07401010
07401010
    HUBBELL(哈伯尔公司)
07401010 数据手册
Wire Management Products Index Dimensions in Inches (mm) www.hubbell-wiring.com Page Number T-2–3 T-4–16 T-6 T-6 T-7 T-8–9 T-8 T-9 T-10–11 T-10 T-10–11 T-12 T-13 T-14 T-15 T-16 T-17–27 T-28–38 T-30–33 T-34–35 T-36–37 T-38 T-39–42 T-43–48 T-49–57 T-50–52 T-53 T-54–57 T-59–74 T-60–64 T-65 T-66 T-67 T-68–74 T-75–96 T-76–78 T-79 T-80 T-81 T-82 T-83 T-84–86 T-87–98 T-99–101 T-102 T-103–107 T-108–109 T-110–111 T-112–113 T-114–117 T-118 Index Product Kellems Wire Mesh Grips Pulling Grips DUA-PULL® Grips DUA-PULL® Feed Tube Overhead Multiple Strength Underground Pulling K-Type T-Type Special Purpose Non-Conductive Slack Grip Closed Mesh, Split Mesh Low Tension Light Duty Junior Wire Rope Splicing Cable Splicing Tools and Bands Swivels and Links Pulling Grip Technical Information Support Grips Standard Support Heavy Support Service Drop Bus Drop Conduit Riser Support Grip Technical Information Fiber Optic Cable Grips Pulling Support Fiber Optic Cable Grips Technical Information Strain Relief for Flexible Cord Deluxe Cord Grips Adaptors for Multi Pin Circular Connectors I-Grips Dust Tight Strain Relief Grips Strain Relief for Flexible Cord Technical Information Cord Connectors for Flexible Cord Straight Male Cord Connectors 45° Male Cord Connectors 90° Male Cord Connectors Straight Female & Underground Feeder Low Profile Straight Male NPT & PG Thread Accessories Hubbell Juniors Miniature Cord Connectors Cord Connectors and Hubbell Juniors Technical Information Strain Relief for Conduit Grips Hose Containment Grips Strain Relief for Conduit Grips Technical Information Non-Metallic Liquid Tight Conduit & Tubing Non-Metallic Liquid Tight Fittings Metallic Liquid Tight Fittings Non-Metallic Liquid Tight Conduit, Tubing & Fittings Metallic Liquid Tight Fittings Wire Management Products Section T Wire Management Products Support Grip Deluxe Cord Grip Seal-Tite® Conduit Grip Seal-Tite® Conduit Grip Support Grip Strain Relief Grip Pulling Grip Kellems® Grips Support Grip T-2 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Overhead Pulling Grip Conduit Riser Grip Deluxe Cord Grip Strain Relief Grip Bus Drop Grip Deluxe Cord Grip Hose Containment Grip Cord Connector Support Grip Underground Pulling Grip Kellems® Grips Dimensions in Inches (mm) www.hubbell-wiring.com T-3 Wire Management Products Pulling Grips Kellems® Pulling Grips Overhead, Underground, Commercial Construction, Specialty Wire Management Products Kellems® Pulling Grips Overhead, Underground, Commercial Construction, Special Flexible or rotating eyes will mate easily with line stringing swivels and links for attachment to pulling lines. They have great strength for trouble free pulling jobs. Shoulder protectors contain the cable inside the grip and smooth the passage of the grip over line stringing blocks or conduit bends. They protect the leading edge of the grip from abrasion. The galvanized steel mesh grip provides strength for secure pulling jobs and a slim profile with little build-up. It has flexibility to follow cable path. The multiweave styles available add strength for big pulling jobs and provide positive gripping power. Endless weave allows easy installation onto cable. It has a snag-free low profile. Reusable tool. Pulling Grips Dimensions in Inches (mm) www.hubbell-wiring.com 2 Wire Management Products Pulling Grips Overhead Pulling Flexible Eye, Double Weave Mesh, Galvanized Steel DUA-PULL® Grips Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-17 through T-27. DUA-PULL Grips DUA-PULL Pulling Grips are the highest strength pulling grips manufactured for overhead transmission line stringing applications. They have a dual function, not provided by any other grip, of working with both bare and insulated conductors and synthetic rope. M E B DUA-PULL Grips Diameter Range Approx. Conductor Rope* Breaking Diameter Diameter Strength E M Inches (cm) Inches (cm) Lbs. (N) Inches (cm) Inches (cm) .19”-.37” (.48-.94) .25”-.65” (.63-1.65) 6,500 (28,912) 10” (25.40) 24” (60.96) .38”-.62” (.97-1.57) .50”-.90” (1.27-2.29) 14,000 (62,227) 12” (30.48) 36” (91.44) .63”-.87” (1.60-2.21) .75”-1.10” (1.90-2.79) 20,000 (88,960) 13” (33.02) 48” (121.92) .88”-1.12” (2.24-2.84) 1.00”-1.50” (2.54-3.81) 30,600 (136,109) 15” (38.10) 60” (152.40) 1.13”-1.37” (2.87-3.48) 1.25”-1.70” (3.17-4.32) 46,800 (208,166) 18” (45.72) 76” (193.04) 1.38”-1.90” (3.51-4.38) 1.50”-2.10” (3.81-5.33) 66,500 (245,792) 24” (60.96) 89” (226.06) E- Eye length M-Mesh length at nominal diameter *For rope, select smallest size grip which meets required work load. **Add to cable or rope diameter. Eye B Diameter Inches (cm) .22” (.55) .375” (.95) .437” (1.11) .500” (1.27) .625” (1.59) .750” (1.90) Diameter Over Cable & Grip** Inches (cm) .20” (.51) .280” (.71) .360” (.91) .500” (1.27) .625” (1.59) .750” (1.90) Color Code Black Dark Green Red Dark Blue Yellow Aluminum Catalog Numbers 033271037 033271038 033271039 033271040 033271041 033271042 Pulling Grips DUA-PULL Feed Tube T-6 For Use With DUAPULL Grip Rope Diameter Inches (cm) Feed Tube Length Inches (cm) Catalog Numbers 033271037 033271038 033271039 033271040 033271041 033271042 .25”-.65” (.63-1.65) .50”-.90” (1.27-2.29) .75”-1.10” (1.90-2.79) 1.00”-1.50” (2.54-3.81) 1.25”-1.70” (3.17-4.32) 1.50”-2.10” (3.81-5.33) 28” (71.12) 40” (101.60) 52” (132.08) 67” (170.18) 83” (210.82) 96” (243.84) 091061043 091061044 091061045 091061046 091061047 091061048 www.hubbell-wiring.com Dimensions in Inches (mm) Overhead Pulling Flexible or Rotating Eye, Triple, Double, Single Weave, Galvanized Steel Multiple Strength Grips Multiple Strength Style Grips Multiple Strength Pulling Grips are designed for pulling ACSR, aluminum or copper bare conductor, ground wires, messenger strands, wire rope and insulated cables. Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-17 through T-27. E M Wire Management Products Pulling Grips Multiple Strength Grip-Rotating Eye Cable Diameter Range Inches (cm) .25”-.49” (.63-1.24) .50”-.74” (1.27-1.88) .75”-.99” (1.90-2.51) 1.00”-1.24” (2.54-3.15) 1.25”-1.49” (3.17-3.78) 1.50”-1.74” (3.81-4.42) 1.75”-2.24” (4.44-5.69) 2.00”-2.49” (5.08-6.32) 2.50”-2.99” (6.35-7.59) 3.00”-3.49” (7.62-8.86) 3.50”-3.99” (8.89-10.13) E-Eye length Approx. Breaking Strength Lbs. (N) 6,800 (20,567) 10,000 (44,480) 14,400 (64,051) 24,600 (109,420) 30,600 (136,109) 30,600 (136,109) 48,000 (213,504) 48,000 (213,504) 48,000 (213,504) 48,000 (213,504) 48,000 (213,504) E Inches (cm) 5” (12.70) 6” (15.24) 6” (15.24) 8” (20.32) 8” (20.32) 9” (22.86) 10” (25.40) 10” (25.40) 10” (25.40) 10” (25.40) 10” (25.40) M Inches (cm) 26” (66.04) 32” (81.28) 41” (104.14) 52” (132.08) 56” (142.24) 60” (152.40) 70” (177.80) 50” (127.00) 52” (132.08) 54” (137.16) 58” (142.24) Rotating Eye Diameter Inches (cm) 7 /8” (2.22) 1” (2.54) 1” (2.54) 13/8” (3.49) 15/8” (4.13) 17/8” (4.76) 17/8” (4.76) 17/8” (4.76) 17/8” (4.76) 17/8” (4.76) 17/8” (4.76) Color Code Dark Green Brown Light Blue Gold Black Red Dark Blue Yellow Orange Aluminum Light Green Catalog Numbers 03302016 03302018 03302020 03302022 03302024 03302026 03302028 03302066 03302097 033021030 033021031 M-Mesh length at nominal diameter E M A Multiple Strength Grip-Flexible Eye Dimensions in Inches (mm) M Inches (cm) 26” (66.04) 32” (81.28) 41” (104.14) 52” (132.08) 56” (142.24) 60” (152.40) 70” (177.80) 50” (127.00) 52” (132.08) 54” (137.16) 58” (142.24) www.hubbell-wiring.com A-Eye Diameter Inches (cm) 1 /4” (.63) 5 /16” (.79) 3 /8” (.95) 1 /2” (1.27) 1 /2” (1.27) 1 /2” (1.27) 5 /8” (1.59) 5 /8” (1.59) 5 /8” (1.59) 5 /8” (1.59) 5 /8” (1.59) Color Code Dark Green Brown Light Blue Gold Black Red Dark Blue Yellow Orange Aluminum Light Green Catalog Numbers 03302044 03302046 03302048 03302050 03302052 03302054 03302056 033021078 033021079 033021080 033021081 T-7 Pulling Grips Cable Diameter Approx. Breaking E Range Inches (cm) Strength Lbs. (N) Inches (cm) .25”-.49” (.63-1.24) 6,800 (20,567) 9” (22.86) .50”-.74” (1.27-1.88) 10,000 (44,480) 9” (22.86) .75”-.99” (1.90-2.51) 14,400 (64,051) 11” (27.94) 1.00”-1.24” (2.54-3.15) 24,600 (109,420) 12” (30.48) 1.25”-1.49” (3.17-3.78) 30,600 (136,109) 12” (30.48) 1.50”-1.74” (3.81-4.42) 30,600 (136,109) 12” (30.48) 1.75”-2.24” (4.44-5.69) 48,000 (215,504) 18” (45.72) 2.00”-2.49” (5.08-6.32) 48,000 (215,504) 18” (45.72) 2.50”-2.99” (6.35-7.59) 48,000 (215,504) 18” (45.72) 3.00”-3.49” (7.62-8.86) 48,000 (215,504) 18” (45.72) 3.50”-3.99” (8.89-10.13) 48,000 (215,504) 18” (45.72) E-Eye length M-Mesh length at nominal diameter Wire Management Products Pulling Grips Underground Pulling Rotating Eye, Double Weave, Galvanized Steel K-Type Grips Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-17 through T-27. K-Type Grips Kellems® Rotating Eye, K-Type Pulling Grips are made of high strength galvanized steel strand. All Grips feature double weave mesh for greater strength and added mesh contact on the cable, to handle longer or heavier pulling jobs. The forged eye mates easily with a swivel or shackle. E M K-Type Grips Cable Diameter Range Inches (cm) Approx. Breaking Strength Lbs. (N) E Inches (cm) M Inches (cm) Rotating Eye Diameter Inches (cm) Catalog Numbers 5,600 (24,909) 6,800 (30,246) 6,800 (30,246) 12,800 (56,934) 12,800 (56,934) 16,400 (72,941) 27,200 (120,986) 33,000 (146,784) 41,000 (182,368) 48,000 (213,504) 48,000 (213,504) 5” (12.70) 5” (12.70) 6” (15.24) 7” (17.78) 7” (17.78) 7” (17.78) 8” (20.32) 10” (25.40) 10” (25.40) 10” (25.40) 10” (25.40) 11” (27.94) 11” (27.94) 20” (50.80) 20” (50.80) 21” (53.34) 25” (63.50) 26” (66.04) 28” (71.12) 30” (76.20) 32” (81.28) 33” (83.82) /8” (2.22) /8” (2.22) 1” (2.54) 13/8” (3.94) 13/8” (3.94) 13/8” (3.94) 15/8” (4.13) 17/8” (4.76) 17/8” (4.76) 17/8” (4.76) 17/8” (4.76) 03301001 03301002 03301013 03301014 03301016 03301017 03301018 03301019 03301020 03301021 033011017 5” (12.70) 5” (12.70) 6” (15.24) 7” (17.78) 7” (17.78) 9” (22.86) 10” (25.40) 10” (25.40) 10” (25.40) 10” (25.40) 10” (25.40) 10” (25.40) 10” (25.40) 16” (40.64) 16” (40.64) 32” (81.28) 33” (83.82) 34” (86.36) 36” (91.44) 38” (96.52) 39” (99.06) 41” (104.14) 42” (106.68) 58” (147.32) 60” (152.40) 66” (167.64) /8” (2.22) /8” (2.22) 1” (2.54) 13/8” (3.49) 13/8” (3.49) 15/8” (4.13) 17/8” (4.76) 17/8” (4.76) 17/8” (4.76) 17/8” (4.76) 17/8” (4.76) 17/8” (4.76) 17/8” (4.76) 03301011 03301012 03301024 03301025 03301026 03301027 03301028 03301029 03301030 03301031 03301039 03301047 03301045 Short .50”-.61” (.27-1.55) .62”-.74” (1.57-1.88) .75”-.99” (1.90-2.51) 1.00”-1.24” (2.54-3.15) 1.25”-1.49” (3.17-3.78) 1.50”-1.99” (3.81-5.05) 2.00”-2.49” (5.08-6.32) 2.50”-2.99” (6.35-7.59) 3.00”-3.49” (7.62-8.86) 3.50”-3.99” (8.89-10.13) 4.00”-4.49” (10.16-11.40) 7 7 Pulling Grips Standard .50”-.61” (.27-1.55) 5,600 (24,909) .62”-.74” (1.57-1.88) 6,800 (30,246) .75”-.99” (1.90-2.51) 9,600 (42,700) 1.00”-1.49” (2.54-3.78) 16,400 (72,947) 1.50”-1.99” (3.81-5.05) 16,400 (72,947) 2.00”-2.49” (5.08-6.32) 27,200 (120,986) 2.50”-2.99” (6.35-7.59) 33,000 (146,784) 3.00”-3.49” (7.62-8.86) 41,000 (182,368) 3.50”-3.99” (8.89-10.13) 48,000 (213,504) 4.00”-4.49” (10.16-11.40) 48,000 (213,504) 4.50”-4.99” (11.43-12.67) 48,000 (213,504) 5.00”-5.99” (12.70-15.21) 48,000 (213,504) 6.00”-6.99” (15.24-17.75) 48,000 (213,504) E-Eye length M-Mesh length at nominal diameter 7 7 Note: Refer to page T-26 for multiple cables in a single pulling grip. T-8 www.hubbell-wiring.com Dimensions in Inches (mm) Underground Pulling Flexible Eye, Double Weave, Galvanized Steel T-Type Grips T-Type Grips Kellems® Flexible T-Type Pulling Grips are made of high strength galvanized steel strand. They feature double weave mesh for positive holding power in medium to heavy pulling jobs. The grip eye will easily attach to a swivel. Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-17 through T-27. Wire Management Products Pulling Grips E M T-Type Grips Cable Diameter Range Inches (cm) Approx. Breaking Strength Lbs. (N) E Inches (cm) M Inches (cm) Catalog Numbers 4,500 (20,016) 5,600 (24,909) 6,800 (30,246) 9,600 (42,701) 16,400 (72,947) 18,500 (82,288) 24,500 (108,976) 24,500 (108,976) 31,000 (137,888) 8” (20.32) 8” (20.32) 9” (22.86) 9” (22.86) 11” (27.94) 12” (30.48) 12” (30.48) 14” (35.56) 14” (35.56) 21” (53.34) 24” (60.96) 24” (60.96) 24” (60.96) 24” (60.96) 24” (60.96) 24” (60.96) 24” (60.96) 26” (66.04) 033041082 033041083 033041084 033041085 033041086 033041087 033041088 033041089 033041090 .75”-.99” (1.90-2.51) 6,800 (30,246) 1.00”-1.49” (2.54-3.78) 9,600 (42,701) 1.50”-1.99” (3.81-5.05) 16,400 (72,947) 2.00”-2.49” (5.08-6.32) 18,500 (82,788) 2.50”-2.99” (6.35-7.59) 24,500 (108,976) 3.00”-3.49” (7.62-8.86) 24,500 (108,976) 3.50”-3.99” (8.89-10.13) 31,000 (137,888) E-Eye length M-Mesh length at nominal diameter 9” (22.86) 9” (22.86) 11” (27.94) 12” (30.48) 12” (30.48) 14” (35.56) 14” (35.56) 36” (91.44) 36” (91.44) 36” (91.44) 36” (91.44) 36” (91.44) 36” (91.44) 40” (101.60) 033041091 033041092 033041093 033041094 033041095 033041096 033041097 Short .50”-.61” (1.27-1.55) .62”-.74” (1.57-1.88) .75”-.99” (1.90-2.51) 1.00”-1.49” (2.54-3.78) 1.50”-1.99” (3.81-5.05) 2.00”-2.49” (5.08-6.32) 2.50”-2.99” (6.35-7.59) 3.00”-3.49” (7.62-8.86) 3.50”-3.99” (8.89-10.13) Standard Note: Refer to page T-26 for multiple cables in a single pulling grip. Pulling Grips Dimensions in Inches (mm) www.hubbell-wiring.com T-9 Wire Management Products Pulling Grips Special Purpose Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-17 through T27. M E A Non-Conductive Grips, Single Eye, Double Weave, Non-Metallic Kellems® Non-Conductive Pulling Grips, made of a high strength, non-conductive aramid fiber, are available for pulling single cable or cable bundles. Their braided double weave design adds strength and positive holding power. Cable Diameter Range Inches (cm) Approx. Breaking Strength Lbs. (N) .50”-.62” (1.27-1.57) 4,000 (17,782) 5.5” (13.97) 24” (60.96) .44” (1.12) Green 03628001 .63”-.74” (1.60-1.88) 5,000 (22,240) 5.5” (13.97) 26” (66.04) .44” (1.12) Yellow 03628002 .75”-.99” (1.90-2.51) 6,000 (26,688) 6.0” (15.24) 31” (78.74) .63” (1.60) Red 03628003 1.00”-1.24” (2.54-3.15) 6,000 (26,688) 6.5” (16.51) 36” (91.44) .63” (1.60) Blue 03628004 E M Inches (cm) Inches (cm) A Color Catalog Inches (cm) Code Numbers 1.25”-1.49” (3.17-3.78) 6,000 (26,688) 6.7” (17.02) 41.5” (105.41) .63” (1.60) E-Eye length M-Mesh length at nominal diameter M White 03628005 E Slack Grip-Closed Mesh, Single Eye, Double Weave, Galvanized Steel Pulling Grips Slack Pulling Grips are offered in three styles made of galavanized steel. The closed type is used when the cable end is accessible. When not, there are split lace and split rod closing styles. All grips feature a single offset eye for easy attachment to a pulling line. Cable Diameter Range Inches (cm) Approx. Breaking E M Strength Lbs. (N) Inches (cm) Inches (cm) Catalog Numbers .75”-.99” (1.90-2.51) 2,600 (11,565) 7” (17.78) 12” (30.48) 03308003 1.00”-1.24” (2.54-3.15) 4,000 (17,792) 8” (20.32) 15” (38.10) 03308004 1.25”-1.49” (3.17-3.78) 5,400 (24,109) 8” (20.32) 16” (40.46) 03308005 1.50”-1.74” (3.81-4.42) 6,600 (29,357) 8” (20.32) 20” (43.18) 03308006 1.75”-1.99” (4.44-5.05) 10,000 (44,480) 10” (25.40) 18” (45.72) 03308007 2.00”-2.49” (5.08-6.32) 11,000 (48,928) 10” (25.40) 19” (48.26) 03308008 2.50”-2.99” (6.35-7.59) 11,000 (48,928) 10” (25.40) 20” (50.80) 03308009 3.00”-3.49” (7.62-8.86) 14,500 (64,496) 12” (30.48) 21” (53.34) 03308010 3.50”-3.99” (8.89-10.13) 14,500 (64,496) 12” (30.48) E-Eye length M-Mesh length at nominal diameter 22” (55.88) 03308011 Standard Note: Refer to page T-26 for multiple cables in a single pulling grip. T-10 www.hubbell-wiring.com Dimensions in Inches (mm) Special Purpose M Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-17 through T27. E Wire Management Products Pulling Grips Slack Grip-Split Mesh, Rawhide Lace Closing, Single Eye, Double Weave, Galvanized Steel Cable Diameter Range Inches (cm) Approx. Breaking E M Strength Lbs. (N) Inches (cm) Inches (cm) Catalog Numbers 2,500 (11,120) 3,500 (15,568) 4,000 (17,792) 4,000 (17,792) 4,000 (17,792) 4,000 (17,792) 4,000 (17,792) 7” (17.78) 8” (20.32) 8” (20.32) 9” (22.86) 10” (25.40) 10” (25.40) 10” (25.40) 12” (30.48) 15” (38.10) 16” (40.64) 17” (43.18) 18” (45.72) 19” (48.26) 20” (50.80) 03309003 03309004 03309005 03309006 03309007 03309008 03309009 4,000 (17,792) 4,000 (17,792) 4,000 (17,792) 4,000 (17,792) 4,000 (17,792) 9” (22.86) 10” (25.40) 10” (25.40) 12” (30.48) 12” (30.48) 25” (63.50) 26” (66.04) 29” (73.66) 32” (81.28) 35” (88.90) 03309015 03309016 03309017 03309018 03309019 Standard .75”-.99” (1.90-2.51) 1.00”-1.24” (2.54-3.15) 1.25”-1.49” (3.17-3.78) 1.50”-1.74” (3.81-4.42) 1.75”-1.99” (4.44-5.05) 2.00”-2.49” (5.08-6.32) 2.50”-2.99” (6.35-7.59) Slack Pulling Grips are offered in three styles made of galvanized steel. The closed type is used when the cable end is accessible. When not accessible, there are split lace and split rod closing styles. All grips feature single offset eye for easy attachment to a pulling line. Long 1.50”-1.99” (3.81-5.05) 2.00”-2.49” (5.08-6.32) 2.50”-2.99” (6.35-7.59) 3.00”-3.49” (7.62-8.86) 3.50”-3.99” (8.89-10.13) M E Slack Grip-Split Mesh, Rod Closing, Single Eye, Single Weave, Galvanized Steel M Inches (cm) 6” (15.24) 8” (20.32) 10” (25.40) 12” (30.48) 14” (35.56) 15” (38.10) 16” (40.64) 19” (48.26) 20” (50.80) 21” (53.34) 24” (60.96) Catalog Numbers 03310001 03310002 03310003 03310004 03310005 03310006 03310007 03310008 03310009 03310010 03310011 Pulling Grips Cable Diameter Approx. Breaking E Range Inches (cm) Strength Lbs. (N) Inches (cm) .50”-.61” (1.27-1.55) 1,500 (6,672) 7” (17.78) .62”-.74” (1.57-1.88) 1,800 (8,006) 7” (17.78) .75”-.99” (1.90-2.51) 2,200 (9,786) 7” (17.78) 1.00”-1.24” (2.54-3.15) 3,400 (15,123) 8” (20.32) 1.25”-1.49” (3.17-3.78) 4,500 (20,016) 8” (20.32) 1.50”-1.74” (3.81-4.42) 5,800 (25,798) 9” (22.86) 1.75” -1.99” (4.44-5.05) 7,600 (33,805) 10” (25.40) 2.00”-2.49” (5.08-6.32) 9,000 (40,032) 10” (25.40) 2.50”-2.99” (6.35-7.59) 11,000 (48,928) 10” (25.40) 3.00”-3.49” (7.62-8.86) 12,000 (53,376) 12” (30.48) 3.50”-3.99” (8.89-10.13) 12,000 (53,376) 12” (30.48) E-Eye length M-Mesh length at nominal diameter Note: Refer to page T-26 for multiple cables in a single pulling grip. Dimensions in Inches (mm) www.hubbell-wiring.com T-11 Wire Management Products Pulling Grips Low Tension Flexible Eye, Single Weave, Galvanized Steel Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-17 through T27. E M Light Duty Grips Light Duty Pulling Grips are made of galvanized steel in a single weave construction. They feature a flexible eye for easy attachment to a pulling line. Cable Diameter Range Inches (cm.) Approx. Breaking E M Strength Lbs. (N) Inches (cm) Inches (cm) Catalog Numbers 2,800 (12,454) 2,800 (12,454) 4,000 (17,792) 5,300 (23,574) 5,300 (23,574) 6,800 (30,246) 8,500 (37,808) 8,500 (37,808) 5” (12.70) 5” (12.70) 6” (15.24) 7” (17.78) 7” (17.78) 8” (20.32) 9” (22.86) 9” (22.86) 11” (27.94) 11” (27.94) 12” (30.48) 13” (33.02) 14” (35.56) 15” (38.10) 17” (43.18) 18” (45.72) 03303001 03303002 03303003 03303004 03303005 03303006 03303007 03303008 2,800 (12,454) 2,800 (12,454) 4,000 (17,792) 6,800 (30,246) 6,800 (30,246) 6,800 (30,246) 8,500 (37,808) 10,600 (47,149) 14,700 (65,386) 14,700 (65,386) 5” (12.70) 5” (12.70) 6” (15.24) 7” (17.78) 7” (17.78) 8” (20.32) 9” (22.86) 9” (22.86) 10” (25.40) 10” (25.40) 16” (40.64) 16” (40.64) 20” (50.80) 20” (50.80) 21” (53.34) 23” (58.42) 25” (63.50) 27” (68.58) 30” (76.20) 32” (81.28) 03303010 03303011 03303012 03303013 03303015 03303016 03303017 03303018 03303019 03303029 Short .50”-.61” (1.27-1.55) .62”-.74” (1.57-1.88) .75”-.99” (1.90-2.51) 1.00”-1.24” (2.54-3.15) 1.25”-1.49” (3.17-3.78) 1.50”-1.74” (3.81-4.42) 1.75”-1.99” (4.44-5.05) 2.00”-2.49” (5.08-6.32) Standard Junior Pulling Grips feature a strong galvanized steel, single weave mesh. A flexible eye easily attaches to a pulling line, snake or fish tape. .50”-.61” (1.27-1.55) .62”-.74” (1.57-1.88) .75”-.99” (1.90-2.51) 1.00”-1.24” (2.54-3.15) 1.25”-1.49” (3.17-3.78) 1.50”-1.99” (3.81-5.05) 2.00”-2.49” (5.08-6.32) 2.50”-2.99” (6.35-7.59) 3.00”-3.49” (7.62-8.86) 3.50”-3.99” (8.89-10.13) E M Junior Grip Kit Junior Grip Kit contains 6 grips, one of each size. Catalog number 033051114. Pulling Grips Junior Pulling Grips Note: Refer to page T-27 for building wire selection chart. Note: Refer to page T-26 for multiple cables in a single pulling grip. T-12 Cable Diameter Approx. Breaking E Range Inches (cm) Strength Lbs. (N) Inches (cm) .19”-.24” (.48-.61) 400 (1,779) 31/4” (8.25) .25”-.36” (.63-.91) 450 (2,002) 31/4” (8.25) .37”-.49” (.94-1.24) 900 (4,003) 33/4” (9.52) .50”-.61” (1.27-1.55) 1,300 (5,782) 41/4” (10.79) .62”-.74” (1.57-1.88) 1,950 (8,674) 5” (12.70) .75”-.99” (1.90-2.51) 2,800 (12,454) 53/4” (14.60) 1.00”-1.24” (2.54-3.15) 3,900 (17,347) 61/2” (16.51) E-Eye length M-Mesh length at nominal diameter. *Not included in Junior Grip Kit, 033051114. www.hubbell-wiring.com M Inches (cm) 41/4” (10.79) 41/4” (10.79) 7” (17.78) 81/2” (21.59) 10” (25.40) 10” (25.40) 111/2” (29.21) Model J19 J25 J37 J50 J62 J75 J100 Catalog Numbers 03305011* 03305001 03305002 03305003 03305004 03305005 03305006 Dimensions in Inches (mm) Wire Rope Splicing Triple, Double, Single Weave, Galvanized Steel Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-17 through T27. Wire Management Products Splicing Grips Regular Wire Rope Grips Cable Diameter Range Inches (cm) Approx. Breaking Strength Lbs. (N) Approx. Length Of Grip Feet (m) Catalog Numbers /16”- 5/8” (1.43-1.59) 7,500 (33,360) 5.75 (1.75) 03316001 3 /4”- 7/8” (1.90-2.22) 12,500 (55,600) 6.75 (1.90) 03316002 1”-11/8” (2.54-2.86) 16,000 (71,168) 7.00 (2.13) 03316003 11/4”- 13/8” (3.17-3.49) 20,000 (88,960) 8.00 (2.44) 03316004 1 /8”- 1 /2” (3.49-3.81) 20,000 (88,960) 8.00 (2.44) 03316006 9 3 1 Kellems® Wire Rope Grips are made of high strength galvanized steel strand in a construction of triple, double and single weave for superior gripping ability. They are available with or without a rotating barrel which will help eliminate twist in the old rope from being transferred to the new rope. Rotating Wire Rope Grips Cable Diameter Range (cm) Approx. Breaking Approx. Length Barrel Dimensions Strength Lbs. (N) Of Grip Feet (m) Lgth. x O.D. Inches (cm) /16”- 1/2” (1.11-1.27) 5,000 (22,240) 5.33 (1.63) 3.00” (7.62) x .87” (2.21) 03317001 /16”- 5/8” (1.43-1.59) 7,500 (33,360) 5.83 (1.78) 4.25” (10.79) x 1.00” (2.54) 03317002 /4”- 7/8” (1.90-2.22) 12,500 (55,600) 6.50 (1.98) 4.25” (10.79) x 1.00” (2.54) 03317003 1”- 1 /8” (2.54-2.86) 16,000 (71,169) 8.67 (2.64) 5.50” (13.97) x 1.37” (3.48) 03317004 11/4”- 13/8” (3.17-3.49) 20,000 (88,960) 9.00 (2.74) 5.50” (13.97) x 1.37” (3.48) 03317005 11/2”- 13/4” (3.81-4.44) 20,000 (88,960) 11.00 (3.35) 5.50” (13.97) x 1.37” (3.48) 03317006 7 9 3 1 Catalog Numbers Pulling Grips Dimensions in Inches (mm) www.hubbell-wiring.com T-13 Wire Management Products Splicing Grips Cable Splicing Double Weave, Galvanized Steel / Single Weave, Galvanized Steel Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-17 through T-27. Splicing Grip Splicing Grips are made of galvanized steel in double weave mesh construction. They are available in various lengths and sizes to suit most applications. Double Weave Tube Cable Diameter Range Inches (cm) Approx. Breaking Strength Lbs. (N) Mesh Length Inches (cm) 18” (45.72) 24” (60.96) 36” (91.44) 48” (121.92) 72” (182.88) .37”-.49” (.94-1.24) .50”-.61” (1.27-1.55) .62”-.74” (1.57-1.88) .75”-.99” (1.90-2.51) 1.00”-1.49” (2.54-3.78) 3,500 (15,568) 3,500 (15,568) 4,400 (19,571) 7,500 (33,360) 10,000 (44,480) 01304064 01304011 • • • 01304009 01304013 013041234 • • • 01304010 01304054 01304017 01304037 • 01304015 01304055 01304029 013041333 Catalog Numbers 013041330 • • • • Junior Splicing Grips, Single Weave Junior Splicing Grips are made of galvanized steel and are designed for use in very light duty and small splicing jobs. Splicing Grips Junior Tube Cable Diameter Range Inches (cm) .18”-.24” (.49-.61) .25”-.36” (.63-.91) T-14 Approx. Breaking Strength Lbs. (N) 400 (1,779) 400 (1,779) Length @ Nom Diameter Inches (cm) 7” (17.78) 8” (20.32) www.hubbell-wiring.com Catalog Numbers 01301008 01301013 Dimensions in Inches (mm) Wire Management Products Accessories Tools and Bands Punch-Lok® Bands Punch-Lok Bands are applied over the tail of a grip to prevent the mesh from being tripped or pulled loose. Also, they assure full gripping action by locking the mesh of the tail in tight contact with the cable or rope. Punch-Lok Bands Grip Banding Range Inches (cm) 1 /4 “-11/8” (.63-2.86) 11/8”-15/8” (2.86-4.13) 15/8”-21/4” (4.13-5.71) 21/4”-31/2” (5.71-8.89) 31/2”-5” (8.89-12.70) Band Width Inches (cm) 3 /8” (.95) 3 /8” (.95) 5 /8” (1.59) 5 /8” (1.59) 5 /8” (1.59) Band Inside Diameter Inches (cm) 13/8” (3.49) 2” (5.08) 21/2” (6.35) 4” (10.16) 6” (15.24) Model Catalog Numbers 0-311 0-316 0-10 0-16 0-24 20320050 20320051 20320052 20320053 20320054 Accessories Punch-Lok Tools Description P-1 Heavy Duty. P-38 Light Duty. Bands & Tools ®Punch-Lok Catalog Numbers 20320048 20320047 is a registered trademark of Punch-Lok Inc. Dimensions in Inches (mm) www.hubbell-wiring.com T-15 Wire Management Products Accessories Swivels and Links Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-17 through T-27. 20308001 Swivels Swivels are essential to the efficiency and safety of any high tension application. They are particularly important where continuous pulls develop higher and higher torque levels. Torque is intensified by the pull-resistance of the cable itself and the resistance of the high tension controlling equipment regulating line sag. Ball bearing swivels release torque and prevent it from reaching dangerous levels that can damage the cable and obstruct the lines as it passes through sheaves, wheels or blocks. C B A E D F G Swivels Approx. Breaking Strength Lbs. (N) A 7 5,400 (24,019) /8” (2.22) 12,000 (53,376) 11/4” (3.17) 22,500 (100,080) 17/16” (3.65) 30,000 (133,440) 17/8” (4.76) 48,000 (213,504) 27/16” (6.19) B 211/32” (5.95) 321/32” (9.29) 4” (10.16) 57/16” (13.81) 77/8” (20.00) Dimensions in Inches (cm) C D E 3 5 /8” (.95) /16” (.79) 33/32” (7.86) 11 7 19 /16” (1.11) /32” (1.51) 4 /32” (9.29) 9 19 /16” (1.43) /32” (1.51) 51/8” (13.02) 3 /4” (1.90) 71/16” (17.94) 13/16” (2.06) 103/16” (25.88) 11/8” (2.86) 1” (2.54) Swivels & Links Links The bullet nose Link, with clevises at 90°, provides a fast, economical method of connecting pulling lines. The result is a reliable pulling line connector with adequate load ratings for the tensions employed in line stringing. Because of its shorter length, the Link contoured bullet nose connector is able to pass through stringing sheaves smoothly and easily without damage. Links Approx. Breaking Strength Lbs. (N) A B 5,400 (24,019) 7/8” (2.22) 15/16” (3.33) 12,000 (53,376) 11/4” (3.17) 13/4” (4.44) T-16 F 5 /16” (.79) 3 /8” (.95) 7 /16” (1.11) 5 /8” (1.59) 7 /8” (2.22) G 15 /32” (1.19) 11 /16” (1.75) 13 /16” (2.06) 15 /16” (2.38) 19/16” (3.97) Catalog Model Numbers A-13L BB-13L B-13L C-13L D-13L 20308001 20308002 20308003 20308004 20308005 C B 093011037 A E G F D Dimensions in Inches (cm) C D E F 5 21/16” (3.33) 3/8” (.95) /16” (.79) 5/16” (.79) 7 19 25/8” (6.67) /16” (1.11) /32” (1.51) 3/8” (.95) www.hubbell-wiring.com G 15 /32” (1.19) 11 /16” (1.75) Catalog Model PL-1/4 PL-3/8 Numbers 093011037 093011038 Dimensions in Inches (mm) Wire Management Products Kellems® Pulling Grips Technical Section Kellems Pulling Grips are reusable tools for pulling electrical cable, bare conductor or rope. They are easy and fast to install, providing the user with a smooth, slim profile that allows for easy passage through ducts, conduit, blocks and sheaves. Kellems Pulling Grips are made of the highest quality galvanized steel strand which assures the user of a long lasting grip. There is a Kellems Pulling Grip for every pulling job. Select The Correct Pulling Grip Each Kellems Grip is designed to work on a specific range of cable diameters. Step 1 Refer to the chart below to determine the style of grip best suited for your application. Step 2 Determine your cable outside diameter. Step 3 Find the grip size that encompasses your cable diameter. Step 4 Estimate the tension to be put on the grip, establish the working load you require and compare this to the listed approximate breaking strength of the grip to insure that the grip will be strong enough. Refer to page T-18 for safety and working load factors. Pulling Grip Selection Chart Grip Style DUA-PULL®, flexible eye Application Extra high strength overhead transmission line stringing for bare or insulated conductor and synthetic rope. Multiple strength, flexible eye Normal overhead transmission and distribution line stringing, for bare or insulated conductor. Multiple strength, forged eye Normal overhead transmission and distribution line stringing, for bare or insulated conductor. K-type grip, forged eye Underground power cables and communication lines. Service lines into factories. T-type grip, flexible eye Underground power cables and communication lines. Service lines into factories. Non-conductive flexible eye Pull insulated distribution cable into place. Universal slack, closed mesh Remove underground cable. For pulling slack in final placement of new cable when end of cable is available. Universal slack split mesh, Remove underground cable. For pulling slack in final placement of rawhide lace closing new cable when end of cable is not available. Universal slack, split mesh, Remove underground cable. For pulling slack in final placement of rod closing new cable when end of cable is not available, with rod closing for quick installation. Light duty, flexible eye Light pulling, underground electrical construction. Industrial plant wiring and rewiring jobs. Junior, flexible eye Connect bundled insulated building wire to a pulling tape. Pull wire through conduit. Regular and rotating