HBL2813
HBL2813
    HUBBELL(哈伯尔公司)
HBL2813 数据手册
Twist-Lock® Devices Twist-Lock® Devices 30 Ampere, 3Ø Y 120/208, 277/480 and 347/600 Volts AC 4 Pole, 5 Wire Grounding X Insulgrip® Connector Bodies and Receptacles W Connector Bodies G W 30A 3ØY 120/208V AC NEMA L21-30R UL/CSA 3 HP 30A 3ØY 277/480V AC NEMA L22-30R UL/CSA 10 HP 30A 3ØY 347/600V AC NEMA L23-30R UL/CSA IP66 IP20 Cord Dia. .35"-1.15" (9-29) .35"-1.15" (9-29) .35"-1.15" (9-29) .35"-1.15" (9-29) Corrosion resistant, yellow nylon. Black and white for flat cable. All black nylon. Y Z Catalog Numbers HBL2813SW Description Black and white nylon. G Z Description Black Valox® housing, white Valox® clamps. Insulgrip G W Y Z Watertight Safety-Shroud® Cord Dia. .35"-1.15" (9-29) X X Y SUITABILITY – 2.75" (69.9) – 4.38" (111.1) SUITABILITY Catalog Numbers HBL2813 HBL2823 HBL2813SW HBL2833 HBL28CM13 – – HBL2813FC – – HBL2813BK – – 2.33" (59.3) 2.21" (56.1) 3.86" (98.0) Accessories on page B-53. HBL2813 Receptacles 2.91" (73.9) Watertight Safety-Shroud, Back Wired IP66 Catalog Numbers HBL2810SW Safety-Shroud Twist-Lock, Back Wired Description Gray Valox® angle housing, one gang. Gray Valox® surface mounting, one gang. Gray Valox® semi-flush, two gang. Accessories on page B-54. Single Flush, Back and Side Wired Description Black nylon face. Isolated ground, orange nylon face. Ring terminal connection. Accessories on page B-52. – IP20 Catalog Numbers HBL2810AR HBL2810SR HBL2810SR2 SUITABILITY – SUITABILITY – – – IP20 3.75" (95.3) 1.75" (44.5) 3.75" (95.3) – – – HBL2810SW 3.14" (79.8) SUITABILITY Catalog Numbers HBL2810 HBL2820 IG2810 – HBL2810RT – HBL2830 – – Catalog Numbers HBL2816 HBL2826 HBL2836 4.57" (116.1 Insulgrip Flanged Receptacles Description Nylon casing, back wired. Accessories on page B-52. 2.88" (73.2) HBL2810AR 1.70" (43.2) 3.06" (77.7) 120° 1.23" (31.2) .77" (19.6) 1.71" (43.4) 1.34" R. (34.0) 5.12" (130.0) .19" 120° (4.8) DIA. 2.27" (57.7) 2.23" (56.6) HBL2816 4.56" (115.8) 1.56" 2.38" 3.28" (39.6) (60.5) (83.3) 2.67" (67.8) #6-32 TAP .98" (24.9) HBL2810 5.12" (130.0) HBL2810SR2 2.84" (72.1) HBL2810SR Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. Dimensions in Inches (mm) www.hubbell-wiring.com B-33 30 Ampere, 3Ø Y 120/208, 277/480 and 347/600 Volts AC Description Gray Valox® housing and flange. Accessories on page B-54.
HBL2813 价格&库存
很抱歉,暂时无法提供与“HBL2813”相匹配的价格&库存,您可以联系我们找货
