HBL2310ST
HBL2310ST
    HUBBELL(哈伯尔公司)
    HUBBELL WIRING DEVICES - HBL2310ST - CONNECTOR, NEMA L5-20R, 20A, BLACK
HBL2310ST 数据手册
20A, 125V, 2 Pole, 3 Wire Grounding Spring Termination Single Flush Receptacle Features Faster termination time No need for screwdriver and torque wrench Spring Termination eliminates strand relaxation High-impact, abuse-resistant nylon face Face color coding by voltage facilitates locating and mating of proper devices Ordering Information Description Nylon face, back wire. Device Color Black UPC Catalog Number 783585569543 HBL2310ST Listings Listed to UL 498 Certified to CSA C22.2 No.42 Specifications Face Base Contacts Spring Mounting Strap Nylon Nylon Brass Steel Brass Performance Electrical Current Interrupting Certified for current interrupting at full rated current Complementary Products Dielectric Voltage Withstands 2,000V minimum Plug Wallplate or Weatherproof Cover Switched Enclosure Mechanical Terminal Accommodation Terminal Identification Environmental Flammability Moisture Resistance Operating Temperatures #10 AWG Solid,#14 #10AWG AWGtoto#12 #8 AWG Stranded, Solid/Stranded #8 AWG Compact Terminals identified in accordance with UL 498 V2 or better per UL94/CSA 22.2 No.0.17 IP20 Suitability Maximum Continuous 75°C; Minimum -40°C (w/o impact) Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. Online Resources Customer Use Drawing eCatalog Installation Instructions HBL2311 1.60" Opening SETL3
HBL2310ST 价格&库存
很抱歉,暂时无法提供与“HBL2310ST”相匹配的价格&库存,您可以联系我们找货
