SECTION L
Table of Contents
HBL® Extra Heavy Duty
Industrial Series
Surge Protection Devices
Industrial and Commercial
Series GFCIs
Product Page
Product Page
HBL® Extra Heavy Duty Hospital Grade Duplex Receptacles
Extra Heavy Duty Industrial GFCI Receptacles
L-12
Products at a Glance
L-2
Commercial GFCI Receptacles
Features and Benefits
L-3
Tamper-Resistant
L-13
L-4
L-14
L-5
Standard
L-15
L-8
Hospital Grade Surge Protection Devices
L-16
L-10
Hubbellock®
Plugs, Connectors and Receptacles
L-17
L-10
Hubbellock®
Mobile X-Ray Devices
L-18
Duplex and Style
SNAPConnect®
Line®
Decorator
Receptacles
Hubbell-PRO Receptacles
USB Charger Receptacles
Single and
4-PLEX®
Receptacles
Tamper-Resistant and Weather Resistant
Hospital Grade Plugs, Connector Bodies and Receptacles
15 and 20A, 125V
L-11
15 and 20A, 250V
L-11
www.hubbell-wiring.com
Wiring Device-Kellems
L-1
Hospital Products
• Hospital Grade with green dot symbol
• One-piece nickel-plated integral ground strap
• ID marking surface for quick circuit identification
• Square head, 10-thread bronze center rivet
• Deep nylon body design increases impact
and chemical resistance
• Hospital and Specification Grade
SpikeShield® Surge Suppression
Plug Strips
• Tamper-Resistant, NOT Plug Resistant™
• UL2930 HCOA’s
• Power indicating LED
• UL1449 SPD’s available
• Steel mounting strap, self-grounding
• 15A and 20A versions
• Compact size requires minimal space
• 6 foot or 15 foot cords available
Extra Heavy Duty SNAPConnect®
• USB versions in several models
Hubbell-PRO Heavy Duty
• Power LED feature
• Circuit ID marking area
• Assembled in USA
• Two Type-C, Type A&C and Type A port
configurations, high power 5 Amp, 5 Volt
USB output
• Heavy duty stainless steel USB ports; rated for
10,000 cord insertions and removals
• Patented Hubbell Tamper-Resistant technology
uses cam action shutters. The friction-free
design of the mechanism’s doors requires
much less force
• Available in SNAPConnect®
Hubbellock® Devices
• Nylon cover, thermoset interior
• Armored, epoxy filled, rubber cord grip
• Black, back wired
• Mobile X-Ray devices
4-PLEX Receptacles
• Hospital Grade and Surge
• Mounts directly to 4-inch square box
• "A" and "B" circuit ID molded into face
• Removable knockouts for mounting to octagon
concrete ring or box
• Heavy duty, triple wipe, brass power and
ground contacts
L-2
Hospital Products
Hubbell “Hospital Grade” Devices
UL requirements for Hospital Grade devices is more stringent than those for
standard devices. Hubbell receptacles are designed to meet and exceed the
standards.
• Exclusive nickel-plated bypass contact design increases contact pressure,
lowering the operating temperature.
• Four point grounding system provides redundant grounding for low
resistance ground continuity in high abuse areas.
• High tech reinforced thermoplastic polyester (RTP) back is tough and
heat resistant.
Because of these features and others, the benefit is performance, reliability,
and value for any health care facility.
HBL8200GY
Housing Design
• Reinforced thermoplastic base
provides superior thermal, electrical
and mechanical properties
• Providing contact stability, this high
performance material will reduce
heat buildup giving you long lasting
performance
• Deep body design increases impact
Terminals
• External wiring clamps allow for visual
inspection of the terminals
• Unique strand containment feature on
the terminal “bundles” the wire, ensuring
100% clamping of wire strands and
reducing heat from the termination
One-Piece Mounting Strap
• Back wired ground terminal allows faster,
easier installation
• One-piece nickel-plated brass integral
ground strap for greater corrosion
resistance
• Patented ground contact provides
redundant grounding
Contacts
• Exclusive bypass contacts are made
of nickel-plated brass alloy, increasing
blade retention, insuring reliable
uninterrupted flow of power
• Barbed assembly arms reduce possibility
of face/base separation
Identification
• I.D. marking surface provides quick,
sure circuit identification
• All Hospital Grade devices are
marked with the green dot symbol,
required by UL
Center Rivet
rivet won’t rotate, reduces stripping
and resists corrosion
L-3
Hospital Products
IP20
SUITABILITY
15A 125V
NEMA 5-15R
UL CSA
0.5 HP
Hospital Grade Receptacles
Duplex
20A 125V
NEMA 5-20R
UL CSA
1 HP
Description
Color
Catalog Number
Flush, thermoplastic polyester face,
back and side wired.
Black
Blue
Brown
Gray
Ivory
Light Almond
Red
White
HBL8200BK
HBL8200
HBL8200GY
HBL8200I
HBL8200LA
HBL8200RED
HBL8200W
HBL8300BL
HBL8300
HBL8300GY
HBL8300I
HBL8300LA
HBL8300RED
HBL8300W
Flush, LED illuminated face,
Gray
Ivory
Red
White
HBL8200ILGY
HBL8200ILI
HBL8200ILR
HBL8200ILW
HBL8300ILGY
HBL8300ILI
HBL8300ILR
HBL8300ILW
Tamper-Resistant receptacle
with wire leads. Complies with
requirements of NEC® article
517-18(c).
Brown
Gray
Ivory
Light Almond
Red
White
HBL8200SGA
HBL8200SGGYA
HBL8200SGIA
HBL8200SGLA
HBL8200SGRA
HBL8200SGWA
HBL8300SGA
HBL8300SGGYA
HBL8300SGIA
HBL8300SGLA
HBL8300SGRA
HBL8300SGWA
Isolated ground∆.
Orange
Red
IG8200
IG8200R
IG8300
IG8300R
Description
Color
Catalog Number
MRI receptacle, flush, thermoplastic
polyester face, back and side wired.
Ivory
Light Almond
Red
White
HBL8200IMRI
HBL8200LAMRI
HBL8200RMRI
HBL8200WMRI
Description
Color
Catalog Number
back, and side wired.
Fed. Spec. verified.
