HBL5464VY
HBL5464VY
    HUBBELL(哈伯尔公司)
HBL5464VY 数据手册
Product Datasheet HBL5464VY -- Straight Blade Products, Valise Plug 2-Pole 3-Wire Grounding, 20A 250V, 6-20P, Yellow Nylon Product Specifications Product Type Body Style Straight Standard NEMA Amperage 20A Voltage 250V Poles and Wires 2 Pole, 3-Wire Grounding Hospital Grade ? No Plug/Connector Grade Valise Color NEMA No. 6-20P Horsepower 2 Cord Dia. .220"-.660" (5.6-16.8) Type 2 Pole, 3 Wire, Grounding Rating 20A, 250V Certification UL Listed to UL498 File E1706, CSA Certified to C22.2 No. 42 File 280 IP Suitability IP20 Housing Material Nylon - Yellow Blade Holder Material Nylon Cord Clamp Material Noryl (Polyphenylene Oxide) Contact Blades Material .060" (1.5) Brass Ground Contact Blade Material .040" (1.0) Copper Alloy Terminal Screw Material Steel (copper or nickel finish) Ground Screw Material Steel (green finish) Dielectric Voltage Withstands 2,000V minimum. Current Interrupting Certified for current interrupting at full rated current. Temperature Rise Max 30°C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of 75%.. Terminal Identification Terminals identified in accordance with UL498 (Brass, White, Green). Terminal Accommodation #18-#12 AWG copper stranded or solid conductor only. Product Identification Permanent part of device Flammability UL 94 V2 Operating Temperatures Maximum continuous 75°C, minimum -40°C (w/o impact). UPC Number 783585013183 Weight in LBs 0.150 Link to Drawing Library Click here for Library Link to PDF Catalog Click here for Catalog NEMA Configuration
HBL5464VY 价格&库存
很抱歉,暂时无法提供与“HBL5464VY”相匹配的价格&库存,您可以联系我们找货
