HBL5278C
HBL5278C
    HUBBELL(哈伯尔公司)
    HBL5278C
HBL5278C 数据手册
Straight Blade Devices 15 and 20 Ampere, 125 Volts 2 Pole, 3 Wire Grounding G G W Flanged Inlets 2.56" (65.0) 2.19" (55.6) .16" (4.1) Dia. 1.72" (43.7) 1.72" (43.7) HBL5278C W 15A 125V NEMA 5-15P UL CSA 20A 125V NEMA 5-20P UL CSA Description Catalog Number Nylon casing, back wired. HBL5278C Weatherproof, gray, with lift cover and multiple drive screws. HBL61CM64 – Weatherproof, black, with lift cover and boot, multiple drive screws. HBL61CM64BK – Stainless steel flange, phenolic body, miniature style, for molded on connectors only, multiple drive screws. HBL5240* – HBL5378C Note: *Specially designed to accept "molded-on" connector bodies. Catalog number HBL5240 will not accept re-wireable size connector bodies listed in this catalog or molded connectors having a "rejection obstruction" as required by Underwriters Laboratories Inc. standard #817 cord sets and power supply cords" effective 7/1/81. See pages A-46 and A-47 for accessories. 2.25" (57.2) .39"(9.9) Dia. 2.88" (73.2) 1.88" (47.8) 2.66" (67.6) .19" (4.8) Dia. 4 Holes 1.56" (39.6) HBL61CM64 G G W 2.56" (65.0) Flanged Receptacles 2.19" (55.6) .16" (4.1) Dia. 1.72" (43.7) 1.72" (43.7) HBL5279C W 15A 125V NEMA 5-15R UL CSA 0.5 HP 20A 125V NEMA 5-20R UL CSA 1 HP Description Catalog Number Nylon casing, back wired. HBL5279C Stainless steel flange, phenolic body, covered terminals, multiple drive screws. HBL5279 – Stainless steel flange, brown phenolic (mounting screws packed separately). HBL5256 – Weatherproof, gray nylon, with lift cover and boot, multiple drive screws. – HBL5379C HBL61CM65** Note: **Not CSA Certified. See pages A-46 and A-47 for accessories. .20" Dia. (5.1) 1.47" (37.3) 2.06" (52.3) 1.09" (27.7) HBL5256 2.25" (57.2) .39"(9.9) Dia. 2.88" (73.2) 1.88" (47.8) 2.66" (67.6) 1.56" (39.6) .19" (4.8) Dia. 4 Holes HBL61CM65 Dimensions in Inches (mm) A-32 ® Wiring Device-Kellems www.hubbell-wiring.com
HBL5278C 价格&库存
很抱歉,暂时无法提供与“HBL5278C”相匹配的价格&库存,您可以联系我们找货
