50 Amp Twist-Lock® Devices
50A Twist-Lock® Devices
Hubbell’s 50 Amp Twist-Lock® Devices feature a heavy-duty
design and super-tough nylon housing built for heavy-duty
applications and impact resistance, even in the harshest
environments. Their rigid construction restricts contact distortion,
minimizing the possibility of mating dissimilar devices. The cord
grip’s offset gripping jaws securely hold the conductors and the
cord jacket for excellent strain relief.
» Support secure, reliable,
superior terminations with
Hubbell’s box terminals
» Ensure durability with solid,
stainless steel shrouds on plugs
» Achieve high heat resistance
on receptacles and inlets with
thermoset interior components
Ideal for:
Construction
Temporary Power
Welding
Data Centers
Ordering Information
Description
Plugs
Cord Diameter
Rating
Catalog Number
.830"-1.250"
(21.08-31.75)
50A
50A
50A
50A
50A
50A
125V AC
250V AC
480V AC
125/250V AC
3Ø 250V AC
3Ø 480V AC
CS6361C
CS8265C
CS8465C
CS6365C
CS8365C
CS8165C
Nylon housing,
thermoplastic polyester interior
.830"-1.250"
(21.08-31.75)
50A
50A
50A
50A
50A
50A
125V AC
250V AC
480V AC
125/250V AC
3Ø 250V AC
3Ø 480V AC
CS6360C
CS8264C
CS8464C
CS6364C
CS8364C
CS8164C
Insulgrip® connector with conduit
adapter; capable of accepting metallic
or non-metallic conduit fittings
½” NPT size
¾” NPT size
1” NPT size
50A 3Ø 250V AC
CS8364CA05
CS8364CA34
CS8364CA10
50A
50A
50A
50A
50A
50A
125V AC
250V AC
480V AC
125/250V AC
3Ø 250V AC
3Ø 480V AC
CS6377
CS8275
CS8475†
CS6375
CS8375
CS8175
50A
50A
50A
50A
50A
50A
125V AC
250V AC
480V AC
125/250V AC
3Ø 250V AC
3Ø 480V AC
CS6370
CS8269
CS8469†
CS6369
CS8369
CS8169
Nylon housing,
Connector body
Flanged inlet
Receptacle
Zinc plated steel casing,
thermoset interior
Black phenolic
Not CSA certified.
hubbell.com/wiringdevice-kellems/en
Plug
Connector
Flanged Inlet
Receptacle
Plug
HBL® Series 50A Twist-Lock® Devices
Description
Cord Diameter
Rating
Plugs
Nylon housing,
.830"-1.250"
(21.08-31.75)
50A 250V DC
50A 600V AC
HBL3763C HBL3765C HBL7765C
Connector body
Nylon housing,
.830"-1.250"
(21.08-31.75)
50A 250V DC
50A 600V AC
HBL3762C HBL3764C HBL7764C
thermoset interior
50A 250V DC
50A 600V AC
HBL3777
HBL3775
HBL7958
thermoset interior with lift cover
50A 250V DC
50A 600V AC
HBL3767
HBL3768
HBL7968
Black phenolic
50A 250V DC
50A 600V AC
HBL3771
HBL3769
HBL7379
Flanged inlet
Receptacle
Connector
Flanged Inlet
with Lift Cover
Female configuration shown.
Accessories
Receptacle
Accessories for FS/FD Box Mounting
Description
Weatherproof receptacle
lift cover plates
Receptacle plates
Catalog Number
Gray
Yellow
Corrosion resistant thermoplastic
HBL7774WO
HBL77CM74WO
HBL7770
Cast aluminum
Cast aluminum; for use with
HBL® Series 50A Twist-Lock devices
with lift cover
no lift cover
Stainless steel single gang wallplate
HBL7382*
HBL7383
SS750
*Not UL Listed “WDL Closed” | IP20 suitability
Receptacle ½” Raised Cover
Description
Catalog Number
Galvanized steel; fits 4” square or 2-gang box
HBL50SC
IP20 suitability
Conduit Adapters
Description
NPT Thread Size
Thermoplastic housing
for use with CS style 50A Twist-Lock® devices
½”
¾”
1”
Catalog Number
CS50CA05
CS50CA34
CS50CA10
Weatherproof Boots
Description
Seal-Tite® triple seal black
elastomeric cover
Catalog Number
for plugs when used with cord sets and
for connector bodies when used with flanged inlets
HBL7716C†
for connector bodies when used with cord sets
HBL7717C†
Not UL Listed
Inlet Closure Plug
Description
Catalog Number
Black closure plug
HBL4892†
Not UL Listed
Replacement Parts
Description
Catalog Number
Cord clamp kit
HBLCSCK
Related Products
Spider ® Temporary Power Distribution Boxes
Rating
50A 120/240V AC
(Maximum)
50A 120/240V AC
(Maximum)
Type
Qty
Straight Blade
Twist-Lock®
Twist-Lock® (Inlet)
Twist-Lock® (Outlet)
Twist-Lock®
Twist-Lock®
Twist-Lock® (Inlet)
6
1
1
1
6
1
1
1
Receptacle Rating
20A, 125V
30A, 250V
50A, 125/250V
50A, 125/250V
20A, 125V
30A, 250V
50A, 125/250V
50A, 125/250V
Catalog Number
TPDS
TPDL
Temporary Power Cables
Rating
Cable Type
50A 125/250V
6/3, 8/1
Length (ft)
50
100
Catalog Number
TPC50
TPC100
Temporary Power Receptacle
Description
Rating
Catalog Number
Pre-wired wall mount receptacle
with 3R enclosure and 2' wire leads
50A 125/250V
SR50
Hubbell Product Literature
Circuit-Lock®
Motor
Disconnects
Wiring Device-Kellems
IEC Pin
and Sleeve
Devices
Watertight
Wiring Devices
Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 • Phone (800) 288-6000 • FAX (800) 255-1031
Printed in U.S.A. Specifications subject to change without notice.
is a registered trademark of Hubbell Incorporated.
WLBL004 5/20
很抱歉,暂时无法提供与“CS8164C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2070.360861+259.04319
- 3+2005.321523+250.90548
- 5+1814.022705+226.97021
