HBL2311VBK
HBL2311VBK
    HUBBELL(哈伯尔公司)
HBL2311VBK 数据手册
Twist-Lock® Devices 20 Ampere, 125, 250 Volts and 277 Volts AC 2 Pole, 3 Wire Grounding W X G G Y 20A 125V NEMA L5-20P UL/CSA 1 HP Plugs Watertight Safety-Shroud® 2.78" (70.6) 4.50" (114.3) IP66 SUITABILITY 2.26" (57.4) 2.04" (51.8) 20A 277V AC NEMA L7-20P UL/CSA 2 HP UL Type 4x, 12 Description Cord Dia. Catalog Number Black Valox® housing, white Valox® clamps. .360"-.930" (9-24) HBL2311SW Description Cord Dia. Catalog Number Black and white nylon body, white Valox® shroud. Can be used with the Insulgrip Connector Bodies. .360"-.930" (9-24) HBL2311S Description Cord Dia. Catalog Number Black and white nylon. .360"-.930" (9-24) HBL2311 HBL2321 Corrosion resistant, yellow nylon. .360"-.930" (9-24) HBL23CM11 HBL23CM21 – All black nylon. .360"-.930" (9-24) HBL2311BK HBL2321BK – Cord clamps with removable inserts. All black nylon. .360"-.930" (9-24) HBL2311EBK HBL2321EBK – Description Cord Dia. Catalog Number Yellow nylon. .325"-.720" (8.26-18.3) HBL2311VY Corrosion resistant, yellow nylon. .325"-.720" (8.26-18.3) HBL23CM11V Black nylon. .325"-.720" (8.26-18.3) HBL2311VBK HBL2321SW Safety-Shroud® HBL2321SW IP20 HBL2331SW SUITABILITY HBL2321S HBL2331S Note: See page B-40 for accessories. Insulgrip® 3.97" (100.8) HBL2321S 2.75" (69.9) 2.26" (57.4) 1.97" (50.0) IP20 Valise® 2.50" (63.5) 1.78" (45.2) HBL2311VY HBL2331 IP20 SUITABILITY HBL2321VY HBL2331VY – – HBL2321VBK HBL2331VBK Note: See page B-51 for accessories. 2.28" (57.9) Flanged Inlets Watertight Safety-Shroud® 3.75" (95.3) Description Valox® 1.63" (41.4) IP66 SUITABILITY Gray housing and flange, reverse service (Not shown). HBL2315SW HBL2325SW – HBL2325SWR HBL2325SW 2.88" (73.2) .19" (4.8) DIA. 120° 120° HBL2335SW – Note: See page B-54 for accessories. Insulgrip® 3.75" (95.3) UL Type 4x, 12 Catalog Number Gray Valox® housing and flange. 1.25" R. (31.8) SUITABILITY Note: See page B-51 for accessories. HBL2311 IP20 Description Catalog Number Nylon casing, back wired. HBL2315 SUITABILITY HBL2325 HBL2335 Note: See page B-50 for accessories. See pages B-69 and B-70 for technical information on Twist-Lock and Watertight Safety-Shroud devices. See page B-74 for technical information on Valise® plugs and connectors. 2.09" (53.1) HBLMITL - For use with Watertight Safety-Shroud receptacles, see page B-39. 2.04" (51.8) HBL2315 Dimensions in Inches (mm) B-18 20A 250V NEMA L6-20P UL/CSA 2 HP Valox® is a trademark of SABIC Innovative Plastics, acquired from General Electric Company. ® Wiring Device-Kellems www.hubbell-wiring.com
HBL2311VBK 价格&库存
很抱歉,暂时无法提供与“HBL2311VBK”相匹配的价格&库存,您可以联系我们找货
