HBL8362WSA
HBL8362WSA
    HUBBELL(哈伯尔公司)
HBL8362WSA 数据手册
Hospital Products Hospital Products 2 Pole, 3 Wire Grounding 15 and 20 Ampere, 125 Volts Straight Blade Hospital Grade – GFCI, Surge Suppression and Isolated Ground/Surge Suppression Duplex Receptacles 1.75" (44.5) G G W 3.28" (83.3) Circuit Guard®, Heavy Duty, Hospital Grade Ground Fault Circuit Interrupter Duplex Receptacles 2.62" (66.5) GF8200 1.30” (33.0) 1.23” (31.2) Color Catalog Numbers Brown GF8200A GF8300A Ivory GF8200IA GF8300IA Gray GF8200GYA GF8300GYA Red GF8200RA GF8300RA White GF8200WA GF8300WA Caution:GFCI-type receptacles should not be used in critical care patient areas or for electrical life support equipment applications because of the possibility of power interruption. Note: All GFCI receptacles listed above are furnished with the proper color nylon wall plate, and, in addition, an S26 302/304 super stainless steel wall plate. See Section H for more information on ground fault devices. Circuit Guard, Heavy Duty, Hospital Grade Surge Suppression Duplex Receptacles Description Flush, with light and alarm, 240 joules/15000A per mode. 3.28” 2.62” (83.3) (66.5) 1.13” (28.7) 1.75” (44.5) 1.30" (33.0) Color Blue Ivory Gray Red White Catalog Numbers HBL8262SA HBL8362SA HBL8262ISA HBL8362ISA HBL8262GYSA HBL8362GYSA HBL8262RSA HBL8362RSA HBL8262WSA HBL8362WSA Circuit Guard, Heavy Duty, Hospital Grade Isolated Ground/Surge Suppression Duplex Receptacles Description Flush, with light and alarm, 240 joules/15000A per mode. HBL8362IS 1.23" (31.2) Color Catalog Numbers Blue IG8262SA IG8362SA Ivory IG8262ISA IG8362ISA Gray IG8262GYSA IG8362GYSA Red IG8262RSA IG8362RSA White IG8262WSA IG8362WSA Orange IG8262OSA IG8362OSA Notes: See Section J for more information on Circuit Guard isolated ground devices. See Section J for more information on Circuit Guard surge suppression devices. Wall Plates 3.28" 2.62" (83.3) (66.5) Hospital Grade Receptacles NEMA 5-20R 20A 125V UL CSA Description Flush, duplex receptacle, side wired only. 1.15" (29.2) High-Impact Nylon Configuration Color Standard Mid-Size 1.13" (28.7) 1.75" (44.5) IG8362OS I-6 NEMA 5-15R 15A 125V UL CSA W Plated Steel Stainless Steel Brass Blue – SPJ26C* Chrome CH26 Smooth SS S26 Ivory – PJ26C* Brass BP26 Smooth SS SJ26Ž Ivory HPS1I PJ26 – – Brass B26 Gray HPS1GY PJ26G – – White HPS1WA PJ26W – – – Orange IGHPS1** – – – – 1-gang Red HPS1R PJ26R – – – Notes: *Premarked “COMPUTER ONLY”. Lettering is black 1 /4” high. **Premarked “ISOLATED GROUND”. Lettering is black 1 /4” high. ŽJumbo size plate. www.hubbell-wiring.com Dimensions in Inches (mm)
HBL8362WSA
PDF文档中包含了以下信息: 1. 物料型号:型号为STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器。
2. 器件简介:该微控制器具有多种通信接口,适用于多种嵌入式应用。
3. 引脚分配:详细列出了所有引脚及其功能,包括电源、地、I/O、通信接口等。
4. 参数特性:包括工作电压、工作频率、存储器大小等。
5. 功能详解:详细介绍了微控制器的各个功能模块,如GPIO、ADC、定时器等。
6. 应用信息:提供了一些应用案例,展示了微控制器在实际项目中的应用。
7. 封装信息:描述了微控制器的物理封装形式,便于用户在设计电路板时参考。
以上信息为用户在设计和开发过程中提供了重要的参考。
HBL8362WSA 价格&库存
很抱歉,暂时无法提供与“HBL8362WSA”相匹配的价格&库存,您可以联系我们找货