Brown
Gray
Green
Ivory
Light Almond
Red
White
HBL8200H
HBL8200HG
HBL8200HI
HBL8200HLA
HBL8200HRED
HBL8200HW
HBL8200GY
HBL8300SGA
MRI Receptacle, Duplex
HBL8300RMRI
HBL8300IMRI
HBL8300LAMRI
HBL8300RMRI
HBL8300WMRI
Slender/Compact, Duplex
HBL8300H
HBL8300HG
HBL8300HGN
HBL8300HI
HBL8300HLA
HBL8300HRED
HBL8300HW
Style Line® Decorator*
HBL8200ILW
Description
Color
Catalog Number
Flush, nylon face,
Brown
Gray
Ivory
Office White
Red
White
HBL2172
HBL2172GY
HBL2172I
HBL2172R
HBL2172WA
Isolated ground∆.
Ivory
Orange
White
HBL2182
HBL2182GY
HBL2182I
HBL2182OW
HBL2182R
HBL2182WA
IG2182I
IG2182
IG2182WA
Note: ∆See section M for additional information on isolated ground devices.
*Not Fed. Spec. Listed.
See pages A-48 and A-49 for accessories.
See page Tech-10 for Tamper-Resistant description.
See section N for wallplates.
HBL2172
Dimensions in Inches (mm)
L-4
NEC® is a registered trademark of the National Fire Protection Association (NFPA).
Hospital Products
IP20
1.56"
(39.7)
SUITABILITY
Extra Heavy Duty
Hospital Grade SNAPConnect®
Duplex
15A 125V
NEMA 5-15R
UL CSA
0.5 HP
Color
Catalog Number
Hospital grade, finder groove, nylon face,
modular receptacle which requires
pigtailed connector below.
Black
Brown
Gray
Ivory
Light Almond
Red
White
Black
Brown
Gray
Ivory
Light Almond
Red
White
Black
Brown
Gray
Ivory
Light Almond
Red
White
Black
Brown
Gray
Ivory
Light Almond
Red
White
Orange
Red
Black
Brown
Gray
Ivory
Light Almond
Red
White
Orange
Red
Black
Brown
Gray
Ivory
Light Almond
Red
White
Orange
Red
SNAP8200BKA
SNAP8200A
SNAP8200GYA
SNAP8200IA
SNAP8200LAA
SNAP8200RA
SNAP8200WA
SNAP8200BKNA
SNAP8200NA
SNAP8200GYNA
SNAP8200INA
SNAP8200LANA
SNAP8200RNA
SNAP8200WNA
SNAP8200BKTRA
SNAP8200TRA
SNAP8200GYTRA
SNAP8200ITRA
SNAP8200LATRA
SNAP8200RTRA
SNAP8200WTRA
SNAP8200BKSCTRA
SNAP8200SCTRA
SNAP8200GYSCTRA
SNAP8200ISCTRA
SNAP8200LASCTRA
SNAP8200RSCTRA
SNAP8200WSCTRA
SNAP8200IGTRA
SNAP8200RIGTRA
SNAP8200BKL
SNAP8200L
SNAP8200GYL
SNAP8200IL
SNAP8200LAL
SNAP8200RL
SNAP8200WL
SNAP8200IGL
SNAP8200RIGL
SNAP8200BKLTRA
SNAP8200LTRA
SNAP8200GYLTRA
SNAP8200ILTRA
SNAP8200LALTRA
SNAP8200RLTRA
SNAP8200WLTRA
SNAP8200IGLTRA
SNAP8200RIGLTRA
Hospital grade, Tamper-Resistant,
smooth nylon face, modular receptacle
which requires pigtailed connector below.
Assembled in USA.
Split Circuit, smooth nylon face,
Assembled in USA.
Isolated ground∆, Hospital grade,
Tamper-Resistant.
Hospital grade, with Power Indicating LED,
Assembled in USA.
with Power Indicating LED.
with Power Indicating LED, smooth
nylon face, modular receptacle which
Assembled in USA.
TR with Power Indicating LED.
2.62"
(66.5)
3.28"
(83.3)
Description
Hospital grade, smooth nylon face,
Assembled in USA.
20A 125V
NEMA 5-20R
UL CSA
1 HP
SNAP8300BKA
SNAP8300A
SNAP8300GYA
SNAP8300IA
SNAP8300LAA
SNAP8300RA
SNAP8300WA
SNAP8300BKNA
SNAP8300NA
SNAP8300GYNA
SNAP8300INA
SNAP8300LANA
SNAP8300RNA
SNAP8300WNA
SNAP8300BKTRA
SNAP8300TRA
SNAP8300GYTRA
SNAP8300ITRA
SNAP8300LATRA
SNAP8300RTRA
SNAP8300WTRA
SNAP8300BKSCTRA
SNAP8300SCTRA
SNAP8300GYSCTRA
SNAP8300ISCTRA
SNAP8300LASCTRA
SNAP8300RSCTRA
SNAP8300WSCTRA
SNAP8300IGTRA
SNAP8300RIGTRA
SNAP8300BKL
SNAP8300L
SNAP8300GYL
SNAP8300IL
SNAP8300LAL
SNAP8300RL
SNAP8300WL
SNAP8300IGL
SNAP8300RIGL
SNAP8300BKLTRA
SNAP8300LTRA
SNAP8300GYLTRA
SNAP8300ILTRA
SNAP8300LALTRA
SNAP8300RLTRA
SNAP8300WLTRA
SNAP8300IGLTRA
SNAP8300RIGLTRA
.86"
(21.9)
SNAP8300WA
1.64"
(41.7)
2.62"
(66.5)
3.28"
(83.3)
.86"
(21.9)
SNAP8300LATR
1.64"
(41.7)
2.62"
(66.5)
3.28"
(83.3)
.86"
(21.9)
SNAP8300L
1.64"
(41.7)
.86"
(21.9)
SNAP8300RLTR
1.63"
(41.3)
SNAPConnect® Extra Heavy Duty Hospital Grade Single Receptacles
Hospital Grade
20A 125V
Color
15A 125V
Almond
Black
Blue
Brown
Gray
Ivory
Light Almond
Red
White
SNAP8210AL
