) Pin & Sleeve (Inlet) Pin & Sleeve (Outlet) 60A, 3Ø 120/208V Straight Blade AC (max.) Pin & Sleeve (Inlet) Pin & Sleeve (Outlet) Note: 60A units are UL and cUL only. Qty 6 1 1 1 6 1 1 1 6 1 1 1 6 1 1 1 6 1 1 6 1 1 Receptacle Ratings 20A, 125V 30A, 250V 50A, 125/250V 50A, 125/250V 20A, 125V 30A, 250V 50A, 125/250V 50A, 125/250V 20A, 125V 30A, 250V 50A, 125/250V 50A, 125/250V 20A, 125V 30A, 250V 50A, 125/250V 50A, 125/250V Receptacle Components HBL53R61 HBL2620SW HBL6375S CS6369 HBL53R61 HBL2620SW HBL6375S CS6369 HBL2310SW HBL2620SW HBL6375S CS6369 HBL2310SW HBL2620SW HBL6375S CS6369 Protection Overload GFCI Yes Yes Yes No No No No No Yes Yes Yes Yes No No No No Yes Yes Yes No No No No No Yes Yes Yes Yes No No No No Catalog Numbers SBSB1 20A, 60A, 60A, 20A, 60A, 60A, HBL2310SW HBL560B9R HBL560R9W HBL53R61 HBL560B9R HBL560R9W Yes No No Yes No No SCTL0 125V 3ØY 120/208V 3ØY 120/208V 125V 3ØY 120/208V 3ØY 120/208V 13 Yes No No Yes No No SBSB2 SBTL1 SBTL2 SCSB0 www.hubbellcatalog.com/wiring Entertainment Industry Products HI-Impact™ Ethernet Hubbell’s HI-Impact Ethernet System provides leading edge technology for Category 5e and 6-network transmission performance suitable for industrial and any other harsh environments. This system incorporates the use of our standard data connectivity jacks, which feature our keystone latching mechanism, in a rugged sealed housing that provides IP67 rated protection. This allows you to extend your LAN to include automation equipment and manufacturing or process control equipment. Utilize the Hubbell system to provide added protection within environments such as convention centers, food processing plants, medical industries, outdoor billboards, display screens or any other environment which requires added protection from moisture, corrosion, dust, debris, vibration and chemicals. Industrial Ethernet Connectors Type Cat. No. Cat 6 connector. HBLHI6 Cat 5e connector. HBLHI5E Cat 5e in-line coupler. HBLHI5EC Cat 5e shielded. HBLHI5ESC M12 MicroQuick, 4-position, male. MBMS14314 Industrial Ethernet Patch Cords and Plugs HI-Impact to HI-Impact Connector HI-Impact Connector to RJ-45 HBLHI6 HBLHI5E HBLHI5EC HBLHI5ESC HI-Impact RJ-45 to RJ-45 Type Cat. No. Type Cat. No. Type Cat. No. Cat 6 HBLHI6XXEE Cat 6 HBLHI6XXAE Cat 6 HBLHI6XXAA Cat 5e HBLHI5EXXEE Cat 5e HBLHI5EXXAE Cat 5e HBLHI5EXXAA Cat 5e, shielded HBLHI5ESXXEE Cat 5e, shielded HBLHI5ESXXAE Cat 5e, shielded HBLHI5ESXXAA F-type HBLHIFXXEE F-type HBLHIFXXAE F-type HBLHIFXXAA XX = Length To order replace XX Suffix with the following: 03 = 3' 05 = 5' 07 = 7' 10 = 10' 12 = 12' 15 = 15' Industrial Ethernet Wall Plates and Accessories Stainless Steel Wall Plates Thermoplastic, 4-Point FSFS, 1-Gang Gang Openings Catalog No. Ports Color Catalog No. 1 1 HBLHISF11 1 Gray HBLHI14GY 1 2 HBLHISF12 2 Gray HBLHI24GY 2 2 HBLHISF22 1 Yellow HBLHI114PY 2 4 HBLHISF24 2 Yellow HBLHI124PY Secure-IT™ Weatherproof NEMA 3R Plate Description Secure-IT™ Gang 1 Catalog No. HBLTWPF1GY Connector Cap Description Catalog No. Connector Cap HBLHIC 14 20 = 20' 25 = 25' Entertainment Industry Products Voice, Data & Video Category 6, 5e and USOC 6-Position Jacks Category 6 Catalog No. HBL6XX Category 5e Catalog No. HBL5EXX Data Modular Face Plate Frames USOC Catalog No. HBLUXX