HBL3523C
HBL3523C
    HUBBELL(哈伯尔公司)
HBL3523C 数据手册
Product Datasheet HBL3523C -- Twist-Lock Connector Body 4P5W, 20A 250V/10A 600V AC, Non-NEMA, Black & White Nylon Product Specifications Product Type Product Item Connector Body Wiring Scheme 4-Pole, 5-Wire Grounding Amperage 20A Voltage Multi Rated NEMA Configuration Non-NEMA Item Style Insulgrip Device Color Black/White Cord Dia. .35"-1.15" (9-29) Terminal Retainer Material Clear polycarbonate Housing Material Black nylon Cord Clamp Material Natural (white) nylon Terminal Clamp Material Cold rolled steel-nickel-plated Terminal Screw Material #8-32 Brass (white finish on neutral screw when used) Ground Screw Material #10-32 Brass (green finish) Multi-drive Cord Clamp Screw Material Steel, zinc plated Multi-drive Body Holding Screw Material Steel, zinc plated Multi-drive Body Contact Carrier Material Natural White Nylon Contact Spring Material Brass Spring Binding Plate Material Brass Ground Contact Material .031" (.8) Brass Ratings Molded In or Stamped On Catalog No Permanently ink marked on product Dielectric Voltage Withstand 2,000V minimum Current Interrupting Certified for current interrupting at full rated current Temperature Rise Max 30C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of .75. Cord Accommodation Round portable service cords of diameters commensurate with the device rating as defined in UL Standard 62, CSA C22.2 No. 49. Terminal Accommodation 20A #12 AWG Terminal Identification Terminals identified in accordance with UL 498 (X, Y, Z, White, Green) Flammability HB or better per UL 94 or CSA 22.2 No. 0.6 Operating Temperatures Maximum Continuous 75 C Minimum -40 C (w/o impact) Moisture Resistance IP20 Listings UL/CSA UPC Number 783585039923 Weight in LBs 0.45 Link to Drawing Library Click here for Library Link to PDF Catalog Click here for Catalog Configuration
HBL3523C 价格&库存
很抱歉,暂时无法提供与“HBL3523C”相匹配的价格&库存,您可以联系我们找货