wire rope Restring wire rope in cranes and oil rigs. Splicing Temporary splice for cable or wire rope. Accessories Tools, bands, swivels, links. Fiber Optic Cable Pulling Grips Pull fiber optic cable into place overhead, underground or through duct and conduit. Page Numbers T-6 T-7 T-7 T-8 T-9 T-10 T-10 T-11 T-11 T-12 T-12 T-13 T-14 T-15, T-16 T-50, T-51, T-52 Technical Data Dimensions in Inches (mm) www.hubbell-wiring.com T-17 Wire Management Products Kellems® Pulling Grips Technical Section Safety And Working Load Factors For Wire Mesh Grips The broad application of Kellems grips on a wide variety of objects requires that adequate safety factors be used to establish working loads. The approximate breaking strength of a Kellems grip represents an average calculation based on data established from actual direct tension testing done in our engineering laboratories. It is impossible to catalog or guarantee a safety factor suitable for all applications as operating conditions are never the same. The tension, diameter, movement, number of objects gripped, gripping surface, and the attachments used are just some of the factors which vary with each application. These factors, together with the effects of abrasion, corrosion, prior use or abuse and any other variables of a specific application, must be considered by the user and the grip replaced as appropriate. Where the conditions of the application are not well defined or known, or where risk of injury to persons or property is involved, a greater safety factor should be utilized. Under normal conditions, Kellems’ recommended factor of safety is five for catalog listed pulling grips, and ten for catalog listed support grips. The factory should be consulted for specific application recommendations where strength and holding power are important factors. Any warranty as to quality, performance or fitness for use of grips is always premised on the condition that the published breaking strengths apply only to new, unused grips, and that such products are properly stored, handled, used, maintained and inspected by the user at a frequency appropriate for the use and condition of the grip. Examples Grip Style Pulling Grips Support Grips Approx. Breaking Strength Lbs. (N) 27,200 (120,986) 1,610 (7,161) Safety Factor 5 10 Max. Rec. Load Lbs. (N) 5,440 (24,197) 161 (716) Catalog Numbers 03301027 02201018 The maximum recommended working load then is the tension to be exerted on the grip in application with a margin of safety to take care of unforeseen and unusual circumstances. It is the end-user’s decision to determine how much of a safety factor is acceptable to him. The metric unit of measure (force) for breaking strength and load is newtons (N). To convert from newtons to the metric unit of weight (kilograms) the conversion factor is 9.808 newtons/kilogram. Pulling Grip Materials Material Galvanized steel wire Technical Data Non-metallic strand Features High strength Not subject to continuous outside environment Superior flex life Non-conductive Corrosion resistant Moderate strength Product Group Pulling Grip Wire rope grips Splicing grips Non-conductive pulling grips Approvals CSA Certification is indicated on appropriate product catalog pages. T-18 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Kellems® Pulling Grips Technical Section Overhead Pulling DUA-PULL® Grips DUA-PULL Pulling Grips are the highest strength pulling grips manufactured for overhead transmission line stringing applications. They have a dual function of working with both bare and insulated conductors and synthetic rope, not provided by any other grip. Kellems’ patented two-over, two-under weave design gives exceptional strength and gripping ability by putting more steel mesh in contact with the cable or rope surfaces. THIS IS THE ONLY PULLING GRIP RECOMMENDED FOR USE ON SYNTHETIC ROPE. Application The DUA-PULL Grips are primarily used in overhead transmission line construction where loads and safety considerations require an extra high strength grip. They are most commonly used for attaching pulling lines to conductors, conductors to running boards and “double socking” for conductorto-conductor connections. The DUA-PULL line accommodates ACSR, ACAR, all aluminum and copper conductors. Also, the grips accommodate ground wires, messenger strands, wire ropes and synthetic ropes. Benefits • Made of high strength galvanized steel strand. • Recommended for pulling bare or insulated conductor, wire rope and synthetic rope. • DUA-PULL mesh design offers the greatest holding power for all pulling applications. • Each grip size is color coded for fast and accurate identification and selection. • Will mate with swivels and link-type connectors. See page T-16. Feed Tubes The Kellems Feed Tube is used when assembling synthetic rope into the DUA-PULL Grip. It is required on the largest two sizes of DUA-PULL Grips. Feed Tubes are available for use on all size DUA-PULL Grips. Benefits • Saves time, allowing fast, easy assembly. • No special skills required. • Completely reusable. Notes: 1. Do not run grips or swivels over bullwheels while under tension. 2. Two Punch-Lok® bands should be firmly attached approximately one inch and two inches (2.54cm and 5.08cm) from the grip’s tail. Banding is required to ensure maximum reliability and guard against accidental release. See page T-15. 3. Double braided rope, as 2-in-1 type, should be back spliced for approximately 2/3 of the mesh length for best gripping results. Grip size should be selected by diameter of back splice. Technical Data Dimensions in Inches (mm) www.hubbell-wiring.com T-19 Wire Management Products Kellems® Pulling Grips Technical Section Overhead Pulling Multiple Strength Grips Multiple Strength Pulling Grips are designed for pulling ACSR, aluminum or copper bare conductor, ground wires, messenger strands, wire rope and insulated cables. They are made of high strength galvanized steel strand and feature a multi-weave mesh construction of single, double and triple weave for firm holding power. Application Kellems Multiple Strength Grips are ideal for overhead transmission and distribution line stringing where moderate loading is anticipated. They are economical tools for attaching conductors to pulling lines and double socking for conductor-to-conductor connections. Rotating Eye Feature Multiple Strength Grips are available with a forged steel rotating eye which can be attached to a swivel. The forged eye is durable, compact and streamlined and will thread through blocks and sheaves without binding. The rotating eye is not a swivel and will not turn while under tension; It can turn to relieve pulling torque when tension is relaxed. If constant swivel action is required, a swivel should be used. For rotating eye dimensions, see page T-21. Swivels see page T-16. Flexible Eye Feature Multiple Strength Grips are also available with a flexible, patented wire rope eye. This compact eye will mate with a swivel, and pass through blocks and sheaves without binding. Benefits • Economical, high strength pulling tool. • Multi-weave construction provides greater strength and holding power. • Endless Weave Grip end lies flat on the cable and will not snag. Technical Data Notes: 1. Do not run grips or swivels over bullwheels while under tension. 2. Two Punch-Lok® bands should be firmly attached approximately one inch and two inches (2.54cm and 5.08cm) from the grip’s tail. Banding is required to ensure maximum reliability and guard against accidental release. See page T-15. T-20 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Kellems® Pulling Grips Technical Section Underground Pulling- K-Type and T-Type Grips K-Type Application Rotating Eye, K-Type Pulling Grips are specially designed for use in the installation of underground power cables, communication lines and service lines into factories, shopping centers, construction projects and general underground electrical construction. Rotating Eye Feature K-Type Grips come equipped with a forged steel rotating eye which can be attached to a swivel. The forged eye is durable, compact and streamlined, and will thread through blocks and sheaves without binding. The rotating eye is not a swivel and will not turn while under tension; it can turn to relieve pulling torque when the tension is relaxed. If constant swivel action is required, a swivel should be used. For swivels, see page T-16. Benefits • • • • An economical tool for pulling cable. Safe, rugged and dependable. Equipped with a rotating eye for spin out of pulling torque after load release. Easily installed and removed. Rotating Eye Dimensions Rotating Eye Dimensions inches (cm) 7 / 8” (2.22) 1” (2.54) 13/8” (3.49) 15/8” (4.13) 17 / 8” (4.76) 3/16 R. A 7 / 8” (2.22) 1” (2.54) 13/8” (3.49) 15/8” (4.13) 17 / 8” (4.76) B 9/32” (2.06) 1/2” (1.27) 1/2” (1.27) 5/8” (1.59) 21/32”(1.67) C 1/2” (1.27) 9/16” (1.43) 111/16” (1.75) 7 / 8” (2.22) 1” (2.54) D 7 / 8” (2.22) 13/16” (2.06) 1” (2.54) 13/16” (3.02) 13/8” (3.49) F 25/8” (6.67) 31/2” (8.89) 41/2” (11.43) 55/16” (13.49) 61/8” (15.56) T-Type Kellems Flexible T-Type Pulling Grips are made of high strength galvanized steel strand. They feature double weave mesh for positive holding power in medium to heavy pulling jobs. The grip eye will easily attach to a swivel. B F C A 1/8 R. D Application T-Type Pulling Grips are used for the installation of underground power cables, communication lines and service lines into factories, construction projects and for general underground electrical construction. Available in two mesh lengths, short for medium pulls, and standard for general purpose pulling. Benefits Will pull a single cable or cable bundles. Patented flexible eye design provides flexibility to follow line of pull. A dependable, reusable pulling tool. Easily installed and removed. Mates easily with a swivel. See page T-16. Dimensions in Inches (mm) www.hubbell-wiring.com Technical Data • • • • • T-21 Wire Management Products Kellems® Pulling Grips Technical Section Special Purpose Grips Non-Conductive Pulling Grips Kellems Non-Conductive Pulling Grips, made of a high strength, nonconductive aramid fiber, are available for pulling single cable or cable bundles. Their braided double weave design adds strength and positive holding power. Application Kellems Non-Conductive Pulling Grips were developed for use by utilities for pulling overhead distribution lines in close proximity to energized lines and hardware. Benefits • Color coded for fast on-site selection. • Extra flexibility for easy installation. • Non-metallic mesh provides for safe pulls over “hot” areas. • Pellethane jacketed aramid fiber mesh resists abrasion. • Grips are corrosion resistant. Notes: Taping is required to guard against accidental release and to insure maximum reliability. Apply vinyl plastic electrical tape starting 2” to 3” (5.08cm to 7.62cm) from the tail of the grip onto 2” to 3” (5.08cm to 7.62cm) of cable. Slack Pulling Grips Slack Pulling Grips are offered in three styles made of galvanized steel. The closed type is used when the cable end is accessible. When not, there are split lace and split rod closing styles. All grips feature single offset eye for easy attachment to a pulling line. Application Slack Grips are widely used in pulling slack for final placement of underground cable after it has been pulled in. They are also used for removing cable. Standard mesh lengths are generally used in restricted space for short pulls. Longer lengths are used for higher pulling loads where space is not restricted. Benefits • Easy attachment to pulling lines. • Reusable rawhide lace for lace closure. • Galvanized steel for strength. Technical Data Notes: 1. Replacement rawhide lace. Catalog number 20920002. 2. See page T-47 for lace and rod closing instructions. T-22 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Kellems® Pulling Grips Technical Section Commercial Construction/Light Duty Grips Light Duty Pulling Grips Light Duty Pulling Grips are made of galvanized steel in a single weave construction. They feature a flexible eye for easy attachment to a pulling line. Application Light duty grips are used in general underground electrical construction where pulling tensions are low. They are easy tools to use in wiring industrial plants and commercial buildings. Benefits • Perfect tools for light pulling jobs. • Installs easily on cable. • Strong, galvanized steel construction. Junior Duty Pulling Grips Junior Pulling Grips feature a strong galvanized steel, single weave mesh. A flexible eye easily attaches to a pulling line, snake or fish tape. Application Designed to pull building wire, Junior grips are safe tools to use in pulling wire at low tension through conduit during electrical construction. Benefits • • • • Installs easily over building wire. Strong secure grip. Reusable. Pulls single cable or cable bundles. Junior Grip Kit Junior Grip Kit contains 6 grips, one of each size. Catalog number 033051114. Note: Refer to page T-27 for building wire selection chart. Technical Data Dimensions in Inches (mm) www.hubbell-wiring.com T-23 Wire Management Products Kellems® Pulling Grips Technical Section Splicing Grips Wire Rope Splicing Kellems Wire Rope Grips are made of high strength galvanized steel strand in a construction of triple, double and single weave for superior gripping ability. They are available with or without a rotating barrel which will help eliminate twist in the old rope from being transferred to the new rope. Application Wire Rope Grips are used for changing wire rope on oil derricks, large cranes, overhead cranes and drag lines. It provides a quick, safe, inexpensive temporary splice. By installing the used wire rope in one end and the new rope in the other, the new wire rope can be pulled in as the old one is pulled out. Benefits • High strength for secure pulling. • Easy installation. • Flexible to pass through sheaves and blocks. Notes: 1. During installation each end of the grip should be banded over the rope to insure smooth passage through sheaves and to guard against accidental release. See page T-15 for end bands. 2. The rotating barrel is not a swivel and will not turn while under tension. It can turn to relieve pulling torque when tension is relaxed. Cable Splicing Splicing Grips are made of galvanized steel in double or single weave mesh construction. They are available in various lengths and sizes to suit most applications. Application Splicing Grips are used as a temporary splice for rope, cable or wire rope. They can also be used as cable reinforcement, and can act as a shield to protect cables and hoses from abrasion. Benefits • Easily installed or removed. • Galvanized steel construction for strength. • Flexible to follow cable path. Technical Data Notes 1. During installation, each end of the splicing grip should be taped down securely to the cable to in-sure smooth passage with the cable and guard against accidental release. 2. See page T-15 for end bands. T-24 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Kellems® Pulling Grips Technical Section Accessories Punch-Lok® Bands Punch-Lok Bands are applied over the tail of a grip to prevent the mesh from being tripped or pulled loose. Also, they assure full gripping action by locking the mesh of the tail in tight contact with the cable or rope. When the tail of a grip is the leading end, the bands are particularly important to prevent accidental release caused by tripping on obstructions. A conductor-to-conductor (double-socking) pulling operation is a good example: where two grips connect two conductors to form a temporary splice. Bands should be applied to the ends of the grips as illustrated herein. It is also common practice to tape over the banded tail area to assure smooth passage through the sheaves. The conductor should be installed in the grip up to the elbows of the aluminum shoulders in order to assure full and complete gripping action. The banding procedure is then followed as illustrated on page T-15. Note: In all cases two Punch-Lok Bands should be double wrapped approximately one inch to two inches (2.54cm to 5.08cm) from the grip’s tail. Banding is required to ensure maximum reliability and guard against accidental release. Swivels Swivels are essential to the efficiency and safety of any high tension application. They are particularly important where continuous pulls develop higher and higher torque levels. Torque is intensified by the pull-resistance of the cable itself and the resistance of the high tension controlling equipment regulating line sag. Ball bearing swivels release torque and prevent it from reaching dangerous levels that can damage the cable and obstruct the lines as it passes through sheaves, wheels or blocks. Technical Data Punch-Lok is a registered trademark of Punch-Lok Inc. ® Dimensions in Inches (mm) www.hubbell-wiring.com T-25 Wire Management Products Kellems® Pulling Grips Technical Section Multiple Cable Selection Charts for Cables of Equal Diameters For Pulling Grips* Caution: When a grip is used on multiple cables, the tail end of the grip should be banded or tightly taped after positioning on the cables. For Cables of Equal Diameters Under “Number of Cables in One Grip,” find diameter of your single cable in vertical column. Read the grip diameter range to the right. If your diameter is the maximum of the range shown, go to the next larger size for Split Grips, stay with the same size for Closed Grips. Example: 3 cables, each with .89” (2.26cm) diameter, for a Closed Grip select the 1.50”-1.74” (3.81cm-4.42cm) range, for a Split Grip select the 1.75”-1.99” (4.44cm-5.05cm) range. Number of Cables in One Grip 2 .30-.38 (.76-.97) .38-.44 (.97-1.12) .44-.59 (1.12-1.50) .59-.75 (1.50-1.90) .75-.90 (1.90-2.29) .90-1.07 (2.29-2.72) 1.07-1.22 (2.72-3.10) 1.22-1.53 (3.10-3.89) 1.53-1.83 (3.89-4.65) 1.83-2.14 (4.65-5.44) 2.14-2.44 (5.44-6.20) 2.44-2.75 (6.20-6.98) 2.75-3.06 (6.98-7.77) 3 .25-.31 (.63-.79) .31-.36 (.79-.91) .36-.49 (.91-1.24) .49-.63 (1.24-1.60) .63-.76 (1.60-1.93) .76-.89 (1.93-2.26) .89-1.02 (2.26-2.59) 1.02-1.28 (2.59-3.25) 1.28-1.53 (3.25-3.89) 1.53-1.79 (3.89-4.55) 1.79-2.05 (4.55-5.21) 2.05-2.30 (5.21-5.84) 2.30-2.56 (5.84-6.50) 4 .22-.27 (.56-.69) .27-.31 (.69-.79) .31-.42 (.79-1.07) .42-.54 (1.07-1.37) .54-.65 (1.37-1.65) .65-.77 (1.65-1.96) .77-.88 (1.96-2.24) .88-1.10 (2.24-2.79) 1.10-1.32 (2.79-3.35) 1.32-1.54 (3.35-3.91) 1.54-1.76 (3.91-4.47) 1.76-1.98 (4.47-5.03) 1.98-2.20 (5.03-5.59) 5 .19-.24 (.48-.61 ) .24-.29 (.61-.74) .29-.38 (.74-.97) .38-.48 (.97-1.22) .48-.58 (1.22-1.47) .58-.67 (1.47-1.70) .67-.77 (1.70-1.96) .77-.96 (1.96-2.44) .96-1.16 (2.44-2.95) 1.16-1.35 (2.95-3.43) 1.35-1.54 (3.43-3.91) 1.54-1.74 (3.91-4.42) 1.74-1.93 (4.42-4.90) 6 and 7 .17-.22 (.43-.56) .22-.26 (.56-.66) .26-.34 (.66-.86) .34-.43 (.86-1.09) .43-.52 (1.09-1.32) .52-.60 (1.32-1.52) .60-.69 (1.52-1.75) .69-.86 (1.75-5.54) .86-1.03 (2.18-2.62) 1.03-1.20 (2.62-3.05) 1.20-1.37 (3.05-3.48) 1.37-1.55 (3.48-3.94) 1.55-1.72 (3.94-4.37) 8 .15-.19 (.38-.48) .19-.23 (.48-.56) .23-.31 (.58-.79) .31-.39 (.79-.99) .39-.46 (.99-1.17) .46-.54 (1.17-1.37) .54-.62 (1.37-1.57) .62-.77 (1.57-1.96) .77-.93 (1.96-2.36) .93-1.08 (2.36-2.74) 1.08-1.24 (2.74-3.15) 1.24-1.39 (3.15-3.53) 1.39-1.55 (3.53-3.94) Grip Dia. Range Inches (cm) .50-.61 (1.27-1.55) .62-.74 (1.57-1.88) .75-.99 (1.90-2.51) 1.00-1.24 (2.54-3.15) 1.25-1.49 (3.17-3.78) 1.50-1.74 (3.81-4.42) 1.75-1.99 (4.44-5.05) 2.00-2.49 (5.08-6.32) 2.50-2.99 (6.35-7.59) 3.00-3.49 (7.62-8.86) 3.50-3.99 (8.89-10.13) 4.00-4.49 (10.16-11.40) 4.50-4.99 (11.43-12.67) 9 .14-.18 (.36-.46) .18-.21 (.46-.53) .21-.28 (.53-.71) .28-.35 (.71-.89) .35-.42 (.89-1.07) .42-.49 (1.07-1.24) .49-.56 (1.24-1.42) .56-.71 (1.42-1.80) .71-.85 (1.80-2.16) .85-.99 (2.16-2.51) .99-1.13 (2.51-2.87) 1.13-1.27 (2.87-3.23) 1.27-1.41 (3.23-3.58) *This chart is not to be used for Conduit Riser Grips. Refer to the chart for Conduit Riser multiple cable section. Technical Data Note: It is always recommended that, when multiple cables are installed in a pulling grip, the tail end be banded and tightly taped after installation on the cable bundle. T-26 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Kellems® Pulling Grips Technical Section Junior Pulling Grip Selection Chart These charts are a general guide to assist in the selection of the correct Junior Pulling Grip for pulling various groupings of building wire. It is not intended to be restrictive inasmuch as the use of “dummy” wires (short pieces of wire used to fill out the Grip) or the tight taping of the wires into a compact bundle may increase or decrease the number of wires per Grip. T.H.W.N., T.H.H.N., X.H.H.W. Building Wire #14 #12 #10 #8 #6 #4 #3 #2 #1 #1/0 19 Strand 19 Strand 19 Strand 19 Strand 19 Strand 19 Strand 19 Strand 19 Strand 37 Strand 37 Strand Cable Dia. Approx. Breaking Range Strength Desc. In. (cm) Lbs. (N) Approximate Number Of Wires In One Grip J 25 J 37 J 50 .25-.36 (.63-.91) .37-.49 (.94-1.24) .50-.61 (1.27-1.55) J 62 .62-.74 (1.57-1.88) J 75 .75-.99 (1.90-2.51) J 100 1.00-1.24 (2.54-3.15) 450 (2,002) 900 (4,003) 1,300 (5,782) Catalog Numbers 4-8 3-6 2-3 2 1 1 1 • • • 03305001 9-16 6-11 4-6 3 2 • • 1 1 1 03305002 16-25 11-17 7-10 4-5 3-4 2 2 • • • 03305003 18-25 11-14 6-8 5-6 3 3 2 2 • 03305004 26-47 15-27 9-16 6-11 4-7 4-5 3-4 3 2-3 03305005 47-74 28-43 16-24 11-17 8-10 6-8 5-7 4-5 4 03305006 #2 7 Strand #1 #1/0 19 Strand 19 Strand 1,950 26-37 (8,674) 2,800 37-66 (12,454) 3,900 66-104 (17,347) R.H.H., R.H., R.W. and R.H.W. Building Wire #14 7 Strand #12 7 Strand #10 7 Strand #8 7 Strand #6 7 Strand #4 7 Strand Cable Dia. Approx. Breaking Range Strength Desc. In. (cm) Lbs. (N) Approximate Number Of Wires In One Grip J 25 J 37 J 50 .25-.36 (.63-.91) .37-.49 (.94-1.24) .50-.61 (1.27-1.55) J 62 .62-.74 (1.57-1.88) J 75 .75-.99 (1.90-2.51) J 100 1.00-1.24 (2.54-3.15) 450 (2,002) 900 (4,003) 1,300 (5,782) 2 2 1 1 Catalog Numbers • • • • • 03305001 3 2-3 2 • 1 1 1 • • 03305002 4-5 4-5 3-4 2 • • • 1 • 03305003 6-7 4-5 3 2 2 • • 1 03305004 8-14 6-10 4-6 3-4 3-4 2-3 2 • 03305005 15-22 11-16 7-10 5-7 4-6 4 3 2-3 03305006 #12 7 Strand #10 7 Strand #8 7 Strand #6 7 Strand #4 7 Strand #2 7 Strand #1 7 Strand #1/0 19 Strand 1,950 6-8 (8,674) 2,800 9-16 (12,454) 3,900 16-24 (17,347) T.H.W. Building Wire #14 7 Strand Cable Dia. Approx. Breaking Range Strength Desc. In. (cm) Lbs. (kg) Approximate Number Of Wires In One Grip J 25 J 37 J 50 .62-.74 (1.57-1.88) J 75 .75-.99 (1.90-2.51) J 100 1.00-1.24 (2.54-3.15) 450 (2,002) 900 (4,003) 1,300 (5,782) 2-4 2-3 2 1 1 1 • • • 03305001 5-7 4-5 3-4 2 • • 1 • • 03305002 8-11 6-8 5-7 3-4 2 2 • 1 1 03305003 9-12 8-10 5-6 3-4 3 2 • • 03305004 1,950 12-16 (8.674) 2,800 17-30 (12,454) 3,900 31-48 (17,347) Dimensions in Inches (mm) 13-24 11-19 7-10 5-7 4-5 3-4 2 2 03305005 25-37 20-30 11-17 8-11 6-8 5-6 3-4 3 03305006 www.hubbell-wiring.com T-27 Technical Data J 62 .25-.36 (.63-.91) .37-.49 (.94-1.24) .50-.61 (1.27-1.55) Catalog Numbers Kellems® Grips for Cable Support Wire Management Products Kellems® Grips for Cable Support Heavy Duty, Standard Duty, Light Duty Tin-Coated Bronze/Stainless Steel Solid eye assemblies provide eye reinforcement at support hardware. Four eye styles available: single (shown), double, universal, and offset. Identification tag shows: catalog number, diameter range, agency approval, and bar code. The strand equalizer positions wires for equal loading throughout the entire grip length. The positive action mesh grip is designed for light duty up to heavy duty. Closed grips fit over the cable end, split grips wrap around the cable mid-span. The standard material is nonmagnetic, tin-coated bronze. Selected items are available in stainless steel. Contact the factory. The endless weave provides easy installation onto cable, and can be easily repositioned. Support Grips Dimensions in Inches (mm) www.hubbell-wiring.com T-29 Wire Management Products Support Grips Standard Duty Support Double Eye, Single Weave, Tin-Coated Bronze Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-43 through T-48. E M Double Eye, Closed Mesh* For permanent support when cable end is available to be installed through grip. Cable Diameter Range Inches (cm) .50”-.62” (1.27-1.57) .63”-.74” (1.60-1.88) .75”-.99” (1.90-2.51) 1.00”-1.24” (2.54-3.15) 1.25”-1.49” (3.17-3.78) 1.50”-1.74” (3.81-4.42) 1.75”-1.99” (4.44-5.05) 2.00”-2.49” (5.08-6.32) 2.50”-2.99” (6.35-7.59) 3.00”-3.49” (7.62-8.86) 3.50”-3.99” (8.89-10.13) Approx. Breaking Strength Lbs. (N) 530 (2,357) 790 (3,415) 1,020 (4,537) 1,610 (7,161) 1,610 (7,161) 1,610 (7,161) 2,150 (9,563) 3,260 (14,500) 3,260 (14,500) 4,900 (21,795) 4,900 (21,795) E Inches (cm) 4” (10.16) 4” (10.16) 4” (10.16) 5” (12.70) 5” (12.70) 5” (12.70) 6” (15.24) 6” (15.24) 6” (15.24) 8” (20.32) 8” (20.32) M Inches (cm) 10” (25.40) 10” (25.40) 13” (33.02) 14” (35.56) 15” (38.10) 17” (43.18) 19” (48.26) 21” (53.34) 23” (58.42) 25” (63.50) 27” (68.58) Catalog Numbers 02201001 02201002 02201003 02201005 02201006 02201007 02201008 02201009 02201010 02201011 02201012 M Inches (cm) 10” (25.40) 10” (25.40) 13” (33.02) 14” (35.56) 15” (38.10) 17” (43.18) 19” (48.26) 21” (53.34) 23” (58.42) 25” (63.50) 27” (68.58) Catalog Numbers 02202001 02202002 02202003 02202005 02202006 02202007 02202008 02202009 02202010 02202011 02202012 M Inches (cm) 81 / 2” (21.59) 81 / 2” (21.59) 101 / 2” (26.67) 121 / 2” (31.75) 141 / 2” (36.83) 151 / 2” (39.37) 161 / 2” (41.91) 191 / 2” (49.53) 211 / 2” (54.61) 231 / 2” (59.69) 251 / 2” (64.77) Catalog Numbers 02203001 02203002 02203003 02203005 02203006 02203007 02203008 02203009 02203010 02203011 02203012 Double Eye, Split Mesh, Lace Closing* For permanent support when cable end is not available. ouble Eye, Closed Mesh Double Eye, Closed Mesh E M Cable Diameter Range Inches (cm) .50”-.62” (1.27-1.57) .63”-.74” (1.60-1.88) .75”-.99” (1.90-2.51) 1.00”-1.24” (2.54-3.15) 1.25”-1.49” (3.17-3.78) 1.50”-1.74” (3.81-4.42) 1.75”-1.99” (4.44-5.05) 2.00”-2.49” (5.08-6.32) 2.50”-2.99” (6.35-7.59) 3.00”-3.49” (7.62-8.86) 3.50”-3.99” (8.89-10.13) Approx. Breaking Strength Lbs. (N) 530 (2,357) 790 (3,415) 1,020 (4,537) 1,610 (7,161) 1,610 (7,161) 1,610 (7,161) 2,150 (9,563) 3,260 (14,500) 3,260 (14,500) 4,900 (21,795) 4,900 (21,795) E Inches (cm) 4” (10.16) 4” (10.16) 4” (10.16) 5” (12.70) 5” (12.70) 5” (12.70) 6” (15.24) 6” (15.24) 6” (15.24) 8” (20.32) 8” (20.32) Double Eye, Split Mesh, Rod Closing* For support when cable end is not available. Double Eye, Split Mesh, Lace Closing Double Eye, Split Mesh, Lace Closing Support Grips E M Double Eye, Split Mesh, Rod Closing T-30 Cable Diameter Approx. Breaking E Range Inches (cm) Strength Lbs. (N) Inches (cm) .50”-.62” (1.27-1.57) 790 (3,415) 4” (10.16) .63”-.74” (1.60-1.88) 790 (3,415) 4” (10.16) .75”-.99” (1.90-2.51) 1,020 (4,537) 4” (10.16) 1.00”-1.24” (2.54-3.15) 1,610 (7,161) 5” (12.70) 1.25”-1.49” (3.17-3.78) 1,610 (7,161) 5” (12.70) 1.50”-1.74” (3.81-4.42) 1,610 (7,161) 5” (12.70) 1.75”-1.99” (4.44-5.05) 2,150 (9,563) 6” (15.24) 2.00”-2.49” (5.08-6.32) 3,260 (14,500) 6” (15.24) 2.50”-2.99” (6.35-7.59) 3,260 (14,500) 6” (15.24) 3.00”-3.49” (7.62-8.86) 5,750 (25,576) 8” (20.32) 3.50”-3.99” (8.89-10.13) 5,750 (25,576) 8” (20.32) E-Eye length M-Mesh length at nominal diameter * Change catalog number from 022 to 024 for stainless steel. Consult factory for availability. www.hubbell-wiring.com Dimensions in Inches (mm) Standard Duty Support Single Eye, Single Weave, Tin-Coated Bronze Single Eye, Closed Mesh* For permanent support when cable end is available to be installed through grip. Cable Diameter Range Inches (cm) .50”-.62” (1.27-1.57) .63”-.74” (1.60-1.88) .75”-.99” (1.90-2.51) 1.00”-1.24” (2.54-3.15) 1.25”-1.49” (3.17-3.78) 1.50”-1.74” (3.81-4.42) 1.75”-1.99” (4.44-5.05) 2.00”-2.49” (5.08-6.32) 2.50”-2.99” (6.35-7.59) 3.00”-3.49” (7.62-8.86) 3.50”-3.99” (8.89-10.13) Approx. Breaking Strength Lbs. (N) 530 (2,357) 790 (3,514) 1,020 (4,537) 1,610 (7,161) 1,610 (7,161) 1,610 (7,161) 2,150 (9,563) 3,260 (14,500) 3,260 (14,500) 4,900 (21,795) 4,900 (21,795) E Inches (cm) 7” (17.78) 8” (20.32) 8” (20.32) 9” (22.86) 10” (25.40) 12” (30.48) 14” (35.56) 16” (40.64) 18” (45.72) 21” (53.34) 24” (60.96) M Inches (cm) 10” (25.40) 10” (25.40) 13” (33.02) 14” (35.56) 15” (38.10) 17” (43.18) 19” (48.26) 21” (53.34) 23” (58.42) 25” (63.50) 27” (68.58) Catalog Numbers 02201013 02201014 02201015 02201017 02201018 02201019 02201020 02201021 02201022 02201023 02201024 M Inches (cm) 10” (25.40) 10” (25.40) 13” (33.02) 14” (35.56) 15” (38.10) 17” (43.18) 19” (48.26) 21” (53.34) 23” (58.42) 25” (63.50) 27” (68.58) Catalog Numbers 02202013 02202014 02202015 02202017 02202018 02202019 02202020 02202021 02202022 02202023 02202024 Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-43 through T-48. Wire Management Products Support Grips E M Single Eye, Split Mesh, Lace Closing* For permanent support when cable end is not available. Cable Diameter Approx. Breaking E Range Inches (cm) Strength Lbs. (N) Inches (cm) .50”-.62” (1.27-1.57) 530 (2,357) 7” (17.78) .63”-.74” (1.60-1.88) 790 (3,514) 8” (20.32) .75”-.99” (1.90-2.51) 1,020 (4,537) 8” (20.32) 1.00”-1.24” (2.54-3.15) 1,610 (7,161) 9” (22.86) 1.25”-1.49” (3.17-3.78) 1,610 (7,161) 10” (25.40) 1.50”-1.74” (3.81-4.42) 1,610 (7,161) 12” (30.48) 1.75”-1.99” (4.44-5.05) 2,150 (9,563) 14” (35.56) 2.00”-2.49” (5.08-6.32) 3,260 (14,500) 16” (40.64) 2.50”-2.99” (6.35-7.59) 3,260 (14,500) 18” (45.72) 3.00”-3.49” (7.62-8.86) 4,900 (21,795) 21” (53.34) 3.50”-3.99” (8.89-10.13) 4,900 (21,795) 24” (60.96) Single Eye, Split Mesh, Rod Closing* Single Eye, Closed Mesh E M Single Eye, Split Mesh, Lace Closing For support when cable end is not available. E-Eye length M Inches (cm) 81 /2” (21.59) 81 /2” (21.59) 101 /2” (26.67) 121 /2” (31.75) 141 /2” (36.83) 151 /2” (39.37) 161 /2” (41.91) 191 /2” (49.53) 211 /2” (54.61) 231 /2” (59.69) 251 /2” (64.77) Catalog Numbers 02203013 02203014 02203015 02203017 02203018 02203019 