HBL4586C
HBL4586C
    HUBBELL(哈伯尔公司)
HBL4586C 数据手册
Twist-Lock® Devices Twist-Lock® Devices 15 Ampere, 125, 250 Volts and 277 Volts AC 2 Pole, 3 Wire Grounding Insulgrip® Plugs and Flanged Inlets W G IP20 1.91" (48.5) SUITABILITY HBL4720C 1.22" (30.9) 2.11" (53.6) 1.53" (38.9) HBL4720CA 2.63" (66.8) 1.56" (39.6) Description Insulgrip plug, black and white nylon. Multiple drive screws. Fed Spec WC596 All black nylon. Insulgrip angle plug, 8 position angle, black and white nylon. Multiple drive screws. Insulgrip plug, corrosion resistant, yellow and white nylon. Multiple drive screws. Fed Spec WC596 Elastogrip® plug, yellow elastomer, dust tight. Elastogrip plug, yellow elastomer, water/dust tight. Valise® plug, yellow nylon. Valise® plug, black nylon. HBL24W47 G G Y 15A 250V NEMA L6-15P UL/CSA 1.5 HP 15A 277V AC NEMA L7-15P UL/CSA 2 HP Cord Dia. .230"-.720" (5.8-18.3) Catalog Numbers HBL4720C™ HBL4570C HBL4770C .230"-.720" (5.8-18.3) .325"-.655" (8.3-16.6) HBL4720CBK HBL4720CA HBL4570CA HBL4770CA .230"-.720" (5.8-18.3) HBL47CM20C HBL45CM70C HBL47CM70C 300"-.655" (7.6-16.6) 300"-.655" (7.6-16.6) HBL2447 – – HBL24W47 – – .220"-.660" (5.6-16.8) HBL4723VY HBL4573VY HBL4773VY .220"-.660" (5.6-16.8) HBL4723VBK HBL4573VBK HBL4773VBK Plugs 1.53" (38.9) W X 15A 125V NEMA L5-15P UL/CSA 0.5 HP – – Accessories on page B-49. 1.88" (47.8) Flanged Inlets 15 Ampere, 125, 250 Volts and 277 Volts AC 1.50" (38.1) Description Insulgrip flanged inlet, nylon casing, back wired. Stainless steel casing, brown phenolic. Corrosion resistant, stainless steel casing, yellow melamine. HBL4723VY 2.56" (52.3) 2.19" (55.6) .16" (4.1) DIA. Catalog Numbers HBL4716C HBL4586C HBL4786C HBL4716* HBL4586* HBL4786* – – HBL47CM16* Accessories on page B-48. 1.72" (43.7) 1.69" (42.9) Notes: HP ratings are AC only. Only plugs are HP rated. For technical information on Insulgrip devices see page B-69. *These flanged inlets will not accept Valise® connector bodies. HBL4716C 2.31" (58.7) 1.94" (49.3) 1.75" (44.5) .16" (4.1) DIA. 1.09" (27.7) 1.50" (38.1) HBL4716 B-10 www.hubbell-wiring.com Dimensions in Inches (mm)
HBL4586C 价格&库存
很抱歉,暂时无法提供与“HBL4586C”相匹配的价格&库存,您可以联系我们找货
