HBL5266CA
HBL5266CA
    HUBBELL(哈伯尔公司)
HBL5266CA 数据手册
Straight Blade Devices Straight Blade Devices INSULGRIP® 15 & 20 Ampere Plugs and Connectors Featuring Integral VARI-SIZE™ Cord Grip Individually molded face for each blade configuration keeps debris out of plug interior. Roomy wiring chamber provides ample space for wiring. Individual wiring terminals completely enclosed in their own separate chambers. Powerful, offsetting cord grips clamp on individual conductors and outer cord jacket to prevent strain on terminals. Ribbed nylon housing is impact and chemical resistant. Features and Benefits Beveled housing prevents snagging when dragged across uneven surfaces. Integral VARI-SIZE insert adjusts to a wide range of cord sizes: .230”-.720” (5.8-18.3). Multiple drive screws provide screwdriver versatility. Pocketed recess for cord grip screws deter slippage of the screwdriver. VARI-SIZE pointer set to “smaller than gauge” position. Cord diameter range is .230”-.360” (5.8-9.0). Accepts slotted and Phillips head drivers. Transparent angled wiring entrance holes permit “straight in” conductor insertion. Catalog number is visible on the device while in use for easy identification. A-14 www.hubbell-wiring.com Powerful offsetting cord grips clamp on individual conductors and outer cord jacket to prevent strain on terminations. Dimensions in Inches (mm) 2 Pole, 3 Wire Grounding 15 and 20 Ampere, 125 Volts INSULGRIP® Heavy Duty Plugs F S IP20 SUITABILITY G G W W Fed.Spec. NEMA 5-15P 15A 125V UL CSA 0.5 HP Insulgrip Plugs Description Black and white nylon. Cord Dia. .230”-.720” (5.8-18.3) Corrosion resistant yellow nylon. .230”-.720” (5.8-18.3) 8-position angle plug, black .325”-.655” and white nylon. (8.3-16.6) 8-position angle plug, .325”-.655” transparent enclosure. (8.3-16.6) Anchor lock, black and .230”-.720” white nylon.(1) (5.8-18.3) Anchor lock, corrosion resistant .230”-.720” yellow nylon.(1) (5.8-18.3) Finger grip, black neoprene, .312”-.468” combination screws. CSA only. (7.9-11.9) Fusible, black vinyl housing, .296”-.625” slotted screws. CSA only. (7.5-15.9) NEMA 5-20P 20A 125V UL CSA 1 HP Catalog Numbers HBL5266C™ HBL5366C™ HBL52CM66C HBL53CM66C HBL5266CA HBL5366CA HBL5266CAT 1.97" (50.0) 1.53" (38.9) Straight Blade Devices Straight Blade Devices HBL5266C 1.22" (30.9) – 2.11" (53.6) HBL5280C – HBL52CM80C – HBL5921 – HBL5299 – 1.53" (38.9) HBL5266CA 1.97" (50.0) Insulgrip Hospital Grade Plugs Description Black and white nylon. Transparent housing. 1.53" (38.9) Catalog Numbers HBL8215C™ HBL8315C HBL8215CT HBL8315CT HBL8215CAT HBL8315CAT HBL5280C 1.97" (50.0) Accessories Seal-Tite® triple seal, black elastomer cover for Insulgrip® plugs when used in a cord set, and connector bodies when used with flanged inlets. Same as above except yellow. PLUGOUT® Lockout device for Hubbell plugs and others. HBL6017* 1.53" (38.9) HBL60CM17* HLD Notes: See page A-39 for accessories. See page A-42 for technical information. (1)UL component listed only. Not for general use applications. *IP55 when installed and used properly with mating components. HBL8215C 1.53 " (38.9) 2.11" (53.6) 1.22" (30.9) HBL8215CAT Dimensions in Inches (mm) www.hubbell-wiring.com A-15 2P 3W, 15A & 20A, 125V INSULGRIP® Plugs 8-position angle plug, transparent housing. Cord Dia. .230”-.720” (5.8-18.3) .230”-.720” (5.8-18.3) .250”-.655” (6.4-16.6)
HBL5266CA 价格&库存
很抱歉,暂时无法提供与“HBL5266CA”相匹配的价格&库存,您可以联系我们找货