02203020 02203021 02203022 02203023 02203024 E M Single Eye, Split Mesh, Rod Closing M-Mesh length at nominal diameter * Change catalog number from 022 to 024 for stainless steel. Consult factory for availability. Dimensions in Inches (mm) www.hubbell-wiring.com T-31 Support????? Grips Cable Diameter Approx. Breaking E Range Inches (cm) Strength Lbs. (N) Inches (cm) .50”-.62” (1.27-1.57) 790 (3,514) 7” (17.78) .63”-.74” (1.60-1.88) 790 (3,514) 8” (20.32) .75”-.99” (1.90-2.51) 1,020 (4,537) 8” (20.32) 1.00”-1.24” (2.54-3.15) 1,610 (7,161) 9” (22.86) 1.25”-1.49” (3.17-3.78) 1,610 (7,161) 10” (25.40) 1.50”-1.74” (3.81-4.42) 1,610 (7,161) 12” (30.48) 1.75”-1.99” (4.44-5.05) 2,150 (9,563) 14” (35.56) 2.00”-2.49” (5.08-6.32) 3,260 (14,500) 16” (40.64) 2.50”-2.99” (6.35-7.59) 3,260 (14,500) 18” (45.72) 3.00”-3.49” (7.62-8.86) 5,750 (25,576) 21” (53.34) 3.50”-3.99” (8.89-10.13) 5,750 (25,576) 24” (60.96) Wire Management Products Support Grips Standard Duty Support Offset Eye, Single Weave, Tin-Coated Bronze Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-43 through T-48. E M Offset Eye, Closed Mesh* For permanent support when cable end is available to be installed through grip. Cable Diameter Range Inches (cm) .50”-.62” (1.27-1.57) .63”-.74” (1.60-1.88) .75”-.99” (1.90-2.51) 1.00”-1.24” (2.54-3.15) 1.25”-1.49” (3.17-3.78) 1.50”-1.74” (3.81-4.42) 1.75”-1.99” (4.44-5.05) 2.00”-2.49” (5.08-6.32) 2.50”-2.99” (6.35-7.59) 3.00”-3.49” (7.62-8.86) 3.50”-3.99” (8.89-10.13) Approx. Breaking Strength Lbs. (N) 500 (2,724) 750 (3,336) 950 (4,226) 1,500 (6,672) 1,500 (6,672) 1,500 (6,672) 2,000 (8,896) 3,100 (13,789) 3,100 (13,789) 3,800 (16,902) 3,800 (16,902) E Inches (cm) 4” (10.16) 4” (10.16) 4” (10.16) 5” (12.70) 5” (12.70) 5” (12.70) 6” (15.24) 9” (22.86) 9” (22.86) 11” (27.94) 11” (27.94) M Inches (cm) 10” (25.40) 10” (25.40) 13” (33.02) 14” (35.56) 15” (38.10) 17” (43.18) 19” (48.26) 21” (53.34) 23” (58.42) 25” (63.50) 27” (68.58) Catalog Numbers 02201037 02201038 02201039 02201041 02201042 02201043 02201044 02201045 02201046 02201047 02201048 M Inches (cm) 10” (25.40) 10” (25.40) 13” (33.02) 14” (35.56) 15” (38.10) 17” (43.18) 19” (48.26) 21” (53.34) 23” (58.42) 25” (63.50) 27” (68.58) Catalog Numbers 02202037 02202038 02202039 02202041 02202042 02202043 02202044 02202045 02202046 02202047 02202048 M Inches (cm) 7” (17.78) 9” (22.86) 10” (25.40) 12” (30.48) 14” (35.56) 15” (38.10) 16” (40.64) 19” (48.26) 20” (50.80) 21” (53.34) 21” (53.34) Catalog Numbers 02203037 02203038 02203039 02203041 02203042 02203043 02203044 02203045 02203046 02203047 02203048 Offset Eye, Split Mesh, Lace Closing* Offset Eye, Closed Mesh E M For permanent support when cable end is not available. Cable Diameter Range Inches (cm) .50”-.62” (1.27-1.57) .63”-.74” (1.60-1.88) .75”-.99” (1.90-2.51) 1.00”-1.24” (2.54-3.15) 1.25”-1.49” (3.17-3.78) 1.50”-1.74” (3.81-4.42) 1.75”-1.99” (4.44-5.05) 2.00”-2.49” (5.08-6.32) 2.50”-2.99” (6.35-7.59) 3.00”-3.49” (7.62-8.86) 3.50”-3.99” (8.89-10.13) Approx. Breaking Strength Lbs. (N) 500 (2,724) 750 (3,336) 950 (4,226) 1,500 (6,672) 1,500 (6,672) 1,500 (6,672) 2,000 (8,896) 2,150 (9,563) 2,150 (9,563) 3,800 (16,902) 3,800 (16,902) E Inches (cm) 4” (10.16) 4” (10.16) 4” (10.16) 5” (12.70) 5” (12.70) 5” (12.70) 6” (15.24) 9” (22.86) 9” (22.86) 11” (27.94) 11” (27.94) Offset Eye, Split Mesh, Lace Closing Offset Eye, Split Mesh, Rod Closing* For support when cable end is not available. E Support Grips M Offset Eye, Split Mesh, Rod Closing Cable Diameter Range Inches (cm) .50”-.62” (1.27-1.57) .63”-.74” (1.60-1.88) .75”-.99” (1.90-2.51) 1.00”-1.24” (2.54-3.15) 1.25”-1.49” (3.17-3.78) 1.50”-1.74” (3.81-4.42) 1.75”-1.99” (4.44-5.05) 2.00”-2.49” (5.08-6.32) 2.50”-2.99” (6.35-7.59) 3.00”-3.49” (7.62-8.86) 3.50”-3.99” (8.89-10.13) E-Eye length Approx. Breaking Strength Lbs. (N) 500 (2,724) 750 (3,336) 950 (4,226) 1,500 (6,672) 1,500 (6,672) 1,500 (6,672) 2,000 (8,896) 3,100 (13,789) 3,100 (13,789) 4,300 (19,126) 4,900 (21,795) E Inches (cm) 4” (10.16) 4” (10.16) 4” (10.16) 5” (12.70) 5” (12.70) 5” (12.70) 6” (15.24) 9” (22.86) 9” (22.86) 11” (27.94) 11” (27.94) M-Mesh length at nominal diameter * Change catalog number from 022 to 024 for stainless steel. Consult factory for availability. T-32 www.hubbell-wiring.com Dimensions in Inches (mm) Standard Duty Support Universal Eye, Single Weave, Tin-Coated Bronze Universal Eye, Closed Mesh* For permanent support when cable end is available to be installed through grip. Cable Diameter Range Inches (cm) .50”-.62” (1.27-1.57) .63”-.74” (1.60-1.88) .75”-.99” (1.90-2.51) 1.00”-1.24” (2.54-3.15) 1.25”-1.49” (3.17-3.78) 1.50”-1.74” (3.81-4.42) 1.75”-1.99” (4.44-5.05) 2.00”-2.49” (5.08-6.32) 2.50”-2.99” (6.35-7.59) Approx. Breaking Strength Lbs. (N) 530 (2,357) 790 (3,514) 1,020 (4,537) 1,610 (7,161) 1,610 (7,161) 1,610 (7,161) 2,150 (9,563) 3,260 (14,500) 3,260 (14,500) E Inches (cm) 18” (45.72) 18” (45.72) 18” (45.72) 18” (45.72) 18” (45.72) 18” (45.72) 18” (45.72) 18” (45.72) 18” (45.72) M Inches (cm) 10” (25.40) 10” (25.40) 13” (33.02) 14” (35.56) 15” (38.10) 17” (43.10) 19” (48.26) 21” (53.34) 23” (58.42) Catalog Numbers 02201051 02201052 02201053 02201050 02201054 02201055 02201056 02201057 02201058 Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-43 through T-48. Wire Management Products Support Grips Dim. to Sliding Bar Fully Ext'd. E M Universal Eye, Split Mesh, Lace Closing* For permanent support when cable end is not available. Cable Diameter Range Inches (cm) .50”-.62” (1.27-1.57) .63”-.74” (1.60-1.88) .75”-.99” (1.90-2.51) 1.00”-1.24” (2.54-3.15) 1.25”-1.49” (3.17-3.78) 1.50”-1.74” (3.81-4.42) 1.75”-1.99” (4.44-5.05) 2.00”-2.49” (5.08-6.32) 2.50”-2.99” (6.35-7.59) 3.00”-3.49” (7.62-8.86) 3.50”-3.99” (8.89-10.13) Approx. Breaking Strength Lbs. (N) 530 (2,357) 790 (3,514) 1,020 (4,537) 1,610 (7,161) 1,610 (7,161) 1,610 (7,161) 2,150 (9,563) 3,260 (14,500) 3,260 (14,500) 4,900 (21,795) 4,900 (21,795) E Inches (cm) 18” (45.72) 18” (45.72) 18” (45.72) 18” (45.72) 18” (45.72) 18” (45.72) 18” (45.72) 18” (45.72) 18” (45.72) 18” (45.72) 18” (45.72) M Inches (cm) 10” (25.40) 10” (25.40) 13” (33.02) 14” (35.56) 15” (38.10) 17” (43.10) 19” (48.26) 21” (53.34) 23” (58.42) 25” (63.50) 27” (68.58) Catalog Numbers 02202050 02202051 02202052 02202054 02202055 02202056 02202057 02202058 02202059 02202060 02202061 Universal Eye, Closed Mesh Dim. to Sliding Bar Fully Ext'd. E M Universal Eye Split Mesh, Lace Closing Universal Eye, Split Mesh, Rod Closing* For support when cable end is not available. Cable Diameter Range Inches (cm) .50”-.62” (1.27-1.57) .63”-.74” (1.60-1.88) .75”-.99” (1.90-2.51) 1.00”-1.24” (2.54-3.15) 1.25”-1.49” (3.17-3.78) 1.50”-1.74” (3.81-4.42) 3.00”-3.49” (7.62-8.86) E Inches (cm) 18” (45.72) 18” (45.72) 18” (45.72) 18” (45.72) 18” (45.72) 18” (45.72) 18” (45.72) M Inches (cm) 81 /2” (21.59) 81 /2” (21.59) 101 /2” (26.67) 121 /2” (31.75) 141 /2” (36.83) 151 /2” (39.37) 231 /2” (59.69) Catalog Numbers 02203064 02203065 02203066 02203068 02203069 02203070 02203074 Dim. to Sliding Bar Fully Ext'd. E M M-Mesh length at nominal diameter * Change catalog number from 022 to 024 for stainless steel. Consult factory for availability. Universal Eye Split Mesh, Rod Closing Dimensions in Inches (mm) www.hubbell-wiring.com T-33 Support Grips E-Eye length Approx. Breaking Strength Lbs. (N) 790 (3,514) 790 (3,514) 1,020 (4,537) 1,610 (7,161) 1,610 (7,161) 1,610 (7,161) 5,750 (25,576) Wire Management Products Support Grips Heavy Duty Support Single Eye, Double Weave, Tin-Coated Bronze Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-43 through T-48. Heavy Duty, Single Eye, Closed Mesh* For heavy duty permanent support when cable end is available to be installed through grip. Cable Diameter Range Inches (cm) .75”-.99” (1.90-2.51) 1.00”-1.24” (2.54-3.15) 1.25”-1.49” (3.17-3.78) 1.50”-1.99” (3.81-5.05) E Approx. Breaking Strength Lbs. (N) 2,820 (12,543) 4,280 (19,037) 4,280 (19,037) 4,280 (19,037) E Inches (cm) 10” (25.40) 12” (30.48) 12” (30.48) 12” (30.48) M Inches (cm) 25” (63.50) 28” (71.12) 30” (76.20) 34” (86.36) Catalog Numbers 02206010 02206011 02206012 02206013 M Heavy Duty, Single Eye, Closed Mesh Single Eye, Split Mesh, Lace Closing* For permanent support when cable end is not available to be installed through grip. E Cable Diameter Range Inches (cm) .75”-.99” (1.90-2.51) 1.00”-1.24” (2.54-3.15) 1.25”-1.49” (3.17-3.78) 1.50”-1.99” (3.81-5.05) E-Eye length M Approx. Breaking Strength Lbs. (N) 2,820 (12,543) 4,280 (19,037) 4,280 (19,037) 4,280 (19,037) E Inches (cm) 10” (25.40) 12” (30.48) 12” (30.48) 12” (30.48) M Inches (cm) 25” (63.50) 28” (71.12) 30” (76.20) 34” (86.36) Catalog Numbers 02207010 02207011 02207012 02207013 M-Mesh length at nominal diameter * Change catalog number from 022 to 024 for stainless steel. Consult factory for availability. Support Grips Single Eye, Split Mesh, Lace Closing T-34 www.hubbell-wiring.com Dimensions in Inches (mm) Heavy Duty Support Double Eye, Double Weave, Tin-Coated Bronze Double Eye, Closed Mesh* For permanent support when cable end is not available to be installed through grip. Cable Diameter Range Inches (cm) .75”- .99”(1.90-2.51) 1.00”-1.24” (2.54-3.15) 1.25”-1.49” (3.17-3.78) 1.50”-1.99” (3.81-5.05) 2.00”-2.49” (5.08-6.32) 2.50”-2.99” (6.35-7.59) 3.00”-3.49” (7.62-8.86) 3.50”-3.99” (8.89-10.13) 4.00”-4.49” (10.16-11.40) 4.50”-4.99” (11.43-12.67) Approx. Breaking Strength Lbs. (N) 2,820 (12,543) 4,280 (19,037) 4,280 (19,037) 4,280 (19,037) 8,050 (35,806) 8,050 (35,806) 10,060 (44,747) 12,070 (53,687) 12,070 (53,687) 12,070 (53,687) E Inches (cm) 10” (25.40) 10” (25.40) 10” (25.40) 10” (25.40) 12” (30.48) 12” (30.48) 12” (30.48) 12” (30.48) 12” (30.48) 12” (30.48) M Inches (cm) 25” (63.50) 28” (71.12) 30” (76.20) 34” (86.36) 36” (91.44) 38” (96.52) 40” (101.62) 44” (111.76) 46” (116.84) 68” (172.72) Catalog Numbers 02206001 02206002 02206003 02206004 02206005 02206006 02206007 02206008 02206009 02208009 Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-43 through T-48. Wire Management Products Support Grips E M Double Eye, Closed Mesh Double Eye, Split Mesh, Lace Closing* For support when cable end is not available. Cable Diameter Range Inches (cm) .75”-.99” (1.90-2.51) 1.00”-1.24” (2.54-3.15) 1.25”-1.49” (3.17-3.78) 1.50”-1.99” (3.81-5.05) 2.00”-2.49” (5.08-6.32) 2.50”-2.99” (6.35-7.59) 3.00”-3.49” (7.62-8.86) 3.50”-3.99” (8.89-10.13) 4.00”-4.49” (10.16-11.40) Approx. Breaking Strength Lbs. (N) 2,820 (12,543) 4,280 (19,037) 4,280 (19,037) 4,280 (19,037) 8,050 (35,806) 8,050 (35,806) 10,060 (44,747) 12,070 (53,687) 12,070 (53,687) E Inches (cm) 10” (25.40) 10” (25.40) 10” (25.40) 10” (25.40) 12” (30.48) 12” (30.48) 12” (30.48) 12” (30.48) 12” (30.48) M Inches (cm) 25” (63.50) 28” (71.12) 30” (76.20) 34” (86.36) 36” (91.44) 38” (96.52) 40” (101.62) 44” (111.76) 46” (116.84) Catalog Numbers 02207001 02207002 02207003 02207004 02207005 02207006 02207007 02207008 02207009 4.50”-4.99” (11.43-12.67) 12,070 (53,687) 12” (30.48) 68” (172.72) 02209009 E-Eye length E M Double Eye, Split Mesh, Lace Closing M-Mesh length at nominal diameter * Change catalog number from 022 to 024 for stainless steel. Consult factory for availability. Support Grips Dimensions in Inches (mm) www.hubbell-wiring.com T-35 Wire Management Products Support Grips Service Drop Single Eye, Tin-Coated Bronze Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-43 through T48. E M Light Duty, Single Eye, Closed Mesh E M Heavy Duty, Single Eye, Closed Mesh Light Duty, Single Eye, Closed Mesh Single Weave* For permanent support when cable end is available to be installed. Cable Diameter Range Inches (cm) .23”-.31” (.58-.79) .29”-.37” (.74-.94) .35”-.44” (.89-1.12) .41”-.50” (1.04-1.27) .46”-.56” (1.17-1.42) .52”-.62” (1.32-1.57) .58”-.68” (1.47-1.73) .64”-.75” (1.63-1.90) .70”-.81” (1.78-2.06) .75”-.87” (1.90-2.21) .81”-.94” (2.06-2.39) .87”-1.00” (2.21-2.54) .94”-1.06” (2.39-2.69) 1.00”-1.18” (2.54-3.00) 1.06”-1.25” (2.69-3.17) Approx. Breaking Strength Lbs. (N) 290 (1,290) 290 (1,290) 500 (2,224) 500 (2,224) 660 (2,936) 790 (3,514) 790 (3,514) 790 (3,514) 790 (3,514) 1,020 (4,537) 1,020 (4,537) 1,020 (4,537) 1,020 (4,537) 1,020 (4,537) 1,020 (4,537) E Inches (cm) 3” (7.62) 5” (12.70) 5.5” (13.97) 5.5” (13.97) 6” (15.24) 7” (17.78) 7” (17.78) 7” (17.78) 7” (17.78) 8” (20.32) 8” (20.32) 8” (20.32) 9” (22.86) 9” (22.86) 9” (22.86) M Inches (cm) 33 /4” (9.52) 41 /4” (10.79) 43 /4” (12.06) 5” (12.70) 51 /4” (13.33) 61 /4” (15.87) 61 /2” (16.51) 63 /4” (17.14) 71 /4” (18.41) 8” (20.32) 81 /4” (20.95) 83 /4” (22.22) 9” (22.86) 91 /2” (24.13) 91 /2” (24.13) Catalog Numbers 02216001 02216002 02216003 02216004 02216005 02216006 02216007 02216008 02216009 02216010 02216011 02216012 02216013 02216014 02216015 Heavy Duty, Single Eye, Closed Mesh Multi-Weave* For permanent support when cable end is available to be installed. Cable Diameter Range Inches (cm) .23”-.31” (.58-.79) .29”-.37” (.74-.94) .35”-.44” (.89-1.12) .41”-.50” (1.04-1.27) .46”-.56” (1.17-1.42) .52”-.62” (1.32-1.57) .58”-.68” (1.47-1.73) .64”-.75” (1.63-1.90) .70”-.81” (1.78-2.06) Approx. Breaking Strength Lbs. (N) 500 (2,224) 500 (2,224) 870 (3,870) 870 (3,870) 1,050 (4,670) 1,050 (4,670) 1,050 (4,670) 1,390 (6,183) 1,390 (6,183) E Inches (cm) 5” (12.70) 5” (12.70) 6” (15.24) 6” (15.24) 6” (15.24) 7” (17.78) 7” (17.78) 7” (17.78) 8” (20.32) M Inches (cm) 41 /2” (11.43) 51 /2” (13.97) 61 /2” (16.51) 71 /2” (19.05) 8” (20.32) 81 /2” (21.59) 91 /2” (24.13) 91 /2” (24.13) 101 /2” (26.67) .75”-.87” (1.90-2.21) .81”-.94” (2.06-2.39) .87”-1.00” (2.21-2.54) 1,390 (6,183) 1,390 (6,183) 1,790 (7,962) 8” (20.32) 8” (20.32) 8” (20.32) 101 /2” (26.67) 101 /2” (26.67) 111 /2” (29.21) 02217010 02217011 02217012 .94”-1.06” (2.39-2.69) 1.00”-1.18” (2.54-3.00) 1.06”-1.25” (2.69-3.17) 1,790 (7,962) 1,790 (7,962) 1,790 (7,962) 9” (22.86) 9” (22.86) 9” (22.86) 121 /2” (31.75) 131 /2” (34.29) 141 /2” (36.83) 02217013 02217014 02217015 E-Eye length Catalog Numbers 02217001 02217002 02217003 02217004 02217005 02217006 02217007 02217008 02217009 M-Mesh length at nominal diameter 1/4'' (.64) Support Grips 5/16 '' (.80) Dia. 2'' (5.08) * Change catalog number from 022 to 024 for stainless steel. Consult factory for availability.. T-36 Screw Hook No. 203-03-001 Yield Strength 900 lbs (4003) www.hubbell-wiring.com 4 7/8'' (12.38) Dimensions in Inches (mm) Service Drop Universal Eye, Tin-Coated Bronze Light Duty, Universal Eye, Closed Mesh, Single Weave* For permanent support when cable end is available to be installed. Cable Diameter Range Inches (cm) .23”-.31” (.58-.79) .29”-.37” (.74-.94) .35”-.44” (.89-1.12) .41”-.50” (1.04-1.27) .46”-.56” (1.17-1.42) .52”-.62” (1.32-1.57) .58”-.68” (1.47-1.73) .64”-.75” (1.63-1.90) .70”-.81” (1.78-2.06) .75”-.87” (1.90-2.21) .81”-.94” (2.06-2.39) .87”-1.00” (2.21-2.54) .94”-1.06” (2.39-2.69) 1.00”-1.18” (2.54-3.00) 1.06”-1.25” (2.69-3.17) Approx. Breaking Strength Lbs. (N) 290 (1,290) 290 (1,290) 500 (2,224) 500 (2,224) 660 (2,936) 790 (3,514) 790 (3,514) 790 (3,514) 790 (3,514) 1,020 (4,537) 1,020 (4,537) 1,020 (4,537) 1,020 (4,537) 1,020 (4,537) 1,020 (4,537) E Inches (cm) 9” (22.86) 10” (25.40) 10” (25.40) 11” (27.94) 12” (30.48) 13” (33.02) 13” (33.02) 13” (33.02) 13” (33.02) 14” (35.56) 14” (35.56) 14” (35.56) 15” (38.10) 15” (38.10) 15” (38.10) M Inches (cm) 33 /4” (9.52) 41 / 4” (10.79) 43 / 4” (12.06) 5” (12.70) 51 / 4” (13.33) 61 / 4” (15.87) 61 / 2” (16.51) 63 / 4” (17.14) 71 / 4” (18.41) 8” (20.32) 81 / 4” (20.95) 8 3 / 4” (22.22) 9” (22.86) 91 / 2” (24.13) 91 / 2” (24.13) Catalog Numbers 02216016 02216017 02216018 02216019 02216020 02216021 02216022 02216023 02216024 02216025 02216026 02216027 02216028 02216029 02216030 Heavy Duty, Universal Eye, Closed Mesh, Multi-Weave* For permanent support when cable end is available to be installed. Dim. to Sliding Bar Fully Ext'd. E M Light Duty, Universal Eye, Closed Mesh Single Weave Cable Diameter Range Inches (cm) .23”-.31” (.58-.79) .28”-.37” (.74-.94) .35”-.44” (.89-1.12) .41”-.50” (1.04-1.27) .46”-.56” (1.17-1.42) .52”-.62” (1.32-1.57) .58”-.68” (1.47-1.73) .64”-.75” (1.63-1.90) .70”-.81” (1.78-2.06) Approx. Breaking Strength Lbs. (N) 500 (2,224) 500 (2,224) 870 (3,870) 870 (3,870) 1,050 (4,670) 1,050 (4,670) 1,050 (4,670) 1,390 (6,183) 1,390 (6,183) E Inches (cm) 11” (27.94) 11” (27.94) 12” (30.48) 12” (30.48) 12” (30.48) 13” (33.02) 13” (33.02) 13” (33.02) 14” (35.56) M Inches (cm) 41 / 2” (11.43) 51 / 2” (13.97) 61 / 2” (16.51) 71 / 2” (19.05) 8” (20.32) 81 / 2” (21.59) 91 / 2” (24.13) 91 / 2” (24.13) 101 / 2” (26.67) .75”-.87” (1.90-2.21) .81”-.94” (2.06-2.39) .87”-1.00” (2.21-2.54) 1,390 (6,183) 1,390 (6,183) 1,790 (7,962) 14” (35.56) 14” (35.56) 14” (35.56) 101 / 2” (26.67) 101 / 2” (26.67) 111 / 2” (29.10) 02217025 02217026 02217027 .94”-1.06” (2.39-2.69) 1.00”-1.18” (2.54-3.00) 1.06”-1.25” (2.69-3.17) 1,790 (7,962) 1,790 (7,962) 1,790 (7,962) 15” (38.10) 15” (38.10) 15” (38.10) 121 / 2” (31.75) 131 / 2” (34.29) 141 / 2” (36.83) 02217028 02217029 02217030 E-Eye length Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-43 through T-48. Wire Management Products Support Grips Catalog Numbers 02217016 02217017 02217018 02217019 02217020 02217021 02217022 02217023 02217024 Dim. to Sliding Bar Fully Ext'd. E M Heavy Duty, Universal Eye, Closed Mesh, Multi-Weave M-Mesh length at nominal diameter. * Change catalog number from 022 to 024 for stainless steel. Consult factory for availability. Support Grips Dimensions in Inches (mm) www.hubbell-wiring.com T-37 Wire Management Products Support Grips Bus Drop Single Eye, Universal Eye, Galvanized Steel Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-43 through T-48. Safety Spring Maximum Approx. Breaking Deflection Strength Length* Diameter Inches/Lbs Lbs. Inches Inches Model Catalog (cm/N) (N) (cm) (cm) Lbs. (n) Numbers 3 / 4” 23/ 4” at 40 lbs. 500 8 1 / 4” 40 lb. spring 20302001 (6.98 cm. at 178 N) (2,224) (20.95) (1.90) (178) 31 / 8” at 80 lbs. 850 8 1 / 4” 1” 80 lb. spring 20302002 (7.94 cm. at 356 N) (3,781) (20.95) (2.54) (356) Springs can be used with single eye grips by disassembling drawbar from coil, placing through eye and replacing drawbar. *No load. Single Eye Wide Range Dim. to Sliding Bar Fully Ext'd. E M Cable Diameter Range Inches (cm) .24”-.32” (.61-.81) .32”-.43” (.81-1.09) .43”-.56” (1.09-1.42) .56”-.73” (1.42-1.85) .73”-.85” (1.85-2.16) .85”-1.00” (2.16-2.54) 1.00”-1.25” (2.54-3.17) Approx. Breaking Strength Lbs. (N) 350 (1,557) 450 (2,002) 550 (2,446) 1,000 (4,448) 1,400 (6,227) 1,400 (6,227) 1,500 (6,672) E Inches (cm) 3” (7.62) 4” (10.16) 6” (15.24) 7” (17.78) 7” (17.78) 8” (20.32) 9” (22.86) M Inches (cm) 31 / 2” (8.89) 4” (10.16) 43/4” (12.06) 6” (15.24) 63/4” (17.14) 8” (20.32) 91 / 2” (24.13) E Inches (cm) 10” (25.40) 12” (30.48) 13” (33.02) 13” (33.02) 14” (35.56) 15” (38.10) M Inches (cm) 4” (10.16) 43/4” (12.06) 6” (15.24) 63/4” (17.14) 8” (20.32) 91 / 2” (24.13) Catalog Numbers 073041276 073041277 073041278 073041279 073041280 073041281 073041282 Universal Eye Wide Range Dim. to Sliding Bar Fully Ext'd. E Cable Diameter Range Inches (cm) .32”-.43” (.81-1.09) .43”-.56” (1.09-1.42) .56”-.73” (1.42-1.85) .73”-.85” (1.85-2.16) .85”-1.00” (2.16-2.54) 1.00”-1.25” (2.54-3.17) E-Eye length Approx. Breaking Strength Lbs. (N) 450 (2,002) 550 (2,446) 1,000 (4,448) 1,400 (6,227) 1,400 (6,227) 1,500 (6,672) Catalog Numbers 073041284 073041285 073041286 073041287 073041288 073041289 M-Mesh length at nominal diameter Bus Drop Grips and Safety Springs M Kellems Bus Drop Grips are offered with either a single eye or universal bale attachment. The mesh is single weave galvanized steel with the patented wide range construction. They are suitable for indoor use only. Application Safety Spring Bus Drop Grips provide a safe, easy and economical method to support flexible cord or bus drop cable at bus duct and other industrial areas. Bus Drop Grips Benefits Strain Relief Grip • Easily installed. • Absorb tension, vibration and pull with no cable damage. • Patented mesh construction. Bus Drop Grips Strain Relief Grip Safety Spring Springs can be used with single eye grips by disassembling drawbar from coil, placing through eye and replacing drawbar. Motor Box T-38 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Support Grips Conduit Riser Ring Type, Single Weave, Tin-Coated Bronze Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-43 through T-48. Single Weave, Closed Mesh Kellems® Conduit Riser Support Grips are available in closed mesh and in split mesh with lace or rod closures, to cover all applications including single cable or cable bundle support. Refer to technical section, T-43 for grip selection assistance for cable bundles. The standard material is tincoated bronze strand. The grip is permanently fastened to a support ring, resulting in a one piece unit which will allow air ventilation within the conduit. This ring supported grip is ideal for supporting electrical cable at standard rigid conduit. The rings will fit schedule 40, standard rigid conduit. The rings will fit schedule 40, standard rigid conduit. See page T-42 for ring dimensions. For permanent support when cable end is available to be installed through the grip. Suitable For Schedule 40 Conduit Only .50”- .62” .63”-.74” .75”- .99” 1.00”- 1.24” 1.25”- 1.49” 1.50”-1.74” 1.75”-1.99” 2.00”- 2.49” (1.27-1.57) (1.60-1-88) (1.90-2.51) (2.54-3.15) (3.17-3.78) (3.81-4.42) (4.44-5.05) (5.08-6.32) R050 R062 R075 R100 R125 R150 R175 R200 2.50” -2.99” (6.35-7.59) R250 3.00”- 3.49” (7.62-8.86) R300 3.50”- 3.99” (8.89-10.13) R350 8” (20.32) 18” (45.72) 20” (50.80) 21” (53.34) Conduit Sizes Inches Catalog Numbers Approx. Breaking Strength Lbs. (N) 3 / 4” 02211106 530 (2,357) • • • • • • • • • • 1” 02211100 490 (2,179) 02211101 790 (3,514) • • • • • • • • • 1 1 / 4” 02211001 450 (2,002) 02211002 740 (3,292) 02211003 • 1,030 (4,581) • • • • • • • 1 1 / 2” • 02211006 690 (3,069) 02211007 970 (4,315) 02211009 • 1,610 (7,161) • • • • • • 2” 0221110 370 (1,645) 02211107 640 (2,847) 02211010 920 (4,092) 02211012 02211013 • 1,520 (6,761) 1,610 (7,161) • • • • • 2 1 / 2” • • • • 02211017 02211018 02211019 • 1,510 (6,716) 1,610 (7,161) 2,150 (9,563) • • • 3” • • • 02211022 02211023 02211024 02211025 02211026 • 1,340 (5,960) 1,400 (6,227) 1,490 (6,627) 1,990 (8,851) 3,260 (14,500) • • 3 1 / 2” • • • • • • • 02211033 2,970 (13,211) 02211034 3,260 (14,500) • • 4” • • • • • • 02211040 02211041 1,670 (7,248) 2,680 (11,921) 02211042 2,890 (12,855) 02211043 • 4,080 (18,148) 4 1 / 2” • • • • • • • • 02211051 2,520 (11,208) 02211052 • 3,470 (15,434) 5” • • • • • • • • 02211061 2,150 (9,563) 02211062 02211063 2,860 (12,721) 3,130 (13,922) 6” • • • • • • • • • 02211072 2,245 (9,986) 9” (22.86) 11” (27.94) 12” (30.48) 12” (30.48) 14” (35.56) 15” (38.10) 17” (43.18) 02211073 2,245 (9,986) Note: Refer to page T-43 for multiple cables in a single conduit riser grip. Dimensions in Inches (mm) www.hubbell-wiring.com T-39 Conduit Riser Grips Cable Sizes Inches (cm) Model Length Inches (cm) Wire Management Products Support Grips Conduit Riser Ring Type, Double Weave, Tin-Coated Bronze Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-41 through T-46. Double Weave, Split Mesh, Lace Closing Kellems® Conduit Riser Support Grips will support cable runs in vertical or sloping standard rigid conduit. The grip is fastened to a support ring which seats on the rim of the conduit. The entire grip is supported by the conduit itself and no other hardware is required. See page T-40 for ring dimensions. The rings will fit schedule 40, standard rigid conduit. For permanent support when cable end is not available. Conduit Riser Grips Suitable For Schedule 40 Conduit Only Cable Sizes Inches (cm) Model Length Inches (cm) .75”- .99” (1.90-2.51) RS075 11” (27.94) 1.00”- 1.24” (2.54-3.15) RS100 12” (30.48) 1.25”- 1.49” (3.17-3.78) RS125 12” (30.48) 1.50”-1.74” (3.81-4.42) RS150 14” (35.56) 1.75”- 1.99” (4.44-5.05) RS175 15” (38.10) 2.00”- 2.49” (5.08-6.32) RS200 17” (43.18) 2.50”- 2.99” (6.35-7.59) RS250 18” (45.72) 3.00”- 3.49” (7.62-8.86) RS300 20” (50.80) 3.50” -3.99” (8.89-10.13) RS350 21” (53.34) Conduit Sizes Inches 1 1 / 4” Catalog Numbers Approx. Breaking Strength Lbs. (N) 02212003 • 1,580 (7,028) • • • • • • • 11 / 2 ” 02212007 1,500 (6,672) 02212009 2,040 (9,024) • • • • • • • 2” 02212010 1,430 (6,361) 02212012 1,930 (8,585) 02212013 2,040 (9,074) • • • • • • 21 / 2 ” • • 02212017 1,910 (8,496) 02212018 2,040 (9,074) 02212019 2,730 (12,143) • • • • 3” • • 02212023 1,780 (7,917) 02212024 1,890 (8,407) 02212025 2,520 (11,209) 02212026 4,300 (19,126) • • • 3 1 / 2” • • • • • 02212033 3,910 (17,392) 02212034 4,300 (19,126) • • 4” • • • • 02212040 2,110 (9,385) 02212041 3,530 (15,701) 02212042 3,820 (16,991) 02212043 5,380 (23,930) • 5” • • • • • • 02212061 2,860 (12,721) 02212062 3,760 (16,724) 02212063 4,170 (18,548) 6” • • • • • • 02212071 2,365 (10,519) 02212072 2,955 (13,144) 02212073 2,955 (13,144) Note: Refer to page T-43 for multiple cables in a single conduit riser grip. T-40 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Support Grips Conduit Riser Ring Type, Single Weave, Tin-Coated Bronze Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-43 through T-48. Single Weave, Split Mesh, Rod Closing Benefits • Easy and fast to install. • Will not damage electrical cable. • Allows cable to expand or contract. • Ideal way to hold cable in vertical conduit. • Prevents cable creep in conduit. • Helps prevent cable pullouts. • The rings will fit schedule 40, standard rigid conduit. • For support when cable end is not available. Suitable For Schedule 40 Conduit Only .75”- .99” (1.90-2.51) RR075 1.00”- 1.24” (2.54-3.15) RR100 1.25”- 1.49” (3.17-3.78) RR125 1.50”- 1.74” (3.81-4.42) RR150 1.75”-1.99” (4.44-5.05) RR175 2.00”- 2.49” (5.08-6.32) RR200 2.50”- 2.99” (6.35-7.59) RR250 3.00”-3.49” (7.62-8.86) RR300 3.50”-3.99” (8.89-10.13) RR350 11” (27.94) 12” (30.48) 13” (33.02) 14” (35.56) 15” (38.10) 16” (40.64) 18” (45.72) 19” (48.26) 21” (53.34) Conduit Sizes Inches Catalog Numbers Approx. Breaking Strength Lbs. (N) 11 / 4” 02213003 1,020 (4,537) • • • • • • • • 11 / 2 ” 02213007 970 (4,315) 02213009 1,610 (7,161) • • • • • • • • 02213012 1,520 (6,761) 02213013 1,610 (7,161) • • • • • • 21 / 2 ” • • 02213017 1,510 (6,716) 02213018 1,610 (7,161) • • • • • 3” • • 02213023 1,400 (6,227) 02213024 1,490 (6,627) 02213025 1,990 (8,851) 02213026 3,260 (14,500) • • • 3 1 / 2” • • • • • 02213033 2,970 (13,211) 02213034 3,260 (14,500) • • 4” • • • • • 02213041 2,680 (13,255) 02213042 2,890 (17,855) • • 2” Conduit Riser Grips Cable Sizes Inches (cm) Model Length Inches (cm) Note: Refer to page T-43 for multiple cables in a single conduit riser grip. Dimensions in Inches (mm) www.hubbell-wiring.com T-41 Wire Management Products Support Grips Conduit Riser Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-43 through T-48 Conduit Ring Dimensions Ring dimensions are found in the chart below. The ring material is corrosion resistant. These rings will fit schedule 40, standard rigid conduit sizes only. O.D. I.D. T T Ring Number C-3/4 C-1 C-11 / 4 C-11 / 2 C-2 C-21 / 2 C-3 3 1 / 2” 4” 4 1 / 2” 5” 6” C-31 / 2 C-4 C-41 / 2 C-5 C-6 O.D. Inches (cm) .94” (2.39) 1.17” (2.97) 1.50” (3.81) 1.76” (4.47) 2.23” (5.66) 2.67” (6.78) 3.20” (8.13) I.D. Inches (cm) .62” (1.57) .80” (2.03) 1.03” (2.62) 1.23” (3.12) 1.55” (3.94) 2.05” (5.21) 2.55” (6.48) S Inches (cm) • • 1.31” (3.33) 1.52” (3.86) 1.97” (5.00) 2.40” (6.10) 2.97” (7.54) T Inches (cm) .19” (.48) .19” (.48) .16” (.41) .16” (.41) .16” (.41) .16” (.41) .22” (.56) 3.80” (9.65) 4.30” (10.92) 3.05” (7.75) 3.55” (9.02) 3.47” (8.81) 3.94” (10.01) .22” (.56) .22” (.56) 4.80” (12.19) 5.30” (13.46) 6.30” (16.00) 4.03” (10.24) 4.46” (11.33) 5.36” (13.61) 4.45” (11.30) 4.96” (12.60) 5.96” (15.14) .22” (.56) .22” (.56) .25” (.63) Conduit Riser Ring Dimensions S Conduit Size Inches 3/4” 1” 1 1 / 4” 1 1 / 2” 2” 2 1 / 2” 3” T-42 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Kellems® Grips For Cable Support Technical Section For Conduit Riser Grips Only† For Cables of Equal Diameters Under “Number of Cables in One Grip,” find diameter of your single cable in vertical column. Read the grip diameter range to the right. If your diameter is the maximum of the range shown, go to the next larger size for Split Grips, stay with the same size for Closed Grips. Example: 3 cables, each with .85” (2.16cm) diameter, for a Closed Grip select the 1.50”-1.74” (3.81cm-4.42cm) range, for a Split Grip select the 1.75”-1.99” (4.44cm-5.05cm) range. Number of Equal Diameter Cables in One Grip 2 3 4 5 6 and 7 8 9 .29-.36 .24-.30 .21-.25 .18-.22 .16-.20 .15-.18 .14-.17 (.74-.91) (.61-.76) (.53-.63) (.46-.56) (.41-.51) (.38-.46) (.36-.43) .37-.43 .31-.36 .26-.30 .23-.27 .21-.24 .19-.22 .18-.20 (.94-1.09) (.79-.91) (.66-.76) (.58-.69) (.53-.61) (.48-.56) (.46-.51) .44-.58 .37-.48 .31-.41 .28-.36 .25-.32 .23-.29 .21-.27 (1.12-1.47) (.94-1.22) (.79-1.04) (.71-.91) (.63-.81) (.58-.74) (.53-.69) .59-.72 .49-.60 .42-.51 .37-.45 .33-.40 .30-.36 .28-.34 (1.50-1.83) (1.24-1.52) (1.07-1.30) (.94-1.14) (.84-1.02) (.76-.91) (.71-.86) .73-.87 .61-.72 .52-.61 .46-.54 .41-.48 .37-.43 .35-.40 (1.85-2.21) (1.55-1.83) (1.32-1.55) (1.17-1.37) (1.04-1.22) (.94-1.09) (.89-1.02) .88-1.01 .73-.85 .62-.71 .55-.63 .49-.56 .44-.51 .41-.47 (2.24-2.57) (1.85-2.16) (1.57-1.80) (1.40-1.60) (1.24-1.42) (1.12-1.30) (1.04-1.19) 1.02-1.16 .86-.96 .72-.81 .64-.72 .57-.64 .52-.58 .48-.54 (2.59-2.95) (2.18-2.44) (1.83-2.06) (1.63-1.83) (1.45-1.63) (1.32-1.49) (1.22-1.37) 1.17-1.44 .97-1.20 .82-1.02 .73-.90 .65-.80 .59-.72 .55-.67 (2.97-3.66) (2.46-3.05) (2.08-2.59) (1.85-2.29) (1.65-2.03) (1.50-1.83) (1.40-1.70) 1.45-1.73 1.21-1.45 1.03-1.22 .91-1.08 .81-.96 .73-.87 .68-.81 (3.68-4.39) (3.07-3.68) (2.62-3.10) (2.31-2.74) (2.06-2.44) (1.85-2.21) (1.73-2.06) 1.74-2.02 1.46-1.69 1.23-1.43 1.09-1.26 .97-1.11 .83-1.01 .82-.94 (4.42-5.13) (3.71-4.29) (3.12-3.63) (2.77-3.20) (2.46-2.82) (2.11-2.57) (2.08-2.39) 