HXJ5EBK
HXJ5EBK
    HUBBELL(哈伯尔公司)
HXJ5EBK 数据手册
JACKS, CATEGORY 5E HUBBELL PREMISE WIRING Category 5e Jacks Category 5e Component Termination Towers • Easy pair splitting • Simple lacing • Fast punch-down DTE Power Compliant Keystone Design Universal Wiring Quicklace™ Combination Two distinct labels eliminates wiring confusion, T568B or T568A Exclusive 1-Punch Termination Tool FEATURES Q Q Q Q Q Q Q Q Q Q Q Q Q Center balanced to Category 5e plug specifications Positive PSACR beyond 190 MHz (channel) Exceeds component requirements by a minimum of 3dB 3+Gbs of Bandwidth (channel) Exceeds IEEE 802.3af DTE Power Specification to 4X the standard Exceeds IEEE 802.3ab Gigabit Specification to < 1 * 10-13 Backwards compatible to Category 5 and 3 IDC pair splitting tower allows for minimum disruption to cable twist Exclusive 1-Punch termination tool reduces termination time by 75% Compatible with standard 110 termination tools Standard HPW keystone mounting HPW Icon compatible 13 different colors SPECIFICATIONS Mechanical X Construction Materials: - Housing: High impact thermoplastic (UL 94 V-0) - Stuffer cap: Lexan (UL 94 V-0) - Dust cover: Polypropylene X Nose Contacts - Material: Beryllium copper with a minimum of 50 micro-inch gold plating over nickel under plating - 2,000+ mating cycles with FCC compliant 8-position plug - Confirmed contact performance over full range of (FCC Spec) deflection limits - Min. contact force 100 grams with FCC compliant 8-position plug - Accepts FCC compliant 6-position plugs X IDC 110 Contacts - Material: Phosphor bronze with 100 micro-inch tin lead 60/40 plating over nickel under plating - 20+ IDC terminations for same size AWG - Accommodates 22 to 26 AWG/Solid Stuffer Cap • Secure strain relief • Positive “snap” latching Xcelerator™ Category 5e modular jacks (XJ5e) deliver industry unmatched component performance. The XJ5e is the first modular jack to undergo extreme DTE Power testing to 4x the standard handling continuous DTE Power, exceeding the IEEE 802.3af standard without failure or any substantial increase in temperature. The XJ5e supports network convergence protocols by delivering maximum bandwidth and extended reliability for all LAN, multimedia and PoE (Power over Ethernet) applications such as VoIP and IP-Video. The QuickLace™ termination process combined with the exclusive 1-Punch tool delivers the fastest termination in the structured cabling industry. The innovative combination reduces termination time by 75% and provides a consistent termination every time. The XJ5e easily installs into all HPW Infin-e-Station™ products, including rear-loading plates and front-loading modules and frames. Xcelerator jacks can be used in multimedia configurations with our SF (Snap Fit) connectors customizing all workstations, consolidation points and telecommunication closets. APPLICATIONS STANDARDS/LISTINGS/VERIFICATIONS O O O O O O O O O O ANSI/TIA/EIA-568-B.2 Category 5e component specifications IEEE 802.3af DTE Power and MDI verified IEEE 802.3ab Gigabit Ethernet verified ETL Verified for Category 5e component ETL Total Solutions UL Listed 1863 CSA Certified FCC part 68.5, subpart F compliant IEC-60603-7-2 compliant ISO 11801 2nd Edition Class D compliant IEEE 802.3: • 1000BASE-T Gigabit Ethernet • 100BASE-T • 10BASE-T V Analog Video V Digital video V Company intranets V 155Mbps ATM V On-line document publishing V DTE Power Applications V Real-time video to the desktop V VoIP V www.hubbell-premise.com JACKS, CATEGORY 5E HUBBELL PREMISE WIRING 1-PUNCH INSTRUCTIONS ORDERING INFORMATION Xcelerator™ Category 5e Jacks Unit Package Order Qty. Color Black Blue Electric Ivory Gold Gray Green Office White Orange Purple Red Telco Ivory White Yellow 1 per Bag Carton of 25 Catalog No. HXJ5EBK HXJ5EB HXJ5EEI HXJ5EGY HXJ5EGN HXJ5EOW HXJ5EOR - HXJ5ER HXJ5ETI HXJ5EW HXJ5EY The “1-Punch” Tool and Xcelerator™ Jacks are made for each other. Designed to punch-down all 4-pairs consistently and cut off all conductors in “1-Punch”. This tool saves valuable installation time over traditional single-blade tools that require multiple cycles. 