HBL5969VY
HBL5969VY
    HUBBELL(哈伯尔公司)
HBL5969VY 数据手册
Product Datasheet HBL5969VY -- Straight Blade Products, Valise Connector Body 2-Pole 3-Wire Grounding, 15A 125V, 5-15R, Yellow Nylon Product Specifications Product Type Body Style Straight Standard NEMA Amperage 15A Voltage 125V Poles and Wires 2 Pole, 3-Wire Grounding Wiring Method Back Wire Hospital Grade ? No Plug/Connector Grade Valise Color NEMA No. 5-15R Cord Dia. .220"-.660" (5.6-16.8) Type 2 Pole, 3 Wire, Grounding Rating 15A, 125V Certification UL Listed to UL498 File E1706, CSA Certified to C22.2 No. 42 File 280 IP Suitability IP20 Housing Material Nylon Cord Clamp Material Noryl Terminal Screw Material #8-32 Steel (copper or nickel finish) Ground Screw Material #8-32 Steel, (green finish) Power Contacts Material .040" (1.0) Phosphor Bronze Dielectric Voltage Withstands 2,000V minimum. Current Interrupting Certified for current interrupting at full rated current. Temperature Rise Max 30°C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of 75%.. Terminal Identification Terminals identified in accordance with UL498 (Brass, White, Green). Terminal Accommodation #18-#12 AWG copper stranded conductor Product Identification Ratings are a permanent part of the device. Flammability UL 94 HB or better. Operating Temperatures Maximum continuous 75°C, minimum -40°C (w/o impact). Certified UL2305 OEM and replacement use on convention center flat cable cord sets. UPC Number 783585013107 Weight in LBs 0.100 Link to Drawing Library Click here for Library Link to PDF Catalog Click here for Catalog NEMA Configuration
HBL5969VY 价格&库存
很抱歉,暂时无法提供与“HBL5969VY”相匹配的价格&库存,您可以联系我们找货