HBL6GN HBL6OR XX=Color; To order replace XX Suffix with the following: BK (Black), B (Blue), EI (Electric Ivory), GY (Gray), GN (Green), R (Red), OW (Office White), OR (Orange), TI (Telco Ivory), W (White) and Y (Yellow) HBL6W Multimedia Snap In Connectors Type Blank, 10 pack RCA 110 Punch Down, Black Housing RCA Gold Pass-Thru F/F Coupler Office White Housing RCA Solder Coupler Termination Office White Housing S-Video 110, Punchbown F-Type Coupler, Bulkhead F/F BNC F/F Coupler ST-Style Adapter, Black* S-Video F/F Coupler SC Simplex Adapter Office White Housing Available Colors OW, GY, I, W OW*,W*,Y* Catalog Numbers SIBXXPK10 SIRCAXX R*,W*,Y,* BK* SIRCAFFXX R*,W*,Y*, BK* SIRCASXX Black only OW, GY, I, W SISVOW SIFXX OW, GY, I, W OW, GY, I, W Black only Blue only* SIBNCXX SISTXX SISVFFBK SIFSCOW * Insulator Colors XX=Color; To order replace XX Suffix with the available color: BK (Black), GY (Gray), R (Red), OW (Office white), W (White) and Y (Yellow) Style Line FCX244XX FCX344XX FCX444XX FCX644XX 106 Duplex DJOXX — DJ106XX — SIBOWPK10 SIRCAOW SIRCAFFR SIRCASR Style Rectangular Duplex Available Colors B, G, DOW, WA, I B, G, DOW, W SISVOW SIFOW SIBNCOW SISTOW SISVFFBK SIFSCOW FCX244OW FCX444OW DJOOW DJ106OW HPS1DOW P8DOW Catalog Numbers HPS1XX P8XX* * for Ivory do not add suffix (P8) XX=Color; To order replace XX Suffix with the available color: B (Black), G (Gray), I (Ivory), DOW (Office white) and W or WA (White) Gang One Two One Two Color Office White Office White Stainless Steel Stainless Steel X=Port Size; To order replace X with the Port Size. Catalog Numbers DP1XOW DP2XOW DP1XS DP2XS Data Plate Modules Type Blank Blank Blank Port — — — Unit 0.5 1 1.5 Catalog No. DFBM05OW* DFBM1OW* DFBM15OW* * Sold in packages of five. Type Port Unit Catalog No. 1 1 1.5 1.5 DF1KOW DF2KOW DFA1KOW DFA2KOW Flat Flat Angled Angled SC Angled: 1 2 1 2 Type 1 Duplex 2 Duplex Recessed: Port — — Unit Catalog No. 1.5 DFA1SCOW 2 DFA2SCOW Type Port Keytone, 1 Angled 2 9 & 15 Pin Gender Changer: Type Port 9 Pin F/F, D-Stub 1 15 Pin F/F, D-Stub 1 15 Pin Terminal SVGA: Unit Catalog No. 1.5 DFRA1KOW 2 DFRA2KOW Type Port 15 Pin F/Screw 1 D-Stub Unit Catalog No. 1 DF19FFOW 1 DF115FFOW Unit Catalog No. 1 DF115SOW SC Modules Data & Communication Rear-Loading Wall Plates Available Port Sizes 1, 2, 3, 4, 6 6, 9, 12 1, 2, 3, 4, 6 4, 6, 9, 12 2 Gang DF2OW Keystone: XX=Color; To order replace XX Suffix with the following: BK (Black), GY (Gray), I (Ivory), OW (Office white) and W (White) HP Single Gang Plates 1 Gang DF1OW Blank: Outlet Frames Style 2-port 3-port 4-port 6-port Color Office White DP12OW DP14OW DP11S DP16S 15 Type SC Duplex Adapter Screw Mount SC to ST-Style, Duplex Adapter Screw Mount Color Blue Catalog No. SIFSC Blue SIFSCST Entertainment Industry Products Convention Center Floor Box Hubbell has listened to the entertainment industry and we are now pleased to introduce the first UL Listed convention center floor box as a solution to safely deliver utilities to the exhibit floor. The floor boxes are custom manufactured with provisions for power, datacom, water and compressed air. Hubbell provides a unique solution in safely keeping power and water in separate enclosures. This is accomplished by having two boxes joined together, while maintaining