SNAP8210BK
SNAP8210BL
SNAP8210
SNAP8210GY
SNAP8210I
SNAP8210LA
SNAP8210R
SNAP8210W
SNAP8310AL
SNAP8310BK
SNAP8310BL
SNAP8310
SNAP8310GY
SNAP8310I
SNAP8310LA
SNAP8310R
SNAP8310W
Hospital Grade
15A 125V
SNAP8210ALTR
SNAP8210BKTR
SNAP8210BLTR
SNAP8210TR
SNAP8210GYTR
SNAP8210ITR
SNAP8210LATR
SNAP8210RTR
SNAP8210WTR
2.62"
(66.5)
3.28"
(83.3)
Tamper-Resistant
20A 125V
SNAP8310ALTR
SNAP8310BKTR
SNAP8310BLTR
SNAP8310TR
SNAP8310GYTR
SNAP8310ITR
SNAP8310LATR
SNAP8310RTR
SNAP8310WTR
3.28"
(83.3)
2.00"
(50.8)
.922"
(23.4)
SNAP8310GY
L-5
Hospital Products
IP20
1.64"
(41.7)
SUITABILITY
2.62"
(66.5)
3.28"
(83.3)
.86"
(21.9)
Description
Color
Catalog Number
Hospital grade, Style Line® decorator,
flush, nylon face, modular receptacle
Black
Brown
Gray
Ivory
Light Almond
Red
White
Black
Brown
Gray
Ivory
Light Almond
Red
White
Black
Brown
Gray
Ivory
Light Almond
Red
White
Black
Brown
Gray
Ivory
Light Almond
Red
White
Orange
Red
Black
Brown
Gray
Ivory
Light Almond
Red
White
Orange
Red
Black
Brown
Gray
Ivory
Light Almond
Red
White
Orange
Red
SNAP2172BKA
SNAP2172A
SNAP2172GYA
SNAP2172IA
SNAP2172LAA
SNAP2172RA
SNAP2172WA
SNAP2172BKNA
SNAP2172NA
SNAP2172GYNA
SNAP2172INA
SNAP2172LANA
SNAP2172RNA
SNAP2172WNA
SNAP2172BKTRA
SNAP2172TRA
SNAP2172GYTRA
SNAP2172ITRA
SNAP2172LATRA
SNAP2172RTRA
SNAP2172WTRA
SNAP2172BKSCTRA
SNAP2172SCTRA
SNAP2172GYSCTRA
SNAP2172ISCTRA
SNAP2172LASCTRA
SNAP2172RSCTRA
SNAP2172WSCTRA
SNAP2172IGTRA
SNAP2172RIGTRA
SNAP2172BKL
SNAP2172L
SNAP2172GYL
SNAP2172IL
SNAP2172LAL
SNAP2172RL
SNAP2172WL
SNAP2172IGL
SNAP2172RIGL
SNAP2172BKLTRA
SNAP2172LTRA
SNAP2172GYLTRA
SNAP2172ILTRA
SNAP2172LALTRA
SNAP2172RLTRA
SNAP2172WLTRA
SNAP2172IGLTRA
SNAP2172RIGLTRA
SNAP2182A
1.64"
(41.7)
Assembled in USA.
2.62"
(66.5)
3.28"
(83.3)
.86"
(21.9)
SNAP2182ITR
1.64"
(41.7)
Style Line® decorator, flush, nylon face,
Assembled in USA.
Split Circuit, Style Line® decorator, flush,
Assembled in USA.
2.62"
(66.5)
3.28"
(83.3)
.86"
(21.9)
SNAP2182RL
Tamper-Resistant.
Assembled in USA.
1.64"
(41.7)
2.62"
(66.5)
3.28"
(83.3)
.86"
(21.9)
SNAP2182GYLTR
.78"
(19.8)
1.48"
(37.6)
.63"
(16.0)
SNAP1RA
L-6
15A 125V
NEMA 5-15R
UL CSA
0.5 HP
Extra Heavy Duty
with Power Indicating LED, Style Line®
decorator, flush, nylon face, modular
receptacle which requires pigtailed
connector below. Assembled in USA.
20A 125V
NEMA 5-20R
UL CSA
1 HP
SNAP2182BKA
SNAP2182A
SNAP2182GYA
SNAP2182IA
SNAP2182LAA
SNAP2182RA
SNAP2182WA
SNAP2182BKNA
SNAP2182NA
SNAP2182GYNA
SNAP2182INA
SNAP2182LANA
SNAP2182RNA
SNAP2182WNA
SNAP2182BKTRA
SNAP2182TRA
SNAP2182GYTRA
SNAP2182ITRA
SNAP2182LATRA
SNAP2182RTRA
SNAP2182WTRA
SNAP2182BKSCTRA
SNAP2182SCTRA
SNAP2182GYSCTRA
SNAP2182ISCTRA
SNAP2182LASCTRA
SNAP2182RSCTRA
SNAP2182WSCTRA
SNAP2182IGTRA
SNAP2182RIGTRA
SNAP2182BKL
SNAP2182L
SNAP2182GYL
SNAP2182IL
SNAP2182LAL
SNAP2182RL
SNAP2182WL
SNAP2182IGL
SNAP2182RIGL
SNAP2182BKLTRA
SNAP2182LTRA
SNAP2182GYLTRA
SNAP2182ILTRA
SNAP2182LALTRA
SNAP2182RLTRA
SNAP2182WLTRA
SNAP2182IGLTRA
SNAP2182RIGLTRA
Note: ∆See section M additional information on isolated ground devices.
See page A-16 for additional information on SNAPConnect® features.
See page Tech-10 for Tamper-Resistant and LED Power Indicators description.
See pages A-50 and A-51 for accessories.
SNAPConnect® Right Angle Pigtailed Connector
Description
Wire Type
General Use
Assembled in USA
Clear right angle terminal with 6 inch leads
#12 AWG THHN/THWN-2; Polycarbonate
housing material
Solid
Stranded
SNAP1RA
SNAP2RA
SNAP1RNA
SNAP2RNA
Note: For Assembled in USA products, must order connector with NA suffix.
Hospital Products
1.75"
(44.5)
SNAPConnect® GFCI LED Hospital Grade ,
Assembled in USA
Description
GFCI LED, self-grounding
staple, requires connector
below, sold separately.