2.03-2.31 1.70-1.93 1.44-1.63 1.27-1.44 1.12-1.27 1.02-1.15 .95-1.08 (5.16-5.87) (4.32-4.90) (3.66-4.14) (3.23-3.66) (2.84-3.23) (2.59-2.92) (2.41-2.74) †This chart is to be used for determining grip size when multiple cables are held in a single conduit riser grip. Grip Dia. Range Inches (cm) .50-.62 (1.27-1.57) .63-.74 (1.60-1.88) .75-.99 (1.90-2.51) 1.00-1.34 (2.54-3.15) 1.25-1.49 (3.17-3.78) 1.50-1.74 (3.81-4.42) 1.75-1.99 (4.44-5.05) 2.00-2.49 (5.08-6.32) 2.50-2.99 (6.35-7.59) 3.00-3.49 (7.62-8.86) 3.50-3.99 (8.89-10.13) Select The Correct Support Grip For Cables of Unequal Diameters Step 1 Take circumference of cable bundle. Step 2 Take circumference bundle divide by 3.1416 which equals approximate cable bundle diameter. Step 3 Choose appropriate grip for application and desired breaking strength and use approximate diameter matched to the cable diameter in the catalog. NOTE: It is always recommended that, when multiple cables are installed in a support grip, the tail end of the grip be banded or tightly taped after installation on the cable bundle. Technical Data Dimensions in Inches (mm) www.hubbell-wiring.com T-43 Wire Management Products Kellems® Grips For Cable Support Technical Section Bus Drop Grips Bus Drop Grips and Safety Springs Safety Spring Kellems Bus Drop Grips are offered with either a single eye or universal bale attachment. The mesh is single weave galvanized steel with the patented wide range construction. They are suitable for indoor use only. Strain Relief Grip Bus Drop Grips Application Strain Relief Grip Motor Box Bus Drop Grips provide a safe, easy and economical method to support flexible cord or bus drop cable at bus duct and other industrial areas. Benefits • Easily installed. • Absorb tension, vibration and pull with no cable damage. • Patented mesh construction. Safety Spring Technical Data Springs can be used with single eye grips by disassembling drawbar from coil, placing through eye and replacing drawbar. T-44 www.hubbell-wiring.com Dimensions in Inches (mm) Technical Section Select the Correct Support Grip Kellems Support Grips Kellems Support Grips are used to hold the weight of Each Kellems grip is designed to work on a specific range of cable diameters. electrical cable as it hangs in a vertical, sloping or Step 1 Refer to the Kellems chart below to determine the grip horizontal position. Electrical cable must be style best suited for your application. supported, or its dead weight can cause excessive Step 2 Determine your cable outside diameter. strain or pullout at the connections resulting in power Step 3 Find the grip size that encompasses your cable failure. Support grips also absorb additional strain diameter. from flexure, vibration, expansion and contraction. Step 4 Whenever possible, use a closed mesh that assembles Kellems Support Grips listed in this catalog are over the cable end. If the cable end is not available, use made of high grade, non-magnetic tin-coated bronze a split mesh. strand. Stainless steel grips, made of alloy 302–304 Step 5 Where available, select an eye style that suits your SST for severe service or unusual environmental needs. conditions, are available on request. Step 6 Select the proper material—tinned bronze or stainless Wire Management Products Kellems® Grips For Cable Support steel*. Step 7 Estimate the tension to be put on the grip, establish the working load you require and compare this to the listed approximate breaking strength of the grip to insure that the grip will be strong enough. Refer to page L-84 for safety and working load considerations. Support Grip Selection Chart Grip Styles Closed mesh Split lace closing Split rod closing Application Page Standard, permanent support, cable end available. T-30 to T-33 Standard, permanent support, cable end unavailable. T-30 to T-33 Standard, temporary support, cable end unavailable. Tape or band tail T-30 to T-33 end of wire mesh grip after positioning for permanent support. Material* Tin-coated bronze standard or stainless steel by special request. T-30 to T-42 Standard support grips Support vertical runs to 99 ft. loads to 600 lbs. T-30 to T-33 Heavy duty grips Support vertical runs over 100 ft loads over 600 lbs. T-34, T-35 Service drop Light duty to support service entrance cable. T-36, T-37 Bus drop Light duty support, indoors only, on Bus drop cable. T-38 Conduit riser Support cable runs in rigid (Schedule 40) conduit. T-39 to T-42 Fiber optic cable support grips Support fiber optic cable. T-53 *Most catalog listed support grips are made of tin-coated bronze strand. To order stainless steel support grips, change the first three catalog number digits from 022-XX-XXX to 024-XX-XXX. Consult factory for details. Eye Styles Dimensions in Inches (mm) Double Universal www.hubbell-wiring.com Technical Data Single Offset T-45 Wire Management Products Kellems® Grips For Cable Support Technical Section Safety And Working Load Factors For Wire Mesh Grips The broad application of Kellems grips on a wide variety of objects requires that adequate safety factors be used to establish working loads. The approximate breaking strength of a Kellems grip represents an average calculation based on data established from actual direct tension testing done in our engineering laboratories. It is impossible to catalog or guarantee a safety factor suitable for all applications as operating conditions are never the same. The tension, diameter, movement, number of objects gripped, gripping surface, and the attachments used are just some of the factors which vary with each application. These factors, together with the effects of abrasion, corrosion, prior use or abuse and any other variables of a specific application, must be considered by the user and the grip replaced as appropriate. Where the conditions of the application are not well defined or known, or where risk of injury to persons or property is involved, a greater safety factor should be utilized. Under normal conditions, Kellems’ recommended factor of safety is five for catalog listed pulling grips, and ten for catalog listed support grips. The factory should be consulted for specific application recommendations where strength and holding power are important factors. Any warranty as to quality, performance or fitness for use of grips is always premised on the condition that the published breaking strengths apply only to new, unused grips, and that such products are properly stored, handled, used, maintained, and inspected by the user at a frequency appropriate for the use and condition of the grip. Examples Approx. Breaking Safety Max. Rec. Grip Style Strength Lbs. (N) Factor Load Lbs. (N) Pulling Grips 27,200 (120,986) 5 5,440 (24,197) Support 1,610 (7,161) 10 161 (716) The maximum recommended working load then is the tension to be exerted on the grip in application with a margin of safety to take care of unforeseen and unusual circumstances. Catalog Numbers 03301027 02202020 It is the end-user’s decision to determine how much of a safety factor is acceptable to him. The metric unit of measure (force) for breaking strength and load is newtons (N). To convert from newtons to the metric unit of weight (kilograms) the conversion factor is 9.808 newtons/kilogram. Support Grip Materials Material Feature Grip Type Tin-coated bronze wire Corrosion resistant for normal outside areas Non-magnetic Moderate strength High strength Support grips Service drop grips Conduit riser grips Support grips Corrosion resistant Slightly magnetic Not subject to continuous outside environment Service drop grips Bus drop grips Bus drop grips Stainless steel wire (302-304) Galvanized steel wire Approvals CSA Certifications are indicated on appropriate product catalog pages. Technical Data Note: It is always recommended that the tail end of the grip be banded after the installation on the cable to prevent accidental release of the mesh. T-46 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Kellems® Grips For Cable Support Technical Section Split Support Grip Lace Closing Instructions Single Weave Grips should be laced with single strand lacing; double weave with double strand. Lacing strands should be the same material as the grip. Kellems supplies the appropriate lacing with each grip. 1. Start the lacing at the lead or anchoring end of the grip. Thread the lacings through the first two loops of the split and pull through until the lacings are centered at this point. Lace as you would your shoe, crossing the lacings before lacing the next two loops. 2. Don’t pull lacing too tight. Leave a space between adjoining loops approximately equal to the width of one diamond of the mesh. 3. Twist the lacing strands tightly together at the tail end of the grip. 4. Wrap the ends of the lacings once or twice tightly around the tail of the grip, twisting the ends together securely. Excess lace can be cut off. Split Support Grip Rod Closing Instructions The stainless steel rod is a precise built-in feature which makes threading easy and fast. The strands of the mesh pass around the rod and match up with the strands from the opposite direction. The rod does not touch the cable at any point and therefore cannot cut the cable. Rod Closing Grips are reusable. They may be removed and reused as many times as desired. 1. Fast to install Wrap the grip around the cable and thread the rod through the performed loops with a corkscrew motion, using the curved end of the rod to engage the loops. 2. The action required is a steady push and twist simultaneously. The fingers of the left hand are used to bring the loops together just ahead of the hook on the end of the rod. 3. To remove, simply pull the rod out. Technical Data Dimensions in Inches (mm) www.hubbell-wiring.com T-47 Wire Management Products Kellems® Grips For Cable Support Technical Section Multiple Cable Selection Charts for Cables of Equal Diameters For Standard Support Grips* For Cables of Equal Diameters Under “Number of Cables in One Grip,” find diameter of your single cable in vertical column. Read the grip diameter range to the right. Caution: When a grip is used on multiple cables, the tail end of the grip should be banded or tightly taped after positioning on the cables. If your diameter is the maximum of the range shown, go to the next larger size for Split Grips, stay with the same size for Closed Grips. Example: 3 cables, each with .85” (2.16cm) diameter, for a Closed Grip select the 1.50”-1.74” (3.81cm-4.42cm) range, for a Split Grip select the 1.75”-1.99” (4.44cm-5.05cm) range. Number of Cables in One Grip 2 .30-.38 (.76-.97) .38-.44 (.97-1.12) .44-.59 (1.12-1.50) .59-.75 (1.50-1.90) .75-.90 (1.90-2.29) .90-1.07 (2.29-2.72) 1.07-1.22 (2.72-3.10) 1.22-1.53 (3.10-3.89) 1.53-1.83 (3.89-4.65) 1.83-2.14 (4.65-5.44) 2.14-2.44 (5.44-6.20) 2.44-2.75 (6.20-6.98) 2.75-3.06 (6.98-7.77) 3 .25-.31 (.63-.79) .31-.36 (.79-.91) .36-.49 (.91-1.24) .49-.63 (1.24-1.60) .63-.76 (1.60-1.93) .76-.89 (1.93-2.26) .89-1.02 (2.26-2.59) 1.02-1.28 (2.59-3.25) 1.28-1.53 (3.25-3.89) 1.53-1.79 (3.89-4.55) 1.79-2.05 (4.55-5.21) 2.05-2.30 (5.21-5.84) 2.30-2.56 (5.84-6.50) 4 .22-.27 (.56-.69) .27-.31 (.69-.79) .31-.42 (.79-1.07) .42-.54 (1.07-1.37) .54-.65 (1.37-1.65) .65-.77 (1.65-1.96) .77-.88 (1.96-2.24) .88-1.10 (2.24-2.79) 1.10-1.32 (2.79-3.35) 1.32-1.54 (3.35-3.91) 1.54-1.76 (3.91-4.47) 1.76-1.98 (4.47-5.03) 1.98-2.20 (5.03-5.59) 5 .19-.24 (.48-.61) .24-.29 (.61-.74) .29-.38 (.74-.97) .38-.48 (.97-1.22) .48-.58 (1.22-1.47) .58-.67 (1.47-1.70) .67-.77 (1.70-1.96) .77-.96 (1.96-2.44) .96-1.16 (2.44-2.95) 1.16-1.35 (2.95-3.43) 1.35-1.54 (3.43-3.91) 1.54-1.74 (3.91-4.42) 1.74-1.93 (4.42-4.90) 6 and 7 .17-.22 (.43-.56) .22-.26 (.56-.66) .26-.34 (.66-.86) .34-.43 (.86-1.09) .43-.52 (1.09-1.32) .52-.60 (1.32-1.52) .60-.69 (1.52-1.75) .69-.86 (1.75-5.54) .86-1.03 (2.18-2.62) 1.03-1.20 (2.62-3.05) 1.20-1.37 (3.05-3.48) 1.37-1.55 (3.48-3.94) 1.55-1.72 (3.94-4.37) 8 .15-.19 (.38-.48) .19-.23 (.48-.56) .23-.31 (.58-.79) .31-.39 (.79-.99) .39-.46 (.99-1.17) .46-.54 (1.17-1.37) .54-.62 (1.37-1.57) .62-.77 (1.57-1.96) .77-.93 (1.96-2.36) .93-1.08 (2.36-2.74) 1.08-1.24 (2.74-3.15) 1.24-1.39 (3.15-3.53) 1.39-1.55 (3.53-3.94) Grip Dia. Range Inches (cm) .50-.61 (1.27-1.55) .62-.74 (1.57-.188) .75-.99 (1.90-2.51) 1.00-1.24 (2.54-3.15) 1.25-1.49 (3.17-3.78) 1.50-1.74 (3.81-4.42) 1.75-1.99 (4.44-5.05) 2.00-2.49 (5.08-6.32) 2.50-2.99 (6.35-7.59) 3.00-3.49 (7.62-8.86) 3.50-3.99 (8.89-10.13) 4.00-4.49 (10.16-11.40) 4.50-4.99 (11.43-12.67) 9 .14-.18 (.36-.46) .18-.21 (.46-.53) .21-.28 (.53-.71) .28-.35 (.71-.89) .36-.42 (.89-1.07) .42-.49 (1.07-1.24) .49-.56 (1.24-1.42) .56-.71 (1.42-1.80) .71-.85 (1.80-2.16) .85-.99 (2.16-2.51) .99-1.13 (2.51-2.87) 1.13-1.27 (2.87-3.23) 1.27-1.41 (3.23-3.58) *This chart is not to be used for Conduit Riser Grips. Refer to the chart for Conduit Riser multiple cable section. Technical Data Select The Correct Support Grip For Cables of Unequal Diameter Step 1 Take circumference of cable bundle. Step 2 Take circumference bundle divide by 3.1416 which equals approximate cable bundle diameter. Step 3 Choose appropriate grip for application and desired breaking strength and use approximate diameter matched to the cable diameter in the catalog. NOTE: It is always recommended that, when multiple cables are installed in a support grip, the tail end of the grip be banded or tightly taped after installation on the cable bundle. T-48 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Kellems® Products for Fiber Optic Cable Pulling Tools, Support Devices OPTISOKTM grip is a new and revolutionary tool to pull preterminated fiber optic cables. They will protect the connectors and guide the bundle through the pulling environment. Pulling Grips are used for outside plant cable. They are easy to install and remove, reusable, and have a slim profile for small build up. Grips for cable support are easy to install or position. They come in a closed style when the cable end is available, and a split rod style for mid-span installation. Will support the cable’s weight as it hangs in vertical, sloping or horizontal position. Fiber Optic Grips Dimensions in Inches (mm) www.hubbell-wiring.com T-49 Wire Management Products Pulling Grips Fiber Optic Cable Grips Special Purpose Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-54 through T-57. OPTISOK™ Non-metallic Fiber Optic Pulling Tool For Preterminated, Inside Plant Fiber Optic Cables and Bundles of Twisted Pair Patented OPTISOK™ Non-Metallic Fiber Optic Pulling Tool Bundle/Size Range Inches (cm) Approx. O/A Length Inches (cm) Ring O.D. Inches (cm) Ring Thickness Inches (cm) Maximum Work Load lbs. (N) Catalog Numbers .125”-.562” (.318-1.427) .250”-.750” (.635-1.905) .750”-1.750” (19.05-44.50) 28” (71.12) 31” (78.74) 33” (83.82) .71” (18.03) .71” (18.03) 1.57” (39.88) .10” (2.54) .10” (2.54) .16” (4.06) 30 (133) 40 (178) 50 (222) CCPS1 CCPS2 CCPS3 Pulling Grip For Loose Tube Fiber Optic Cable, Galvanized Steel Fiber Optic Grips Patented Pulling Grip For Loose Tube Fiber Optic Cable, Galvanized Steel Diameter Range Inches (cm) .312”-.625” (.79-1.59) T-50 Mesh Length Inches (cm) 22.5” (57.15) Eye Length Inches (cm) 6.3” (16.00) Eye Diameter Inches (cm) .20” (.51) www.hubbell-wiring.com Lug Diameter Inches (cm) .51” (1.30) Maximum Breaking Strength lbs. (N) 3,000 (13,344) Catalog Number PFOLT312 Dimensions in Inches (mm) Fiber Optic Cable Grips Double/Single Weave Mesh, Galvanized Steel, for Outside Plant Cable Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-54 through T-57. F-O Pulling Grip, Flexible Eye E M Wire Management Products Pulling Grips Patented D F-O Pulling Grip, Flexible Eye Cable Diameter Range Inches (cm) .10”-.22” (.25-.56) .21”-.35” (.53-.89) .32”-.48” (.81-1.22) .42”-.61” (1.07-1.55) .53”-.74” (1.35-1.88) .64”-.87” (1.63-2.21) E-Eye length Approx. Breaking Strength E M D Lbs. (N) Approx Inches (cm) 1,000 (4,448) 5.5” (14) 9” (23) 0.8” (2) 1,500 (6,672) 5.5” (14) 14” (36) 0.8” (2) 2,200 (9,786) 6.0” (15) 18” (46) 0.9” (2.30) 2,800 (12,454) 6.0” (15) 21” (53) 0.9” (2.30) 3,300 (14,678) 6.5” (17) 24” (61) 1.3” (3.30) 4,700 (20,906) 6.5” (17) 27” (69) 1.3” (3.30) M-Mesh length at nominal diameter Catalog Numbers 033291000 033291001 033291002 033291003 033291004 033291005 F-O Pulling Grip, Swivel Eye E M Patented D F-O Pulling Grip, Swivel Eye Approx. Breaking E M Strength Approx. Approx. Lbs. (N) Inches (cm) Inches (cm) 1,000 (4,448) 4.0” (10.16) 9” (22.86) 1,500 (6,672) 4.0” (10.16) 14” (35.56) 2,200 (9,786) 4.0” (10.16) 18” (45.72) 2,800 (12,454) 4.0” (10.16) 21” (53.34) 3,300 (14,678) 4.5” (11.43) 24” (60.96) 4,700 (20,906) 4.5” (11.43) 27” (68.58) M-Mesh length at nominal diameter Dimensions in Inches (mm) D Approx. Inches (cm) 0.9” (2.29) 0.9” (2.29) 0.9” (2.29) 0.9” (2.29) 1.3” (1.3) 1.3” (1.3) Catalog Numbers 033291007 033291008 033291009 033291010 033291011 033291012 www.hubbell-wiring.com Fiber Optic Grips Cable Diameter Range Inches (cm) .10”-.22” (.25-.56) .21”-.35” (.53-.89) .32”-.48” (.81-1.22) .42”-.61” (1.07-1.55) .53”-.74” (1.35-1.88) .64”-.87” (1.63-2.21) E-Eye length T-51 Wire Management Products Pulling Grips Fiber Optic Cable Grips Galvanized Steel for Outside Plant Cable Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-54 through T-57. F-O Pulling Grip, Flexible Eye, Low Profile, Double/Single Weave Mesh M E F-O Pulling Grip, Flexible Eye, Low Profile, Approx. Cable Breaking E Diameter Range Strength Approx. Inches (cm) Lbs. (N) Inches (cm) .10”-.22 (.25-.56) 900 (4,003) 7.5” (19) .21”-.35” (.53-.89) 1,400 (6,227) 7.5” (19) .32”-.48” (.81-1.22) 2,000 (8,896) 8.5” (22) .42”-.61” (1.07-1.55) 2,500 (11,120) 8.5” (22) .53”-.74” (1.35-1.88) 3,000 (13,344) 8.5” (22) .64”-.87” (1.63-2.21) 4,200 (18,862) 8.5” (22) .75”-1.00” (1.90-2.54) 4,200 (18,862) 8.5” (22) E-Eye length M-Mesh length at nominal diameter M Approx. Inches (cm) 10” (25) 14” (36) 19” (48) 21” (53) 23” (58) 25” (64) 28” (71) Catalog Numbers 033291193 033291194 033291195 033291196 033291197 033291198 033291199 F-O Pulling Grip, Single Weave Mesh M E F-O Slack Pulling Grip, Split Mesh Rod Closing, Single Weave Fiber Optic Grips Approx. Cable Breaking E Diameter Range Strength Approx. Inches (cm) Lbs. (N) Inches (cm) .25”-.37” (.63-.94) 300 (1,334) 3” (7.6) .38”-.49” (.97-1.24) 800 (3,558) 3” (7.6) .50”-.61” (1.27-1.55) 800 (3,558) 3” (7.6) .62”-.74” (1.57-1.88) 1,200 (5,338) 3” (7.6) E-Eye length M-Mesh length at nominal diameter T-52 www.hubbell-wiring.com M Approx. Inches (cm) 4.7” (12) 5” (13) 7.5” (19) 8” (20) Catalog Numbers 033291015 033291016 033291017 033291018 Dimensions in Inches (mm) Fiber Optic Cable Grips Single Weave, Tin-Coated Bronze Single Eye, Closed Mesh Single Weave Cable Diameter Range Inches (cm) .18”-.25” (.46-.63) .23”-.32” (.58-.81) .30”-.39” (.76-.99) .37”-.48” (.94-1.22) .46”-.58” (1.17-1.47) .56”-.71” (1.42-1.80) .69”-.88” (1.75-2.24) E-Eye length Approx. Breaking E Strength Approx. Lbs. (N) Inches (cm) 300 (1,334) 3” (7.6) 300 (1,334) 3” (7.6) 300 (1,334) 4” (10) 300 (1,334) 5” (13) 400 (1,779) 6” (15) 600 (2,669) 7” (18) 800 (3,558) 8” (20) M-Mesh length at nominal diameter M Approx. Inches (cm) 1.7” (4.30) 2.5” (6.40) 2.5” (6.40) 4” (10) 4” (10) 5.5” (14) 6” (15) Catalog Numbers 022291000 022291001 022291002 022291003 022291004 022291005 022291006 Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-54 through T-57. For permanent support when cable end is available to be installed through grip. Wire Management Products Support Grips E M Single Eye, Split Mesh, Rod Closing Single Weave Approx. Cable Breaking E Diameter Range Strength Approx. Inches (cm) Lbs. (N) Inches (cm) .18”-.25” (.46-.63) 300 (1,334) 3” (7.60) .23”-.32” (.58-.81) 300 (1,334) 3” (7.60) .30”-.39” (.76-.99) 300 (1,334) 4” (10) .37”-.48” (.94-1.22) 300 (1,334) 5” (13) .46”-.58” (1.17-1.47) 400 (1,779) 6” (15) .56”-.71” (1.42-1.80) 600 (2,669) 7” (18) .69”-.88” (1.75-2.24) 800 (3,558) 8” (20) E-Eye length M-Mesh length at nominal diameter M Approx. Inches (cm) 2.5” (6.40) 2.5” (6.40) 2.5” (6.40) 4” (10) 5” (13) 5” (13) 6” (15) Single Eye, Closed Mesh, Single Weave Catalog Numbers 022291016 022291017 022291018 022291019 022291020 022291021 022291022 For support when cable end not available. E M Single Eye, Split Mesh, Rod Closing, Single Weave Fiber Optic Grips Dimensions in Inches (mm) www.hubbell-wiring.com T-53 Wire Management Products Kellems® Fiber Optic Cable Products Technical Section Kellems has wide experience with grips for the new technology of fiber optic cable. As the industry leader in producing wire mesh grips for the stringent requirements of fiber optic applications, Kellems has developed several completely new series of grips for use with fiber optic communications cable. These new grips include pulling grips with built in swivels, grips with steel ends to protect fragile cable ends, grips with low profiles to pull cables in tight places and the OPTISOK™ an effective tool to place preterminated cables. Also available are grips to support fiber optic cable. Select the Correct Fiber Optic Grip Each Kellems grip is designed to work on a specific range of cable diameters. Step 1 Determine your cable outside diameter. Step 2 Find the grip size that encompasses your cable diameter. Step 3 Whenever possible, use a closed mesh that assembles over the cable end. If the cable end is not available, use a split mesh. Step 4 Where available, select an eye style that suits your needs. Step 5 Estimate the tension to be put on the grip, establish the working load you require and compare this to the listed approximate breaking strength of the grip to insure that the grip will be strong enough. Safety And Working Load Factors For Wire Mesh Grips The broad application of Kellems grips on a wide variety of objects requires that adequate safety factors be used to establish working loads. The approximate breaking strength of a Kellems grip represents an average calculation based on data established from actual direct tension testing done in our engineering laboratories. It is impossible to catalog or guarantee a safety factor suitable for all applications as operating conditions are never the same. The tension, diameter, movement, number of objects gripped, gripping surface, and the attachments used are just some of the factors which vary with each application. These factors, together with the effects of abrasion, corrosion, prior use or abuse and any other variables of a specific application, must be considered by the user and the grip replaced as appropriate. Where the conditions of the application are not well defined or known or where risk of injury to persons or property is involved, a greater safety factor should be utilized. Under normal conditions, Kellems’ recommended factor of safety is five for catalog listed pulling grips, and ten for catalog listed support grips. The factory should be consulted for specific application recommendations where strength and holding power are important factors. Any warranty as to quality, performance or fitness for use of grips is always premised on the condition that the published breaking strengths apply only to new, unused grips, and that such products are properly stored, handled, used, maintained and inspected by the user at a frequency appropriate for the use and condition of the grip. For grip applications on materials other than those that the grips have been specifically designed for, consult the factory. Examples Grip Approx. Breaking Safety Max. Rec. Catalog Style Strength Lbs. (N) Factor Load Lbs. (N) Numbers Pulling 2,500 (11,120) 5 500 (2,224) 033291196 Support 400 (1,779) 10 40 (178) 022291004 The maximum recommended working load then is the tension to be exerted on the grip in application with a margin of safety to take care of unforeseen and unusual circumstances. It is the end-user’s decision to determine how much of a safety factor is acceptable to him. Fiber Optic Grip Materials Material Galvanized steel wire Technical Data Tin-coated bronze wire Non-metallic braid Features High strength Not subject to continuous outside environment Corrosion resistant for normal outside areas Non-magnetic Moderate strength Superior flex life Non-conductive Corrosion resistant Moderate strength Product Group Pulling Grip Support grips OPTISOK Approvals CSA Certification is indicated on appropriate product catalog pages. T-54 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Kellems® Fiber Optic Cable Products Technical Section Product Data OPTISOK™ Kellems offers a unique and simple to use tool for the installation of preconnectorized fiber optic cables, jumpers and bundles of twisted pair communication cables - the OPTISOK. The OPTISOK is a highly flexible and expandable nonmetallic sleeve open on one end and with a pulling ring on the other. It will expand to enclose the larger group of fiber optic connectors and grab the cable below the connector bundle by wrapping and taping to provide a gripping tool that will grab the cable(s) below the connectors. The pulling ring can be attached to a pulling line or fish tape and the OPTISOK will act as the pulling tool. 1 OPTISOK will contain and protect the connector bundle and save time and labor by making the pulling job easier, protecting the connectors from possible damage during the pull and facilitating the passage of the connector bundle through cramped and tight spaces. The OPTISOK can be used to pull cables through plenums, underfloor duct, office partitions, raised access floors and conduits. Three sizes are available for all applications. How to Select OPTISOK • Identify connector bundle diameter to be inserted into the OPTISOK. • Choose appropriate catalog number based on size range. 2 Installation Information Step 1. Expand open end of OPTISOK and gently work in fiber optic connector bundle. Step 2. Still gently, work connector bundle up to the forward section of the Optisok. Step 3. Starting at approximately 6” from tail end of OPTISOK, tightly fold over the Optisok around cables and tape wrapped section 3” past tail end onto the bundle. 3 Step 4. Securely attach pulling line or tape to pulling ring. Technical Data Note: To remove OPTISOK carefully unwrap tape and slide out cables and connectors or cut OPTISOK away without damaging connectors or cables. 