HBLS460R7W
HBLS460R7W
    HUBBELL(哈伯尔公司)
    HUBBELL WIRING DEVICES - HBLS460R7W - POWER ENTRY CONN, SKT, 3P4W, 60A, RED
HBLS460R7W 数据手册
Switch-Rated IEC Pin and Sleeve 60A 3 Phase 480V, 3 Pole, 4 Wire Watertight Receptacle Features Mates with existing installed base of IEC 60309-2 pin and sleeve devices Approved as a disconnecting means for motor circuits and branch circuits UL Type 4X, 12 and IP69k environmental ratings Impact and corrosion-resistant PBT that is color coded by voltage. Unswitched ground and power indicating LED lights Ordering Information Description Watertight IEC Pin and Sleeve Receptacle UPC 783585478647 Catalog Number HBLS460R7W Listings UL Listed, File E146033 CSA Certified File LR280C UL Classified to IEC 60309-1 IEC 60309-2 Specifications Housing Closure Covers Sealing Gasket Retainer Gaskets PBT PBT Solid Neoprene High-Impact Thermoset Santoprene Performance Electrical Current Interrupting Dielectric Voltage Max. Working Voltage Mechanical Impact Resistance Product Identification Terminal Identification Environmental Flammability Ingress Protection Moisture Resistance Operating Temperatures Certified for current interrupting at full rated current Withstand 3000V AC 600V RMS Per CSA C22.2 No. 182.1 / UL1682 Identification and ratings are a permanent part of the device housing Terminals identified in accordance with North American and IEC conventions V-0 TYPE 3R,3RX,4X AND IP68,IP69K IEC 60309-1 Maximum Continuous 75°C; Minimum - 40°C w/o impact Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice.
HBLS460R7W
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款红外发射二极管。
2. 器件简介:EL817是一种红外发射二极管,常用于遥控器等设备。
3. 引脚分配:EL817有2个引脚,分别为阳极和阴极。
4. 参数特性:工作电压范围为1.4V-1.8V,工作电流为50mA,发射波长为940nm。
5. 功能详解:EL817通过电流控制发光强度,用于红外线信号发射。
6. 应用信息:主要用于遥控器、红外线通信等领域。
7. 封装信息:EL817采用黑色环氧树脂封装,尺寸为3.5mm x 1.8mm。
HBLS460R7W 价格&库存
很抱歉,暂时无法提供与“HBLS460R7W”相匹配的价格&库存,您可以联系我们找货
