HBL2430SR
HBL2430SR
    HUBBELL(哈伯尔公司)
HBL2430SR 数据手册
Twist-Lock® Devices Twist-Lock® Devices 20 Ampere, 125/250 Volts 3Ø 250 and 3Ø 480 Volts AC 3 Pole, 4 Wire Grounding Insulgrip® Connector Bodies and Receptacles X G Connector Bodies X W X G Y Z 20A 125/250V NEMA L14-20R UL/CSA 2 (1) HP 20A 3Ø 250V AC NEMA L15-20R UL/CSA 3 HP 20A 3Ø 480V AC NEMA L16-20R UL/CSA 5 HP IP66 Description Black Valox® housing, white Valox® clamps. Catalog Numbers HBL2413SW HBL2423SW Insulgrip IP20 Description Black and white nylon. Cord Dia. .35"-1.15" (9-29) .35"-1.15" (9-29 .35"-1.15" (9-29) Corrosion resistant, yellow nylon. All black nylon. Y Z Watertight Safety-Shroud® Cord Dia. .35"-1.15" (9-29) G Y 2.75" (69.9) SUITABILITY HBL2433SW 4.38" (111.1) HBL2423SW SUITABILITY Catalog Numbers HBL2413 HBL2423 HBL2433 HBL24CM13 HBL24CM33 HBL24CM23 3.86" (98.0) 2.33" (59.2 ) HBL2413BK – 2.21" (56.1) – Accessories on page B-53. HBL2413 Receptacles 2.91" (73.9) Watertight Safety-Shroud, Back Wired IP66 SUITABILITY Catalog Numbers HBL2410SW HBL2420SW Safety-Shroud Twist-Lock, Back Wired Description Gray Valox® angle housing, one gang. Gray Valox® surface mounting, one gang. Gray Valox® semi-flush, two gang. IP20 HBL2430SW 3.75" (95.3) SUITABILITY Catalog Numbers HBL2410AR HBL2420AR HBL2410SR HBL2420SR HBL2410SR2 HBL2420SR2 HBL2430AR HBL2430SR HBL2430SR2 3.75" (95.3) 1.75" (44.5) HBL2420SW Accessories on page B-54. Single Flush, Back and Side Wired Description Black nylon face. Isolated ground, orange nylon face. Ring teminal connection. Accessories on page B-52. IP20 3.14" (79.8) SUITABILITY Catalog Numbers HBL2410 HBL2420 IG2410 IG2420 HBL2410RT HBL2420RT HBL2430 – – Catalog Numbers HBL2416 HBL2426 HBL2436 4.57" (116.1) Insulgrip Flanged Receptacles Description Nylon casing, back wired. Accessories on page B-52. 2.85" (72.4) HBL2420AR 3.06" (77.7) 1.70" (43.2) 120° 1.23" (31.2) 1.71" (43.4) .77" (19.6) 1.34" R (34.0) .19" (4.8) 120° DIA. 2.67" (67.8) 1.56" 2.38" 3.28" (39.6) (60.5) (83.3) 5.12" (130.0) 4.56" (115.8) 2.27" (57.7) 2.23" (56.6) HBL2416 .98" (24.9) #6-32 TAP HBL2410 5.12" (130.0) 2.84" (72.1) HBL2420SR2 HBL2420SR Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. Dimensions in Inches (mm) www.hubbell-wiring.com B-21 20 Ampere, 125/250 Volts 3Ø 250 and 3Ø 480 Volts AC Description Gray Valox® housing and flange. Accessories on page B-54.
HBL2430SR 价格&库存
很抱歉,暂时无法提供与“HBL2430SR”相匹配的价格&库存,您可以联系我们找货