25 per Bag Bag of 25 Catalog No. HXJ5EBK25 HXJ5EB25 HXJ5EEI25 HXJ5EGL25 HXJ5EGY25 HXJ5EGN25 HXJ5EOW25 HXJ5EOR25 HXJ5EP25 HXJ5ER25 HXJ5ETI25 HXJ5EW25 HXJ5EY25 This tool should be used exclusively with Xcelerator™ jacks and with the Hubbell Premise Wiring “Jack Knuckles” termination aid. Five easy steps get the job done: ACCESSORIES 1 Icon System Identify the work area or the cross connect with Hubbell's new icon system. The new icons are offered in packs of 100 blank or with a computer or telephone molded in. Customize each blank icon with our preprinted icon booklet. Each booklet has 11 pages with numerous labels ranging from A to G, FAX to Data, providing a multitude of options, which adheres to ANSI/TIA/EIA-606-A. Color Black Blue Brown Electric Ivory Gray Green Orange Purple Red White Yellow Blank IBK100 IB100 IBN100 IEI100 IGY100 IGN100 IOR100 IP100 IR100 IW100 IY100 Computer IBK100C IB100C IBN100C IEI100C IGY100C IGN100C IOR100C IP100C IR100C IW100C IY100C Telephone IBK100T IB100T IBN100T IEI100T IGY100T IGN100T IOR100T IP100T IR100T IW100T IY100T DIMENSIONS 2 4 Lace the jack and place in a Hubbell termination aid. Always use this tool with a termination aid. Align the head of the punch down tool over the target jack with the slots of the tool head ready to slide onto the shoulder of the jack nose. With one hand hold the termination aid. With the other, depress the handle completely down until the tool cycles impact. Place the punch down head onto the Hubbell Xcelerator jack. 3 Remove the tool head from the jack and inspect the jack and install stuffer cap onto termination towers. 5 ORDER INFORMATION - 1-PUNCH TOOL Delivery 1 Impact handle 1 Punch-down head for Xcelerator™ jacks 1 “Jack Knuckles” termination aid Description Catalog No. 1-Punch Tool with head, blades and termination aid ACCESSORIES TX4P Replacement 4-pair XJ head TX4PH TX4PHBL HXTA HXTP25 HXJDC25 Replacement 4-pair XJ blades Jack Knuckles termination aid Snap-X termination puck (25-pack) Xcelerator Hinged Dust Cover (25-pack) Hubbell Premise Wiring HUBBELL INCORPORATED (Delaware) 14 Lord’s Hill Road • Stonington, CT 06378-0901 • (860) 535-8326 • 800-626-0005 Fax: (860) 535-8328 • Internet site: http://www.hubbell-premise.com DS-C25 08/03 Worldwide Locations Hubbell Hubbell Hubbell Hubbell Hubbell Hubbell Premise Wiring, Asia Pacific Canada Inc. Premise Wiring, China Premise Wiring, Europe Int’l. Inc., Korea Branch Premise Wiring, Latin America 852-2836-7131 905-839-1138 86-21-63090119 44-(0)1234-848550 82-2-(0)2607-1363 305-251-4236 Fax: Fax: Fax: Fax: Fax: Fax: 852-2836-7132 905-839-9108 86-21-63090122 44-(0)1234-856190 82-2-(0)2603-7386 305-251-4087 Hubbell de Mexico, S.A. de C.V. Hubbell Premise Wiring, Middle East Hubbell Premise Wiring, Puerto Rico Hubbell-Taian Co., Ltd., Taiwan Hubbell Incorporated, Turkey Hubbell Premise Wiring, Venezuela 52-5-559-5304 971-4-393-4192 787-720-7185 886-2-(0)2515-0855 90-216-414-8147 58-16-6807453 Fax: Fax: Fax: Fax: Fax: Fax: 52-5-559-5885 971-4-393-4194 787-789-2796 886-2-(0)2515-0899 90-216-414-8148 58-281-2820323
HXJ5EBK
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817有6个引脚,分别为1脚阳极,2脚阴极,3脚输出,4脚集电极,5脚发射极,6脚地。
4. 参数特性:工作温度范围为-55℃至125℃,隔离电压为5000Vrms。
5. 功能详解:EL817通过光电效应实现信号传输,具有高速响应和低功耗特点。
6. 应用信息:广泛应用于通信、工业控制、医疗设备等领域。
7. 封装信息:采用DIP6封装,尺寸为9.1mm x 3.6mm。
HXJ5EBK 价格&库存
很抱歉,暂时无法提供与“HXJ5EBK”相匹配的价格&库存,您可以联系我们找货
