Twist-Lock Devices
30A 125/250V, 3-Pole 4-Wire
Spring Terminated InsulGrip Plug
Features
Faster termination time
No need for screwdriver and torque wrench
Spring Termination eliminates strand relaxation
Funnel shaped wire entry for ease of termination.
Superior cord grip design protects terminations from excess strain
Ordering Information
Description
Black and white nylon.
Cord Diameter
UPC Number
350"-1.150" (9-29) 7 78358568160
Catalog Number
HBL2711ST
Listings
Listed to UL 498
Fed.Spec. W-C-596
Certified to CSA C22.2 No.42
Specifications
Housing / Cord Clamp
Terminal Retainer
Plunger
Blades
Terminal Spring Clamp
Assemby Screws
Weight (lbs)
Nylon
Nylon
Nylon
Copper Alloy
Spring Steel
Zinc Plated Tri-drive
0.25
Performance
Electrical
Current Interrupting
Dielectric Voltage
Certified for current interrupting at full rated
current
Withstands 3,000V minimum
Mechanical
Terminal Accommodation
#14 AWG - #8 AWG stranded copper wire only
Terminal Identification
Terminals identified in accordance with UL 498
Environmental
Flammability
Moisture Resistance
Operating Temperatures
HB or better per UL94/CSA 22.2 No.0.17
IP20 Suitability
Maximum Continuous 75°C, Minimum -40°C
(w/o impact)
Dimensions in Inches (mm)
Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484
Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice.
Online Resources
eCatalog
很抱歉,暂时无法提供与“HBL2711ST”相匹配的价格&库存,您可以联系我们找货