4 Dimensions in Inches (mm) www.hubbell-wiring.com T-55 Wire Management Products Kellems® Fiber Optic Cable Products Technical Section Product Data Pulling Grip for Loose Tube Fiber Optic Cable Kellems offers a wire mesh specifically designed to pull loose tube fiber optic cable and meet the special pulling requirements recommended by fiber optic cable manufacturers. Many fiber optic cable manufacturers require special cable preparation prior to pulling where a short section of the outer jacket is stripped off exposing the aramid strength member. This creates two cable diameters, one including the jacket and a second smaller diameter at the strength member. Kellems new grip with its special weave will accommodate and securely grab both diameters, at the outside jacket and the internal aramid strength member. Additionally, this galvanized steel mesh grip has longer leads at the pulling eye to facilitate pulling the cable up through the top, a very low profile lug and eye to slip through tight areas, and short shoulders to protect the cable while maintaining the slim profile. The grip can be used to pull cable overhead as well as underground through conduit and duct. It easily mates with a swivel and has the necessary strength to securely make pulls. Application Information • Prior to pulling cable, follow cable manufacturers’ cable preparation recommendations. • Never exceed cable manufacturers’ pulling tension recommendations. • Never use grips to approximate breaking strength-factor of safety of 5 recommended. Pulling Grips for Other Outside Plant Cables, Swivel Eye, Flexible Eye, Split Style, Low Profile Kellems Pulling Grips for fiber optic cable are made of high strength galvanized steel strand. They feature a multiweave mesh, with one-half the mesh length double weave, and the second half single weave. This special weave provides positive holding power while allowing the grip to remain flexible with no damage to the cable jacket. Added features include a steel nose cone which protects the cable end and allows the grip to pass easily through conduit and enclosures. The eye connects easily to a swivel or a pulling line. Several grip sizes are available to accommodate all diameters of fiber optic cable. Application Kellems Flexible Eye Pulling Grips for fiber optic cable are used for the installation of fiber optic communication lines either underground, overhead, through conduit or through enclosures. They will fit single cables or cable bundles, are easily installed on the cable, and are reusable. Technical Data Benefits • • • • • T-56 High strength multiweave mesh for positive holding power. Highly flexible mesh to follow the pulling path of the cable. Steel nose cone reduces snags and hang-ups and protects cable end. Easily installed and removed. A dependable, reusable pulling tool. www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Kellems® Fiber Optic Cable Products Technical Section Product Data Support Grips for Fiber Optic Cable Kellems Support Grips for fiber optic cable are specially designed to hold the cable weight as it hangs in a vertical or horizontal position. Fiber optic cable must be supported and Kellems Grips provide the support easily and economically. These grips are made of high grade, non-magnetic tin-coated bronze strand. They are offered in universal bale or single eye configurations and are available in either closed mesh (for use where the cable end is available) or in split mesh, rod closing (for installation on existing cable runs or at specific locations). Split Support Grip Rod Closing Instructions The stainless steel rod is a precise built-in feature which makes threading easy and fast. The strands of the mesh pass around the rod and match up with the strands from the opposite direction. The rod does not touch the cable at any point and therefore cannot cut the cable. Rod Closing Grips are reusable. They may be removed and reused as many times as desired. Fast to Install Step 1. Wrap the grip around the cable and thread the rod through the preformed loops with a corkscrew motion, using the curved end of the rod to engage the loops. Step 2. The action required is a steady push and twist simultaneously. The fingers of the left hand are used to bring the loops together just ahead of the hook on the end of the rod. Step 3. To remove, simply pull the rod out. Technical Data Dimensions in Inches (mm) www.hubbell-wiring.com T-57 Wire Management Products Note Page (Blank Page) NOTES T-58 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Kellems® Grips for Strain Relief Liquidtight, Dusttight For Insulated Cables and Flexible, Liquidtight Conduits Endless weave provides easy cable/flexible conduit installation. Stainless steel mesh is corrosion resistant. Can be used inside or outside. It eliminates cable or flexible conduit pull out and reduces costly downtime. Multiweave grip gives cable arc-of-bend control minimizing cable damage and extending cable life. It is the strongest strain relief device available. Meets and exceeds all code requirements. Prevents cable/conduit pull-out. A liquidtight fitting is available with both cable and conduit fittings. Prevents liquids from running through the fitting into the enclosure. Deluxe Cord GrIps An NPT and PG threaded body allows easy attachment to either threaded hub or knock-out in box. Dimensions in Inches (mm) www.hubbell-wiring.com T-59 Wire Management Products Strain Relief Deluxe Cord Grips Aluminum Fittings, Stainless Steel Mesh, Liquidtight, for Insulated Cables Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-68 through T-74. Straight Male Aluminum Body Aluminum Compression Nut Deluxe Cord GrIps Stainless Steel Mesh Tapered Threads Aluminum Collar Neoprene Bushing *Cable jacket may have to be stripped to pass through connector body. Kellems® Deluxe Cord Grips are suitable for use in hazardous locations per Class I Div. 2, Class II Div. 1 & 2, Class III Div. 1 & 2 of the National Electric Code Sections 501-4(b), 5024(a), 502-4(b), 503-3(a) and 503 3(b). T-60 Straight Male Thread Grip Diameter Range Inches (cm) .250”-.312” (.63-.79) .312”-.375” (.79-.95) .375”-.437” (.95-1.11) .187”-.250” (.47-.63) .250”-.375” (.63-.95) .375”-.500” (.95-1.27) .500”-.625” (1.27-1.59) .625”-.750” (1.59-1.90) .750”-.875” (1.90-2.22) .187”-.250” (.47-.63) .250”-.375” (.63-.95) .375”-.500” (.95-1.27) .500”-.625” (1.27-1.59) .625”-.750” (1.59-1.90) .750”-.875” (1.90-2.22) .375”-.500” (.95-1.27) .500”-.625” (1.27-1.59) .625”-.750” (1.59-1.90) .750”-.875” (1.90-2.22) .875”-1.000” (2.22-2.54) 1.000”-1.125” (2.54-2.86) 1.125”-1.250” (2.86-3.17) 1.250”-1.375” (3.17-3.49) .750”-.875” (1.90-2.22) .875”-1.000” (2.22-2.54) 1.000”-1.125” (2.54-2.86) 1.125”-1.250” (2.86-3.17) 1.250”-1.375” (3.17-3.49) .750”-.875” (1.90-2.22) .875”-1.000” (2.22-2.54) 1.000”-1.125” (2.54-2.86) 1.125”-1.250” (2.86-3.17) 1.250”-1.375” (3.17-3.49) 1.312”-1.437” (3.33-3.65) 1.437”-1.562” (3.65-3.97) 1.562”-1.687” (3.97-4.28) 1.687”- 1.812” (4.28-4.60) 1.750”-1.875” (4.44-4.76) 1.250”-1.375” (3.17-3.49) 1.312”-1.437” (3.33-3.65) 1.437”-1.562” (3.65-3.97) 1.562”-1.687” (3.97-4.28) 1.687”-1.812” (4.28-4.60) 1.750”- 1.875” (4.44-4.76) 1.812”-1.937” (4.60-4.92) 1.937”-2.062” (4.92-5.24) 2.062”-2.187” (5.24-5.55) 2.187”-2.312” (5.55-5.87) 2.312”-2.437” (5.87-6.19) 1.688”-1.812” (4.29-4.60) 1.812”-1.937” (4.60-4.92) 1.937”-2.062” (4.92-5.24) 2.062”-2.187” (5.24-5.55) 2.187”-2.312” (5.55-5.87) 2.312”-2.437” (5.87-6.19) 1.937”-2.062” (4.92-5.24) 2.062”-2.187” (5.24-5.55) 2.187”-2.312” (5.55-5.87) 2.312”-2.437” (5.87-6.19) 2.437”-2.625” (6.19-6.67) 2.625”-2.812” (6.67-7.14) 2.812”-3.000” (7.14-7.62) 3.000”-3.250” (7.62-8.25) www.hubbell-wiring.com Thread Size N.P.T. (Inches) Form Size 3 /8” F1 1/2” F2 1/2” F3 3/4” F2 3/4” F3 1” F4 1” F5 11/4” F5 11/2” F5 11/2” F6 2” F6 2” F7 21/2” F7 3” F7 3” F8 Catalog Numbers 07401001 07401002 07401003 07401004 07401006 07401008 07401010 074011247* 074011248* 07401011 07401013 07401015 07401017 07401018 074011249* 074011195 07401019 07401021 07401023 07401025 074011250* 074011028* 074011029* 074011251 07401026 07401027 07401028 074011178* 074011252 07401029 07401030 07401031 07401032 074011253 074011254* 074011255* 074011256* 074011257* 074011258 074011259 07401033 07401034 07401035 074011260 074011261 074011262* 074011263* 074011264* 074011265* 074011030 074011031 074011032 074011033 074011034 074011266* 074011036 074011037 074011038 074011039 074011186 074011187 074011188 074011189* Dimensions in Inches (mm) Deluxe Cord Grips Aluminum Fittings, Stainless Steel Mesh, Liquidtight, for Insulated Cables 90° Male Thread Grip Diameter Range Inches (cm) .250”-.312” (.63-.79) .312”-.375” (.79-.95) .375”-.437” (.95-1.11) .187”-.250” (.47-.63) .250”-.375” (.63-.95) .375”-.500” (.95-1.27) .500”-.625” (1.27-1.59) .375”-.500” (.95-1.27) .500”-.625” (1.27-1.59) .625”-.750” (1.59-1.90) .750”-.875” (1.90-2.22) .500”-.625” (1.27-1.59) .625”-.750” (1.59-1.90) .750”-.875” (1.90-2.22) .875”-1.000” (2.22-2.54) 1.000”-1.125” (2.54-2.86) .750”-.875” (1.90-2.22) .875”-1.000” (2.22-2.54) 1.000”-1.125” (2.54-2.86) 1.125”-1.250” (2.86-3.17) 1.000”-1.125” (2.54-2.86) 1.125”-1.250” (2.86-3.17) 1.250”-1.375” (3.17-3.49) 1.312”-1.437” (3.33-3.65) 1.437”-1.562” (3.65-3.97) 1.687”-1.812” (4.28-4.60) 1.750”-1.875” (4.44-4.76) Thread Size N.P.T. (Inches) Form Size 3/8” F1 1 /2” F2 3 /4” F3 1” F4 1 1 /4” F5 11 /2” F5 2” F6 Catalog Numbers 07401071 07401072 07401073 07401074 07401076 07401078 07401080* 07401081 07401083 07401084* 074011275* 07401085 07401087 07401089 07401091* 074011229* 074011230 07401137 07401108 074011042* 074011045 074011046 074011047 074011233 074011244 074011246 074011234* Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-68 through T-74. Wire Management Products Strain Relief 90° Female Thread .375”-.500” .500”-.625” (.95-1.27) (1.27-1.59) 1 /2” F2 07401043 07401045 .500”-.625” .625”-.750” (1.27-1.59) (1.59-1.90) 3/4” 3/4” F2 F4 07401052 07401053 1 /2” F2 45° Male Thread .250”-.375” .375”-.500” .500”-.625” .500”-.625” .625”-.750” .750”-.875” .625”-.750” .750”-.875” .875”-1.000” 1.000”-1.125” 1.125”-1.250” (.63-.95) (.95-1.27) (1.27-1.59) (1.27-1.59) (1.59-1.90) (1.90-2.22) (1.59-1.90) (1.90-2.22) (2.22-2.54) (2.54-2.86) (2.86-3.17) 3/4” F3 1” F4 1 1 /4” F5 074011236 074011021 074011237* 074011049 074011051* 074011239* 074011055 074011057 074011199* 074011059 074011060 Female *Cable jacket may have to be stripped to pass through connector body. Dimensions in Inches (mm) www.hubbell-wiring.com T-61 Deluxe Cord Grips 45° Wire Management Products Strain Relief Deluxe Cord Grips Nylon Fittings, Stainless Steel Mesh, Liquidtight, for Insulated Cables Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-68 through T-74. Straight Male Thread Grip Diameter Range Inches (cm) .187”-.250” (.47-.63) .250”-.375” (.63-.95) .375”-.500” (.95-1.27) .500”-.625” (1.27-1.59) .375”-.500” (.95-1.27) .500”-.625” (1.27-1.59) .625”-.750” (1.59-1.90) .750”-.875” (1.90-2.22) .625”-.750” (1.59-1.90) .750”-.875” (1.90-2.22) .875”-1.000” (2.22-2.54) 1.000”-1.125” (2.54-2.86) Thread Size N.P.T. (Inches) Form Size 1 /2” F2 3/4” F3 1” F4 Catalog Numbers 074011331 074011332 074011333 074011334* 074011335 074011336 074011337 074011338* 074011341 074011342 074011343 074011344* 90° Male Thread Grip Diameter Range Thread Size Form Inches (cm) N.P.T. (Inches) Size .250”-.375” (.63-.95) 1 /2” .375”-.500” (.95-1.27) F2 .500”-.625” (1.27-1.59) .375”-.500” (.95-1.27) 3/4” .500”-.625” (1.27-1.59) F3 .625”-.750” (1.59-1.90) *Cable jacket may have to be stripped to pass through connector body. Straight Male Catalog Numbers 074011346 074011347 074011348* 074011349 074011350 074011351* 90° Deluxe Cord Grips Nylon Nylon Body Compression Nut Tapered Threads Stainless Steel Mesh T-62 Stainless Steel Collar Neoprene Bushing www.hubbell-wiring.com Dimensions in Inches (mm) Deluxe Cord Grips Nylon Fittings, Non-metallic Mesh, Liquidtight, for Insulated Cables and Stainless Steel Fittings, Stainless Steel Mesh, Liquidtight, for Insulated Cables Nylon Fittings Non-metallic Mesh, Liquidtight for Insulated Cables Straight Male Thread Grip Diameter Range Inches (cm) .187”-.250” (.47-.63) .250”-.312” (.63-.79) .312”-.375” (.79-.95) .187”-.250” (.47-.63) .250”-.375” (.63-.95) .375”-.500” (.95-1.27) .375”-.500” (.95-1.27) .500”-.625” (1.27-1.59) .625”-.750” (1.59-1.90) .500”-.625” (1.27-1.59) .625”-.750” (1.59-1.90) .750”-.875” (1.90-2.22) .875”-1.000” (2.22-2.54) Thread Size N.P.T. (Inches) Form Size 3/8” F1 1 /2” F2 3/4” F3 1” F4 Thread Size N.P.T. (Inches) 1 /2” Form Size F2 3/4” F3 1” F4 Catalog Numbers CG304NM CG305NM CG306NM CG404NM CG406NM CG408NM CG608NM CG610NM CG612NM CG810NM CG812NM CG814NM CG816NM Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-68 through T-74. Wire Management Products Strain Relief 90° Male Thread Grip Diameter Range Inches (cm) .250”-.375” (.63-.95) .375”-.500” (.95-1.27) .375”-.500” (.95-1.27) .500”-.625” (1.27-1.59) .625”-.750” (1.59-1.90) .625”-.750” (1.59-1.90) .750”-.875” (1.90-2.22) Catalog Numbers CG40690NM CG40890NM CG60890NM CG61090NM CG61290NM* CG81290NM CG81490NM Straight Male Note: Non-metallic locknuts are available upon request. Refer to page L-99. *Cable jacket may have to be stripped to pass through connector body. Stainless Steel Fittings, Stainless Steel Mesh, Liquidtight, for Insulated Cables Straight Male Thread Thread Size N.P.T. (Inches) Form Size 1 /2” F2 3/4” F3 1” F4 Catalog Numbers CG404SST CG406SST CG408SST CG410SST CG608SST CG610SST CG612SST CG614SST CG810SST CG812SST CG814SST CG816SST 90° Deluxe Cord Grips Grip Diameter Range Inches (cm) .187”-.250” (.47-.63) .250”-.375” (.63-.95) .375”-.500” (.95-1.27) .500”-.625” (1.27-1.59) .375”-.500” (.95-1.27) .500”-.625” (1.27-1.59) .625”-.750” (1.59-1.90) .750”-.875” (1.90-2.22) .500”-.625” (1.27-1.59) .625”-.750” (1.59-1.90) .750”-.875” (1.90-2.22) .875”-1.000” (2.22-2.54) Straight Male Dimensions in Inches (mm) www.hubbell-wiring.com T-63 Wire Management Products Strain Relief PG Threaded Deluxe Cord Grip Aluminum Fittings, Stainless Steel Mesh, Liquidtight, for Insulated Cables Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-68 through T-74. Straight Male Thread Cord Diameter Range Hub Catalog Inches (cm) Size Numbers .500”-.625” (1.27-1.59) PG16 074PG16010 .500”-.625” (1.27-1.59) PG21 074PG21010 .625”-.750” (1.59-1.90) PG21 074PG211247 .750”-.875” (1.90-2.22) PG21 074PG211248 .625”-.750” (1.59-1.90) PG29 074PG29021 .750”-.875” (1.90-2.22) PG29 074PG29023 .875”-1.000” (2.22-2.54) PG29 074PG29025 1.125”-1.250” (2.86-3.17) PG29 074PG291028* 1.125”-1.250” (2.86-3.17) PG36 074PG36028* *Cable jacket may have to be stripped to pass through connector body. Specifications Straight Male Material Body Mesh Bushing Aluminum Stainless Steel Neoprene Operating Temperature Hazardous Locations Flammability Mesh grip Fitting Rated UL 94HB. Rated UL 94V-2. Control numbers UL898D, UL899D. Deluxe Cord Grips Agency Approvals Underwriters Laboratories Inc. Wet Locations The products are suitable for use in wet locations when a listed sealing ring is used between box and fitting. –30° F to +225° F (–34° C to +107° C). Suitable for use in hazardous locations per Class 1, Div. 2, Class II, Div. 1 & 2, Class III, Div. 1 & 2. T-64 www.hubbell-wiring.com Dimensions in Inches (mm) Adapters for Multi-Pin, Circular, Connectors Aluminum Adapters for Multi-Pin Connectors Kellems Adapters are devices formating AN-MS connectors and other multi-pin connectors to Kellems grips with NPT threaded fittings. They are made of aluminum with internal threads and replace the connector cord clamp. These adapters permit the installation of Kellems Grips, to prevent cable or conduit pull-out and control arc-of-bend. Applications Adapters allow the installation of Kellems® Grips on multi-pin connectors at electrical consoles, mobile equipment, control switches, assembly equipment and testing machines. Benefits • Easy installation. • Allows the use of Kellems grips. • Extends connector and cable life. Wire Management Products Strain Relief Liquidtight Adapters Adapters AN-MS Connector Size** AN-MS Cable Clamp Number*** Thread Size A in. 8S, 10S 10SL, 12, 12S 14, 14S 3057-3 3057-4 3057-6 1/2” 5/8” 3/4” 14, 14S 16, 16S 18 3/4” 7/8” Deluxe Cord Grips N.P.T. Thread Catalog Size B in. Numbers Cable Diameter Range Inches (cm) Liquidtight Conduit Grips (Insulated Throat) Strain Relief Grips Catalog Numbers Cable Diameter Range Inches (cm) Catalog Numbers Catalog Numbers 091041000 .250”-.312” (.63-.79) 091041001 .312”-.375” (.79-.95) 091041002 .375”-.437” (.95-1.11) 07401001 07401002 07401003 091041003 .187”-.250” (.47-.63 091041004 .250”-.375” (.63-.95) 091041006 .375”-.500” (.95-1.27) .500”-.625” (1.27-1.59) 07401004 .24”-.32” (.61-.81) 073031200 07401006 .32”-.43” (.81-1.09) 073031201 07401008 .43”-.54” (1.09-1.37) 073031202 07401010* – 074093512 – 7/8” x 20 3/4” 1” x 20 13/16” x 18 091041005 .187”-.250” (.47-.63) 091041007 .250”-.375” (.63-.95) 091041008 .375”-.500” (.95-1.27) .500”-.625” (1.27-1.59) .625”-.750” (1.59-1.90) 07401011 07401013 07401015 07401017 07401018 .54”-.74” (1.37-1.85) 073031203 074093513 3057-12 3057-16 3057-20 3057-24 13/16” x 18 17/16” x 18 13/4” x 18 1” 2” x 18 091041009 091041010 091041012 091041015 074011195 07401019 07401021 .73”-.97” (1.85-2.46) 073031204 07401023 07401025 074093514 24, 28 32 36 3057-16 3057-20 3057-24 17/16” x 18 13/4” x 18 11/4” 2” x 18 091041011 .750”-.875” (1.90-2.22) 091041013 .875”-1.000” (2.22-2.54) 091041016 1.000”-1.125” (2.54-2.86) 1.125”-1.375” (2.86-3.17) 074011251 07401026 07401027 .97”-1.25” (2.46-3.17) 073031205 07401028 32 36 40 3057-20 3057-24 3057-28 13/4” x 18 2” x 18 21/4” x 16 091041014 .875”-1.000” (2.22-2.54) 091041017 1.000”-1.125” (2.54-2.86) 091041019 1.125”-1.250” (2.86-3.17) 1.250”-1.375” (3.17-3.49) 07401029 07401030 07401031 07401032 x 28 x 24 x 20 3/8” 3057-6 3057-8 3057-10 x 20 x 20 1” x 20 1/2” 16, 16S 18 20, 22 3057-8 3057-10 3057-12 20, 22 24, 28 32 36 11/2” .375”-.500” (.95-1.27) .500”-.625” (1.27-1.59) .625”-.750” (1.59-1.90) .750”-.875” (1.90-2.22) .875”-1.000” (2.22-2.54) – 074093515 074093516 * Cable jacket may have to be stripped to pass through connector body. ** No. stamped on connector shell. *** No. stamped on clamp shell. Thread "A" N.P.T. Thread Size "B" Cable Or Conduit Grip Connector Adapter Adapters Dimensions in Inches (mm) www.hubbell-wiring.com T-65 Wire Management Products Strain Relief I-Grips Plastic-Coated, Galvanized Steel Mesh for Insulated Cables Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-68 through T-74. Application Kellems® I-Grips will fit 2 wire, 3 wire, 4 wire and 5 wire Hubbell Insulgrip® plugs and connector bodies. The eye tabs fit under the nylon cord clamp and the screws slide through the eyelets, securing the grip in place. These grips are for indoor use only. Benefits • Easily attached to Insulgrip plugs and connector bodies. • Controls cable arc-of-bend. • Provides heavy-duty strain relief. • Fits all sizes. Note: I-Grips should not be used on Insulgrip devices when “Seal-Tite®” weatherproof covers are to be installed. I-Grips Cable Diameter E M Catalog Range Inches (cm) Inches (cm) Inches (cm) Numbers .32”-.43” (.81-1.09) 1.25” (3.17) 4” (10.16) 07310001 .43”-.56” (1.09-1.42) 1.25” (3.17) 4.75” (12.06) 07310002 .56”-.73” (1.42-1.85) 1.50” (3.81) 6” (15.24) 07310003 .73”-.85” (1.85-2.16) 1.50” (3.81) 6.5” (16.51) 07310004 .85”-1.00” (2.16-2.54) 1.50” (3.81) 8” (20.32) 07310005 1.00”-1.25” (2.54-3.17) 1.50” (3.81) 10” (25.40) 07310006 E-Eye length M-Mesh length at nominal diameter Eyelet hole diameter .203 (.52) E I-Grips M T-66 www.hubbell-wiring.com Dimensions in Inches (mm) Dustight Strain Relief Grips Aluminum Fittings, Galvanized Steel Mesh, for Insulated Cables Non-Insulated Wide Range Strain Relief Cable Diameter Range Inches (cm.) .24”-.32” (.61-.81) .32”-.43” (.81-1.09) .43”-.54” (1.09-1.37) .54”-.73” (1.37-1.85) .73”-.97” (1.85-2.46) .97”-1.25” (2.46-3.17) .73”-.97” (1.85-2.46) Thread Size N.P.T. (Inches) 1/2” 1/2” 1/2” 3/4” 1” 11/4” PG29 Mesh Length @ Nom. Dia. Inches (cm) 31/4” (8.25) 33/4” (9.52) 43/4” (12.06) 61/2” (16.51) 7” (17.78) 9” 7” (22.86) (17.78) Catalog Numbers 073031200 073031201 073031202 073031203 073031204 Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-68 through T-74. Wire Management Products Strain Relief 073031205 073PG291204 Insulated Wide Range Strain Relief with Insulating Bushing Cable Diameter Range In. (cm.) .24”-.32” (.61-.81) .32”-.43” (.81-1.09) .43”-.54” (1.09-1.37) .54”-.73” (1.37-1.85) .73”-.97” (1.85-2.46) .97”-1.25” (2.46-3.17) 1.25”-1.50” (3.17-3.81) 1.50”-1.70” (3.81-4.32) 1.70”-2.00” (4.32-5.08) 2.00”-2.45” (5.08-6.22) Mesh Thread Length @ Size Nom. Dia. Dim. Inches Inches(cm) A In.(cm) 1/2” N.P.S. 31/4” (8.25) 1” (2.54) 1/2” N.P.S. 33/4” (9.52) 1” (2.54) 1/2” N.P.S. 43/4” (12.06) 1” (2.54) 3/4” N.P.S. 61/2” (16.51) 1” (2.54) 1” N.P.S. 7” (17.78) 13 /16” (3.02) 11/4” N.P.S. 9” (22.86) 13 /16” (3.02) 11/2” N.P.T. 113 /4” (29.84) 13 /16” (3.02) 2” N.P.T. 131/4” (33.65) 13 /8” (3.49) 21/2” N.P.T. 131/2” (34.29) 11/2” (3.81) 21/2” N.P.T. 133/4” (34.92) 11/2” (3.81) Min. Space Between Grips Catalog B In.(cm) Numbers 11/4” (3.17) 073031206 11/4” (3.17) 073031207 11/4” (3.17) 073031208 11/2” (3.81) 073031209 13/4” (4.44) 073031210 21/4” (5.71) 073031211 21/2” (6.35) 073031212 31/4” (8.25) 073031213 35 /8” (9.21) 073031214 35 /8” (9.21) 073031215 Non-Insulated A Insulated Strain Relief Grips Dimensions in Inches (mm) www.hubbell-wiring.com T-67 Wire Management Products Kellems® Grips for Strain Relief Technical Section Kellems Strain Relief Grips are designed to prevent tension from being transmitted to joints and terminals on electrical cord, cable and conduit. In most applications, a Kellems grip for strain relief is stronger than the cable itself and gives much greater security than the use of a fitting alone. Kellems Grips for strain relief help make electrical systems safer, and save money by minimizing downtime from costly electrical failure due to cable pull-out. Kellems Grips also aid in compliance with the National Electric Code’s terminal tension protection requirements (see NEC Section 400-10.). Select the Correct Grip for Strain Relief Kellems Grips for strain relief are designed to fit on electrical cord, cable or flexible conduit. Step 1 Step 2 Step 3 Step 4 Step 5 Refer to the chart below to determine the grip style best suited for your application. Determine your cable outside diameter or conduit size. Locate environment—indoors or outdoors. Decide if a liquidtight seal is required. Select N.P.T. size and fitting style. Technical Data Strain Relief System Selection Chart Cord or Conduit Type Fitting or Range Inches (cm) Attachment Page Number .187”-3.250” (.47-8.25) PG, N.P.T. aluminum, male straight, 45° male, 90° male, female straight. Thread sizes 3 /8”-3”. T-60, T-61, T-64 Nylon fitting, stainless .187”-1.125” steel mesh, double-single (.47-2.86) weave, neoprene oil-andwatertight bushing. N.P.T. nylon, male straight, 90° male. Thread sizes 1 /2”-1”. T-62 Non-metallic grip is corrosion resistant, nonconductive and provides superior gripping and flexing benefits. Neoprene liquidtight bushing. Nylon fitting. .187”-1.000” (.47-2.54) N.P.T. nylon, T-63 straight male, thread sizes 3 /8”-1” 90° male, thread sizes 1 /2”-1”. .187”-1.000” (.47-2.54) Straight male Only with N.P.T. Thread sizes 1 /2”-1”. T-63 Indoor use only for wiring of electrical enclosures, machine tools, portable power tools, bus drop cable systems. Neoprene gasket–seals .240”-2.450” out cips, dirt, dust. (.61-6.22) One piece design with galvanized steel mesh. Insulating bushing available. Zinc-plated steel locknut. Straight male N.P.S. or N.P.T. T-67 Non-metallic Flexible Conduit Grip (UL Type A) Wiring or machine tools, electrical enclosures, motors and systems where conduit is subject to vibration and strain. Stainless steel mesh, liquidtight fittings with “O” ring and locknut. .375”-2.008” trade size male N.P.T. steel, Hubbell fittings, straight male, 90° Thread sizes 1 /2”-2”. T-100 Liquidtight, Flexible, Metal Conduit Grip Wiring of machine tools, electrical enclosures, motors and systems where metallic liquidtight flexible conduit is subjected to vibration, flexure, motion or strain. Stainless steel mesh, liquidtight fittings. Sealing “O” rings (optional). Choice of fittings. .375”-4.000” trade sizes N.P.T. 1 /2”-4”, Hubbell fittings, Male straight, 45° male, 90° male, female straight. T-101 Grip Type Application Features Deluxe Cord Aluminum Fitting/ Stainless SteelGrip Outdoors or indoors where subjected to moisture or splash. Examples are crane and hoist pendant drop stations, hand tools, pumps and processing equipment. Aluminum fittings, stainless steel mesh, neoprene oil-andwatertight bushing. Double-single weave. Deluxe Cord Nylon Fitting/ Stainless SteelGrip Outdoors or indoors where subjected to moisture or splash. Examples are marine and food processing equipment. Deluxe Cord Nylon Fitting/ Non-metallic Grip Indoor or outdoors. Provides liquidtight seal, where exposed to moisture. Excellent for oil refining and chemical processing. Deluxe Cord Stainless SteelFitting And Grip Indoor or outdoor use where Stainless steel fitting exposed to moisture. Very and grip for strength. strong for heavy abuse areas Neoprene liquidtight such as drilling platforms, bushing. Double/single steel mills and mines. weave grip. Wide Range Strain Relief T-68 www.hubbell-wiring.com Dimensions in Inches (mm) Technical Section Safety And Working Load Factors For Wire Mesh Grips The broad application of Kellems grips on a wide Under normal conditions, Kellems’ variety of objects requires that adequate safety recommended factor of safety is five for catalog factors be used to establish working loads. The listed pulling grips, and ten for catalog listed approximate breaking strength of a Kellems grip support grips. The factory should be consulted represents an average calculation based on data for specific application recommendations established from actual direct tension testing done where strength and holding power are in our engineering laboratories. important factors. It is impossible to catalog or guarantee a safety Any warranty as to quality, performance or fitness factor suitable for all applications as operating for use of grips is always premised on the condition conditions are never the same. The tension, that the published breaking strengths apply only to diameter, movement, number of objects gripped, new, unused grips, and that such products are gripping surface, and the attachments used are just properly stored, handled, used, maintained and some of the factors which vary with each inspected by the user at a frequency appropriate application. These factors, together with the effects for the use and condition of the grip. of abrasion, corrosion, prior use or abuse and any For grip applications on materials other than those other variables of a specific application, must be that the grips have been specifically designed for, considered by the user and the grip replaced as consult the factory. appropriate. Where the conditions of the application are not well defined or known or where risk of injury to persons or property is involved, a greater safety factor should be utilized. Should our opinion be needed, call the factory. Wire Management Products Kellems® Grips for Strain Relief Examples Grip Style Bus Drop Approx. Breaking Strength Lbs. (N) 1,000 (4,448) Safety Factor 10 Max. Rec. Load Lbs. (N) 100 (448) Catalog Numbers 073041279 The maximum recommended working load then is the tension to be exerted on the grip in application with a margin of safety to take care of unforeseen and unusual circumstances. It is the end-user’s decision to determine how much of a safety factor is acceptable to him. Wire Mesh Grip Materials Material Galvanized steel wire Stainless steel wire (302-304) Dimensions in Inches (mm) Superior flex life Non-conductive Corrosion resistant Moderate strength www.hubbell-wiring.com Product Group Strain relief grips I-Grips Deluxe cord grips Liquidtight, flexible, metal conduit grips UL type A conduit grips Hose containment grips Technical Data Non-metallic strand Features High strength Not subject to continuous outside environment High strength Corrosion resistant Slightly magnetic Non-metallic deluxe cord grips T-69 Wire Management Products Kellems® Grips for Strain Relief Technical Section Operating Temperatures Material Temperature Range Aluminum –40°F to +300°F (–40°C to +149°C). Nylon –40°F to +225°F (–40°C to +107°C). Stainless Steel –60°F to +1000°F (–51°C to +537°C). Neoprene (bushings) –30°F to +240°F (–34°C to +115°C). Due to the limiting factors of nylon and neoprene, any complete Deluxe Cord Grip, Form 1-5 will continuously perform in the range of –30°F to +225°F (–34°C to +107°C). Hazardous Locations The product categories listed to the right are suitable for use in hazardous locations per Class I, Div. 2, Class II, Div. 1 & 2, Class III, Div. 1 & 2. Product Categories Deluxe cord grip, aluminum fitting; Deluxe cord grip, nylon fitting; Deluxe cord grip, non-metallic; Sealtite conduit grips; Dustight strain relief grips. Flammability Non-metallic deluxe cord grips will not support combustion. Listed below are the ratings. Component Mesh grip Fitting Rating UL 94HB. UL 94V-2. Approvals UL Listing and CSA Certification are indicated on appropriate product catalog pages. File numbers are listed below. Agency Control Numbers Underwriters Laboratories Inc. UL 898 D, UL899D Wet Locations Technical Data The products noted to the right are suitable for use in wet locations when a listed sealing ring is used between box and fitting. Product Categories Deluxe cord grip, aluminum fitting; Deluxe sealing ring cord grip; Deluxe cord grip, non-metallic; Sealtite conduit grips; Hubbell non-metallic conduit grips; Cord connectors; Hubbell Juniors; PolyTuff® connectors; Hubbell sealtite conduit connectors. T-70 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Kellems® Grips for Strain Relief Technical Section Form Size Definition The term “Form Size” refers to the physical mass or overall dimensions of a cord connector. Form 1 is the smallest size, Form 8 is the largest size. Knockout Holes N.P.T. Hub Size 1/4” 3/8” 1/2” 3/4” 1” Knockout Hole Recommended Min. to Max. Inches (cm) .540” to .570” (1.37-1.45) .671” to .701” (1.70-1.78) .859” to .906” (2.18-2.30) 1.094 “ to 1.141” (2.78-2.90) 1.359 “ to 1.406” (3.45-3.57) 11/4” 11/2” 2” 21/2” 3” 1.719” 1.969” 2.453” 2.953 “ 3.578” to to to to to 1.766” 2.016” 2.500” 3.000” 3.625” (4.37-4.49) (5.00-5.12) (6.23-6.35) (7.50-7.62) (9.09-9.21) Product Data Deluxe Cord Grips, Liquidtight for Insulated Cables Deluxe Cord Grips completely eliminate pull tension on terminals, control cable arc-of-bend, prevent cord pull-out, and provide a liquidtight seal. They are offered with either aluminum, stainless steel or nylon fittings in a variety of configurations and N.P.T. thread sizes. Additionally, a completely non-metallic product is offered on page T-63. Application Deluxe Cord Grips are used indoors or outdoors to prevent cord pullout, and where cables are subjected to moisture, splash or submersion. Specific uses are: wiring enclosures, pendant stations, hand tools, construction, processing and material handling equipment, pumps, motors and machine tools. Benefits • Prevents cable pull-out. • Controls cable arc-of-bend. • Provides a liquidtight seal. • Corrosion resistant stainless steel mesh with aluminum collar. Technical Data Dimensions in Inches (mm) www.hubbell-wiring.com T-71 Wire Management Products Kellems® Grips for Strain Relief Technical Section Deluxe Cord Grips Fitting Dimensions Straight Hubbell Connectors Aluminum, Inches (cm) F A B C N.P.T. Inches Form Dia. Ref. 3 /8”-18 1 .88” .90” .46” (2.24) (2.29) (1.17) D E Throat Dia. A/C* A/F* .44” .99” .88” (1.12) (2.51) (2.24) Nylon, Inches (cm) Stainless Steel, Inches (cm) C D E A B C D E Throat Throat Dia. Ref. Dia. A/C* A/F* A/C* A/F Dia. A/C* A/F* 1.00” 1.10” .43” .45” 1.00” .93” 1.01” .88” .90” .46” .45” .87” .75” (2.54) (2.79) (1.09) (1.14) (2.54) (2.36) (2.57) (2.24) (2.29) (1.17) (1.14) (2.21) (1.90) A B 1 /2”-14 1 .88” .90” .46” (2.24) (2.29) (1.17) .44” 1.00” (1.12) (2.54) .88” (2.24) 1.00” 1.10” .46” .45” 1.00” .93” (2.54) (2.79) (1.17) (1.14) (2.54) (2.36) • 1 /2”-14 2 1.13” 1.10” .55” (2.87) (2.79) (1.40) .64” 1.11” (1.63) (2.82) 1.00” (2.54) 1.32” 1.50” .53” .58” 1.25” 1.12” (3.35) (3.81) (1.35) (1.47) (3.17) (2.84) 1.30” 1.13” 1.10” .54” .63” 1.16” 1.00” (3.30) (2.87) (2.79) (1.37) (1.60) (2.95) (2.54) 1 /2”-14 3 1.38” 1.50” .55” (3.51) (3.81) (1.40) .64” 1.40” (1.63) (3.56) 1.25” (3.17) • • • • • • • • • • • • • 3 /4”-14 2 1.13” 1.10” .55” (2.87) (2.79) (1.40) .64” 1.29” (1.63) (3.28) 1.13” (2.87) • • • • • • • • • • • • • 3 /4-14 3 1.38” 1.50” .55” (3.51) (3.81) (1.40) .82” 1.40” (2.08) (3.56) 1.25” (3.17) 1.56” 1.60” .55” .77” 1.44” 1.31” (3.96) (4.06) (1.40) (1.96) (3.66) (3.33) 1”-111 /2 3 • • • 1”-111 /2 4 1.75” 1.60” .71” (4.44) (4.06) (1.80) 1.02” 1.81” (2.59) (4.60) 1.62” (4.11) 1.88” 1.75” .70” 1.01” 1.84” 1.63” (4.78) (4.44) (1.78) (2.57) (4.67) (4.14) 2.02” 1.75” 1.40” .70” 1.03” 1.88” 1.63” (5.13) (4.44) (3.56) (1.78) (2.62) (4.78) (4.14) 1”-111 /2 5 2.31” 1.70” .66” (5.87) (4.32) (1.68) 1.01” 2.28” (2.57) (5.79) 2.00” (5.08) • • • • • • • • • • • • • 11 /4”-111 /2 5 2.31” 1.70” .74” (5.87) (4.32) (1.88) 1.26” 2.28” (3.20) (5.79) 2.12” (5.38) • • • • • • • • • • • • • 11 /2”-11 5 2.31” 1.70” .74” (5.87) (4.32) (1.88) 1.38” 2.28” (3.51) (5.79) 2.12” (5.38) • • • • • • • • • • • • • 11 /2”-111 /2 6 3.00” 2.20” .75” (7.62) (5.59) (1.90) 