Hubbellock® Devices
60A, 600V AC, 4 Pole, 5 Wire Grounding
Hubbellock® Flanged Inlet
Features
Molded-in male contacts are resistant to damage and provide a
consistently positive connection
Color coded metallic housing enhances safety and abuse
resistance
Box terminals in conjunction with stainless steel terminal screws
provide maximum termination strength and dependability
Ordering Information
Description
Black phenolic interior
with steel housing and
flange
Device Color
Yellow
UPC
783585017624
Catalog Number
HBL26522
Listings
Listed to UL Standard
Certified to CSA Standard
Specifications
Flanged Housing
Inlet Interior
Contacts
Terminal
Terminal Screws
Zinc plated steel
Phenolic
Brass
Copper
Stainless Steel
Performance
Electrical
Current Interrupting
Dielectric Voltage
Certified for current interrupting at full rated current
2,000V minimum
Mechanical
Terminal Accomodation
Terminal Identification
#8 AWG - #4 AWG solid or stranded copper wire only.
Terminals identified in accordance with UL 498
Environmental
Flammability
Moisture Resistance
Operating Temperatures
UL 94 V0
IP30 Suitability
Maximum Continuous 75°C Minimum -40°C (w/o impact)
Dimensions in Inches (mm)
Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484
Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice.
Accessories
Connector
Resources
Customer Use Drawing
eCatalog
HBL26516
很抱歉,暂时无法提供与“HBL26516”相匹配的价格&库存,您可以联系我们找货