Rating
Color
15 and 20A Almond
Black
125V AC
Brown
Gray
Ivory
Light Almond
Red
White
15A 125V
NEMA 5-15R
UL CSA
0.5 HP
20A 125V
NEMA 5-20R
UL CSA
1 HP
Meets UL
Standard 943
Class A GFCI
2.76"
(70.0)
3.28"
(83.3)
Catalog Number
GFRST82SNAPAL
GFRST82SNAPBK
GFRST82SNAP
GFRST82SNAPGY
GFRST82SNAPI
GFRST82SNAPLA
GFRST82SNAPR
GFRST82SNAPW
GFRST83SNAPAL
GFRST83SNAPBK
GFRST83SNAP
GFRST83SNAPGY
GFRST83SNAPI
GFRST83SNAPLA
GFRST83SNAPR
GFRST83SNAPW
1.10"
(27.8)
GFRST83SNAPR
1.75"
(44.5)
Tamper and Weather Resistant, Assembled in USA
Description
GFCI TR/WR, self-grounding
Rating
Color
15 and 20A Almond
Black
125V AC
Brown
Gray
Ivory
Light Almond
Red
White
Catalog Number
GFTWRST82SNAPAL
GFTWRST82SNAPBK
GFTWRST82SNAP
GFTWRST82SNAPGY
GFTWRST82SNAPI
GFTWRST82SNAPLA
GFTWRST82SNAPR
GFTWRST82SNAPW
GFTWRST83SNAPAL
GFTWRST83SNAPBK
GFTWRST83SNAP
GFTWRST83SNAPGY
GFTWRST83SNAPI
GFTWRST83SNAPLA
GFTWRST83SNAPR
GFTWRST83SNAPW
2.76"
(70.0)
3.28"
(83.3)
1.10"
(27.8)
GFTWRST83SNAPI
1.75"
(44.5)
SNAPConnect® USB Charger
Hospital Grade , Duplex Receptacles
15A 125V
NEMA 5-15R
UL CSA
0.5 HP
Description
Color
Catalog Number
USB Charger, Tamper-Resistant
Style Line® decorator duplex receptacle,
two USB type 2.0 ports 3 Amp, 5 Volt DC,
15 or 20 Amp, 125 Volt AC.
Black
Brown
Gray
Ivory
Light Almond
Red
White
SNAP8200USBBK
SNAP8200USB
SNAP8200USBGY
SNAP8200USBI
SNAP8200USBLA
SNAP8200USBR
SNAP8200USBW
SNAPConnect® Surge Protection
Hospital Grade , Tamper-Resistant
Receptacle with Power Indicating LED
20A 125V
NEMA 5-20R
UL CSA
1 HP
SNAP8300USBBK
SNAP8300USB
SNAP8300USBGY
SNAP8300USBI
SNAP8300USBLA
SNAP8300USBR
SNAP8300USBW
15A 125V
NEMA 5-15R
UL CSA
0.5 HP
Description
Color
Catalog Number
Surge supression, Tamper-Resistant,
smooth face, duplex receptacle.
Blue
Gray
Ivory
Light Almond
Red
White
SNAP8262S
SNAP8262GYS
SNAP8262IS
SNAP8262LAS
SNAP8262RS
SNAP8262WS
2.62"
(66.5)
3.28"
(83.3)
20A 125V
NEMA 5-20R
UL CSA
1 HP
1.54"
(39.1)
SNAP8300USBW
1.75"
(44.5)
2.62"
(66.5)
3.28"
(83.3)
SNAP8362S
SNAP8362GYS
SNAP8362IS
SNAP8362LAS
SNAP8362RS
SNAP8362WS
1.33"
(33.8)
SNAP8262S
.78"
(19.8)
1.48"
(37.6)
SNAPConnect® Right Angle Pigtailed Terminal
.63"
(16.0)
Description
Wire Type
General Use
Assembled in USA
Clear right angle terminal with 6 inch leads,
600V, #12 AWG THHN/THWN-2,
Polycarbonate housing material.
Solid
Stranded
SNAP1RA
SNAP2RA
SNAP1RNA
SNAP2RNA
Note: See page Tech-10 for Tamper-Resistant and Weather Resistant descriptions.
SNAP1RA
L-7
Hospital Products
Hubbell-PRO Heavy Duty Receptacles
• Automatic self-grounding staple
• Combination Tamper-Resistant and LED for
pediatric emergency circuits
• Nylon face and base construction
• Back and side wiring
• Tri drive screws
8200REDLTRA
1.57"
(39.9)
15A 125V
NEMA 5-15R
UL CSA
0.5 HP
Duplex
2.73"
(69.3)
3.28"
(83.3)
1.15"
(29.1)
Description
Color
Catalog Number
Hospital grade,
smooth nylon face,
Assembled in USA.
Black
Brown
Gray
Ivory
Light Almond
Red
White
8200BK
8200
8200GY
8200IV
8200LA
8200RED
8200WHI
8300BK
8300
8300GY
8300IV
8300LA
8300RED
8300WHI
smooth nylon face,
Assembled in USA.
Black
Brown
Gray
Ivory
Light Almond
Red
White
8200BKTRA
8200TRA
8200GYTRA
8200IVTRA
8200LATRA
8200REDTRA
8200WTRA
8300BKTRA
8300TRA
8300GYTRA
8300IVTRA
8300LATRA
8300REDTRA
8300WTRA
Hospital grade,
smooth nylon face,
Assembled in USA.
Black
Brown
Gray
Ivory
Light Almond
Red
White
8200BKL
8200L
8200GYL
8200IVL
8200LAL
8200REDL
8200WL
8300BKL
8300L
8300GYL
8300IVL
8300LALM
8300REDL
8300WL
smooth nylon face,
Assembled in USA.
Black
Brown
Gray
Ivory
Light Almond
Red
White
8200BKLTRA
8200LTRA
8200GYLTRA
8200IVLTRA
8200LALTRA
8200REDLTRA
8200WLTRA
8300BKLTRA
8300LTRA
8300GYLTRA
8300IVLTRA
8300LALTRA
8300REDLTRA
8300WLTRA
8200LA
1.57"
(39.9)
2.73"
(69.3)
3.28"
(83.3)
1.15"
(29.1)
8200TRA
1.57"
(39.9)
3.28"
(83.3)
2.73"
(69.3)
20A 125V
NEMA 5-20R
UL CSA
1 HP
Note: See pages A-48 and A-49 for accessories.
1.15"
(29.1)
8200REDLTRA
L-8
The products listed on this page are Assembled in USA, and many are Buy American
Compliant. Please contact Hubbell with any certification requirements.
Hospital Products
• Tri drive screws
2182IVLTRA
15A 125V
NEMA 5-15R
UL CSA
0.5 HP
1.57"
(39.9)
20A 125V
NEMA 5-20R
UL CSA
1 HP
Description
Color
Catalog Number
Hospital grade,
flush, nylon face,
Assembled in USA.
Black
Brown
Gray
Ivory
Light Almond
Red
White
2172BK
2172
2172GY
2172IV
2172LA
2172RED
2172W
2182BK
2182
2182GY
2182IV
2182LA
2182RED
2182W
flush, nylon face,
Assembled in USA.