1.50” 2.97” (3.81) (7.54) 2.75” (6.98) • • • • • • • • • • • • • 2”-111 /2 6 3.00” 2.20” .80” (7.62) (5.59) (2.03) 1.92” 3.24” (4.88) (8.24) 3.00” (7.62) • • • • • • • • • • • • • 2”-111 /2 7 3.85” 2.70” .88” (9.78) (6.86) (2.24) 1.94” 4.05” 3.75” (4.93) (10.29) (9.52) • • • • • • • • • • • • • 21 /2”-8 7 3.85” 2.70” 1.30” (9.78) (6.86) (3.30) 2.32” 4.34” 4.02” (5.89) (11.02) (10.21) • • • • • • • • • • • • • 21 /2”-8 8 4.75” 2.70” 1.25” (12.06) (6.86) (3.17) 2.38” 4.86” 4.50” (6.05) (12.34) (11.43) • • • • • • • • • • • • • 3”-8 7 3.85” 2.70” 1.30” (9.78) (6.86) (3.30) 2.54” 4.34” 4.01” (6.45) (11.02) (10.21) • • • • • • • • • • • • • 3”-8 8 4.50” 2.70” 1.38” (11.43) (6.86) (3.51) 3.00” 4.86” 4.50” (7.62) (12.34) (11.43) • • • • • • • • • • • • • • • • • • • • • • • • • • • • 1.59” 1.38” 1.30” .56” .81” 1.44” 1.25” (4.04) (3.51) (3.30) (1.42) (2.06) (3.66) (3.17) • • • • • • • *A/C— Across Corners; A/F—Across Flats Technical Data A (Overall) B Ref. E F C Dimensions shown are approximate and are subject to change without notice. D T-72 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Kellems® Grips for Strain Relief Technical Section Deluxe Cord Grips Fitting Dimensions 45° Hubbell Connectors Aluminum, Inches (cm) F N.P.T. 1 /2”-14 Form 2 3 /4”-14 3 1”-111 /2 4 11 /4”-111 /2 5 11 /2”-111 /2 5 A B C Ref 2.00” (5.08) 2.30” (5.84) 2.60” (6.60) 3.90” (9.91) Ref 1.90” (4.83) 2.50” (6.53) 2.80” (7.11) 3.90” (9.91) 3.90” (9.91) 3.90” (9.91) B Ref. G .550” (1.40) .560” (1.42) .700” (1.78) .740” (1.88) D Throat Dia. .560” (1.42) .750” (1.90) 1.000” (2.54) 1.250” (3.17) Across Comers 1.270” (3.23) 1.480” (3.76) 1.690” (4.29) 2.45” (6.22) .740” (1.88) 1.500” (3.81) 2.45” (6.22) E G Across Flats 1.110” (2.79) 1.281” (3.25) 1.500” (3.81) 2.125” (5.40) Dia. 1.125” (2.86) 1.375” (3.49) 1.750” (4.44) 2.310” (5.87) 2.125” (5.40) 2.310” (5.87) A Ref. E F C D 90° Hubbell Connectors Aluminum, Inches (cm) A B C D Throat N.P.T. Form Ref Dia. 3 /8”-18 1 1.27” 2.00” .460” .440” (3.23) (5.08) (1.17) (1.12) 1 /2”-14 2 1.56” 2.30” .500” .546” (3.96) (5.84) (1.27) (1.39) 3 /4”-14 3 1.79” 2.80” .560” .765” (4.55) (7.11) (1.42) (1.94) 1”-111 /2 4 2.08” 3.20” .700” 1.000” (5.28) (8.13) (1.78) (2.54) 11 /4-”111 /2 5 3.18” 4.30” .730” 1.260” (8.08) (10.92) (1.85) (3.20) 11 /2”-111 /2 5 3.18” 4.30” .750” 1.500” (8.08) (10.92) (1.92) (3.81) 2”-111 /2 6 3.51” 5.50” .800” 1.920” (8.92) (13.97) (2.03) (4.88) *A/C - Across Corners; A/F - Across Flats F E AIC* 1.15” (2.92) 1.30” (3.30) 1.49” (3.78) 1.70” (4.32) 2.47” (6.27) 2.47” (6.27) 2.98” (7.57) G A/F* 1.10” (2.79) 1.13” (2.87) 1.31” (3.33) 1.50” (3.81) 2.15” (5.46) 2.15” (5.46) 2.78” (7.06) Dia. .875” (2.22) 1.125” (2.86) 1.375” (3.49) 1.750” (4.44) 2.310” (5.87) 2.310” (5.87) 3.000” (7.62) Nylon, Inches (cm) A B C Throat Ref • • • Dia. • AIC* • A/F • Dia. • 1.41” (3.58) 1.65” (4.19) 1.99” (5.05) • 2.50” (6.35) 2.81” (7.14) 3.30” (8.38) • .550” (1.40) .560” (1.42) .700” (1.78) • .575” (1.46) .765” (1.94) 1.010” (2.57) • 1.23” (3.12) 1.42” (3.61) 1.82” (4.62) • 1.12” (2.82) 1.29” (3.28) 1.60” (4.06) • 1.315” (3.34) 1.560” (3.96) 1.875” (4.76) • • • • • • • • • • • • • • • D E G B Ref. G A Technical Data E F D D Dimensions shown are approximate and are subject to change without notice. Dimensions in Inches (mm) www.hubbell-wiring.com T-73 Wire Management Products Kellems® Grips for Strain Relief Technical Section Deluxe Cord Grips Fitting Dimensions Female Hubbell Connectors A (Overall) Aluminum Inches (cm) F B Ref. E C (N.P.T. Thread Depth) B C D Throat Dia. Across Corners E Across Flats N.P.T. 3 /8”-18 Form Dia. Ref 1 .88” (2.24) 1.40” (3.56) .560” (1.42) .44” (1.12) .94” (2.39) .81” (2.06) 1 /2”-14 2 1.13” (2.87) 1.80” (4.57) .560” (1.42) .63” (1.60) 1.15” (2.92) 1.00” (2.54) 3 /4”-14 2 1”-111 /2 4 1 1 /4”-111 /2 5 1 1 /2”-111 /2 5 1.13” (2.87) 1.75” (4.44) 2.31” (5.87) 2.31” (5.87) 2.10” (5.33) 2.30” (5.84) 2.80” (7.11) 2.80” (7.11) .750” (1.90) .880” (2.24) .950” (2.41) .950” (2.41) .63” (1.60) 1.10” (2.79) 1.43” (3.63) 1.43” (3.63) 1.44” (3.66) 1.88” (4.78) 2.64” (6.71) 2.64” (6.71) 1.25” (3.17) 1.63” (4.14) 2.29” (5.82) 2.29” (5.82) D F A Product Data Dust Tight Strain Relief Grips for Insulated Cables Kellems Strain Relief Grips connect flexible cord or bus drop cable to electrical enclosures. For indoor use only, they are available with either insulated or non-insulated aluminum fittings, and feature single weave, galvanized steel mesh grips with patented wide range mesh construction. They come with a locknut and a neoprene gasket that provides a dust tight seal. Application Used to connect electrical cable to power boxes, cabinets, panel boards, power centers, machine tools and with bus drop systems. Benefits • Prevents cord or cable pull-out. • Provides a dust tight seal. • Easy installation. • Patented mesh construction. • One piece design. Technical Data I-Grips for Insulated Cables Kellems I-Grips are made of high strength, plastic coated galvanized steel strand. They are offered in six sizes to fit all cable diameters used with Hubbell Insulgrip® Kellems l-Grips will control cable arc-ofbend and reduce high pull tensions from being transmitted to the wiring terminals. Application Kellems I-Grips will fit 2 wire, 3 wire, 4 wire and 5 wire Hubbell Insulgrip plugs and connector bodies. The eye tabs fit under the nylon cord clamp and the screws slide through the eyelets, securing the grip in place. I-Grips can be used on any Insulgrip cord set which requires cable, arc-of-bend control or heavy duty strain relief. Cord sets used at indoor construction sites or for plant maintenance jobs are examples. These grips are for indoor use only. Dimensions shown are approximate and are subject to change without notice. T-74 Benefits • Easily attached to Insulgrip plugs and connector bodies. • Fits all sizes. • Provides heavy duty strain relief. • Controls cable arc-of-bend. Note: I-Grips should not be used on Insulgrip devices when “Seal-Tite®” weatherproof covers are to be installed. www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Cord Connectors Features and Benefits Machined threads provide a strong positive seal. The tapered interior dome easily drives the bushing into the connector body. The patented GOTHCA® ring incorporates a split hinge design to prevent friction and provide strain relief, also color-coded for sizing identification. Lubricated neoprene bushing compresses easily for a liquidtight seal and added pull-out protection. The connector body is a one-piece design with machined threads. A tapered interior seats the bushing evenly for a liquidtight seal. Dimensions in Inches (mm) Their machined steel nut and body allows for tightening the compression nut and N.P.T. hub without worrying about stripping the threads. For larger size cord, N.P.T. hub sizes 1” to 2”, Hubbell utilizes malleable iron connectors which provide excellent holding and liquidtight performance. Hubbell’s nylon cord connectors resist most common industrial corrosives and provide highly effective pullout protection in a lightweight design. They are ideal for any application where weight, conductivity or corrosion may be an issue. They’re available in N.P.T. hub sizes from 1 /4” to 1”. Stainless steel cord connectors provide superior strength and corrosion resistance for industrial and military applications. They are machined from 300 series stainless steel and come in 1 /4” through 1”, N.P.T. hub sizes. www.hubbell-wiring.com T-75 Cord Connector Features and Benefits Hubbell has the broadest line and the widest choice of materials in the industry. N.P.T. hub sizes from 1 /4” to 3” in straight male end, 90°, 45°, female and underground feed connectors. They are available in your choice of aluminum, plated steel, nylon and stainless steel. Hubbell offers a full line of machined aluminum cord connectors in N.P.T. hub sizes 1 /4” through 1” and cast aluminum 1” to 3”. They provide durable performance and a clean attractive look without adding unwanted weight. N.P.T. hub sizes 1 /4” to 1” feature an attractive knurled finish which makes them easy to handle and maintain a U.L. listing by hand tightening. The zinc-plated steel cord connectors offers the strength of steel and the corrosion resistance of zinc-plating. These heavy-duty connectors hold up to most manufacturing chemicals including acid solutions, solvents and other corrosive materials. Wire Management Products Cord Connectors Straight Male Form Size 1-4 UL Listed to Type 4, 4X, 12 and Type 13 IP66* SUITABILITY N.P.T. Cord Dia. Hub Inches Size (mm) Machined Aluminum 1/4” 3/8” Machined Zinc-Plated Steel 1/2” 1/2” 1/2” .06”-.13” (1.6-3.2) .13”-.19” (3.2-4.7) .19”-.25” (4.7-6.3) .25”-.31” (6.3-7.9) .31”-.38” (7.9-9.5) .38”-.44” (9.5-11) .06”-.13” (1.6-3.2) .13”-.19” (3.2-4.7) .19”-.25” (4.7-6.3) .25”-.31” (6.3-7.9) .31”-.38” (7.9-9.5) .38”-.44” (9.5-11.0) .19”-.25” (4.7-6.3) .25”-.31” (6.3-7.9) .31”-.38” (7.9-9.5) .38”-.44” (9.5-11.0) Machined Aluminum Machined Zinc-Plated Steel Stainless Steel Gray Black • • • SHC1001CR • Orange SHC1002 • • SHC1002CR • Red SHC1003 • SHC1003SS SHC1003CR • Black SHC1004 • SHC1004SS SHC1004CR • White SHC1005** • • SHC1005CR SHC2005CR Blue • • • SHC1006CR • Green SHC1007 • • • • Orange SHC1008 SHC1008ZP • SHC1008CR SHC2008CR Red SHC1009 • SHC1009SS SHC1009CR • Black SHC1010 SHC1010ZP • SHC1010CR SHC2010CR White SHC1011 • SHC1011SS SHC1011CR SHC2011CR Blue SHC1012 SHC1012ZP SHC1012SS SHC1012CR SHC2012CR Red SHC1015 • • • • Black SHC1016 • • • • White SHC1017 • • • • Blue SHC1018 • • • • Green SHC1019 • • SHC1019CR • Orange SHC1020 SHC1020ZP SHC1020SS SHC1020CR • Red SHC1021 SHC1021ZP SHC1021SS SHC1021CR SHC2021CR White SHC1022 SHC1022ZP SHC1022SS SHC1022CR SHC2022CR Blue SHC1023 SHC1023ZP SHC1023SS SHC1023CR SHC2023CR Brown SHC1024 SHC1024ZP SHC1024SS SHC1024CR** SHC2024CR** Blue SHC1025 • • • • Brown SHC1026 • • • • Yellow SHC1027** SHC1027ZP** • • • Orchid SHC1028** SHC1028ZP** • • • Form Color Size Code Green F1 F1 F1 .06”-.13” (1.6-3.2) .13”-.19” (3.2-.4.7) .19”-.25” F2 (4.7-6.3) .25”-.38” (6.3-.9.7) .38”-.50” (9.7-12.7) .50”-.62” (12.7-15.9) .38”-.50” (9.7-12.7) .50”-.63” (12.7-15.9) .63”-.75” F3 (15.9-19.0) .75”-.88” (19.0-22.2) Nylon Cord Connectors Note: See pages T-87 to T-98 for additional technical data and dimensional drawings. *IP66 Suitability when used with optional metal clad O-ring shown on page T-83. **Cable jacket may have to be stripped to pass through connector body. T-76 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Cord Connectors Straight Male Form Size 1-4 UL Listed to Type 4, 4X, 12 and Type 13 IP66* SUITABILITY N.P.T. Cord Dia. Hub Inches Form Color Size (mm) Size Code 3/4” 3/4” 1” 1” Machined Machined Zinc-Plated Aluminum Steel Stainless Steel Gray Black Green SHC1029 • • • • Orange SHC1030 SHC1030ZP • • • Red SHC1031 SHC1031ZP • • • White SHC1032 SHC1032ZP • • • Blue SHC1033 SHC1033ZP • • • Brown SHC1034 SHC1034ZP • • • .38”-.50” (9.5-12.7) .50”-.63” F3 (12.7-15.9) .63”-.75” (15.9-19.0) .75”-.88” (19.0-22.2) Blue SHC1035ZP SHC1035SS SHC1035CR SHC2035CR Brown SHC1036 SHC1036ZP SHC1036SS SHC1036CR SHC2036CR Yellow SHC1037 SHC1037ZP SHC1037SS SHC1037CR SHC2037CR .50”-.63” F3 (12.7-15.9) .63”-.75” (15.9-19.0) .75”-.88” (19.0-22.2) Brown • SHC1097ZP • • • Yellow • SHC1098ZP • • • Orchid • SHC1099ZP • • • .38”-.50” (9.7-12.7) .50”-.63” (12.7-15.9) .63”-.75” F4 (15.9-19.0) .75”-.88” (19.0-22.2) .88”-1.00” (22.2-25.4) 1.00”-1.13” (25.4-28.6) Blue SHC1039 • • SHC1039CR • Brown SHC1040 • • SHC1040CR • Yellow SHC1041 • SHC1041SS SHC1041CR SHC2041CR Orchid SHC1042 • SHC1042SS SHC1042CR SHC2042CR Gray SHC1043 SHC1043ZP • SHC1043CR SHC2043CR Pink SHC1044**• SHC1044SS** SHC1044CR** SHC2044CR** .06”-.13” (1.6-3.2) .13”-.19” (3.2-4.7) .19”-.25” F2 (4.7-6.3) .25”-.38” (6.3-9.7) .38”-.50” (9.7-12.7) .50”-.63” (12.7-15.9) • Nylon Stainless Steel Orchid SHC1038**SHC1038ZP** SHC1038SS** SHC1038CR** SHC2038CR** Gray Nylon Black Nylon Note: See pages T-87 to T-98 for additional technical data and dimensional drawings. *IP66 Suitability when used with optional metal clad O-ring shown on page T-83. **Cable jacket may have to be stripped to pass through connector body. Form 4 aluminum and plated steel nuts are machined, bodies are cast aluminum. Cord Connectors Dimensions in Inches (mm) www.hubbell-wiring.com T-77 Wire Management Products Cord Connectors Straight Male Form Size 5-8 UL Listed to Type 4, 4X, 12 and Type 13 IP66* SUITABILITY Cast Aluminum Cord Connectors Cast Aluminum Malleable Iron T-78 N.P.T. Cord Dia. Form Hub Size Inches (mm) Size Cast Aluminum Malleable Iron† .88”-1.00” (22.2-25.4) SHC1046 • 1” 1.00”-1.13” (25.4-28.6) F5 SHC1047** • 1.13”-1.25” (28.6-31.7) SHC1048** • 1.25”-1.38” (31.7-34.9) SHC1049** • .75”-.88” (19.0-22.2) SHC1050 • .88”-1.00” (22.2-25.4) SHC1051 • 11/4” 1.00”-1.13” (25.4-28.6) F5 SHC1052 SHC1052ZP 1.13”-1.25” (28.6-31.7) SHC1053 SHC1053ZP 1.25”-1.38” (31.7-34.9) SHC1054** SHC1054ZP .75”-.88” (19.0-22.2) SHC1055 • .88”-1.00” (22.2-25.4) SHC1056 • 1.00”-1.13” (25.4-28.6) F5 SHC1057 SHC1057ZP 11/2” 1.13”-1.25” (28.6-31.7) SHC1058 SHC1058ZP 1.25”-1.38” (31.7-34.9) SHC1059 SHC1059ZP 1.38”-1.50” (34.9-38.1) SHC1061 • 11/2” 1.50”-1.63” (38.1-41.3) F6 SHC1062** • 1.63”-1.75” (41.3-44.4) SHC1063** • 1.75”-1.88” (44.4-47.6) SHC1064** • 1.25”-1.38” (31.7-34.9) SHC1065 • 1.38”-1.50” (34.9-38.1) SHC1066 • 2” 1.50”-1.63” (38.1-41.3) F6 SHC1067 • 1.63”-1.75” (41.3-44.4) SHC1068 • 1.75”-1.88” (44.4-47.6) SHC1069 • 1.69”-1.81” (42.9-46.0) SHC1070 • 1.81”-1.94” (46.0-49.2) SHC1071 • 2” 1.94”-2.06” (49.2-52.4) F7 SHC1072** • 2.06”-2.19” (52.4-55.6) SHC1073** • 2.19”-2.31” (55.6-58.7) SHC1074** • 1.69”-1.81” (42.9-46.0) SHC1076 • 1.81”-1.94” (46.0-49.2) SHC1077 • 21/2” 1.94”-2.06” (49.2-52.4) F7 SHC1078 • 2.06”-2.19” (52.4-55.6) SHC1079 • 2.19”-2.31” (55.6-58.7) SHC1080 • 2.31”-2.44” (58.7-61.9) SHC1081** • 1.69”-1.81” (42.9-46.0) SHC1086 • 1.81”-1.94” (46.0-49.2) SHC1087 • 3” 1.94”-2.06” (49.2-52.4) F7 SHC1088 • 2.06”-2.19” (52.4-55.6) SHC1089 • 2.19”-2.31” (55.6-58.7) SHC1090 • 2.31”-2.44” (58.7-61.9) SHC1091 • 2.44”-2.63” (61.9-66.7) SHC1092 • 2.63”-2.81” (66.7-71.4) SHC1093 • 3” 2.81”-3.00” (71.4-76.2) F8 SHC1094 • 3.00”-3.25” (76.2-82.5) SHC1095** • Note: See pages T-87 to T-98 for additional technical data and dimensional drawings. *IP66 Suitability when used with optional metal clad O-ring shown on page T-83. **Cable jacket may have to be stripped to pass through connector body. F5 and larger will not be color coded. www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Cord Connectors 45° Male Form Size 2-5 UL Listed to Type 4, 4X, 12 and Type 13 IP66* SUITABILITY Form Size 1-5 N.P.T. Hub Cord Dia. Size Inches .19”-.25” 1 /2” .25”-.38” (mm) (4.7-6.3) Machined Form Color Machined Zinc-Plated Size Code Aluminum† Steel F2 Red VHC1021 • Cast Aluminum • (6.3-9.7) White VHC1022 VHC1022ZP • .38”-.50” (9.7-12.7) Blue VHC1023 VHC1023ZP • .50”-.63” (12.7-15.9) Brown VHC1024** VHC1024ZP** • .38”-.50” (9.7-12.7) Blue VHC1035 • • 3/4” .50”-.63” (12.7-15.9) F3 Brown VHC1036 • • .63”-.75” (15.9-19.0) Yellow VHC1037** • • 1” .63”-.75” (15.9-19.0) Yellow VHC1041 • • .75”-.88” (19.0-22.2) F4 Orchid VHC1042 • • 11/4” 1.00”-1.13” (25.4-28.6) • • VHC1052 1.13”-1.25” (28.6-31.7) F5 • • VHC1053** Note: See pages T-87 to T-98 for additional technical data and dimensional drawings. * IP66 Suitability when used with optional metal clad O-ring shown on page T-83. ** Cable jacket may have to be stripped to pass through connector body. †Nuts are machined aluminum and bodies are cast aluminum. Nuts are machined zinc-plated steel and bodies are malleable iron, cadmium plated. Machined Aluminum† Machined Zinc-Plated Steel∆ Cast Aluminum Cord Connectors Dimensions in Inches (mm) www.hubbell-wiring.com T-79 Wire Management Products Cord Connectors 90° Male Form Size 1-6 UL Listed to Type 4, 4X, 12 and Type 13 IP66* SUITABILITY Form 1-6 N.P.T. Hub Size Cord Machined Dia. Form Color Machined Zinc-Plated Nylon Nylon Inches (mm) Size Code Aluminum† Steel Gray Black .25”-.31” (6.3-7.9) Black NHC1010 • • • 3/8” .31”-.38” (7.9-9.5) F1 White NHC1011 • • • .38”-.44” (9.5-11.0) Blue NHC1012 • • • .06”-.13” (1.6-3.2) Green • • • • .13”-.19” (3.2-4.7) Orange NHC1020 • NHC1020CR • 1/2” .19”-.25” (4.7-6.3) F2 Red NHC1021 NHC1021ZP NHC1021CR • .25”-.38” (6.3-9.7) White NHC1022 NHC1022ZP NHC1022CR NHC2022CR .38”-.50” (9.7-12.7) Blue NHC1023 NHC1023ZP NHC1023CR NHC2023CR .50”-.63” (12.7-15.9) Brown NHC1024** NHC1024ZP** NHC1024CR** NHC2024CR** .38”-.50” (9.7-12.7) Blue NHC1035 NHC1035ZP NHC1035CR • 3/4” .50”-.63” (12.7-15.9) F3 Brown NHC1036 NHC1036ZP NHC1036CR • .63”-.75” (15.9-19.0) Yellow NHC1037 NHC1037ZP NHC1037CR • .75”-.88” (19.0-22.2) Orchid NHC1038 NHC1038ZP NHC1038CR • .50”-.63” (12.7-15.9) Brown NHC1040 NHC1040ZP • • .63”-.75” (15.9-19.0) Yellow NHC1041 NHC1041ZP NHC1041CR NHC2041CR 1” .75”-.88” (19.0-22.2) F4 Orchid NHC1042 NHC1042ZP NHC1042CR NHC2042CR** .88”-1.00” (22.2-25.4) Gray NHC1043** • NHC1043CR NHC2043CR** 1.00”-1.13” (25.4-28.7) Pink NHC1044** • • • .88”-1.00” (22.2-25.4) • • • • • 11/4” 1.00”-1.13” (25.4-28.6) F5 • • • • • 1.13”-1.25” (28.6-31.7) • • • • • 1.25”-1.38” (31.7-.349) • • • • • 1.00”-1.13” (25.4-28.6) • • • • • 11/2” 1.13”-1.25” (28.6-31.7) F5 • • • • • 1.25”-1.38” (31.7-34.9) • • • • • 2” 1.38”-1.50” (34.9-38.1) F6 • • • • • Note: See pages T-87 to T-98 for additional technical data and dimensional drawings. * IP66 Suitability when used with optional metal clad O-ring shown on page T-83. ** Cable jacket may have to be stripped to pass through connector body. † Nuts are machined aluminum and bodies are cast aluminum. Compression nuts are machined zinc-plated steel and bodies are zinc-plated malleable iron. Cord Connectors Machined Aluminum† Gray Nylon T-80 Black Nylon www.hubbell-wiring.com Cast Aluminum • • • • • • • • • • • • • • • • • • NHC1051 NHC1052 NHC1053** NHC1054** NHC1057 • NHC1059 NHC1066 Machined Zinc-Plated Steel∆ Cast Aluminum Dimensions in Inches (mm) Wire Management Products Cord Connectors Straight Female and Underground Feeder Form 1-4 N.P.T. Hub Size 1/2” Cord Dia. Form Color Machined Inches (mm) Size Code Aluminum .25”-.38” (6.3-9.7) F2 White FHC1022 .38”-.50” (9.7-12.7) Blue FHC1023 3/4” .38”-.50” (9.7-12.7) F2 Blue FHC1033 .50”-.63” (12.7-15.9) Brown FHC1034 1” .75”-.88” (19.0-22.2) F4 Orchid FHC1042† .88”-1.00” (22.2-25.4) Gray FHC1043† Note: See pages T-87 to T-98 for additional technical data and dimensional drawings. *Cable jacket may have to be stripped to pass through connector body. †Nuts are machined aluminum and bodies are cast aluminum. Machined Aluminum IP66* SUITABILITY Underground Feeder Connectors N.P.T. UF** Machined Hub Diameter Wire Machined Zinc-Plated Nylon Nylon Size Inches (mm) Size Aluminum Steel Gray Black 1/2” .2”x.4” min (5.1 x 10.2) 2 # 14, .25”-.55” max (6.3 x 14.0) 2 # 12, UFC0001 UFC0001ZP UFC0001CR UFC2001CR 2 # 10. 3/4” .2”x.4” min (5.1x10.2) 2 # 14, .25”-.55” max (6.3x14.0) 2 # 12, UFC0002 • • • 2 # 10. 3/4” .2”x.6” min (5.1x15.2) 3 # 14, .26”x.78” max (6.6x19.8) 3 # 12, UFC0003 • UFC0003CR UFC2003CR 3 # 10. Note: See pages T-87 to T-98 for additional technical data and dimensional drawings. *IP66 Suitability when used with optional metal clad O-ring shown below. **Wire sizes vary among manufacturers. Machined Aluminum Zinc-Plated Steel Cord Connectors Gray Nylon Black Nylon Dimensions in Inches (mm) www.hubbell-wiring.com T-81 Wire Management Products Non-metallic Cord Connectors Straight Male N.P.T. & PG Thread Low Profile IP68* SUITABILITY Low Profile N.P.T. Cord Connectors SEC100B N.P.T. Cord Dia. Catalog Hub Size Inches (mm) Color Numbers 3 /8” .20”-.32” (5.1-8.13) Gray SEC38G 3 /8” .20”-.32” (5.1-8.13) Black SEC38B 1 /2” .24”-.47” (6.1-12) Gray SEC50G 1 /2” .24”-.47” (6.1-12) Black SEC50B 3 /4” .47”-.71” (12-18) Gray SEC75G 3 /4” .47”-.71” (12-18) Black SEC75B 1” .67”-.98” (17-25) Gray SEC100G 1” .67”-.98” (17-25) Black SEC100B Note: See pages T-87 to T-91 for additional technical data and dimensional drawings. Low Profile PG Cord Connectors SECP29G Hub Size PG7 PG7 PG9 PG9 PG11 PG11 PG13.5 PG13.5 PG16 PG16 PG21 Cord Dia. Inches .18”-.26” .18”-.26” .20”-.32” .20”-.32” .22”-.39” .22”-.39” .47”-.71” .47”-.71” .32”-.55” .32”-.55” .47”-.71” (mm) (4.5-6.6) (4.5-6.6) (5.1-8.13) (5.1-8.13) (5.6-9.9) (5.6-9.9) (12-18) (12-18) (8.13-14) (8.13-14) (12-18) Color Gray Black Gray Black Gray Black Gray Black Gray Black Gray Catalog Numbers SECP7G SECP7B SECP9G SECP9B SECP11G SECP11B SECP13G SECP13B SECP16G SECP16B SECP21G Cord Connectors & Accessories PG21 .47”-.71” (12-18) Black SECP21B PG29 .67”-.98” (17-25) Gray SECP29G PG29 .67”-.98” (17-25) Black SECP29B PG36 .79”-1.26” (20-32) Gray SECP36G PG36 .79”-1.26” (20-32) Black SECP36B Note: See pages T-87 to T-91 for additional technical data and dimensional data. PG Non-Metallic Locknuts LNPG29BPK25 Hub Size PG7 PG9 PG11 PG13.5 PG16 PG21 PG29 PG36 Color Black Black Black Black Black Black Black Black Catalog Numbers LNPG7BPK100 LNPG9BPK100 LNPG11BPK100 LNPG13BPK100 LNPG16BPK100 LNPG21BPK100 LNPG29BPK25 LNPG36BPK25 Notes: Catalog numbers above with “PK100” suffix, i.e. LNPG7BPK100, are bulk packed 100 per carton. Catalog numbers above with “PK25” suffix, i.e. LNPG29BPK25, are bulk packed 25 per carton. T-82 www.hubbell-wiring.com Dimensions in Inches (mm) Accessories Cord Connector Parts N.P.T. Hub Size 1/4”, 3/8”, 1/2” 1/2”, 3/4” 1/2”, 3/4” 1” Cord Dia. Inches (mm) Form Size Bushing Catalog Numbers GOTCHA® Ring Color Code Catalog Numbers .062”-.125” .125”-.187” .187”-.250” .250”-.312” .312”-.375” .375”-.437” (1.58-3.17) (3.17-4.76) (4.76-6.35) (6.35-7.93) (7.93-9.50) (9.50-11.1) F1 31518101BPK100 31518102BPK100 31518103BPK100 31518104BPK100 31518105BPK100 31518106BPK100 Green Orange Red Black White Blue 31648035GPK100 31648036GPK100 31648037GPK100 31648038GPK100 31605010GPK100 31648039GPK100 .062”-.125” .125”-.187” .187”-.250” .250”-.375” .375”-.500” .500”-.625” .375”-.500” .500”-.625” .625”-.750” .750”-.875” .375”-.500” .500”-.625” .625”-.750” .750”-.875” .875”-1.00” 1.00”-1.125” (1.58-3.17) (3.17-4.76) (4.76-6.35) (6.35-9.50) (9.50-12.7) (12.7-15.8) (9.50-12.7) (12.7-15.8) (15.8-19.0) (19.0-22.2) (9.50-12.7) (12.7-15.8) (15.87-19.0) (19.0-22.2) (22.2-25.4) (25.4-28.5) F2 31518110BPK100 31518111BPK100 31518112BPK100 31518113BPK100 31518116BPK100 31518117BPK100 31518118BPK100 31518119BPK100 31518123BPK100 31518125BPK100 31518126BPK100 31518127BPK100 Green Orange Red White Blue Brown Blue Brown Yellow Orchid Blue Brown Yellow Orchid Gray Pink 31648042GPK100 31605015G 31648043GPK100 31648044GPK100 31648045GPK100 31648046GPK100 31648047GPK100 31648048GPK100 31648050GPK100 31648051GPK100 31648052GPK100 31648053GPK100 31648054GPK100 F3 F4 Wire Management Products Cord Connectors Note: Catalog numbers above with “PK100” suffix, i.e. 31518101BPK100, are bulk packed 100 per carton. Locknuts — Steel and Non-metallic N.P.T. Hub Size 1/4” 3/8” 1/2” 3/4” 1” 11/4” 11/2” Zinc-Plated Steel Non-metallic • • 00322001LPK50 00322002LPK50 00322003LPK50 00322004LPK50 00322005LPK50 31622001LPK50 31622002LPK50 31622003LPK50 31622007LPK50 31622008LPK50 • • Zinc-Plated Steel Locknuts Notes: Catalog numbers above with “PK50” suffix, i.e. 00322001LPK50, are bulk packed 50 per carton. See page T-96 for additional technical data and dimensional drawings. Metal Clad Sealing O-Rings Non-metallic Locknuts Dimensions in Inches (mm) www.hubbell-wiring.com Metal Clad Sealing O-Rings T-83 Accessories N.P.T. Hub Size Catalog Numbers 1/2” 20509001 3/4” 20509002 1” 20509003 11/4” 20509004 11/2” 20509005 2” 20509006 21/2” 20509007 3” 20509008 Note: See page T-96 for additional technical data and dimensional drawings. Hubbell Juniors® Wire Management Products Hubbell Juniors® Features and Benefits Nylon spiral provides arc-of-bend control for cord protection. Nylon compression nut has a tapered interior dome to easily drive the bushing into the connector body. Wire Management Products Hubbell Juniors® Miniature Cord Connectors Patented GOTCHA® ring incorporates a split hinge design to prevent friction and provide strain relief. Lubricated neoprene bushing compresses evenly for a liquidtight seal and added pull-out protection. Nylon connector body is a one piece design with a tapered interior that seals the bushing evenly for a positive seal. Threaded hexagon shaped nylon locknut secures tightly and is also corrosion resistant. Hubbell Juniors are a miniature liquidtight version of the full-sized Hubbell cord connectors. They feature the same GOTCHA® ring technology and neoprene bushings. They also come with or without a nylon spiral for arc-of-bend control and longer cord life. They are available in 1/4”, 3/8”, and 1/2” N.P.T. sizes in both gray and black. Features and Benefits Dimensions in Inches (mm) www.hubbell-wiring.com T-85 Wire Management Products Miniature Nylon Cord Connectors HUBBELL JUNIORS® Miniature Nylon Cord Connector Cord Dia. Range Inches .08”-.14” .14”-.20” .20”-.27” .15”-.21” .21”-.28” .28”-.34” .06”-.13” .13”-.19” .19”-.25” .25”-.31” .31”-.38” .38”-.44” N.P.T. Hub Size 1 /4” Gray Cord Connector 3 /8” 1 /2” Black Cord Connector (mm) (1.9-3.4) (3.4-5.1) (5.1-6.7) (3.7-5.3) (5.3-7.0) (7.0-8.6) (1.6-3.2) (3.2-4.7) (4.7-6.3) (6.3-7.9) (7.9-9.5) (9.5-11.1) Gray HJ1001GPK25 HJ1002GPK25 HJ1003GPK25 HJ1004GPK25 HJ1005GPK25 HJ1006GKP25 HJ1055GPK25 HJ1056GPK25 HJ1057GPK25 HJ1058GPK25 HJ1059GPK25 HJ1060GPK25 Black HJ1001BPK25 HJ1002BPK25 HJ1003BPK25 HJ1004BPK25 HJ1005BPK25 HJ1006BKP25 HJ1055BPK25 HJ1056BPK25 HJ1057BPK25 HJ1058BPK25 HJ1059BPK25 HJ1060BPK25 Miniature Nylon Cord Connector with Spiral Gray Cord Connectorwith with Spir Spiral Gray Cord Connector Cord Dia. Range Inches .08”-.14” .14”-.20” .20”-.27” .15”-.21” .21”-.28” .28”-.34” .13”-.19” .19”-.25” .25”-.31” .31”-.38” .38”-.44” N.P.T. Hub Size 1 /4” 3 /8” Black Cord Connector with Spiral 1 /2” (mm) (1.9-3.4) (3.4-5.1) (5.1-6.7) (3.7-5.3) (5.3-7.0) (7.0-8.6) (3.2-4.7) (4.7-6.3) (6.3-7.9) (7.9-9.5) (9.5-11.1) Gray HJ1010GPK25 HJ1011GPK25 HJ1012GPK25 HJ1013GPK25 HJ1014GPK25 HJ1015GPK25 HJ1038GPK25 HJ1039GPK25 HJ1040GPK25 HJ1041GPK25 HJ1042GPK25 Black HJ1010BPK25 HJ1011BPK25 HJ1012BPK25 HJ1013BPK25 HJ1014BPK25 HJ1015BPK25 HJ1038BPK25 HJ1039BPK25 HJ1040BPK25 HJ1041BPK25 HJ1042BPK25 Miniature Nylon Snap-In Cord Connector Hubbell Juniors® Gray Snap-In Cord Connector Black Snap-In Cord Connector T-86 Cord Diameter Range Inches (mm) .22”-.27” (5.6-6.9) .28”-.32” (7.1-8.1) .30”-.36” (7.6-9.1) .32”-.43” (8.1-10.9) For Chassis Thickness .10” (2.5) Max .10” (2.5) Max .13” (3.2) Max .13” (3.2) Max Gray HS1001GPK25 HS1002GPK25 HS1003GPK25 HS1004GPK25 Black HS1001BPK25 HS1002BPK25 HS1003BPK25 HS1004BPK25 Notes: Catalog numbers above with “PK25” suffix, i.e. HJ1001GPK25, are bulk packed 25 per carton. See pages T-97 and T-98 for additonal technical data and dimensional drawings. www.hubbell-wiring.com Dimensions in Inches (mm) Technical Data Operating Temperatures Material Temperature Range Aluminum -40°F to +300°F (-40°C to +149°C) Nylon (connectors and GOTCHA® rings) -40°F to +225°F (-40°C to +107°C) Plated steel* -60°F to +1000°F (-51°C to +537°C) Stainless steel* -60°F to +1000°F (-51°C to +537°C) Neoprene (bushings) -30°F to +240°F (-34°C to +115°C) *Due to the limiting factors of nylon and neoprene, any complete cord connector with a GOTCHA ring, Form 1-5, will continuously perform in the range of -30°F to +225°F (-34°C to +107°C). Wire Management Products Cord Connectors Cord connectors without GOTCHA rings, Form 6-8, will continuously operate in the range -30°F to +240°F (-34°C to +115°C) due to the limiting factor of neoprene. Hazardous Locations Hubbell cord connectors are suitable for use in hazardous locations per Class I Div. 2, Class II Div. 1 & 2, Class Ill Div. 1 & 2 NEC Reference 501-4(b), 502-4(a), 502-4(b), 503-3(a), and 503-3(b). Flammability Hubbell nylon cord connectors have a UL 94-V2 rating. Approvals Agency UL Listed in accordance with Standard 514B. CSA Certified. United States Coast Guard Approved, Title 46-Part 111. Form Size Definition The term “Form Size” refers to the physical overall size of a cord connector. Form 1 is the smallest size. Form 8 is the largest size. Knockout Holes Knockout Hole Recommended Min. to Max. Inches (mm) .54”-.57” (13.7-14.5) .67”-.70” (17.0-17.8) .86”-.91” (21.8-23.0) 1.09”-1.14” (27.8-29.0) 1.36”-1.41” (34.5-35.7) 1.72”-1.77” (43.7-44.9) 1.97”-2.02” (50.0-51.2) 2.45”-2.50” (62.3-63.5) 2.95”-3.00” (75.0-76.2) 3.58”-3.63” (90.9-92.1) N.P.T. Hub Size 1 /4” 3 /8” 1 /2” 3 /4” 1” 11 /4” 11 /2” 2” 21 /2” 3” N.P.T - PG Thread Low Profile Connectors Technical Data Specifications Material: Polyamide Sealing Grommet: Neoprene Temperature Range: -30°C to 100°C. Cord Connectors are Halogen and Silicon free. Protection Class: IP67. Flame Retardant: UL 94V-0. Listings/Certifications: UL 514B, VDE 0619, CSA C22.2 No. 18. SECP29G Dimensions in Inches (mm) www.hubbell-wiring.com T-87 Wire Management Products Cord Connectors Technical Data Dimensional Charts Straight Hubbell Connectors Aluminum Inches (mm) F A B C Dia. .88” (22.4) .88” (22.4) .88” (22.4) 1.13” (28.7) 1.38” (35.1) 1.13” (28.7) 1.38” (35.1) Ref. .90” (22.9) .90” (22.9) .90” (22.9) 1.10” (27.9) 1.50” (38.1) 1.10” (27.9) 1.50” (38.1) Nylon Inches (mm) .46” (11.7) .46” (11.7) .46” (11.7) .55” (14.0) .55” (14.0) .55” (14.0) .55” (14.0) D Throat Dia. .32” (8.1) .44” (11.2) .44” (11.2) .64” (16.3) .64” (16.3) .64” (16.3) .82” (20.8) E A/C* .99” (25.1) .99” (25.1) 1.00” (25.4) 1.11” (28.2) 1.40” (35.6) 1.29” (32.8) 1.40” (35.6) A B C .43” (10.9) .43” (10.9) .46” (11.7) .53” (13.5) • D Throat Dia. .33” (8.4) .45” (11.4) .45” (11.4) .58” (14.7) • A/F* .88” (22.4) .88” (22.4) .88” (22.4) 1.00” (25.4) 1.25” (31.7) 1.13” (28.7) 1.25” (31.7) Dia. 1.00” (25.4) 1.00” (25.4) 1.00” (25.4) 1.32” (33.5) • Ref. 1.10” (27.9) 1.10” (27.9) 1.10” (27.9) 1.50” (38.1) • • E A/C* .1.00” (25.4) 1.00” (25.4) 1.00” (25.4) 1.25” (31.7) • A/F* .93” (23.6) .93” (23.6) .93” (23.6) 1.12” (28.4) • • • • • • 1.56” (39.6) 