HBL2311S
HBL2311S
    HUBBELL(哈伯尔公司)
HBL2311S 数据手册
Twist-Lock® Devices 20A, 125V AC, 2 Pole, 3 Wire Grounding Safety-Shroud® Plug Features Impact resistant shroud protects blades against bending and breaking. Ribbed nylon housing provides a secure grip and impact and chemical resistance. Superior cord grip design protects terminations from excess strain. Integral dust shield protects wiring chamber from dust or contaminants. Ordering Information Description Black and white nylon body, white PBT shroud. Cord Diameter .360"-.930" (9-24) UPC 783585234069 Catalog Number HBL2311S Listings Listed to UL 498 Fed.Spec. W-C-596 Certified to CSA C22.2 No.42 Specifications Safety-Shroud® Housing / Cord Clamp Terminal Retainer Blades Terminal Screws Terminal Clamp Assembly Screws White PBT Nylon Clear polycarbonate Brass #10-32 Brass (Phillips / Slotted / Robertson) Cold rolled steel – nickel plated Steel - nickel plated Performance Electrical Current Interrupting Dielectric Voltage Certified for current interrupting at full rated current Withstands 2,000V minimum Mechanical Terminal Accommodation #16 AWG - #8 AWG stranded copper wire only. Terminal Identification Terminals identified in accordance with UL 498 Environmental Flammability Moisture Resistance Operating Temperatures HB or better per UL94 or CSA 22.2 No. 0.6 IP20 Suitability Maximum Continuous 75°C Minimum -40°C (w/o impact) Accessories Connector Receptacle - Angle Housing Receptacle - Surface Mount Receptacle - Semi Flush Resources Customer Use Drawing eCatalog Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. HBL2313 HBL2310AR HBL2310SR HBL2310SR2
HBL2311S 价格&库存
很抱歉,暂时无法提供与“HBL2311S”相匹配的价格&库存,您可以联系我们找货