Black
Brown
Gray
Ivory
Light Almond
Red
White
2172BKTRA
2172TRA
2172GYTRA
2172IVTRA
2172LATRA
2172REDTRA
2172WTRA
2182BKTRA
2182TRA
2182GYTRA
2182IVTRA
2182LATRA
2182REDTRA
2182WTRA
Hospital grade,
flush, nylon face,
Assembled in USA.
Black
Brown
Gray
Ivory
Light Almond
Red
White
2172BKL
2172L
2172GYL
2172IVL
2172LAL
2172REDL
2172WL
2182BKL
2182L
2182GYL
2182IVL
2182LAL
2182REDL
2182WL
flush, nylon face,
Assembled in USA.
Black
Brown
Gray
Ivory
Light Almond
Red
White
2172BKLTRA
2172LTRA
2172GYLTRA
2172IVLTRA
2172LALTRA
2172REDLTRA
2172WLTRA
2182BKLTRA
2182LTRA
2182GYLTRA
2182IVLTRA
2182LALTRA
2182REDLTRA
2182WLTRA
2.73"
(69.3)
3.28"
(83.3)
1.15"
(29.1)
2172LATRA
1.57"
(39.9)
2.73"
(69.3)
3.28"
(83.3)
1.15"
(29.1)
2172L
1.57"
(39.9)
3.28"
(83.3)
2.73"
(69.3)
1.15"
(29.1)
2182IVLTRA
L-9
Hospital Products
1.75"
(44.5)
15A 125V
NEMA 5-15R
UL CSA
0.5 HP
Hospital Grade USB Charger
3.28"
(83.3)
2.61"
(66.3)
1.82"
(46.1)
Description
Color
Catalog Number
Hospital Grade USB Charger Outlet:
two Type-C port configurations,
high power 5 Amp, 5 Volt USB output,
Tamper-Resistant duplex receptacle,
USB ports rated 10,000 cycles.
Black
Brown
Gray
Ivory
Light Almond
Red
White
USB8200C5BK
USB8200C5
USB8200C5GY
USB8200C5I
USB8200C5LA
USB8200C5R
USB8200C5W
USB8300C5BK
USB8300C5
USB8300C5GY
USB8300C5I
USB8300C5LA
USB8300C5R
USB8300C5W
one Type A and one Type-C port configurations,
Black
Brown
Gray
Ivory
Light Almond
Red
White
USB8200AC5BK
USB8200AC5
USB8200AC5GY
USB8200AC5I
USB8200AC5LA
USB8200AC5R
USB8200AC5W
USB8300AC5BK
USB8300AC5
USB8300AC5GY
USB8300AC5I
USB8300AC5LA
USB8300AC5R
USB8300AC5W
two Type A port configurations,
Black
Brown
Gray
Ivory
Light Almond
Red
White
USB8200A5BK
USB8200A5
USB8200A5GY
USB8200A5I
USB8200A5LA
USB8200A5R
USB8200A5W
USB8300A5BK
USB8300A5
USB8300A5GY
USB8300A5I
USB8300A5LA
USB8300A5R
USB8300A5W
USB8300C5W
1.75"
(44.5)
3.28"
(83.3)
2.61"
(66.3)
1.82"
(46.1)
USB8200AC5W
1.63"
(41.4)
Hospital Grade
Single Receptacles
3.28"
(83.3)
1.94"
(49.3)
.92”
(23.4)
.1”
(2.5)
IP20
SUITABILITY
Description
Color
Catalog Number
Flush, nylon face,
back and side wired,
Almond
Brown
Gray
Ivory
Red
White
HBL8210
HBL8210GY
HBL8210I
HBL8210R
HBL8210W
HBL8310AL
HBL8310
HBL8310GY
HBL8310I
HBL8310R
HBL8310W
Panel mount on 1.94 in.
(49.2) centers.
Brown
Ivory
HBL8284
HBL8284I
HBL8384I
Isolated ground∆.
Orange
IG8210
IG8310
1.19"
(30.2)
HBL8210GY
20A 125V
NEMA 5-20R
UL CSA
1 HP
4.30” sq.
(109.2)
4-PLEX® Hospital Grade
3.02” (76.7)
3.38” (85.9)
HBL415HI
Color
Catalog Number
4 outlet high impact resistant
Polycarbonate construction.
Mount to 4 in. square box.
Brown
Gray
Ivory
Red
White
HBL415H
HBL415HI
HBL415HR
HBL415HW
.38" (9.7)
3.28"
(83.3)
4.78"
(121.4)
.19" (4.8)
2.75"
(69.9)
HBL420H
HBL420HGY
HBL420HI
HBL420HR
HBL420HW
4-PLEX® Accessories
Description
Color
Catalog Number
4-PLEX adapter plates for
1- and 2-gang, device boxes.
Brown
Gray
Ivory
Red
White
HBL4AP
HBL4APGY
HBL4API
HBL4APR
HBL4APW
1.75"
(44.5 )
3.38"sq. (85.9)
HBL4API
Receptacles
Description
HBL4AP
HBL4APGY
HBL4API
HBL4APR
HBL4APW
Note: See page A-25 for additional information on 4-PLEX devices.
L-10
Hospital Products
G
IP20
G
W
W
SUITABILITY
Hospital Grade
15A 125V
NEMA 5-15P
UL CSA
Plugs
20A 125V
NEMA 5-20P
UL CSA
Insulgrip®
HBL8215C
Description
Cord Diameter
Catalog Number
Black and white nylon.
.230"-.720" (5.8-18.3)
HBL8215C
HBL8315C
Transparent housing.
HBL8215CT
HBL8315CT
8 position angle plug,
transparent housing.
.250"-.655" (6.4-16.6)
HBL8215CAT*
HBL8315CAT*
Valise®
Description
Cord Diameter
Catalog Number
White nylon.
.300"-.660" (7.6-16.8)
HBL8115V
Insulation displacement,
white nylon.
.300"-.360" (7.6-9.1)
HBL8013V*
Note: *Not Fed. Spec. Listed.
See page A-49 for accessories
HBL8364V
G
G
IP20
SUITABILITY
Hospital Grade
Plugs
15A 250V
NEMA 6-15P
UL CSA
1.5 HP
20A 250V
NEMA 6-20P
UL CSA
2 HP
Valise®
HBL8115V
Description
Cord Diameter
Catalog Number
Valise plug, white nylon.
HBL8666V
HBL8464V
Note: HP ratings listed above are based on 208 to 240V AC only.