1.60” (40.6) .55” (14.0) .77” (19.6) 1.44” (36.6) 1.31” (33.3) N.P.T. 1 /4”-18 Form 1 3 / 8”-18 1 1 / 2”-14 1 1 / 2”-14 2 1 / 2”-14 3 3 / 4”-14 2 3 / 4”-14 3 1”-111 / 2 4 1.75” (44.4) 1.60” (40.6) .71” (18.0) 1.02” (25.9) 1.81” (46.0) 1.62” (41.1) 1.88” (47.8) 1.75” (44.4) .70” (17.8) 1.01” (25.7) 1.84” (46.7) 1.63” (41.4) 1”-111 / 2 5 2.31” (58.7) 1.70” (43.2) .66” (16.8) 1.01” (25.7) 2.28” (57.9) 2.00” (50.8) • • • • • • 11 / 4”-111 / 2 5 2.31” (58.7) 1.70” (43.2) .74” (18.8) 1.26” (32.0) 2.28” (57.9) 2.12” (53.8) • • • • • • 11 / 2”-111 / 2 5 2.31” (58.7) 1.70” (43.2) .74” (18.8) 1.38” (35.1) 2.28” (57.9) 2.12” (53.8) • • • • • • 11 / 2”-111 / 2 6 3.00” (76.2) 2.20” (55.9) .75” (19.0) 1.50” (38.1) 2.97” (75.4) 2.75” (69.8) • • • • • • 2”-111 / 2 6 3.00” (76.2) 2.20” (55.9) .80” (20.3) 1.92” (48.8) 3.24” (82.4) 3.00” (76.2) • • • • • • 2”-111 / 2 7 3.85” (97.8) 2.70” (68.6) .88” (22.4) 1.94” (49.3) 4.05” 3.75” (102.9) (95.2) • • • • • • 21 / 2”-8 7 3.85” 2.70” 1.30” (97.8) (68.6) (33.0) 21 / 2”-8 8 4.75” 2.70” 1.25” (120.6) (68.6) (31.7) 3”-8 7 3.85” 2.70” 1.30” (97.8) (68.6) (33.0) 3”-8 8 4.50” 2.70” 1.38” (114.3) (68.6) (35.1) *A/C— Across Corners; A/F—Across Flats 2.32” (58.9) 2.38” (60.5) 2.54” (64.5) 3.00” (76.2) 4.34” (110.2) 4.86” (123.4) 4.34” (110.2) 4.86” (123.4) • • • • • • • • • • • • • • • • • • • • • • • • 4.02” (102.1) 4.50” (114.3) 4.02” (102.1) 4.50” (114.3) Technical Data A (Overall) B Ref. Dimensions shown are approximate and are subject to change without notice. E F C D T-88 www.hubbell-wiring.com Dimensions in Inches (mm) Technical Data Dimensional Charts Straight Hubbell Connectors Zinc-Plated Steel Inches (mm) F A B C Stainless Steel Inches (mm) N.P.T. 1/4”- 18 Form 1 A/C* • A/F* • Ref. • • D Throat Dia. • E A 3/8”-18 1 1/2”-14 1 .98” (24.9) .98” (24.9) .88” (22.4) .88” (22.4) .90” (22.9) .90” (22.9) .42” (10.7) .55” (14.0) .45” (11.4) .45” (11.4) .99” (25.1) 1.00” (25.4) .88” (22.4) .88” (22.4) 1/2”-14 2 1.27” 1.13” 1.20” .55” .64” (32.3) (28.7) (30.5) (14.0) (16.3) 1.10” (28.2) 1.00” (25.4) 1.30” 1.13” 1.10” (33.0) (28.7) (27.9) .54” .63” 1.16” 1.00” (13.7) (16.0) (29.5) (25.4) 1/2”-14 3 1.55” 1.38” 1.50” .55” .64” (39.4) (35.1) (38.1) (14.0) (16.3) 1.40” (35.6) 1.25” (31.7) • • • • • • • 3/4”-14 2 1.27” 1.13” 1.20” .55” .64” (32.3) (28.7) (30.5) (14.0) (16.3) 1.29” (32.8) 1.13” (28.7) • • • • • • • 3/4”-14 3 1.55” 1.38” 1.40” .55” .82” (39.4) (35.1) (35.6) (14.0) (20.8) 1.40” (35.6) 1.25” (31.7) 1.59” 1.38” 1.30” (40.4) (35.1) (33.0) .56” .81” 1.44” 1.25” (14.2) (20.6) (36.6) (31.7) 1”-111/2 3 1”-111/2 5 11/4”-111/2 5 11/2”-111/2 5 11/2”-111/2 6 2”-111/2 6 2”-111/2 7 21/2”-8 7 .70” (17.8) .70” (17.8) .70” (17.8) .73” (18.5) .74” (18.8) .75” (19.0) .78” (19.8) .78” (19.8) • .89” (22.6) 1.02” (25.9) 1.02” (25.9) 1.27” (32.3) 1.39” (35.3) 1.52” (38.6) 1.92” (48.8) 1.99” (50.5) • 1.54” (39.1) 1.95” (49.5) 2.46” (62.5) 2.48” (63.0) 2.48” (63.0) 3.04” (77.2) 3.32” (84.3) 4.18” (106.2) • 1.38” (35.1) 1.69” (42.9) 2.15” (54.6) 2.19” (55.6) 2.19” (55.6) 2.83” (71.9) 3.07” (78.0) 3.89” (98.8) • • 4 1.40” (35.6) 1.60” (40.6) 1.70” (43.2) 1.70” (43.2) 1.70” (43.2) 2.20” (55.9) 2.20” (55.9) 2.70” (68.6) • • 1”-111/2 1.55” 1.38” (39.4) (35.1) 1.92” 1.69” (48.8) (42.9) 2.40” (61.0) 2.40” (61.0) 2.40” (61.0) 3.06” (77.7) 3.06” (77.7) 3.95” (100.3) • • 21/2”-8 • • • • • • • 3”-8 7 • • • • • 3”-8 8 • • • • • A/C* • A/F* • A/C* 1.01” (25.7) 1.01” (25.7) • B A/F* .88” (22.4) .88” (22.4) • • C D Throat Dia. .46” .38” (11.7) (9.7) .46” .45” (11.7) (11.4) • • .90” (22.9) .90” (22.9) • • • E A/C* .87” (22.1) .87” (22.1) • • A/F* .75” (19.0) .75” (19.0) • Wire Management Products Cord Connectors • 2.02” 1.75” 1.40” (51.3) (44.4) (35.6) • • • .70” 1.03” 1.88” 1.63” (17.8) (26.2) (47.8) (41.4) • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • • *A/C— Across Corners; A/F—Across Flats A (Overall) Technical Data B Ref. E F C D Dimensions in Inches (mm) www.hubbell-wiring.com T-89 Wire Management Products Cord Connectors Technical Data Dimensional Charts 45° Hubbell Connectors Aluminum Inches (mm) F N.P.T. A B Ref. C Zinc Plated Steel Inches (mm) D E G Throat Across Across Dia. Corners Flats Dia. A B C D E G Throat Across Across Across Across Dia. Corners Flats Corners Flats Form Ref. Ref. Ref. 1/2”-14 2 2.00” 1.90” (50.8) (48.3) .55” .56” (14.0) (14.2) 1.27” (32.3) 1.10” (27.9) 1.13” (28.6) 1.97” (50.0) 1.90” (48.3) .55” .57” (14.0) (14.4) 1.24” (31.5) 1.06” (26.9) 1.27” (32.3) 1.13” (28.6) 3/4”-14 3 2.30” 2.50” (58.4) (65.3) .56” .75” (14.2) (19.0) 1.48” (37.6) 1.28” (32.5) 1.38” (34.9) • • • • • • • • 1”-111/2 4 2.60” 2.80” (66.0) (71.1) .70” 1.00” (17.8) (25.4) 1.69” (42.9) 1.50” (38.1) 1.75” (44.4) • • • • • • • • 11/2”-111/2 5 3.90” 3.90” (99.1) (9.91) .74” 1.25” (18.8) (31.7) 2.45” (62.2) 2.13” (54.0) 2.31” (58.7) • • • • • • • • 11/2”-111/2 5 3.90” 3.90” (99.1) (99.1) .74” 1.50” (18.8) (38.1) 2.45” (62.2) 2.13” (54.0) 2.31” (58.7) • • • • • • • • 90° Hubbell Connectors Aluminum Inches (mm) F A B Zinc Plated Steel Inches (mm) C D E G Throat Across Across Dia. Corners Flats Dia. A B C N.P.T. Form Ref. D E G Throat Across Across Across Across Dia. Corners Flats Corners Flats 3/8”-18 1 1.27” 2.00” (32.3) (50.8) .46” (11.7) .44” (11.2) 1.15” (29.2) 1.10” (27.9) .88” (22.2) • • • • 1/2”-14 2 1.56” 2.30” (39.6) (58.4) .50” .55” (12.7) (13.9) 1.30” (33.0) 1.13” (28.7) 1.13” (28.6) 1.65” (41.9) 2.38” (60.5) 3/4”-14 3 1.79” 2.80” (45.5) (71.1) .56” .77” (14.2) (19.4) 1.49” (37.8) 1.31” (33.3) 1.38” (34.9) 1.88” (47.8) 1”-111/2 4 2.08” 3.20” (52.8) (81.3) .70” 1.00” (17.8) (25.4) 1.70” (43.2) 1.50” (38.1) 1.75” (44.4) 11/4”-111/2 5 3.18” 4.30” .73” 1.26” (80.8) (109.2) (18.5) (32.0) 2.47” (62.7) 2.15” (54.6) 11/2”-111/2 5 3.18” 4.30” .75” 1.50” (80.8) (109.2) (19.2) (38.1) 2.47” (62.7) 2”-111/2 6 3.51” 5.50” .80” 1.92” (89.2) (139.7) (20.3) (48.8) 2.98” (75.7) Ref. B Ref. G • • • • .55” .55” (14.0) (13.8) 1.29” (32.8) 1.13” (28.7) 1.27” (32.3) 1.13” (28.6) 2.90” (73.7) .56” .77” (14.2) (19.4) 1.52” (38.6) 1.33” (33.8) 1.55” (39.2) 1.38” (34.9) 2.16” (54.9) 3.20” (81.3) .70” 1.00” (17.8) (25.4) 1.72” (43.7) 1.50” (38.1) 1.92” (48.8) 1.69” (42.8) 2.31” (58.7) • • • • • • • • 2.15” (54.6) 2.31” (58.7) • • • • • • • • 2.78” (70.6) 3.00” (76.2) • • • • • • • • 90° Hubbell Connectors Nylon Inches (mm) F A Ref. E F C D Throat Dia. E Across Across Corners Flats Dia. Ref. G Form 3/8”-18 1 • • • • • • • 1/2”-14 2 1.41” (35.8) 2.50” (63.5) .55” (14.0) .58” (14.6) 1.23” (31.2) 1.12” (28.2) 1.32” (33.4) 3/4”-14 3 1.65” (41.9) 2.81” (71.4) .56” (14.2) .77” (19.4) 1.42” (36.1) 1.29” (32.8) 1.56” (39.6) 1”-111/2 4 1.99” (50.5) 3.30” (83.8) .70” (17.8) 1.01” (25.7) 1.82” (46.2) 1.60” (40.6) 1.88” (47.6) D Technical Data B N.P.T. C B Ref. A G A E F D D T-90 Dimensions shown are approximate and are subject to change without notice. www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Cord Connectors Technical Data Dimensional Charts Female Hubbell Connectors Aluminum A (Overall) Inches (mm) F A B N.P.T. Form Dia. Ref. 3/8”-18 1 .88” (22.4) 1.40” (35.6) 1/2”-14 2 1.13” (28.7) D Throat Dia. Across Corners Across Flats .56” (14.2) .44” (11.2) .94” (23.9) .81” (20.6) 1.80” (45.7) .56” (14.2) .63” (16.0) 1.15” (29.2) 1.00” (25.4) ”-14 2 1.13” (28.7) 2.10” (53.3) .75” (19.0) .63” (16.0) 1.44” (36.6) 1.25” (31.7) 1”-111/2 4 1.75” (44.5) 2.30” (58.4) .88” (22.4) 1.10” (27.9) 1.88” (47.8) 1.63” (41.4) 11/4”-111/2 5 2.31” (58.7) 2.80” (71.1) .95” (24.1) 1.43” (36.3) 2.64” (67.1) 2.29” (58.2) 11/2”-111/2 5 2.31” (58.7) 2.80” (71.1) .95” (24.1) 1.43” (36.3) 2.64” (67.1) 2.29” (58.2) 3/4 C E B Ref. E D C (N.P.T. Thread Depth) Underground Feeder Connectors F Aluminum Inches (mm) Nylon Inches (mm) A A B C D E Thrt. N.P.T. Form Dia. Ref. Dia. A/C* A/F* 1/2”-14 2 1.13” 1.10” .55” .64” 1.10” 1.00” (28.7) (27.9) (14.0) (16.3) (27.9) (25.4) B D E A Thrt. Dia. Ref. Dia. A/C* A/F* A/C* A/F* 1.32” 1.50” .55” .58” 1.25” 1.13” 1.27” 1.13” (33.5) (38.1) (14.0)(14.7) (31.7) (28.7) (32.3) (28.7) • C • • A (Overall) Zinc-Plated Steel Inches (mm) • • B C D E Thrt. Ref. Dia. A/C* A/F* 1.20” .55” .64” 1.11” 1.00” (30.5) (14.0) (16.3) (28.2)(25.4) 3/4”-14 2 1.13” 1.10” .55” .64” 1.29” 1.13” • (28.7) (27.9) (14.0) (16.3) (32.8) (25.4) 1.27” 1.13” 1.20” .55” .64” 1.29” 1.13” (32.3) (28.7) (30.5) (14.0) (16.3) (32.8)(28.7) 3/4”-14 3 1.13” 1.50” .55” .82” 1.40” 1.25” 1.56” 1.60” .56” .77” 1.44” 1.31” 1.55” 1.38” 1.40” .56” .82” 1.40” 1.25” (28.7) (38.1) (14.0) (20.8) (35.6) (31.7) (39.6) (40.6) (14.2)(19.6) (36.6) (33.3) (39.4) (35.1) (35.6) (14.2) (20.8) (35.6)(31.7) B Ref. E F C *A/C - Across Corners; A/F - Across Flats D Low Profile Non-Metallic N.P.T. and PG Thread Connectors B C Inches (mm) N.P.T. A B C D E F 3/8” .984” (25) .591” (15) .591” (15) .33” (8.38) .827” (21) .748” (19) 1/2” 1.378” (35) .787” (20) .591” (15) .47” (12) 1.063” (27) .945” (24.23) 3/4” 1.417” (36) .866” (22) .591” (15) .72” (18.3) 1.417” (36) 1.299” (33) 1” 1.654” (42) .984” (25) .984” (25) 1.00” (25.4) 1.850” (47) 1.654” (42) G A B C D E F G .827” (21) .472” (12) .315” (8) .26” (6.6) .669” (17) .591” (15) .492” (12.5) PG9 .984” (25) .591” (15) .315” (8) .33” (8.38) .827” (21) .748” (19) .598” (15.19) PG11 1.181” (30) .709” (18) .315” (8) .40” (10.16) .984” (25) .866” (22) .732” (18.6) PG13.5 1.378” (35) .787” (20) .354” (9) .47” (12) 1.063” (27) .945” (24) .803” (20.4) PG16 1.378” (35) .827” (21) .394” (10) .55” (14) 1.181” (30) 1.063” (27) .886” (22.5) PG21 1.417” (36) .866” (22) .433” (11) .72” (18.3) 1.417” (36) 1.299” (33) 1.114” (28.3) PG29 1.653” (42) .984” (25) .433” (11) 1.46” (37) 1.85” (47) 1.654” (42) 1.457” (37) PG36 1.811” (46) 1.181” (30) .512” (13) 1.85” (47) 2.283” (58) 2.087” (53) 1.85” (47) Dimensions in Inches (mm) www.hubbell-wiring.com F BBELL HU E D T-91 Technical????? Data A PG7 ® PG Thread E.C.C. Nylon Wire Management Products Cord Connectors Selection Chart 2 Conductors Cord Type SVO, SV, SVT SJ, SJO, SJT, SJTO S, SO, ST, STO Cord Size #18 #18 #16 #14 Approximate .25” .31” .33” .37” Diameter (6.2) (7.8) (8.4) (9.3) N.P.T. Form Catalog Numbers* 1/4” 1 HC1004 HC1004 HC1005 HC1005 3/8” 1 HC1010 HC1010 HC1011 HC1011 1/2” 1 HC1016 HC1016 HC1017 HC1017 1/2” 2 HC1022 HC1022 HC1022 HC1022 1/2” 3 • • • • 3/4” 2 HC1032 HC1032 HC1032 HC1032 3/4” 3 • • • • 1” 4 • • • • 1” 5 • • • • 11/4” 5 • • • • 11/2” 5 • • • • 11/2” 6 • • • • 2” 6 • • • • 2” 7 • • • • 21/2” 7 • • • • 3” 7 • • • • Color Black Black White White * Must add prefix, see Note 1; suffix, see Note 2, on page T-95. #18 .38” (9.7) #16 .40” (10.2) #14 .54” (13.7) #12 .62” (15.6) #10 .68” (17.1) #8 .81” (20.6) HC1006 HC1012 HC1018 HC1023 HC1025 HC1033 HC1035 HC1039 • • • • • • • • Blue HC1006 HC1012 HC1018 HC1023 HC1025 HC1033 HC1035 HC1039 • • • • • • • • Blue • • • HC1024 HC1026 HC1034 HC1036 HC1040 • • • • • • • • Brown • • • HC1024 HC1026 HC1034 HC1036 HC1040 • • • • • • • • Brown • • • • HC1027 • HC1037 HC1041 • • • • • • • • Yellow • • • • HC1028 • HC1038 HC1042 HC1045 HC1050 HC1055 • • • • • Orchid 3 Conductors Technical Data Cord Type SVO, SV, SVT SJ, SJO, SJT, SJTO S, SO, ST, STO Cord Size #18 #18 #16 #14 Approximate .26” .33” .35” .39” Diameter (6.5) (8.3) (8.9) (9.8) N.P.T. Form Catalog Numbers* 1/4” 1 HC1004 HC1005 HC1005 HC1006 3/8” 1 HC1010 HC1011 HC1011 HC1012 1/2” 1 HC1016 HC1017 HC1017 HC1018 1/2” 2 HC1022 HC1022 HC1022 HC1023 1/2” 3 • • • HC1025 3/4” 2 HC1032 HC1032 HC1032 HC1033 3/4” 3 • • • HC1035 1” 4 • • • HC1039 1” 5 • • • • 11/4” 5 • • • • 11/2” 5 • • • • 11/2” 6 • • • • 2” 6 • • • • 2” 7 • • • • 21/2” 7 • • • • 3” 7 • • • • Color Black White White Blue * Must add prefix, see Note 1; suffix, see Note 2, on page T-95. T-92 #18 .39” (9.9) #16 .42” (10.7) #14 .57” (14.4) #12 .65” (16.4) #10 .71” (18.0) #8 .85” (21.5) HC1006 HC1012 HC1018 HC1023 HC1025 HC1033 HC1035 HC1039 • • • • • • • • Blue HC1006 HC1012 HC1018 HC1023 HC1025 HC1033 HC1035 HC1039 • • • • • • • • Blue • • • HC1024 HC1026 HC1034 HC1036 HC1040 • • • • • • • • Brown • • • • HC1027 • HC1037 HC1041 • • • • • • • • Yellow • • • • HC1027 • HC1037 HC1041 • • • • • • • • Yellow • • • • HC1028 • HC1038 HC1042 HC1045 HC1050 HC1055 • • • • • Orchid www.hubbell-wiring.com Dimensions in Inches (mm) Selection Chart 2 Conductors CordType SVO, SV, SVT SJ, SJO, SJT, SJTO S, SO, ST, STO Cord Size #6 #4 #3 #2 Approx. .94” 1.08” 1.17” 1.27” Diameter (23.8) (27.4) (29.7) (33.3) N.P.T. Form Catalog Numbers* 1/4” 1 • • • • 3/8” 1 • • • • 1/2” 1 • • • • 1/2” 2 • • • • 1/2” 3 • • • • 3/4” 2 • • • • 3/4” 3 • • • • 1” 4 HC1043 HC1044 • • 1” 5 HC1046 HC1047 HC1048 HC1049 11/4” 5 HC1051 HC1052 HC1053 HC1054 11/2” 5 HC1056 HC1057 HC1058 HC1059 11/2” 6 • • • HC1060 2” 6 • • • HC1065 2” 7 • • • • 21/2” 7 • • • • 3” 7 • • • • Color Gray‡ Pink‡ ‡ ‡ * Must add prefix, see Note 1; suffix, see Note 2, on page T-95. ‡ F5 and larger will not be color coded. #1 1.44” (36.6) #1/0 1.52” (38.6) #2/0 1.65” (41.9) #3/0 1.77” (45.0) #4/0 1.92” (48.8) #250 2.16” (51.9) • • • • • • • • • • • HC1061 HC1066 • • • ‡ • • • • • • • • • • • HC1062 HC1067 • • • ‡ • • • • • • • • • • • HC1063 HC1068 • • • ‡ • • • • • • • • • • • HC1064 HC1069 HC1070 HC1076 HC1086 ‡ • • • • • • • • • • • • • HC1071 HC1077 HC1087 ‡ • • • • • • • • • • • • • HC1073 HC1079 HC1089 ‡ Wire Management Products Cord Connectors 3 Conductors CordType SVO, SV, SVT SJ, SJO, SJT, SJTO S, SO, ST, STO Dimensions in Inches (mm) #1 1.51” (38.4) #1/0 1.65” (41.9) #2/0 1.75” (44.5) #3/0 1.80” (48.0) #4/0 2.07” (52.6) #250 2.39” (60.7) • • • • • • • • • • • HC1062 HC1067 • • • ‡ • • • • • • • • • • • HC1063 HC1068 • • • ‡ • • • • • • • • • • • HC1064 HC1069 HC1070 HC1076 HC1086 ‡ • • • • • • • • • • • • • HC1071 HC1077 HC1087 ‡ • • • • • • • • • • • • • HC1073 HC1079 HC1089 ‡ • • • • • • • • • • • • • HC1075 HC1081 HC1091 ‡ www.hubbell-wiring.com T-93 Technical Data Cord Size #6 #4 #3 #2 Approx. 1.00” 1.17” 1.24” 1.34” Diameter (25.4) (29.7) (31.5) (34.0) N.P.T. Form Catalog Numbers* 1/4” 1 • • • • 3/8” 1 • • • • 1/2” 1 • • • • 1/2” 2 • • • • 1/2” 3 • • • • 3/4” 2 • • • • 3/4” 3 • • • • 1” 4 HC1044 • • • 1” 5 HC1047 HC1048 HC1048 HC1049 11/4” 5 HC1052 HC1053 HC1053 HC1054 11/2” 5 HC1057 HC1058 HC1058 HC1059 11/2” 6 • • • HC1060 2” 6 • • • HC1065 2” 7 • • • • 21/2” 7 • • • • 3” 7 • • • • Color Gray‡ ‡ ‡ ‡ * Must add prefix, see Note 1; suffix, see Note 2, on page T-95. ‡ F5 and larger will not be color coded. Wire Management Products Cord Connectors Selection Chart 4 Conductors Cord Type SJ, SJO, SJT, SJTO S, SO, ST, STO Cord Size #18 #16 #14 #18 Approx. .36” .39” .43” .42” Diameter (9.0) (9.8) (10.8) (10.7) N.P.T. Form Catalog Numbers* 1/4” 1 HC1005 HC1006 HC1006 HC1006 3/8” 1 HC1011 HC1012 HC1012 HC1012 1/2” 1 HC1017 HC1018 HC1018 HC1018 1/2” 2 HC1022 HC1023 HC1023 HC1023 1/2” 3 • HC1025 HC1025 HC1025 3/4” 2 • HC1033 HC1033 HC1033 3/4” 3 • HC1035 HC1035 HC1035 1” 4 • HC1039 HC1039 HC1039 1” 5 • • • • 11/4” 5 • • • • 11/2” 5 • • • • 11/2” 6 • • • • 2” 6 • • • • 2” 7 • • • • 21/2” 7 • • • • 3” 7 • • • • Color White Blue Blue Blue * Must add prefix, see Note 1; suffix, see Note 2, on page T-95. ‡ F5 and larger will not be color coded. #16 .45” (11.4) #14 .61” (15.5) #12 .70” (17.8) #10 .77” (19.4) #8 .97” (24.6) • • • HC1023 HC1025 HC1033 HC1035 HC1039 • • • • • • • • Blue • • • HC1024 HC1026 HC1034 HC1036 HC1040 • • • • • • • • Brown • • • • HC1027 • HC1037 HC1041 • • • • • • • • Yellow • • • • HC1028 • HC1038 HC1042 • • • • • • • • Orchid • • • • • • • HC1043 HC1046 HC1051 HC1056 • • • • • Gray‡ Technical Data 5 Conductors Cord Type S, SO, ST, STO Cord Size #18 #16 #14 Approx. .50” .54” .70” Diameter (12.7) (13.7) (17.7) N.P.T. Form Catalog Numbers* 1/2” 2 HC1023 HC1024 • 1/2” 3 HC1025 HC1026 HC1027 3/4” 2 HC1033 HC1034 • 3/4” 3 HC1035 HC1036 HC1037 1” 4 HC1039 HC1040 HC1041 1” 5 • • • 11/4” 5 • • • 11/2” 5 • • • Color Blue Brown Yellow * Must add prefix, see Note 1; suffix, see Note 2, on page T-95. ‡ F5 and larger will not be color coded. T-94 #12 .76” (19.3) #10 .83” (21.1) #8 1.06” (26.9) #6 1.18” (30.0) • HC1028 • HC1038 HC1042 HC1045 HC1050 HC1055 Orchid‡ • HC1028 • HC1038 HC1042 HC1045 HC1050 HC1055 Orchid‡ • • • • HC1044 HC1047 HC1052 HC1057 Pink • • • • • HC1048 HC1053 HC1058 ‡ www.hubbell-wiring.com Dimensions in Inches (mm) Selection Chart 4 Conductors Cord Type SJ, SJO, SJT, SJTO S, SO, ST, STO Cord Size #6 #4 #3 Approx. .94” 1.08” 1.17” Diameter (23.8) (27.4) (29.7) N.P.T. Form Catalog Numbers* 1/4” 1 • • • 3/8” 1 • • • 1/2” 1 • • • 1/2” 2 • • • 1/2” 3 • • • 3/4” 2 • • • 3/4” 3 • • • 1” 4 HC1044 • • 1” 5 HC1047 HC1049 HC1049 11/4” 5 HC1052 HC1054 HC1054 11/2” 5 HC1057 HC1059 HC1059 11/2” 6 • HC1060 HC1060 2” 6 • HC1064 HC1065 2” 7 • • • 21/2” 7 • • • 3” 7 • • • Color Pink‡ ‡ ‡ * Must add prefix, see Note 1; suffix, see Note 2, below. ‡ F5 and larger will not be color coded. #2 1.27” (33.3) #1 1.44” (36.6) #1/0 1.52” (38.6) #2/0 1.65” (41.9) #3/0 1.77” (45.0) #4/0 1.92” (48.8) • • • • • • • • • • • HC1061 HC1066 • • • ‡ • • • • • • • • • • • HC1063 HC1068 • • • ‡ • • • • • • • • • • • HC1064 HC1069 HC1070 HC1076 HC1086 ‡ • • • • • • • • • • • • • HC1071 HC1077 HC1087 ‡ • • • • • • • • • • • • • HC1073 HC1079 HC1089 ‡ • • • • • • • • • • • • • HC1074 HC1080 HC1090 ‡ Notes 1. Add the proper prefix to the HC number to identify the type of connector desired: SHC = Straight Hubbell Connector NHC = 90° Hubbell Connector FHC = Female Hubbell Connector VHC = 45° Hubbell Connector Dimensions in Inches (mm) 4. *Cable jacket may have to be stripped to allow conductors to pass through connector body. www.hubbell-wiring.com T-95 Technical Data 2. Add the proper suffix to identify material desired: Aluminum = No suffix Zinc-Plated Steel = ZP Corrosion Resistant Nylon = CR Stainless Steel = SS 3. This chart is a general guide to assist in the selection of Hubbell Cord Connectors for various cord sizes. The Hubbell Cord Connector catalog numbers selected, have been inserted into spaces which in our judgment represent the best cord connector which will fit the listed cord size. The diameters of the cords are approximate and may vary depending on the manufacturer. It is suggested that the appropriate cord manufacturer’s dimension chart be consulted for exact dimensions. Wire Management Products Cord Connectors Wire Management Products Locknuts and Sealing O-Rings Technical Data Locknuts – Sizes 1/2” - 3” C Maximum Diameter B Minimum THK. A Thread Size (N.P.S.) Carbon Steel with Commercial Bright Zinc Plate A B Trade Thd. Size Min. Thk. Size inch inch (mm) 1/2” 1/2”-14 .09” (2.3) 3/4” 3/4”-14 .11” (2.8) 1” 1”-111/2 .13” (3.3) 11/4” 11/4”-111/2 .13” (3.3) 11/2” 11/2”-111/2 .13” (3.3) 2” 2”-111/2 .13” (3.3) 21/2” 21/2”-8 .18” (4.6) 3” 3”-8 .36” (9.1) C Max. Dia. inch (mm) Catalog Numbers 1.14” 1.43” 1.77” 2.28” 2.60” 3.18” 3.56” 4.13” (29.0) (36.3) (45.0) (57.9) (66.0) (80.8) (90.4) (104.9) 00322001 00322002 00322003 00322004 00322005 00322006 00322007 00322082 C Thk. inch .16” .16” .16” (mm) (3.2) (3.2) (3.2) Catalog Numbers 20509001 20509002 20509003 .16” .16” .16” (3.2) (3.2) (3.2) 20509004 20509005 20509006 .24” .24” .29” (6.1) (6.1) (7.4) 20509007 20509008 20509009 Metal Clad Sealing O-Rings – Sizes 1/2” - 4” A B C Zinc-Plated Steel with Neoprene Ring N.P.T. A B Hub Inside Dia. Outside Dia. Size inch (mm) inch (mm) 1/2” .80” (20.3) 1.08” (27.4) 3/4” 1.00” (25.4) 1.34” (34.0) 1” 1.25” (31.6) 1.63” (41.4) 11/4” 1.61” (40.9) 2.00” (50.8) 11/2” 1.84” (46.7) 2.36” (59.9) 2” 2.31” (58.7) 2.83” (71.9) Chrome Plated Steel with Neoprene Ring 21/2” 2.91” (73.9) 3.44” (87.4) 3” 3.52” (89.4) 4.08” (103.6) 4” 4.54” (115.3) 5.30” (134.6) Technical Data Nylon PG Thread Locknuts PG Thread Size PG7 PG9 A inch .784” .866” PG11 PG13.5 PG16 PG21 PG29 PG36 .945” (24) 1.06” (27) 1.18” (30) 1.417” (36) 1.811” (46) 2.362” (60) (mm) (20) (22) B inch (mm) .828” (21) .945” (24) C inch (mm) .492 (12.5) .598 (15.2) D Catalog inch (mm) Numbers .197” (5) LNPG7B .197” (5) LNPG9B 1.024” 1.142” 1.299” 1.535” 1.969” 2.598” .732 .803 .886 1.114 1.457 1.850 .197” .236” .236” .276” .276” .317” (26) (29) (33) (39) (50) (66) (18.5) (20.4) (22.5) (28.3) (37) (47) (5) (6) (6) (7) (7) (8.05) LNPG11B LNPG13B LNPG16B LNPG21B LNPG29B LNPG36B Dimensions shown are approximate and are subject to change without notice. T-96 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products HUBBELL JUNIORS® Miniature Nylon Cord Connectors Technical Data Hubbell Juniors Operating Temperature Range Nylon (connectors and GOTCHA® rings) -40°F to +225°F (-40°C to +107°C) Neoprene (bushings) -30°F to +240°F (-34°C to +115°C) Due to the limiting factors of nylon and neoprene, any complete liquidtight Hubbell Junior will continuously perform in the range of -30°F to +225°F (-34°C to +107°C). Snap-In continuously performs -40°F to +225°F (-40°C to +107°C). Flammability Hubbell Juniors have a UL 94V-2 rating. Certifications Product Liquidtight and Liquidtight with Spiral Snap-In Agency UL Listed CSA Certified UL Recognized CSA Certified Knockout Holes N.P.T. Hub Size 1/4” 3/8” 1/2” Knockout Hole Recommended Min. to Max. inches (mm) .54”-.57” .67”-.70” .86”-.91” (13.7-14.5) (17.0-17.8) (21.8-23.1) Technical Data Dimensions shown are subject to change without notice. Dimensions in Inches (mm) www.hubbell-wiring.com T-97 Wire Management Products HUBBELL JUNIORS® Miniature Nylon Cord Connectors Technical Data Snap-In G C Dia. Range Inches (mm) .22”-.27” (5.6-6.9) .28”-32” (7.1-8.1) .30”-.36” (7.6-9.1) .32”-.43” (8.1-10.9) E F A Chassis Thickness Max B For Chas. Thk. (Max.) Inches (mm) .10” (2.5) .10” (2.5) .13” (3.3) .13” (3.3) Required Hole Size A Inches (mm) .50” (12.7) .50” (12.7) .63” (16.0) .75” (19.0) B Inches (mm) .45” (11.4) .47” (11.9) .55” (14.0) .66” (16.8) Dimensional Specifications C D Inches Inches (mm) (mm) .28” .28” (7.1) (7.1) .28” .33” (7.1) (8.4) .36” .37” (9.1) (9.4) .45” .44” (11.4) (11.2) E Inches (mm) .54” (13.7) .59” (15.0) .65” (16.5) .75” (19.1) F Inches (mm) .12” (3.0) .12” (3.0) .14” (3.6) .14” (3.6) G Inches (mm) 1.84” (44.2) 1.84” (44.2) 2.18” (55.4) 2.60” (66.0) Liquidtight F B A C Dia. Inches (mm) .65” (16.5) .81” (20.6) 1.00” (25.4) N.P.T. 1/4”-18 D A B 3/8”-18 1/2”-14 F C Ref. Inches (mm) 1.30” (33.0) 1.44” (36.6) 1.56” (39.6) D Inches (mm) .40” (10.2) .41” (10.4) .46” (11.7) Throat Dia. Inches (mm) .29” (7.4) .36” (9.1) .45” (11.4) Across Corners Inches (mm) .65” (16.5) .81” (20.6) .99” (25.1) E Across Flats Inches (mm) .60” (15.2) .75” (19.1) .92” (23.4) E Liquidtight with Spiral B A G C E D N.P.T. 1/4”-18 G F 3/8”-18 Technical Data 1/2”-14 T-98 A Dia. Inches (mm) .65” (16.5) .81” (20.6) 1.00” (25.4) B Ref. Inches (mm) 2.55” (64.8) 3.10” (78.7) 3.72” (94.5) www.hubbell-wiring.com C Inches (mm) .40” (10.2) .41” (10.4) .46” (11.7) E Throat Dia. Inches (mm) .29” (7.4) .36” (9.1) .45” (11.4) E Inches (mm) .27” (6.9) .35” (8.9) .45” (11.4) Across Corners Inches (mm) .65” (16.5) .81” (20.6) .99” (25.1) F Across Flats Inches (mm) .60” (15.2) .75” (19.1) .92” (23.4) Dimensions in Inches (mm) Flexible Non-Metallic Conduit Grips Steel Fitting, Stainless Steel Mesh, Liquidtight, for UL Type A Conduit Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-106 through T-107. Straight Male Hubbell Fitting Conduit Trade Size (Inches) 3/8” 1/2” 3/4” 1” 11/4” 11/2” 2” Trade Size N.P.T. (Inches) 1/2” 1/2” 3/4” 1” 11/4” 11/2” 2” Mesh Length Inches (cm) 33/4” (9.52) 41/2” (11.43) 61/4” (15.87) 71/2” (19.05) 9” (22.86) 131/2” (34.29) 141/2” (36.83) Wire Management Products Strain Relief Catalog Numbers H038CNK H050CNK H075CNK H100CNK H125CNK H150CNK H200CNK Straight Male with Fitting 90° Male Hubbell Fitting Conduit Trade Size (Inches) 3/8” 1/2” 3/4” 1” 11/4” 11/2” 2” Trade Size N.P.T. (Inches) 1/2” 1/2” 3/4” 1” 11/4” 11/2” 2” Mesh Length Inches (cm) 33/4” (9.52) 41/2” (11.43) 61/4” (15.87) 71/2” (19.05) 9” (22.86) 131/2” (34.29) 141/2” (36.83) Catalog Numbers H0389CNK H0509CNK H0759CNK H1009CNK H1259CNK H1509CNK H2009CNK 90° Angle Flexible Non-metallic Conduit Grips Dimensions in Inches (mm) www.hubbell-wiring.com T-99 Wire Management Products Strain Relief Flexible Metallic Conduit Grips Steel Fitting, Stainless Steel Mesh, Liquidtight, for Liquidtight Flexible Metal Conduit Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-103 through T-105. Straight with Male Fitting Benefits • Prevents conduit pull-out and damage at the fitting. • Reduces equipment downtime. Straight With Male Fitting Conduit Trade Size (Inches) 3/8” 1/2” 3/4” 1” 11/4” 11/2” 2” 21/2” 3” 4” Trade Size N.P.T. (Inches) 1/2” 1/2” 3/4” 1” 11/4” 11/2” 2” 21/2” 3” 4” Mesh Length Inches (cm) Catalog Numbers (Insulated) Catalog Numbers (Non-insulated) 3” 31/2” 4” 5” (7.62) (8.89) (10.16) (12.70) 074093511 074093512 074093513 074093514 074093401 074093402 074093403 074093404 6” (15.24) 074093515 074093405 63/4” 8” 93/4” 11” 14” (17.14) (20.32) 074093516 074093518 074093406 074093408 (24.76) (27.94) (35.56) 074093520 074093522 074093526 074093410 074093412 • Mesh Length Inches (cm) 3” (7.62) 31/2” (8.89) 4” (10.16) 5” (12.70) 6” (15.24) 63/4” (17.14) 8” (20.32) 93/4” (24.76) 11” (35.56) Catalog Numbers (Insulated) 074093541 074093542 074093543 074093544 074093545 074093546 074093548 074093550 074093552 Catalog Numbers (Non-insulated) 074093421 074093422 074093423 074093424 074093425 074093426 074093428 • • 90° Angle With Male Fitting Trade Size N.P.T. (Inches) 1/2” 1/2” 3/4” 1” 11/4” 11/2” 2” 21/2” 3” Flexible Non-metallic Conduit Grips 90° Angle with Male Fitting Conduit Trade Size (Inches) 3/8” 1/2” 3/4” 1” 11/4” 11/2” 2” 21/2” 3” T-100 www.hubbell-wiring.com Dimensions in Inches (mm) Flexible Metallic Conduit Grips Steel Fitting, Stainless Steel Mesh, Liquidtight, for Flexible Metal Liquidtight Conduit 45° Angle With Male Fitting Conduit Trade Size Trade Size Mesh Length (Inches) N.P.T. (Inches) Inches (cm) 3/8” 1/2” 3” (7.62) 1/2” 1/2” 31/2” (8.89) 3/4” 3/4” 4” (10.16) 1” 1” 5” (12.70) 11/4” 11/4” 6” (15.24) 11/2” 11/2” 63/4” (17.14) 2” 2” 8” (20.32) Note: Refer to page T-89 for fitting dimensions. Catalog Numbers (Insulated) Catalog Numbers (Non-insulated) 074093561 074093562 074093563 074093564 074093441 074093442 074093443 074093444 074093565 074093566 074093568 074093445 074093446 074093448 Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-103 through T-105. Wire Management Products Strain Relief 45° Angle with Male Fitting Straight With Chase Fitting Conduit Trade Size (Inches) 1/2” 3/4” 1” 11/4” 11/2” Trade Size N.P.T. (Inches) 1/2” 3/4” 1” 11/4” 11/2” Mesh Length Inches (cm) 31/2” (8.89) 4” (10.16) 5” (12.70) 6” (15.24) 63/4” (17.14) Catalog Numbers 07406079 07406080 07406081 07406082 07406083 Dimensions in Inches (mm) www.hubbell-wiring.com T-101 Flexible Non-metallic Conduit Grips Straight with Chase Connector Wire Management Products Strain Relief Hose Containment Grips Custom Designed Grips, for High Pressure Hose Restraint Read This Data It is important that you read all breaking strength, safety and technical data relating to this product on pages T-68 through T-69. Types of Attachment The five attachment methods shown below provide unlimited flexibility of attachment to meet any condition. Type E Double Eye Grip, used where fastening is made with eyebolts or similar anchor terminations. Type A Single Eye Grip, used where fastening MUST be made from one point. Type U Universal Bale Grip, used to fasten around a structure or closed eye. Type Y Threaded bolt (5/16-18 x 1 1/2” long), used to fasten through drilled holes in plate. Hose Containment Grips Type F Split fitting to fit AN-818 nuts. Fitting is positioned over nut and located with internal flange. A hose clamp is furnished and required to hold the fitting in correct position. Note: It should be emphasized that Kellems® Hose Containment Grips are not to be used as a pressure reinforcing device for hose systems. These grips are custom made. To order Consult factory for details. Kellems Hose Containment Grips are used on high pressure, flexible hose lines to prevent the hose from whipping violently in the event of hose failure at the fitting. These grips will prevent serious injury to personnel and damage to equipment by holding the hose in place in the event of hose failure. Kellems patented Hose Containment Grips are made of stainless steel with double weave mesh construction for high strength and come complete with hose clamps. Kellems Hose Containment Grips are supplied in diameters, length and attachments to meet individual requirements. Contact the Wiring Device-Kellems factory for specific information. These grips help meet OSHA Federal Register 1926-302 (b), 1926-603 (9), (10), JIC H-1-1973 (H13.11) and JIC P-1-1975 (P11.34) requirements. T-102 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Kellems® Grips for Strain Relief Technical Section Conduit Grips for Liquidtight Flexible Metal Conduit Kellems Liquidtight, Flexible Metal Conduit Grips are offered with high quality Hubbell plated steel fittings in a wide variety of N.P.T. sizes and configurations, either insulated or non-insulated. The addition of a stainless steel mesh to these fittings makes them stronger than the conduit itself. Kellems Conduit Grips prevent conduit pull-out from the connecting fitting that is subject to stress, pull tension, vibration, motion or strain. They promote safe electrical systems and reduce equipment downtime. Benefits • Prevents conduit pull-out and damage at the fitting. • Reduces equipment downtime. • Liquidtight fittings. • Easily installed. • Stainless steel grip resists corrosion. Kellems Conduit Grips are suitable for use in hazardous locations per Class I Div. 2, Class II Div. 1 & 2, Class III Div. 1 & 2 of the National Electric Code sections 501-4(b), 502-4(a), 502-4(b), 503-3(a) and 503-3(b). Application Kellems Conduit Grips are used in the wiring of machine tools, motors, molding equipment, transformers, weaving and paper machines, fans, lighting, bakeries, breweries, food processing, chemical plants, dairies, mines and any application that requires Liquidtight Conduit. Safety And Working Load Factors For Wire Mesh Grips The broad application of Kellems grips on a wide Under normal conditions, Kellems’ variety of objects requires that adequate safety recommended factor of safety is five for catalog factors be used to establish working loads. The listed pulling grips, and ten for catalog listed approximate breaking strength of a Kellems grip support grips. The factory should be consulted represents an average calculation based on data for specific application recommendations established from actual direct tension testing done where strength and holding power are in our engineering laboratories. important factors. It is impossible to catalog or guarantee a safety Any warranty as to quality, performance or fitness factor suitable for all applications as operating for use of grips is always premised on the condition conditions are never the same. The tension, that the published breaking strengths apply only to diameter, movement, number of objects gripped, new, unused grips, and that such products are gripping surface, and the attachments used are just properly stored, handled, used, maintained and some of the factors which vary with each inspected by the user at a frequency appropriate application. These factors, together with the effects for the use and condition of the grip. of abrasion, corrosion, prior use or abuse and any For grip applications on materials other than those other variables of a specific application, must be that the grips have been specifically designed for, considered by the user and the grip replaced as consult the factory. appropriate. Where the conditions of the application are not well defined or known or where risk of injury to persons or property is involved, a greater safety factor should be utilized. Should our opinion be needed, call the factory. Grip Style Bus Drop Approx. Breaking Strength Lbs. (N) 1,000 (4,448) Safety Factor 10 Max. Rec. Load Lbs. (N) 100 (448) Catalog Numbers 074093402 The maximum recommended working load then is the tension to be exerted on the grip in application with a margin of safety to take care of unforeseen and unusual circumstances. It is the end-user’s decision to determine how much of a safety factor is acceptable to him. Dimensions in Inches (mm) www.hubbell-wiring.com T-103 Technical Data Examples Wire Management Products Kellems® Grips for Strain Relief Technical Section Conduit Grips for Liquidtight Flexible Metal Conduit Nylon gland ring is split for ease of installation and greater compresConnectors with insulated throats sion. Reversible design cannot be protect insulation on wires during installed facing the wrong way. wire pulling. Yellow color easily Nylon is impervious to liquids, seen by inspectors. 