HBL7593
HBL7593
    HUBBELL(哈伯尔公司)
    HBL7593
HBL7593 数据手册
Twist-Lock® Devices 15 Ampere, 125 and 125/250 Volts Midget Twist-Lock® Connector Bodies and Flanged Receptacles X IP20 1.77" (45.0) W SUITABILITY Y Connector Bodies 15A 125V NEMA ML-1R 15A 125/250V NEMA ML-3R 15A 125V NEMA ML-2R Description Cord Dia. Catalog Number Valise® connector body, black nylon, polarized. .220"-.385" (5.6-9.8) HBL7464V* Valise® connector body, black nylon, insulation displacement terminals. .300"-.430" (7.6-10.9) – Black nylon cover, phenolic body, screw terminals. .281"-.421" (7.1-10.7) – HBL7593 – Angle connector body, black nylon cover, phenolic body, screw terminals. .335"-.421" (8.5-10.7) – HBL7571 – Valise® type, black nylon, with insulation displacement terminals, multiple drive screws. .300"-.430" (7.6-10.9) – – Black nylon body, phenolic base, multiple drive screws, cord grip. .281"-.421" (7.1-10.7) – – HBL7484* Same as above, except for angle cord grip. .335"-.421" (8.5-10.7) – – HBL7433* – – HBL7593V – 1.06" (26.9) .97" (24.6) HBL7464V 1.98" (50.4) 1.19" (30.2) HBL7484V* HBL7593V 2.42" (61.5) 1.17" (29.7) 1.13" (28.7) Flanged Receptacles HBL7593 Description Catalog Number Stainless steel flange, exposed terminals. HBL7468* – – – HBL7596N – Exposed terminals, black nylon flange. Exposed terminals, stainless steel flange. – HBL7596 – Covered terminals, stainless steel flange, accepts cord .500" (12.7) in dia. – HBL7598 – 1.28" (32.5) 1.17" (29.7) Exposed terminals, black nylon flange. – – HBL7487N* Exposed terminals, stainless steel flange. – – HBL7487* Covered terminals, stainless steel flange, accepts cord .500" (12.7) in diameter. – – HBL7489* 1.69" (42.9) HBL7571 Note: See page B-6 for accessories. *UL Listed only. Female ML-2R devices have solid center ground pins. Female ML-3R devices have hollow center neutral sleeves. 1.97" (50.0) 1.19" (30.2) HBL7484V 2.02" (51.3) 1.13" (28.7) 1.17" (29.7) HBL7484 .97" (24.6) 2.06" (52.3) 1.17" (29.7) 1.75" (44.5) .16" (4.1) DIA. HBL7596 1.00" (25.4) 1.25" (31.8) 2.06" (52.3) 2.06" (52.3) 1.17" (29.7) 1.75" (44.5) .78" (19.8) 1.14" (29.0) 1.75" (44.5) 1.63" (41.4) 1.38" (35.1) .15" (3.8) DIA. .16" (4.1) DIA. HBL7596N HBL7598 1.03" (26.2) .16" (4.1) DIA. HBL7468 Dimensions in Inches (mm) www.hubbell-wiring.com ® Wiring Device-Kellems B-5
HBL7593 价格&库存
很抱歉,暂时无法提供与“HBL7593”相匹配的价格&库存,您可以联系我们找货