IP20
SUITABILITY
Hospital Grade
Insulgrip®
Connector Bodies
15A 125V
NEMA 5-15R
UL CSA
0.5 HP
20A 125V
NEMA 5-20R
UL CSA
1 HP
Description
Cord Diameter
Catalog Number
HBL8219C
HBL8319C
HBL8219CT
HBL8319CT
HBL8219C
Valise®
Description
Cord Diameter
Catalog Number
White nylon.
HBL8119V
Note: See page A-49 for accessories.
Hospital Grade
Valise®
HBL8219CT
G
Connector Bodies
Description
Cord Diameter
White nylon.
G
15A 250V
NEMA 6-15R
UL CSA
1.5 HP
20A 250V
NEMA 6-20R
UL CSA
2 HP
Catalog Number
HBL8469V
G
Duplex
G
15A 250V
NEMA 6-15R
UL CSA
1.5 HP
Description
Color
Catalog Number
face, back and side wired,
multiple drive screws.
Brown
Ivory
HBL8600
HBL8600I
20A 250V
NEMA 6-20R
UL CSA
2 HP
HBL8400
HBL8400I
HBL8600I
Note: See page A-48 for accessories.
L-11
Hospital Products
Meets UL Standard 943
Class A GFCI
Extra Heavy Duty Hospital Grade GFCI Receptacles
10kA Short Circuit Current Rating
Limits improper access to energized contacts
• Exclusive patented tamper-resistant protection through switching technology
• Continually tests and monitors for people protection automatically
• Patented self test diagnostics
Power indication
• Steady “ON” GREEN LED provides indication of power
Ground fault indicator
• Steady “ON” RED LED provides visual indication of a ground fault condition;
flashing red indicates device has lost capability to provide protection
No power at face if reverse wired
• Open circuit condition eliminates false assumption of protection at face
Durable face with V-0 flammability rating
• Polyester face cover
GFR8300SGI
AUTOGUARD® Self Test GFCI Receptacles
Description
Rating
Flush, polyester face,
GFR8300SGW
15 and 20A
125V AC
15A 125V
NEMA 5-15R
UL CSA
0.5 HP
20A 125V
NEMA 5-20R
UL CSA
1 HP
Color
Catalog Number
Black
Brown
Gray
Ivory
Red
White
GFR8200SGBK
GFR8200SG
GFR8200SGGY
GFR8200SGI
GFR8200SGR
GFR8200SGW
GFR8300SGBK
GFR8300SG
GFR8300SGGY
GFR8300SGI
GFR8300SGR
GFR8300SGW
Note: GFCI type receptacles should not be used in critical care patient areas or for electrical life support equipment applications because
of the possibility of power interruption. All GFCI receptacles listed above are furnished with both a matching color nylon wallplate,
and a SS26 302/304 super stainless steel wallplate. 20 amp feed-through capability.
GFCI Receptacle Specifications per GFCI Products Listed (Pages L-12 to L-15)
Trip Level
Trip Time
Frequency
Voltage
Amperage
Maximum Interrupting Capacity
Operating Temperature
Maximum Humidity
Listings and Standards
Codes
4 to 6 mA.
.025 second nominal.
60 Hz.
120V AC +10% - 15% (102V to 132V).
15A/20A, 20A Feed Thru.
10,000A.
-35°C to 66°C or -30°F to 150°F.
95%.
Meets UL498 for receptacles, UL943 Class A for GFCIs UL File E41978.
CSA Certified.
Meets all NEC® and CEC requirements. NEMA WD-6 ANSI 73.
L-12
Hospital Products
Class A GFCI
Commercial Tamper-Resistant GFCI Receptacles
• Patented shutter design for tamper-resistant protection
• Compliant with NEC® 406.12 and NEC® 517-18(c)
• Patented AUTOGUARD® self test technology includes
disconnecting power to the receptacle if critical components
are damaged and GFCI protection is lost
• Alarm version provides audible notification of a trip condition
GFTRST83B
15A 125V
NEMA 5-15R
UL CSA
0.5 HP
Hospital Grade
Tamper-Resistant
Description
Rating
20A 125V
NEMA 5-20R
UL CSA
1 HP
Color
Catalog Number
Night Light
Two LED Night Lights,
Flush, nylon face,
multiple drive screws,
self-grounding staple.
15 and 20A
125V AC
Almond
Black
Brown
Gray
Ivory
Light Almond
Red
White
GFTRST82ALNL
GFTRST82BKNL
GFTRST82NL
GFTRST82GYNL
GFTRST82INL
GFTRST82LANL
GFTRST82RNL
GFTRST82WNL
GFTRST83ALNL
GFTRST83BKNL
GFTRST83NL
GFTRST83GYNL
GFTRST83INL
GFTRST83LANL
GFTRST83RNL
GFTRST83WNL
Alarm,
Flush, nylon face,
15 and 20A
125V AC
Almond
Black
Brown
Gray
Ivory
Light Almond
Red
White
GFTRST82ALB
GFTRST82BKB
GFTRST82B
GFTRST82GYB
GFTRST82IB
GFTRST82LAB
GFTRST82RB
GFTRST82WB
GFTRST83ALB
GFTRST83BKB
GFTRST83B
GFTRST83GYB
GFTRST83IB
GFTRST83LAB
GFTRST83RB
GFTRST83WB
GFTRST83WNL
GFTRST83GYB
Product Dimensions Inches (mm)
E
GFCI Receptacle
A
3.27 (83.1)
B
2.75 (69.8)
C
1.75 (44.5)
D
1.47 (37.4)
E
1.10 (27.9)
A
B
C
D
L-13
Hospital Products
Class A GFCI
Commercial Tamper and Weather Resistant GFCI Receptacles
• Meets NEC® requirements for TR (517-18c) and WR (406.9),
UV and corrosion resistance for harsh and damp applications
