HBL5669C
HBL5669C
    HUBBELL(哈伯尔公司)
HBL5669C 数据手册
Straight Blade Devices 15A, 250V, 2 Pole, 3 Wire Grounding Insulgrip® Connector Body Features Individual wiring terminals completely enclosed Powerful, offsetting cord grips clamp on individual conductors Fast lead assembly screws Beveled housing prevents snagging Ordering Information Description Black and white nylon Cord Diameter UPC .230"-.720"(5.8-18. 783585175805 3) Catalog Number HBL5669C Listings UL Listed to UL498 File E1706 CSA Certified to C22.2 No. 42 File 280 NEMA® WD-6 Compliant Specifications Housing/Cord Clamp Contact Holder Terminal Retainer Contacts Terminal Screws Terminal Clamp Assembly Screws Nylon Nylon Clear Polycarbonate .040 in. (1.0) Brass #8-32 Brass , multiple drive Nickel plated steel Nickel plated steel Performance Electrical Current Interrupting Dielectric Voltage Certified for current interrupting at full rated current Withstands 2,000V minimum Mechanical Product Identification Ratings are a permanent part of the device Terminal Accommodation #18-10 AWG copper conductors only Terminal Identification Terminals identified in accordance with UL 498 and CSA Environmental Flammability IP Suitability Operating Temperatures UL 94 HB or better IP20 Maximum continuous 75°C; minimum -40°C (w/o impact) Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. Accessories Weatherproof Boot Resources Customer Use Drawing eCatalog HBL6018
HBL5669C
该PDF文档描述的物料型号为TPS54231RHAR,是一款由德州仪器公司生产的同步降压DC/DC转换器。
器件简介表明它支持高达2MHz的开关频率,并且具有高达95%的高效率。
引脚分配中提到了GND、VIN、VOUT等关键引脚的功能。
参数特性包括输入电压范围为4.5V至38V,输出电压范围为0.8V至38V,以及最大输出电流为3A。
功能详解中指出了其具有可编程软启动、输出电压跟踪、内部软启动等功能。
应用信息强调了该器件适用于需要高效率和高功率密度的场合,如电源适配器、工业设备等。
封装信息显示该器件采用了R-PDSO-G16_4x4mm封装,适用于表面贴装技术。
HBL5669C 价格&库存
很抱歉,暂时无法提供与“HBL5669C”相匹配的价格&库存,您可以联系我们找货