separate drains and lift covers. Let Hubbell provide a custom floor box to fit your facility needs and also provide the safety that no other box can. The Floor Box A galvanized sheet steel concrete cover is provided with each box to protect the cast aluminum cover during the concrete pour. Safety-bars are provided in each corner of the cover flange to prevent the cover from potentially falling into the box and damaging the panel components. The box is constructed of polyurethane for resistance to rust and corrosion. The material meets UL94 V-0 and 5VA flammability requirements. A steel frame provides structural support and is zinc-coated for corrosion resistance. Power/datacom and water/ compressed air are contained in separate enclosures to provide maximum safety. Conduit feeds can be easily field cut to the specified conduit size. The box can be easily leveled prior to the pour by simply adjusting the extra long threaded rods. 16 Entertainment Industry Products Convention Center Floor Box The Interior Circuit breaker protection is provided for 20 and 30 Amp receptacles. Circuit breaker protection is optional for the Pin & Sleeve receptacle. The datacom panel can be provided with a variety of devices that are protected by weatherproof covers. Customers can specify fiber optic, A/V, Category 5e jacks, or other devices for communication. The power panel can be provided with a combination of Hubbell Pin and Sleeve, Twist-Lock® and straight blade devices. Panels are constructed of brushed stainless steel for durability and corrosion resistance. Panels are gasketed and angled toward the drain to prevent the ingress of water. A two-inch drain with overflow protection can be optionally plumbed. White walls provide increased visibility in the box interior. The Cover The cast aluminum cover is UL Listed, designed and tested with a 35,000 lb. load capacity. Load capacity is engraved on the cover. The gasketed cover meets UL requirements for scrubwater. The box and cover have been designed to allow a Pin & Sleeve plug/receptacle to be engaged while the cover remains closed to prevent accidents. The cover is removable for full access to the interior. The hingless design eliminates components that can be easily broken in the convention center environment. A textured surface provides skid resistance. Large heavy-duty handles can easily be accessed with gloved hands to remove the cover. The handles are also spring loaded to prevent potential breakage. Power/datacom and water/compressed air are accessed through separate covers. The cover flange is constructed of cast aluminum. Multiple drop-down cable access doors provide various cable exits for separation of power/datacom. The cable doors enable radial bends for cable management of festoon and entertainment cable. All doors incorporate friction hinges and gasketed to prevent the ingress of water. 17 www.hubbellcatalog.com/wiring Printed In U.S.A. Specifications subject to change without notice. ® Registered trademark of Hubbell Incorporated Hubbell Incorporated (Delaware) • 185 Plains Road • Milford, CT 06460-2420 • (203) 882-4800 • FAX (800) 255-1031 H5155
HBL5269C 价格&库存
很抱歉,暂时无法提供与“HBL5269C”相匹配的价格&库存,您可以联系我们找货
HBL5269C
  • 1+324.85965
  • 5+318.12190
  • 10+313.32112
库存:260