• Protects against line and load reversal, no power to the face
or downstream if device is miswired
GFTWRST83WIG
GFTWRST82AL
Description
GFTWRST83GYU
GFTWRST82BKIG
15A 125V
NEMA 5-15R
UL CSA
0.5 HP
Hospital Grade • Tamper-Resistant
Weather Resistant
Rating
20A 125V
NEMA 5-20R
UL CSA
1 HP
Color
Catalog Number
Standard,
Flush, nylon face,
15 and 20A
125V AC
Almond
Black
Brown
Gray
Ivory
Light Almond
Red
White
GFTWRST82AL
GFTWRST82BK
GFTWRST82
GFTWRST82GY
GFTWRST82I
GFTWRST82LA
GFTWRST82R
GFTWRST82W
GFTWRST83AL
GFTWRST83BK
GFTWRST83
GFTWRST83GY
GFTWRST83I
GFTWRST83LA
GFTWRST83R
GFTWRST83W
Assembled in USA,
Flush, nylon face,
15 and 20A
125V AC
Almond
Black
Brown
Gray
Ivory
Light Almond
Red
White
GFTWRST82ALU
GFTWRST82BKU
GFTWRST82U
GFTWRST82GYU
GFTWRST82IU
GFTWRST82LAU
GFTWRST82RU
GFTWRST82WU
GFTWRST83ALU
GFTWRST83BKU
GFTWRST83U
GFTWRST83GYU
GFTWRST83IU
GFTWRST83LAU
GFTWRST83RU
GFTWRST83WU
Isolated Ground,
Flush, nylon face,
15 and 20A
125V AC
Almond
Black
Brown
Gray
Ivory
Light Almond
Red
White
GFTWRST82ALIG
GFTWRST82BKIG
GFTWRST82IG
GFTWRST82GYIG
GFTWRST82IIG
GFTWRST82LAIG
GFTWRST82RIG
GFTWRST82WIG
GFTWRST83ALIG
GFTWRST83BKIG
GFTWRST83IG
GFTWRST83GYIG
GFTWRST83IIG
GFTWRST83LAIG
GFTWRST83RIG
GFTWRST83WIG
SNAPConnect®,
Flush, nylon face,
15 and 20A
125V AC
Almond
Black
Brown
Gray
Ivory
Light Almond
Red
White
GFTWRST82SNAPAL
GFTWRST82SNAPBK
GFTWRST82SNAP
GFTWRST82SNAPGY
GFTWRST82SNAPI
GFTWRST82SNAPLA
GFTWRST82SNAPR
GFTWRST82SNAPW
GFTWRST83SNAPAL
GFTWRST83SNAPBK
GFTWRST83SNAP
GFTWRST83SNAPGY
GFTWRST83SNAPI
GFTWRST83SNAPLA
GFTWRST83SNAPR
GFTWRST83SNAPW
GFTWRST83SNAPI
Description
SNAP1RA
L-14
Wire Type
Clear right angle terminal with 6 inch leads Solid
#12 AWG THHN/THWN-2; Polycarbonate Stranded
housing material.
General Use
Catalog Number
Assembled in USA
Catalog Number
SNAP1RA
SNAP2RA
SNAP1RNA
SNAP2RNA
Hospital Products
Class A GFCI
Commercial Standard Hospital Grade • GFCI Receptacles
• Fed. Spec UL Listed, Hospital Grade
• Green power indicator and red trip indicator
• Flush, nylon face, back and side wired, multiple drive screws,
15A 125V
NEMA 5-15R
UL CSA
0.5 HP
Rating
Rating
Standard,
Flush, nylon face,
15 and 20A
125V AC
Assembled in USA,
Flush, nylon face,
15 and 20A
125V AC
Night Light
15 and 20A
125V AC
Alarm,
Flush, nylon face,
15 and 20A
125V AC
SNAPConnect®,
Flush, nylon face,
15 and 20A
125V AC
Flush, nylon face,
Color
Catalog Number
Almond
Black
Brown
Gray
Ivory
Light Almond
Red
White
Almond
Black
Brown
Gray
Ivory
Light Almond
Red
White
Almond
Black
Brown
Gray
Ivory
Light Almond
Red
White
Almond
Black
Brown
Gray
Ivory
Light Almond
Red
White
Almond
Black
Brown
Gray
Ivory
Light Almond
Red
White
GFRST82AL
GFRST82BK
GFRST82
GFRST82GY
GFRST82I
GFRST82LA
GFRST82R
GFRST82W
GFRST82ALU
GFRST82BKU
GFRST82U
GFRST82GYU
GFRST82IU
GFRST82LAU
GFRST82RU
GFRST82WU
GFRST82ALNL
GFRST82BKNL
GFRST82NL
GFRST82GYNL
GFRST82INL
GFRST82LANL
GFRST82RNL
GFRST82WNL
GFRST82ALB
GFRST82BKB
GFRST82B
GFRST82GYB
GFRST82IB
GFRST82LAB
GFRST82RB
GFRST82WB
GFRST82SNAPAL
GFRST82SNAPBK
GFRST82SNAP
GFRST82SNAPGY
GFRST82SNAPI
GFRST82SNAPLA
GFRST82SNAPR
GFRST82SNAPW
20A 125V
NEMA 5-20R
UL CSA
1 HP
GFRST83AL
GFRST83BK
GFRST83
GFRST83GY
GFRST83I
GFRST83LA
GFRST83R
GFRST83W
GFRST83ALU
GFRST83BKU
GFRST83U
GFRST83GYU
GFRST83IU
GFRST83LAU
GFRST83RU
GFRST83WU
GFRST83ALNL
GFRST83BKNL
GFRST83NL
GFRST83GYNL
GFRST83INL
GFRST83LANL
GFRST83RNL
GFRST83WNL
GFRST83ALB
GFRST83BKB
GFRST83B
GFRST83GYB
GFRST83IB
GFRST83LAB
GFRST83RB
GFRST83WB
GFRST83SNAPAL
GFRST83SNAPBK
GFRST83SNAP
GFRST83SNAPGY
GFRST83SNAPI
GFRST83SNAPLA
GFRST83SNAPR
GFRST83SNAPW
GFRST82WNL
GFRST82R
GFRST83INL
GFRST83BKB
Description
Wire Type
General Use
Catalog Number
Assembled in USA
Catalog Number
housing material.
Solid
Stranded
SNAP1RA
SNAP2RA
SNAP1RNA
SNAP2RNA
GFRST83SNAPGY
L-15
Hospital Products
1.75"
(44.3)
Hospital Grade
2.62"
(66.5)
3.31"
(84.0)
1.33"
(33.8)
SNAP8362GYS
1.30"
(33.0)
Circuit Guard® Receptacles
2.62"
(66.5)
1.75"
(44.5)
1.13"
(28.7)
Color
Catalog Number
SNAPConnect®
Tamper-Resistant,
surge supression receptacle,
smooth face, duplex. Requires connector
on page L-15, sold separately.
Blue
Gray
Ivory
Light Almond
Red
White
SNAP8262S
SNAP8262GYS
SNAP8262IS
SNAP8262LAS
SNAP8262RS
SNAP8262WS
SNAP8362S
SNAP8362GYS
SNAP8362IS
SNAP8362LAS
SNAP8362RS
SNAP8362WS
Surge suppression receptacles with
light and alarm, 240 joules/15000A
per mode.