2 12" - 4" sizes unaffected by temperature include insulating bushing instead extremes and resists abrasion. of fixed insulator. Steel grounding ferrule easily threaded by hand. Fits convolutions to conduit. Eliminates pullouts and insures continuty of ground. Hexagonal compression nut is Hardened Steel Locknut Distortion free to remain reusable. screw machined steel through has tangs that dig into 1" and malleable iron on larger box for excellent contisizes. nuity of ground. Locknut will not slip or spin. Body is virutally unbreakable. Straight connectors through 1" are screw machine steel; other sizes malleable iron. Threads at left are tapered to insure liquidtight seal in threaded hub. Liquidtight conduit cutaway view shows flexible steel core under plastic jacket. Wire mesh grip prevents pullout. Liquidtight conduit cutaway view shows flexible steel core under plastic jacket. Technical Data Optional Sealing Washer gives better liquidtight protection around knockout of sheet metal box. Neoprene gasket seals out liquids and steel retaining ring protects gasket from distortion. Order separately. T-104 www.hubbell-wiring.com Dimensions in Inches (mm) Technical Section Liquidtight Flexible Metal Conduit Grip Fitting Dimensions-Inches 45° Angle with Male Fitting E A/C A/F Dimensions M Throat Dia. C A Ref. Trade H Size B Ref. J H L N A/C A/F M N Throat Catalog Dia. A/C* A/F* Numbers 3/8” 1.19” 1.28” .59” 1.20” 1.06” .60” 1.16” 1.02” 074093441 1/2” 1.19” 1.28” .59” 1.34” 1.19” .61” 1.21” 1.06” 074093442 3/4” 1.19” 1.43” .59” 1.55” 1.45” .84” 1.50” 1.32” 074093443 1” 1.38” 1.53” .66” 1.95” 1.69” 1.05” 1.82” 1.59” 074093444 11/4” 1.42” 1.69” .63” 2.39” 2.06” 1.37” 2.32” 2.03” 074093445 11/2” 1.66” 2.00” .66” 2.72” 2.38” 1.60” 2.62” 2.29” 074093446 2” 3.21” 2.80” 074093448 1.69” 2.25” .66” 3.08” 2.88” 2.05” Dimensions Trade H Size P A/C A/F F L A/C* A/F* K 45° Angle with Male Fitting with Insulated Throat M Throat Dia. K J Ref. D E J Ref. L A/C* A/F* K M N Throat Catalog Dia. A/C* A/F* Numbers 3/8” 1.25” 1.28” .66” 1.20”1.06” .57” 1.16” 1.02” 074093561 1/2” 1.25” 1.28” .66” 1.34” 1.19” .57” 1.21” 1.06” 074093562 3/4” 1.25” 1.44” .66” 1.55” 1.45” .78” 1.50” 1.32” 074093563 1” 1.44” 1.53” .72” 1.95” 1.69” .98” 1.82” 1.59” 074093564 11/4” 1.48” 1.69” .69” 2.39” 2.06” 1.29” G O Throat Dia. 2.32” 2.03” 074093565 11/2” 1.72” 2.00” .72” 2.72” 2.38” 1.53” 2.62” 2.29” 074093566 2” 3.21” 2.80” 074093568 1.75” 2.25” .72” 3.08” 2.87” 1.95” 90° Angle with Male Fitting Straight with Male Fitting Dimensions D C E Throat A/C* A/F* Dia. A/C* A/F* Catalog Numbers Trade D Size E Dimensions O P G Throat Catalog A/C* A/F* Ref. Dia. A/C* A/F* Numbers F Trade A Size Ref. B 3/8” 1.43” .59” 1.20” 1.06” .61” 1.07” .93” 074093401 3/8” 1.31” .59” 1.20” 1.06” 1.44” .60” 1.13” .99” 1/2” 1.43” .59” 1.34” 1.19” .61” 1.22” 1.06” 074093402 1/2” 1.31” .59” 1.34” 1.12” 1.44” .61” 1.21” 1.00” 074093422 3/4” 1.56” .59” 1.55” 1.37” .84” 1.43” 1.25” 074093403 3/4” 1.44” .59” 1.55” 1.45” 1.63” .83” 1.48” 1.29” 074093423 1” 1.68” .66” 1.95” 1.69” 1.06” 1.73” 1.56” 074093404 1” 1.78” .66” 1.95” 1.60” 2.19” 1.05” 1.80” 1.57” 074093424 11/4” 2.03” .63” 2.39” 2.06” 1.37” 2.36” 2.08” 074093405 11/4” 1.97” .63” 2.39” 2.06” 2.50” 1.37” 2.32” 2.02” 074093425 11/2” 2.21” .63” 2.72” 2.38” 1.53” 2.79” 2.48” 074093406 11/2” 2.19” .66” 2.72” 2.38” 2.69” 1.61” 2.58” 2.25” 074093426 2” 2.28” .69” 3.08” 2.87” 2.06” 3.32” 2.90” 074093408 2” 3.14” 2.75” 074093428 Straight with Male Fitting with Insulated Throat Trade A Size Ref. C B A/C* Dimensions D E Throat A/F* Dia. A/C* A/F* 2.53” .66” 3.08” 2.87” 3.25” 2.05” 074093421 90° Angle with Male Fitting with Insulated Throat Dimensions Catalog Numbers 3/8” 1.50” .66” 1.20” 1.06” .57” 1.07” .93” 1/2” 1.50” .66” 1.34” 1.19” .57” 1.22” 1.06” 074093512 074093511 1.62” .66” 1.55” 1.38” .78” 1.43” 1.25” 074093513 1” 1.75” .72” 1.95” 1.69” .98” 1.73” 1.56” 074093514 11/4” 2.09” .69” 2.39” 2.06” 1.29” 2.36” 2.08” 074093515 11/2” 2.28” .69” 2.72” 2.37” 1.53” 2.79” 2.48” 074093516 2” 2.34” .75” 3.08” 2.87” 1.95” 3.32” Trade D Size E F G A/C* A/F* Ref. O P Throat Catalog Dia. A/C* A/F* Numbers 3/8” 1.38” .66” 1.20” 1.06” 1.44” .60” 1.13” .99” 1/2” 1.38” .66” 1.34” 1.12” 1.44” .57” 1.21” 1.00” 074093542 074093541 3/4” 1.50” .66” 1.55” 1.45” 1.63” .78” 1.48” 1.29” 074093543 1” 1.84” .66” 1.95” 1.60” 2.19” .98” 1.80” 1.57” 074093544 11/4” 2.03” .69” 2.39” 2.06” 2.50” 1.29” 2.32” 2.02” 074093545 2.90” 074093518 11/2” 2.25” .69” 2.72” 2.38” 2.69” 1.53” 2.58” 2.20” 074093546 3.14” 2.75” 074093548 21/2” 3.56” 1.06” 3.92” 3.62” 2.42” 3.85” 3.60” 074093520 2” 2.59” .72” 3.08” 2.87” 3.25” 1.95” 3” 3.81” 1.06” 4.70” 4.31” 3.01” 4.65” 4.33” 074093522 21/2” 3.44” 1.00” 3.92” 3.63” 4.25” 2.42” 3.78” 3.50” 074093550 4” 3.81” 1.06” 5.75” 5.31” 3.96” 5.75” 5.39” 074093526 3” 4.64” 4.30” 074093552 3.75” 1.00” 4.70” 4.31” 4.87” 3.01” Dimensions shown are approximate and are subject to change without notice. www.hubbell-wiring.com T-105 Technical Data 3/4” Dimensions in Inches (mm) Wire Management Products Kellems® Grips for Strain Relief Wire Management Products Kellems® Grips for Strain Relief Technical Section Conduit Grips for (UL Type A) Non-metallic, Flexible, Liquidtight Conduit Kellems Grips for UL Type A, non-metallic, flexible, liquidtight conduit are available in straight and 90° male and feature a high quality Hubbell plated steel or malleable iron fitting, complete with a sealing O-ring, lock nut and stainless steel mesh. These grips increase the retention of the conduit in the fitting, control its arc-of-bend and provide a liquidtight seal. Application These grips are used on UL Type A non-metallic conduit connections at limit switches, motor boxes, panel boards, control stations and on all types of machinery and machine tools. Benefits • Provides a liquidtight seal. • Helps prevent conduit pull-out. • Reduces conduit cutting, kinking, fraying and splitting at the fitting. • Easily installed. Body is virtually unbreakable. Straight connectors through 1" are screw machine steel; other sizes are malleable iron. Threads are tapered to insure liquidtight seal when used in threaded hub. Octagonal shape inside holds the ferrule to prevent conduit from twisting during installation. Steel Locknut has tangs that dig into box for excellent continuity of ground. Locknut will not slip or spin. Neoprene "O"-ring is factory assembled into the body to seal out liquids. Technical Data Insulated throat protects insulation on wires during pulling. Yellow color easily seen by inspectors. Yellow nylon ferrule fits inside nonmetallic conduit to hold the shape. Barb in designed to assure liquidtight seal even with non-square cut. Ferrule is keyed to fit into body to prevent conduit twisting. Wire mesh grip prevents pullout. Hexagonal compression nut is machine steel through 1" malleable iron on larger sizes. Tapered interior compresses sleeve over conduit sealing out liquids and preventing pullout. Yellow nylon sleeve installs over conduit. Six slits in sleeve permit tight compression onto conduit as compression nut is tightened. T-106 www.hubbell-wiring.com Dimensions in Inches (mm) Technical Section Dimensional Charts For (UL Type A) Non-metallic, Liquidtight, Conduit Grip Fittings Straight with Male Fitting with Insulated Throat Trade Size N.P.T. Inches 3/8” 1/2” 3/4” 1” 11/4” 11/2” 2” Dimensions Inches (cm) B C .547” (1.39) 1.156” (2.94) .547” (1.39) 1.250” (3.17) .578” (1.47) 1.500” (3.81) .687” (1.74) 1.844” (4.68) .656” (1.67) 2.312” (5.87) .656” (1.67) 2.578” (6.55) .656” (1.67) 3.187” (8.09) A 1.875” (4.76) 1.875” (4.76) 2.000” (5.08) 2.125” (5.40) 2.125” (5.40) 2.250” (5.71) 2.312” (5.87) D 3.75” (9.52) 4.50” (11.43) 6.25” (15.87) 7.50” (19.05) 9.00” (22.86) 13.50” (34.29) 14.50” (36.83) Catalog Numbers H038CNK H050CNK H075CNK H100CNK H125CNK H150CNK H200CNK Wire Management Products Kellems® Grips for Strain Relief C Flats B Ref. D A Ref. 90° Angle with Male Fitting with Insulated Throat Trade Size N.P.T. Inches 3/8” 1/2” 3/4” 1” 11/4” 11/2” 2” E 1.875” (4.76) 1.875” (4.76) 2.016” (5.12) 2.375” (6.03) 2.281” (5.79) 2.562” (6.51) 2.937” (7.46) Dimensions Inches (cm) F G .547” (1.39) 1.156” (2.94) .547” (1.39) 1.250” (3.17) .578” (1.47) 1.500” (3.81) .687” (1.74) 1.894” (4.81) .656” (1.67) 2.312” (5.87) .656” (1.67) 2.578” (6.55) .656” (1.67) 3.187” (8.09) H 1.453” (3.69) 1.453” (3.69) 1.000” (2.54) 2.125” (5.40) 2.344” (5.95) 2.500” (6.35) 2.781” (7.06) I 3.75” (9.52) 4.50” (11.43) 6.25” (15.87) 7.50” (19.05) 9.00” (22.86) 13.50” (34.29) 14.50” (36.83) Catalog Numbers H0389CNK H0509CNK H0759CNK H1009CNK H1259CNK H1509CNK H2009CNK G Flats E I F H Technical Data Dimensions shown are approximate and are subject to change without notice. Dimensions in Inches (mm) www.hubbell-wiring.com T-107 Wire Management Products Non-metallic Liquidtight Conduit Product Features and Benefits POLYTUFF® Liquidtight Conduit PolyTuff I Conduit–Gray Rigid PVC core bonded to flexible PVC jacket. All nonmetallic construction ends metal fatigue and separation problems. UL Listed and CSA Certified. Non-metallic Liquidtight Conduit Cuts cleanly with a knife or PVC cutter so there are no jagged metal edges. IP66 SUITABILITY PolyTuff I Conduit Trade Catalog Size (metric designator) Numbers Feet (m) 3/8” (12) G1038 100 (30.5) 1/2” (16) G1050 100 (30.5) 3/4” (21) G1075 100 (30.5) 1” (27) G1100 100 (30.5) 11/4” (35) G1125 100 (30.5) 11/2” (41) G1150 50 (15.2) 2” (53) G1200 50 (15.2) Note: See pages T-114 to T-115 for additional technical data and dimensional drawings. T-108 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Non-metallic Liquidtight Tubing Product Features and Benefits POLYTUFF® Liquidtight Conduit PolyTuff II Tubing–Black PVC core with corrugated walls bonded to PVC jacket. Handles twists, turns, bends, switchbacks and straightaways with ease. All nonmetallic construction ends fatigue and separation problems. Can be cut with a knife or PVC cutters. UL Recognized and CSA Certified. Non-metallic Liquidtight Tubing IP66 SUITABILITY PolyTuff II Tubing Trade Catalog Size (metric designator) Numbers Feet (m) 1/4 (10) B2025 100 (30.5) 3/8 (12) B2038 100 (30.5) 1/2 (16) B2050 100 (30.5) 3/4 (21) B2075 100 (30.5) 1 (27) B2100 100 (30.5) 11/4 (35) B2125 100 (30.5) 11/2 (41) B2150 50 (15.2) 2 (53) B2200 50 (15.2) Note: See pages T-114 to T-115 for additional technical data and dimensional drawings. Dimensions in Inches (mm) www.hubbell-wiring.com T-109 Wire Management Products Nonmetallic Liquidtight Connectors Product Features and Benefits POLYTUFF® Nonmetallic Connectors Nylon two-piece swivel body enables fitting to twist from 0° to 90°. Nonmetallic Liquidtight Fittings Non-integral ferrule provides conduit seal and superior pullout protection. Neoprene O-ring provides liquidtight seal at hub or enclosure. Nylon compression nut has a tapered dome to tighten ferrule onto conduit. T-110 Nylon locknut fastens connector securely to enclosure and provides superior corrosion resistance. www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Non-metallic Liquidtight Connectors Flexible Non-metallic Conduit and Tubing Fittings POLYTUFF® Non-metallic Fittings Type 4X, 12 and 13 Straight with Male Non-Metallic Liquidtight Fittings Trade Size (metric designator) 3/8” (12) 1/2” (16) 3/4” (21) 1” (27) 1/4” (10) 11/4 “(35) 11/2” (41) 2” (53) Black Catalog Numbers P038NBKA P050NBKA P075NBKA P100NBKA F2025 P125NBK P150NBK P200NBK Gray Catalog Numbers P038NGYA P050NGYA P075NGYA P100NGYA – P125NGY P150NGY P200NGY P075NGYA Note: See pages T-116 and T-117 for additional technical data and dimensional drawings. P125NGY SwivelLok® Multi-Position with Male Non-Metallic Liquidtight Fittings Trade Size (metric designator) 3/8” (12) 1/2” (16) 3/4” (21) 1” (27) Black Catalog Numbers PS0389NBK PS0509NBK PS0759NBK PS1009NBK Gray Catalog Numbers PS0389NGY PS0509NGY PS0759NGY PS1009NGY PSO509NGY - SwivelLok Note: See pages T-116 and T-117 for additional technical data and dimensional drawings. PSO509NGY - SwivelLok 90° Angle with Male Non-Metallic Liquidtight Fittings Black Catalog Numbers F20259 P1259NBK Gray Catalog Numbers – P1259NGY Note: See pages T-116 and T-117 for additional technical data and dimensional drawings. Non-metallic Liquidtight Fittings Trade Size (metric designator) 1/4” (10) 11/4” (35) P1259NGY SwivelLok Flexible Conduit Kit Trade Size (metric designator) Fitting and Conduit 1/2” (16) 2 PS0509NGY, 6’ G1050 3/4” (21) 2 PS0759NGY, 6’ G1075 Catalog Numbers PS05GYKIT PS07GYKIT PS05GYKIT Note: See pages T-116 and T-117 for additional technical data and dimensional drawings. Dimensions in Inches (mm) www.hubbell-wiring.com T-111 Wire Management Products Metallic Liquidtight Fittings Product Features and Benefits Flexible Metallic, Liquidtight Conduit Fittings Hexagonal, screw-machined steel thru 1", and malleable iron on larger sizes. Nut compresses gland-ring onto conduit. Split, nylon, gland-ring compresses conduit onto ferrule. Metallic Liquidtight Fittings Non-integral, reusable steel, ferrule is easily installed, to seal conduit. Threaded one-piece steel body. Tapered, machined threads fasten securely and provide additional liquidtight sealing. Optional insulated and non-insulated throat. Optional Neoprene O-ring provides liquidtight seal at hub. Locknut has hardened steel tangs to grip securely. T-112 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Metallic Liquidtight Fittings Flexible Metallic Conduit Fittings Straight Conduit Fitting Trade Size (metric designator) Insulated 3/8” (12) H0381 1/2” (16) H0501 3/4” (21) H0751 1” (27) H1001 11/4” (35) H1251 11/2” (41) H1501 2” (53) H2001 21/2” (63) H2501 3” (78) H3001 Note: See page T-118 for additional technical data. Non-Insulated H038 H050 H075 H100 H125 H150 H200 – – Straight with Male Hubbell Conduit Fitting H0501 45° Conduit Fitting Trade Size (metric designator) Insulated 3/8” (12) H03841 1/2” (16) H05041 3/4” (21) H07541 1” (27) H10041 11/4” (35) H12541 11/2” (41) H15041 2” (53) H20041 Note: See page T-118 for additional technical data. Non-Insulated H0384 H0504 H0754 H1004 H1254 H1504 H2004 45˚ Angle with Male Hubbell Conduit Fitting H05041 90° Conduit Fitting Dimensions in Inches (mm) Non-Insulated H0389 H0509 H0759 H1009 H1259 H1509 H2009 Metallic Liquidtight Fittings Trade Size (metric designator) Insulated 3/8” (12) H03891 1/2” (16) H05091 3/4” (21) H07591 1” (27) H10091 11/4” (35) H12591 11/2” (41) H15091 2” (53) H20091 Note: See page T-118 for additional technical data. 90˚ Angle with Male Hubbell Conduit Fitting H0509 www.hubbell-wiring.com T-113 Wire Management Products Non-metallic Liquidtight Conduit and Tubing Technical Data POLYTUFF® PolyTuff I Conduit Operating Temperature Range Wet environment Oil environment Dry environment 0°F to +140°F (-18°C to +60°C) 0°F to +158°F (-18°C to +70°C) 0°F to +176°F (-18°C to +80°C) Certifications UL Listed, CSA Certified UL Standard 1660. Sunlight resistant approved for outdoor use, direct burial. Meets requirements of NEC Article 351-B Voltage Rating Maximum 600V Material Conduit Co-extruded rigid and flexible PVC. PolyTuff II Tubing Operating Temperature Range Operating Environment 0°F to +140°F (-18°C to +60°C) Certifications UL Recognized CSA Certified Voltage Rating Maximum Same as wire insulation rating. Material Tubing Co-extruded rigid and flexible PVC. Technical Data PolyTuff I Conduit Trade Size (metric designator) 3/8” (12) 1/2” (16) 3/4” (21) 1” (27) 11/4” (35) 11/2” (41) 2” (53) T-114 Conduit ID/OD Inches (mm) .49”/.70” (12.6/17.8) .63”/.83” (16.1/21.1) .83”/1.04” (21.1/26.4) 1.05”/1.30” (26.0/33.1) 1.40”/1.65” (35.4/41.8) 1.59”/1.88” (40.3/47.8) 2.03”/2.36” (51.6/59.9) PolyTuff II Tubing Bend Radius Inches (mm) 2.00” (50.8) 3.00” (76.2) 4.00” (101.6) 5.00” (217.0) 6.30” (158.8) 7.50” (190.5) 10.00” (254.0) Trade Size (metric designator) 1/4”(10) 3/8” (12) 1/2” (16) 3/4” (21) 1” (27) 11/4” (35) 11/2” (41) 2” (53) www.hubbell-wiring.com Conduit ID/OD Inches (mm) .36”/.57” (9.3/14.5) .49”/.70” (12.6/17.8) .63”/.83” (16.1/21.1) .83”/1.04” (21.1/26.4) 1.05”/1.30” (26.0/33.1) 1.40”/1.65” (35.4/41.8) 1.59”/1.88” (40.3/47.8) 2.03”/2.36” (51.6/59.9) Bend Radius Inches (mm) 1.50” (38.1) 2.00” (50.8) 2.00” (50.8) 3.00” (76.2) 3.00” (76.2) 5.00” (127.0) 5.00” (127.0) 5.00” (127.0) Dimensions in Inches (mm) Technical Data POLYTUFF® PolyTuff I and II Conduit/Tubing; PVC Chemical Resistance Chemical Temp. Conc* 70°F 150°F 21°C 66°C Acetate Solvents Acetic Acid Acetic Acid (Glacial) Acetone Acrylontrile Alcohols (Aliphatic) Aluminum Chloride Aluminum Sulfate (Alums) Ammonia (Anhydrous Liquids) Ammonia (Aqueous) Ammoniated Latex Ammonium Chloride Ammonium Hydroxide Amyl Acetate Aniline Oils Aromatic Hydrocarbons Asphalt ASTM Fuel A ASTM Fuel B ASTM #1 Oil ASTM #3 Oil Barium Chloride Barium Sulfide Barium Hydroxide Benzene (Benzol) Benzine (Petroleum Ether) Black Liquor Bordeaux Mixture Boric Acid Butyl Acetate Butyl Alcohol Calcium Hydroxide Calcium Hypochlorite Carbolic Acid (Phenol) Carbon Dioxide Carbon Disulfide Carbon Tetrachloride Carbonic Acid Casein Caustic Soda Chlorine Gas (wet) Chlorine Gas (dry) Chlorine (water solution) Chlorobenzene Chlorinated Hydrocarbons Chromic Acid Citric Acid Coal Tar D B C D A C A A D C D D B C A A D A A A A D D D D C D B C A A A D C A A A D B A A B A D D A A A D D C D D B A D D A C A A D D D D C D C D A A A D C A A A D C A A C A D D A C B D D D D D C A D Chemical Temp. Conc* 70°F 150°F 21°C 66°C Coconut Oil C Corn Oil A Cottonseed Oil C Creosote D Cresol C Crysylic Acid D Cyclohexane B DDT Weed Killer A Dibutyl Phthalate D Diesel Oils C Diethylene Glycol B Diethyl Ether A Di-isodecyl Phthalate D Dioctyl Phthalate D Dow General Weed Killer (Phenol) D Dow General Weed Killer (H2O) B Ethyl Alcohol C Ethylene Dichloride D Ethylene Glycol B Ferric Chloride A Ferric Sulfate A Ferrous Chloride A Ferrous Sulfate A Formaldehyde D Fuel Oil B Furfural C Gallic Acid A Gasoline (Hi Test) C Glycerine A Grease A Green Sulfate Liquor A Heptachlor in Petroleum Solvents A Heptane C Hexane C Hydrobromic Acid A Hydrochloric Acid 10% A Hydrochloric Acid 40% C Hydrofluoric Acid 70% D Hydrofluorosilicic Acid A Hydrofluorosilicic Acid 10% A Hydrogen Peroxide A Iso-Octane C Isopropyl Acetate D Isopropyl Acid B Jet Fuels (JP-3, and 5) C Kerosene C Ketones D Linseed Oil A D B D D D D C C D D C C D D D C C D C A A A A D C C A D A C A C D D A A C D A A B C D C D C D A (All ratings apply to concentrated or saturated solutions unless otherwise specified.) Chemical resistance ratings are based upon information supplied by the raw material manufacturers. Use as a general guide only – samples should be tested by user under actual conditions. Chemical Temp. Conc* 70°F 150°F 21°C 66°C Lubricating Oils Magnesium Chloride Magnesium Hydroxide Magnesium Sulfate Malathion 50 in Aromatics Malic Acid Methyl Acetate Methyl Alcohol Methyl Bromide Methyl Ethyl Ketone Methylene Chloride Mineral Oil Monochlorobenezene Muriatic Acid (see Hydrochloric Acid) Naphtha Naphthalene Nitric Acid 10% Nitric Acid 35% Nitric Acid 70% Oleic Acid Oleum Oxalic Acid Pentachlorophenol in Oil Pentane Perchloroethylene Petroleum Ether Phenol Phosphoric Acid 10% Pitch 50% Potassium Hydroxide Sodium Cyanide Stoddard Solvent Styrene Sulfur Dioxide (liquid) Sulfuric Acid 50% Sulfuric Acid 98% Sulfurous Acid Tall Oil Tannic Acid Toluene Trichlorethylene Triethanol Amine Tricresyl Phosphate (Skydrol) Turpentine Vinegar Vinyl Chloride Water White Liquor Xylene Zinc Chloride Zinc Sulfate A A A A D A D C D D D A A A A D A D C D D D A A C D A A D A D A B C B C A A A C A D D D A D B D A D D C D C A D A A D A A D D B C D C D A C D C C A A B D A D D D B D C D A D D D D D B D A A D A A Wire Management Products Non-metallic Liquidtight Conduit and Tubing *Conc. - Concentration B-Good service life. Moderate to minor effect. Good for intermittent service. Generally suitable for continuous service. Dimensions in Inches (mm) C-Fair or limited service. Depends on operating conditions. Generally suitable for intermittent service. Not recommended for continuous service. D-Unsatisfactory service. Not recommended. www.hubbell-wiring.com T-115 Technical Data Rating Code A-Excellent service No harmful effect to reduce service life. Suitable for continuous service. Wire Management Products Non-metallic Liquidtight Fittings Technical Data POLYTUFF® Fittings PolyTuff Fittings Operating Temperature* Nylon (Body, Nut, Gripping Ring and Locknut) Neoprene (Sealing Ring) –40°F to +225°F (–40°C to +107°C). –30°F to +240°F (–34°C to +116°C). Flammability Fire Gas Toxicity Product Testing Nylon PolyTuff Fittings have a UL 94V-2 rating. Certifications UL Listed CSA Certified UL50 Type 4X, 12 and 13 PolyTuff I Fittings, Poly Tuff II Fittings. Liquidtight Fittings Operating Temperature** Steel/Malleable Iron (Nut, Body, Ferrule) Nylon (Gland Ring) –60°F to +1000°F (–51°C to +538°C). –40°F to +225°F (–40°C to +107°C). Hazardous Locations Class I, Div. 2 Class II, Div. 1 Class II, Div. 2 Class III, Div. 1 Class III, Div. 2 NEC Reference 501-4b 502-4a2 502-4b2 503-3a2 503-3b Certifications UL Listed CSA Certified *Due to the limiting factors of nylon and neoprene, PolyTuff Fittings will continuously perform in the range –30°F to +225°F (–34°C to +107°C). Technical Data **Due to the limiting factors of nylon, metallic liquidtight flexible conduit fittings will continuously perform in the range of –40°F to +225°F (–40°C to +107°C). T-116 www.hubbell-wiring.com Dimensions in Inches (mm) Wire Management Products Non-metallic Liquidtight Fittings Technical Data POLYTUFF® Fittings Straight with Male Non-Metallic Liquidtight Fittings Trade A B C Size (md**) 1/4” .93” 1.45” .39” (10) (23.6) (36.8) (9.9) 3/8” 1.14” 1.63” .57” (12) (29.0) (41.4) (14.5) 1/2” 1.30” 2.14” .57” (16) (33.0) (54.4) (14.5) 3/4” 1.53” 2.22” .58” (21) (38.9) (56.4) (14.7) 1” 1.80” 2.32” .72” (27) (45.7) (58.9) (18.3) 11/4” 2.20” 2.15” .74” (35) (55.9) (54.6) (18.8) 11/2” 2.49” 2.35” .76” (41) (63.2) (59.7) (19.3) 2” 3.05” 2.51” .79” (53) (77.4) (63.6) (20.1) *A/C = Across Corners A/F = Across Flats D Throat Dia. E E A/C* .32” (8.1) A/F* .86” (Dia.) (21.8) .42” (10.7) 1.41” (35.8) 1.30” (33.0) .55” (14.0) 1.41” (35.8) 1.30” (33.0) .74” 1.85” (18.8) (47.0) .96” 1.94” (24.4) (49.3) 1.30” 2.38” (33.0) (60.5) 1.46” 2.63” (37.1) (66.8) 1.90” 3.13” (48.3) (79.5) **md = metric designator 1.53” (38.9) 1.80” (45.7) 2.18” (55.4) 2.43” (61.7) 2.93” (74.4) A Dia. C B Sizes: 1/4", 11/4", 11/2", 2" E A D C B Sizes: 3/8", 1/2", 3/4", 1" 90° with Male Non-Metallic Liquidtight Fittings Trade A B C Size (md**) 1/4” .93” 1.88” .39” (10) (23.6) (47.8) (9.9) 11/4” 2.21” 3.57” .74” (35) (56.1) (90.7) (18.9) *A/C = Across Corners A/F = Across Flats D B D E Throat Dia. A/C* A/F* .32” .86”(Dia.) (8.1) (21.8) 1.30” 2.38” 2.18” (33.0) (60.5) (55.4) **md = metric designator E A Dia. C SwivelLok® Multi-Position Liquidtight Fittings D Trade Size (md**) A B C D E F A/C* A/F* 3/8” 1.30” (33.0) 3.27” (83.1) .57” (14.5) .55” (14.0) 1.43” (36.3) 2.00” (50.8) 1.41” (35.8) 1.30” (33.0) 1.43” (36.3) 2.00” (50.8) 1.41” (35.8) 1.30” (33.0) 1.59” 2.23” 1.65” (40.4) (56.6) (41.9) 1.84” 2.30” 1.94” (46.7) (58.4) (49.3) **md = metric designator 1.53” (38.9) 1.80” (45.7) (12) 1/2” 1.30” 3.27” .57” .55” (16) (33.0) (83.1) (14.5) (14.0) 3/4” 1.53” 3.66” .58” .74” (21) (38.9) (93.0) (15.7) (18.8) 4.00” .72” .96” 1” 1.80” (27) (45.7) (101.6) (18.3) (24.4) *A/C = Across Corners A/F = Across Flats G Technical Data A F G D B E 90° Position Dimensions in Inches (mm) C 45° Position www.hubbell-wiring.com Straight Position T-117 Wire Management Products Metallic Liquidtight Conduit Fittings Technical Data Straight with Male Metallic Metal Fitting E D Throat Dia. C B Ref. A Trade Size (md**) 3/8” (12) 1/2” (16) 3/4” (21) 1” (27) 11/4” (35) 11/2” (41) 2” (53) 21/2” (63) 3” (78) 31/2” (91) 4” (103) A Ref. 1.43” (36.3) 1.43” (36.3) 1.56” (39.6) 1.68” (42.7) 2.03” (51.6) 2.21” (56.1) 2.28” (57.9) 3.56” (90.4) 3.81” (96.8) 3.81” (96.8) 3.81” (96.8) B C A/C* 1.20” (30.0) 1.34” (34.0) 1.55” (39.0) 1.95” (50.0) 2.39” (61.0) 2.72” (69.0) 3.08” (78.0) 3.92” (100.0) 4.70” (119.0) 5.29” (134.0) 5.75” (146.0) .59” (15.0) .59” (15.0) .59” (15.0) .66” (16.8) .63” (16.8) .63” (16.8) .69” (17.5) 1.06” (26.9) 1.06” (26.9) 1.06” (26.9) 1.06” (26.9) D Throat Dia. .61” (15.5) .61” (15.5) .84” (21.3) 1.06” (26.9) 1.37” (34.8) 1.53” (38.9) 2.06” (52.3) 2.42” (61.5) 3.01” (76.5) 3.49” (88.6) 3.96” (100.6) A/F* 1.06” (26.9) 1.19” (30.2) 1.37” (34.8) 1.69” (42.9) 2.06” (52.3) 2.38” (60.5) 2.87” (72.9) 3.62” (91.9) 4.31” (109.5) 4.81” (122.2) 5.31” (134.9) E A/C* 1.07” (27.2) 1.22” (31.0) 1.43” (36.3) 1.73” (43.9) 2.36” (59.9) 2.79” (70.9) 3.32” (84.3) 3.85” (97.8) 4.65” (118.1) 5.18” (131.6) 5.75” (146.1) A/F* .93” (23.6) 1.06” (26.9) 1.25” (31.8) 1.56” (39.6) 2.08” (52.8) 2.48” (63.0) 2.90” (73.7) 3.60” (91.4) 4.33” (110.0) 4.82” (122.4) 5.39” (136.9) 45° with Male Metallic Metal Fitting B A D F C E Throat Dia. Trade Size (md**) 3/8” (12) 1/2” (16) 3/4” (21) 1” (27) 11/4” (35) 11/2” (41) 2” (53) A B C 1.19” (30.2) 1.19” (30.2) 1.19” (30.2) 1.38” (35.1) 1.42” (36.1) 1.66” (42.2) 1.69” (42.9) 1.28” (32.5) 1.28” (32.5) 1.43” (36.3) 1.53” (38.9) 1.69” (42.9) 2.00” (50.8) 2.25” (57.2) .59” (15.0) .59” (15.0) .59” (15.0) .66” (16.8) .63” (16.0) .66” (16.8) .66” (16.8) D A/C* 1.20” (30.5) 1.34” (34.0) 1.55” (39.4) 1.95” (49.5) 2.39” (60.7) 2.72” (69.1) 3.08” (78.2) A/F* 1.06” (26.9) 1.19” (30.2) 1.45” (36.8) 1.69” (42.9) 2.06” (52.3) 2.38” (60.5) 2.88” (73.2) E Throat Dia. .60” (15.2) .61” (15.2) .84” (21.3) 1.05” (26.7) 1.37” (34.8) 1.60” (40.6) 2.05” (52.1) F A/C* 1.16” (29.5) 1.21” (30.7) 1.50” (38.1) 1.82” (46.2) 2.32” (58.9) 2.62” (66.5) 3.21” (81.5) E Throat Dia. .60” (15.2) .61” (15.5) .83” (21.1) 1.05” (26.7) 1.36” (34.5) 1.61” (40.9) 2.05” (52.1) 2.42” (61.5) 3.01” (76.5) 3.96” (100.6) A/C* 1.13” (29.0) 1.12” (28.0) 1.48” (38.0) 1.80” (46.0) 2.32” (59.0) 2.58” (66.0) 3.14” (80.0) 3.78” (96.0) 4.64” (118.0) 5.76” (146.0) A/F* 1.02” (25.9) 1.06” (26.9) 1.32” (33.5) 1.59” (40.4) 2.03” (5.16) 2.29” (58.2) 2.80” (71.1) 90° with Male Metallic Metal Fitting F C D B A Technical Data E Throat Dia. Trade Size (md**) 3/8” (12) 1/2” (16) 3/4” (21) 1” (27) 11/4” (35) 11/2” (41) 2” (53) 21/2” (63) 3” (78) 4” (103) A 1.31” (33.3) 1.31” (33.3) 1.44” (36.6) 1.78” (45.2) 1.97” (50.0) 2.19” (55.6) 2.53” (64.3) 3.44” (87.4) 3.75” (95.3) 4.25” (108.0) B .59” (15.0) .59” (15.0) .59” (15.0) .59” (15.0) .63” (16.0) .63” (16.0) .66” (16.8) 1.00” (25.4) 1.00” (25.4) 1.00” (25.4) C A/C* 1.20” (30.5) 1.34” (34.0) 1.55” (39.4) 1.95” (49.5) 2.39” (60.7) 2.72” (69.1) 3.08” (78.2) 3.92” (99.6) 4.70” (119.4) 5.75” (146.1) D A/F* 1.06” (26.9) 1.12” (28.4) 1.45” (36.8) 1.60” (40.6) 2.06” (52.3) 2.38” (60.5) 2.87” (72.9) 3.63” (92.2) 4.31” (109.5) 5.31” (134.9) *A/C = Across Corners A/F = Across Flats T-118 www.hubbell-wiring.com Ref. 1.44” (36.6) 1.44” (36.6) 1.63” (41.4) 2.19” (55.6) 2.50” (63.5) 2.69” (68.3) 3.25” (82.6) 4.25” (108.0) 4.87” (123.7) 5.63” (143.0) F A/F* .99” (25.1) 1.00” (25.4) 1.29” (32.8) 1.57” (39.9) 2.02” (51.3) 2.25” (57.2) 2.75” (69.9) 3.50” (88.9) 4.30” (109.2) 5.38” (136.7) **md = metric designator Dimensions in Inches (mm)
07401010 价格&库存
很抱歉,暂时无法提供与“07401010”相匹配的价格&库存,您可以联系我们找货
  • 1+1200.064701+155.95147
  • 5+823.377235+106.99997
库存:8
