HBLI45123GF220M1
HBLI45123GF220M1
    HUBBELL(哈伯尔公司)
    HUBBELL WIRING DEVICES - HBLI45123GF220M1 - PWR CORD, PLUG-OUTLET BOX- 2X RCPT, 45
HBLI45123GF220M1 数据手册
Wire Management Products Cord and Cable Reels Industrial Power Cord Reels Features Durable, Corrosion Resistant Cast Aluminum Construction UL Type 1 Multi-Position Guide Arm can be mounted in two different positions Positive Latch mechanism automatically maintains desired cord length Ratchet Lock can be disengaged in field for constant tension applications Ordering Information Description White Industrial Reel with Black Portable Outlet Box, GFCI Module and (2) 20A Duplex Receptacles, UL Type 1, 45 Ft, #12/3 SJO, 20 A, 250 VAC UPC 783585586410 Catalog Number HBLI45123GF220M 1 Listings cULus Listed Specifications Spool Guide Frame Cord Internal Terminals Ball Stopper Fitting Aluminum Thermoplastic Copper Copper Alloy Thermoplastic Aluminum Complementary Products Pivot Base Mounting Bracket Ball Stop Performance Electrical Amperage Max. Working Voltage Number of Wires Environmental Moisture Resistance 20 A 250V AC 3-Wire Dry, Indoor, Non-Hazardous Locations - UL Type 1 Online Resources Customer Sales Drawing eCatalog Installation Instructions Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. HBLI340PB HBLIMB HBLI12BS
HBLI45123GF220M1 价格&库存
很抱歉,暂时无法提供与“HBLI45123GF220M1”相匹配的价格&库存,您可以联系我们找货
