HBLDS3SSJ
HBLDS3SSJ
    HUBBELL(哈伯尔公司)
    HUBBELL WIRING DEVICES - HBLDS3SSJ - LOAD BREAK SWITCH, 3 POLE, 30A, 600VAC - Contact Current AC Max...
HBLDS3SSJ 数据手册
Designed for Convenience, Safety and Savings Circuit-Lock® Motor Disconnects with Jog Switch Hubbell Disconnects with integral Jog switch are another addition to the Circuit-Lock® family of switched enclosures. Consistent with our standard enclosures, they are designed to withstand harsh environments with exposure to water, chemicals, oils and frequent wash downs. Enclosures are UL Listed Type 4X, 12 and IP69k and available in Non-Metallic or Stainless Steel. The Three Position Jog Switch (TEST, OFF and RUN) Provides Users: • Cost Savings by utilizing existing space in the motor disconnect enclosure reducing parts and labor costs. • Convenience by having point of use control circuit to PLC within line of sight of the motor • Added Safety by allowing maintenance personnel the functionality to “Try Out" after LO/TO Motor Disconnect Features: • UL 508 / 60947-4-1 Rated Switch • Non-Metallic, Stainless Steel & Stainless Steel Sloped Top Enclosures • Type 4X, 12 and IP69k • Highly Visible Red Rotary Handle with OSHA Compliant LO/TO Handle • 65kA SCCR Rating when Protected by a Class J Fuse Jog Switch Features • Two Auxiliary Contacts for Communication with PLC • Momentary “TEST” and Maintained “OFF” and “RUN” Settings IP69k Circuit-Lock® Motor Disconnects with Jog Switch 30 and 60 Amp Disconnects with Jog Switch Amps Description Catalog Numbers Non-Metallic Disconnect with Jog Switch  HBLDS3J Non-Metallic Disconnect with NO+NC Aux Contact and Jog Switch  HBLDS3ACJ 30A Non-Metallic Disconnect with NO Break Before Main Aux Contact and Jog Switch  HBLDS3VFDJ Stainless Steel Disconnect with Jog Switch  HBLDS3SSJ Sloped Stainless Steel Disconnect with Jog Switch  HBLDS3SSRJ HBLDS3J  HBLDS6J 60A Non-Metallic Disconnect with Jog Switch Replacement Covers and Auxiliary Contacts Description Catalog Numbers Replacement Cover for Non-Metallic 30A Disconnect with Jog Switch HBLDS3RCJ Replacement Cover for Stainless Steel 30A Disconnect with Jog Switch HBLDS3SSRCJ Replacement Cover for Sloped Stainless Steel 30A Disconnect with Jog Switch HBLDS3SSRRCJ Replacement Cover for Non-Metallic 60A Disconnect with Jog Switch HBLDS6RCJ “Break After Main Break”, 1 set of n/o contacts, 1 set of n/c contacts HBLAC1 “Break Before Main Break”, 1 set of n/o contacts HBLAC2 HBLDS3SSJ Materials Part Non-Metallic Stainless Steel Base Valox® Top Valox® Handle Valox® Conduit Hub Zinc 30A Unfused - ¾ in. 60 Unfused - 1¼ in. Enclosure Gasket Neoprene Shaft (Unfused) Valox® Shaft Seal Molded Neoprene Frame Galvanized Steel Enclosure Screws Stainless Steel 300 Series #14 Gauge Type 304 Stainless Steel #14 Gauge Type 304 Stainless Steel Valox® Zinc 30A - ¾ in. Neoprene Valox® Molded Neoprene N/A Stainless Steel Horsepower Ratings Dimensions inch (mm) Labelless Non-Metallic Key 30A HBLDS3SSRJ 60A Stainless Steel, Square Top 30A Stainless Steel, Sloped Top 30A Voltage 30A 60A 1Ø 120V AC 1 7.5 1Ø 200–240V AC 3 15 A 6.00 (152) 7.75 (197) B 5.12 (130) 6.87 (175) 4.87 (124) 5.41 (137) 1Ø 480V AC 5 30 C 4.12 (105) 4.75 (121) 3.30 (84) 4.50 (114) 3Ø 200–240V AC 7.5 30 D 6.62 (168) 8.00 (203) — 3Ø 480V AC 15 50 E 7.62 (194) 9.95 (253) 7.05 (179) 8.60 (218) 3Ø 600V AC 15 50 F 8.50 (216) 11.00 (279) 8.38 (213) 8.22 (209) G 4.12 (105) 5.94 (151) 5.39 (137) 4.92 (125) H 1.08 (28) 1.08 (28) 5.39 (137) 4.77 (121) — — — H H www.hubbell-wiring.com Hubbell Wiring Systems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 • Phone (800) 288-6000 • FAX (800) 255-1031 Printed in U.S.A. Specifications subject to change without notice. WLFDS005 1/17
HBLDS3SSJ 价格&库存
很抱歉,暂时无法提供与“HBLDS3SSJ”相匹配的价格&库存,您可以联系我们找货
