HBL2431ST
HBL2431ST
    HUBBELL(哈伯尔公司)
    HUBBELL WIRING DEVICES - HBL2431ST - POWER ENTRY CONN, NEMA L16-20P, 20A/480V
HBL2431ST 数据手册
® Twist-Lock Devices 20A 3-Phase 480V AC, 3-Pole 4-Wire ® Spring Terminated InsulGrip Plug Features Faster termination time No need for screwdriver and torque wrench Spring Termination eliminates strand relaxation Funnel shaped wire entry for ease of termination. Superior cord grip design protects terminations from excess strain Ordering Information Description Black and white nylon. Cord Diameter UPC Number 350"-1.150" (9-29) 7 78358568154 Catalog Number HBL2431ST Listings Listed to UL 498 Fed.Spec. W-C-596 Certified to CSA C22.2 No.42 Specifications Housing / Cord Clamp Terminal Retainer Plunger Blades Terminal Spring Clamp Assemby Screws Weight (lbs) Nylon Nylon Nylon Copper Alloy Spring Steel Zinc Plated Tri-drive 0.25 Performance Electrical Current Interrupting Dielectric Voltage Certified for current interrupting at full rated current Withstands 3,000V minimum Mechanical Terminal Accommodation #14 AWG - #8 AWG stranded copper wire only Terminal Identification Terminals identified in accordance with UL 498 Environmental Flammability Moisture Resistance Operating Temperatures HB or better per UL94/CSA 22.2 No.0.17 IP20 Suitability Maximum Continuous 75°C, Minimum -40°C (w/o impact) Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. Online Resources eCatalog
HBL2431ST 价格&库存
很抱歉,暂时无法提供与“HBL2431ST”相匹配的价格&库存,您可以联系我们找货
