HBL7596
HBL7596
    HUBBELL(哈伯尔公司)
HBL7596 数据手册
Product Datasheet HBL7596 -- Twist-Lock Flanged Receptacle 2P3W, 15A 125V, ML-2R, Stainless Flange Product Specifications Product Type Product Item Flanged Receptacle Wiring Scheme 2-Pole, 3-Wire Grounding Amperage 15A Voltage 125V AC NEMA Configuration ML-2R Item Style Standard Device Color Black/Stainless Terminal Screw Material #5-40 Brass Ground Screw Material Brass (green finish) Contact Spring Material .032" (.8) Bronze Flanged Casing Material .025" Stainless Steel Mounting Screw Material Nickel-plated Brass Round head screws Ground Contact Material .032" Bronze Ratings Molded In or Stamped On Catalog No Permanently ink marked on product Dielectric Voltage Withstand 2,000V minimum Current Interrupting Certified for current interrupting at full rated current Temperature Rise Max 30C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of .75. Terminal Accommodation 15A #14 AWG Terminal Identification Terminals identified in accordance with UL 498 (X, Y, Z, White, Green) Flammability UL 94 VO for Receptacles and Inlets. HB or better for Plugs and Connectors. Operating Temperatures Maximum Continuous 75 C Minimum -40 C (w/o impact) Listings UL/CSA UPC Number 783585237817 Weight in LBs 0.05 Link to Drawing Library Click here for Library Link to PDF Catalog Click here for Catalog NEMA Configuration
HBL7596 价格&库存
很抱歉,暂时无法提供与“HBL7596”相匹配的价格&库存,您可以联系我们找货
