HBL5865VY
HBL5865VY
    HUBBELL(哈伯尔公司)
HBL5865VY 数据手册
Straight Blade Devices 15A, 125V, 2 Pole, 2 Wire Non-Grounding Valise® Plug Features Hinged one piece body design for easy assembly Two captive multiple drive assembly screws Powerful cord grips prevent conductor slippage and strain Non-polarized blades Ordering Information Description Yellow nylon, non-polarized Cord Diameter UPC .218"-.385"(5.5-9.8 783585013060 ) Catalog Number HBL5865VY Listings UL Listed to UL498 File E1706 CSA Certified to C22.2 No. 42 File 280C NEMA® WD-6 Compliant Specifications Housing Blades Assembly Screws Cable Inserts Terminal Screws Terminal Clamp Assembly Screws Nylon Brass Plated Steel PPO Brass Nickel plated steel Plated steel Performance Electrical Current Interrupting Dielectric Voltage Certified for current interrupting at full rated current Withstands 2,000V minimum Mechanical Product Identification Molded Rating on Device Face Terminal Accommodation #18-#14 AWG stranded copper wire only Terminal Identification Terminals identified in accordance with UL 498 and CSA Environmental Flammability IP Suitability Operating Temperatures UL 94 HB IP20 Maximum continuous 75°C; minimum -40°C (w/o impact) Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. Resources Customer Use Drawing eCatalog
HBL5865VY 价格&库存
很抱歉,暂时无法提供与“HBL5865VY”相匹配的价格&库存,您可以联系我们找货
