HBL2510
HBL2510
    HUBBELL(哈伯尔公司)
HBL2510 数据手册
Product Datasheet HBL2510 -- Twist-Lock Receptacle 4P5W, 20A 3PH 120/208V AC, L21-20R, Black Nylon Face Product Specifications Product Type Product Item Single Receptacle Wiring Scheme 4-Pole, 5-Wire Grounding Amperage 20A Voltage 3 Phase Y 120/208V AC NEMA Configuration L21-20R Item Style Standard Device Color Black Horsepower 2 Terminal Clamp Material .040" (1.0 ) Brass Terminal Screw Material #10-32 Bronze (White finish on neutral screw when used) Ground Screw Material #10-32 Bronze (Green) Contact Spring Material .040" Brass Mounting Screw Material Steel-zinc-plated Cover (Top) Material Black Nylon Base Material Nylon Polyester Ground Contact Material .040" Brass Bridge (Mounting Strap) Material .050" Brass Back Plate Material .040" Brass Rivet Material Brass Auto Ground Clip Material Stainless Steel Ratings Molded In or Stamped On Catalog No Permanently ink marked on product Dielectric Voltage Withstand 2,000V minimum Current Interrupting Certified for current interrupting at full rated current Temperature Rise Max 30C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of .75. Terminal Accommodation #14 to #8 AWG Copper Only Terminal Identification Terminals identified in accordance with UL 498 (X, Y, Z, White, Green) Flammability UL 94 VO for Receptacles and Inlets. HB or better for Plugs and Connectors. Operating Temperatures Maximum Continuous 75 C Minimum -40 C (w/o impact) Listings FED SPEC UL/CSA UPC Number 783585235851 Weight in LBs 0.3 Link to Drawing Library Click here for Library Link to PDF Catalog Click here for Catalog NEMA Configuration
HBL2510 价格&库存
很抱歉,暂时无法提供与“HBL2510”相匹配的价格&库存,您可以联系我们找货