Almond
Blue
Gray
Ivory
Red
White
HBL8262ALSA
HBL8262SA
HBL8262GYSA
HBL8262ISA
HBL8262RSA
HBL8262WSA
HBL8362ALSA
HBL8362SA
HBL8362GYSA
HBL8362ISA
HBL8362RSA
HBL8362WSA
Isolated ground, surge suppression
receptacles with light and alarm,
240 joules/15000A per mode.
Blue
Gray
Ivory
Orange
Red
White
IG8262SA
IG8262GYSA
IG8262ISA
IG8262OSA
IG8262RSA
IG8262WSA
IG8362SA
IG8362GYSA
IG8362ISA
IG8362OSA
IG8362RSA
IG8362WSA
4-PLEX® surge suppression receptacles
with lights, 80 joules/6500A per mode.
Blue
Ivory
Red
HBL420HS
HBL420HIS
HBL420HRS
Note: See page Tech-10 for Tamper-Resistant and LED Power Indicators descriptions.
HBL8362ISA
.92"
(23.4)
20A 125V
NEMA 5-20R
UL CSA
1 HP
Description
1.23"
(31.2)
3.28"
(83.3)
15A 125V
NEMA 5-15R
UL CSA
0.5 HP
.1"
(2.5)
4.30" sq.
(109.2)
3.02"
(76.7)
3.38" (85.9)
4-PLEX® Accessories
Description
Color
Catalog Number
4-PLEX Adapter Plates for 1- and 2-gang,
and 4 in. (101.6) square device boxes.
Blue
Ivory
Red
HBL4APBL
HBL4API
HBL4APR
4-PLEX Portable Box. Portable 4 in. (101.6)
square box with cord grip. Accepts up to
.66 in. (16.8) diameter cord.
Ivory
HBL4PBI
Note: 4-PLEX Box is not UL Listed.
HBL420HS
UL2930 Listed
UL2930 Health Care Outlet Assembly (HCOA)
Description
# of Outlets
Cord Length Color
15 Amp
20 Amp
HBL6MG620
UL 2930 HCOA
with L-N Surge Protection
6
6'
White
HBL6MG6
6
15'
White
HBL6MG15
HBL6MG1520
UL 2930 HCOA
Relocatable Power Tap (RPT)
6
6'
White
HBL6MGRPT6
HBL6MGRPT620
6
15'
White
HBL6MGRPT15
HBL6MGRPT1520
HBL6MGRPT620
Listed to UL1449
SpikeShield®
Surge Protective Devices (SPD) with
Tamper-Resistant Receptacles and Heavy Duty Plug
Description
HBL6HGUSB6
15 Amp
20 Amp
Type 3 SPD, Heavy Duty
Metal Housing
# of Outlets
6
Cord Length Color
6'
White
HBL6HG6
HBL6HG620
6
15'
White
HBL6HG15
HBL6HG1520
UL Type 3 SPD, Heavy Duty
Metal Housing with 2-port USB
4
6'
White
HBL6HGUSB6
L-16
Hospital Products
Hubbellock® Plugs, Connector Bodies and Receptacles
For Hospital Use Only
Hubbellock® Plugs and Connector Bodies
20A 125V AC
20A 125V AC
Description
Plugs
Connector Bodies
Nylon cover, thermoset interior.
HBL23014HGB
HBL23001HGB
Armored, epoxy filled, rubber cord grip.
HBL23004HG
Note: Cord clamp range for plug and connector .300" to .660" (7.6 to 16.8).
Receptacles
Description
Catalog Number
Black, back wired.
HBL23000HG
Wallplates
Description
Catalog Number
Stainless steel 302/304, single-gang.
HBL23901HG
Stainless steel 302/304, three-gang for two receptacles.
HBL23909HG
Note: Suffix HG or HGB type for hospital use only.
IP30
SUITABILITY
20A 125V AC
Explosion Proof Plug
Description
Catalog Number
Plug, with, epoxy kit, accepts #12 or #14 type SO cable.
HBL24312
Hazardous to Non-hazardous Location Receptacle Conversion Kits
Conversion kits for replacement of explosion proof receptacles listed above, with non-explosion proof receptacles,
in the hospital areas formerly classified as hazardous locations and now classified non-hazardous locations due to
the change from flammable anesthetizing gases to nonflammable anesthetizing gases.
For Conversion To:
Catalog Number
20A, 125V, duplex receptacle (Hubbell HBL830 Series). Includes adapter ring and
stainless steel wall plate for duplex receptacle (receptacle not included).
HBL24300RKD
20A, 125V, Hospital Hubbellock receptacle (Hubbell HBL23000HG) or 20A, 125V,
straight blade single receptacle (Hubbell HBL8310 series). Includes adapter ring
and stainless wall plate for single receptacle ( receptacle not included.
HBL24300RKS
HBL24300RKD Duplex retrofit kit accepts
20A duplex straight blade hospital grade
receptacles (HBL8300, HBL8300I, IG8300, etc.).
Order receptacles separately.
24352 Low-profile style explosion-proof
receptacle (now discontinued).
HBL24300RKS Single retrofit accepts hospital only
Hubbellock single receptacles (Hubbell HBL23000HG)
or 20A single straight blade hospital grade receptacles
(Hubbell HBL8310, HBL8310I, IG8310, etc.).
L-17
Hospital Products
Hubbellock® Mobile X-Ray Devices
IP30
SUITABILITY
50A 250V AC
Mobile X-Ray Plugs
60A 250V AC
Description
Catalog Number
Plug, with epoxy kit, less cord clamp.
HBL25515
HBL25615
Plug, with cord clamp, less epoxy kit.
HBL25525
HBL25625
Note: Cord clamp range of plugs with cord clamps .830" to 1.3" (21.1 to 33.0).
50A plugs fit 50A or 60A receptacles.
Mobile X-Ray Receptacles
50A 250V AC
60A 250V AC
Description
Catalog Number
Receptacle with stainless steel plate assembly.
HBL25505
HBL25605
Receptacle with cast aluminum plate assembly.
HBL25503
HBL25603
Replacement receptacle interior.
IN16494
Accessory
Description
Catalog Number
Box stamped steel 8" x 8" x 4" (203.2 x 203.2 x 101.6),
accommodates 50A and 60A mobile X-ray receptacles.
Knockout sizes 1¼", 1½" and 2".
HBL25509
L-18
