HBL7465V
HBL7465V
    HUBBELL(哈伯尔公司)
    HBL7465V
HBL7465V 数据手册
Midget Twist-Lock® Devices 15A, 125V, 2 Pole, 2 Wire Non-Grounding Valise® Plug Features Fully insulated, abuse resistant nylon housing Insulation displacement terminals reduce wiring time Insulation displacement terminal Powerful, cord-gripping jaws Totally insulated body adds extra measure of safety Ordering Information Description Black Valise® plug. Cord Diameter .220"-.385" (5.6-9.8) UPC 783585237282 Catalog Number HBL7465V Listings Listed to UL 498 Certified to CSA C22.2 No.42 Fed Spec W-C-596 Specifications Housing Blades Terminal Screws Terminal Clamps Body Holding Screws Nylon Brass #6 - 32 Steel (Philips / Slotted / Robertson) Steel - Nickel plated Steel - Zinc plated Accessories Performance Electrical Current Interrupting Dielectric Voltage Valise® Connector Flanged Receptacle Weatherproof Boot Certified for current interrupting at full rated current Withstands 2,000V minimum Resources Mechanical Terminal Accomodation Terminal Identification #18 AWG - #14 AWG stranded copper wire only. Terminals identified in accordance with UL 498 Environmental Flammability Moisture Resistance Operating Temperatures HB or better per UL94/CSA 22.2 No.0.17 IP20 Suitability Maximum Continuous 75°C Minimum -40°C (w/o impact) Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. Customer Use Drawing eCatalog HBL7464V HBL7468 HBL7490V
HBL7465V 价格&库存
很抱歉,暂时无法提供与“HBL7465V”相匹配的价格&库存,您可以联系我们找货
