HBL2341
HBL2341
    HUBBELL(哈伯尔公司)
HBL2341 数据手册
Product Datasheet HBL2341 -- Twist-Lock Plug 2P3W, 20A 480V AC, L8-20P, Black & White Nylon Product Specifications Product Type Product Item Plug Wiring Scheme 2-Pole, 3-Wire Grounding Amperage 20A Voltage 480V AC NEMA Configuration L8-20P Item Style Insulgrip Device Color Black/White Horsepower 3 Cord Dia. .360"-.930" (9-24) Blade Holder Material Natural White Nylon Terminal Retainer Material Clear polycarbonate Housing Material Black nylon Cord Clamp Material Natural (white) nylon Blade Material Brass Terminal Clamp Material .08" (2) steel-nickel plated Terminal Screw Material #10-32 Brass (white finish on neutral screw when used) Multi-drive Ground Screw Material #10-32 Brass (green finish) Multi-drive Cord Clamp Screw Material Steel, zinc plated Multi-drive Body Holding Screw Material Steel, zinc plated Multi-drive Ratings Molded In or Stamped On Catalog No Permanently ink marked on product Dielectric Voltage Withstand 2,000V minimum Current Interrupting Certified for current interrupting at full rated current Temperature Rise Max 30C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of .75. Cord Accommodation Round portable service cords of diameters commensurate with the device rating as defined in UL Standard 62, CSA C22.2 No. 49. Terminal Accommodation 20A #12 AWG Terminal Identification Terminals identified in accordance with UL 498 (X, Y, Z, White, Green) Flammability HB or better per UL 94 or CSA 22.2 No. 0.6 Operating Temperatures Maximum Continuous 75 C Minimum -40 C (w/o impact) Moisture Resistance IP20 Listings FED SPEC UL/CSA UPC Number 783585037950 Weight in LBs 0.3 Link to Drawing Library Click here for Library Link to PDF Catalog Click here for Catalog NEMA Configuration
HBL2341
- 物料型号:HBL2341 - 器件简介:这是一款Twist-Lock类型的设备,具有2极3线接地配置,适用于20A 480V AC的电气连接。 - 引脚分配:2-Polk, 3-Wre Grounding - 参数特性: - 额定电流:20A - 额定电压:480V AC - NEMA配置:L8-20P - 绝缘电压耐受:至少2000V - 电流温度上升:根据UL标准62,与设备额定值相符 - 功能详解:该设备设计用于承受高电流和电压,具有多种材料制成的部件,包括天然白色Nylon、透明聚碳酸酯等,以确保性能和安全性。 - 应用信息:适用于需要高电流和电压的工业和商业环境。 - 封装信息:包括部件材料、颜色、尺寸等详细信息,以及UL和CSA的认证信息。
HBL2341 价格&库存
很抱歉,暂时无法提供与“HBL2341”相匹配的价格&库存,您可以联系我们找货
