Product Datasheet
HBL2326 -- Twist-Lock Flanged Receptacle
2P3W, 20A 250V, L6-20R, White Nylon
Product Specifications
Product Type
Product Item
Flanged Receptacle
Wiring Scheme
2-Pole, 3-Wire Grounding
Amperage
20A
Voltage
250V AC
NEMA Configuration
L6-20R
Item Style
Standard
Device Color
White
Horsepower
2
Terminal Retainer Material
Clear polycarbonate
Terminal Clamp Material
.08" (2) steel-nickel plated
Terminal Screw Material
#10-32 Brass (white finish on neutral screw when used) Multi-drive
Ground Screw Material
#10-32 Brass (green finish) Multi-drive
Body Holding Screw
Material
Steel, zinc plated Multi-drive
Body Contact Carrier
Material
Natural White Nylon
Contact Spring Material
Brass
Spring Binding Plate
Material
Brass
Flanged Casing Material
Natural White Nylon
Mounting Screw Material
Nickel-plated Brass Round head screws
Ground Contact Material
.031" (.8) Brass
Ratings
Molded In or Stamped On
Catalog No
Permanently ink marked on product
Dielectric Voltage Withstand 2,000V minimum
Current Interrupting
Certified for current interrupting at full rated current
Temperature Rise
Max 30C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power
factor of .75.
Terminal Accommodation
20A #12 AWG
Terminal Identification
Terminals identified in accordance with UL 498 (X, Y, Z, White, Green)
Flammability
HB or better per UL 94 or CSA 22.2 No. 0.6
Operating Temperatures
Maximum Continuous 75 C Minimum -40 C (w/o impact)
Listings
FED SPEC UL/CSA
UPC Number
783585037875
Weight in LBs
0.25
Link to Drawing Library
Click here for Library
Link to PDF Catalog
Click here for Catalog
NEMA Configuration
很抱歉,暂时无法提供与“HBL2326”相匹配的价格&库存,您可以联系我们找货
