HBL5284
HBL5284
    HUBBELL(哈伯尔公司)
HBL5284 数据手册
Product Datasheet HBL5284 -- Straight Blade Products, Panel Mount Receptacle 2-Pole 3-Wire Grounding, 15A 125V, 5-15R, Panel mount on 1.94" (49.3) Centers, Brown Product Specifications Product Type Receptacle Style Single Face Shape Traditional Standard NEMA Amperage 15A Voltage 125V Poles and Wires 2 Pole, 3-Wire Grounding Hospital Grade ? No Panel Mounting Dimension Panel Mount 1.94" ctrs. Receptacle Grade Heavy Duty Spec Grade Face Style Finder Groove Color NEMA No. 5-15R Horsepower 0.5 Type 2 Pole, 3 Wire, Grounding Rating 15A, 125V Certification UL Listed File E2186, Guide Fed. Spec. WC 596F, Listed to UL Standard 498. Certified to CSA 22.2, No. 42 where applicable. Terminal Screw Material #8-32 Brass /Ni plated for neutral Ground Screw Material #8-32 Brass, Multiple Drive (Green) Top Material Nylon Base Material Reinforced PET Power Contacts Material .040" (1.0) Brass Mounting Strap Material .050" (1.3) Brass Mounting Screw Material Steel-Zinc Plated Dielectric Voltage Withstands 2,000V minimum. Current Interrupting Certified for current interrupting at full rated current. Temperature Rise Max 30°C temperature rise at full rated current after 50 cycles of overload at 150% of rated current at a power factor of 75%.. Terminal Identification Terminals identified in accordance with UL498 (Brass, White, Green). Terminal Accommodation #14-#10 AWG copper stranded or solid conductor only. Product Identification Ratings are a permanent part of the device. Flammability UL 94 V2. Operating Temperatures Maximum continuous 75°C, minimum -40°C (w/o impact). UPC Number 783585014227 Weight in LBs 0.200 Link to Drawing Library Click here for Library Link to PDF Catalog Click here for Catalog NEMA Configuration
HBL5284
- 物料型号: HBL5284 - 器件简介: 这是一个2极3线接地的面板安装插座,额定电流为15A,额定电压为125V,符合NEMA标准。 - 引脚分配: 未在文档中明确列出,但通常2极3线配置包括两个电源端子和一个接地端子。 - 参数特性: - 额定电流:15A - 额定电压:125V - 面板安装尺寸:1.94英寸中心距 - 插座等级:重型规格等级 - 材料:面板材料为尼龙,基座材料为增强PET,电源接触材料为0.040英寸厚的黄铜 - 功能详解: 该插座设计用于承受15A的电流和125V的电压,具有接地功能,以确保电气安全。 - 应用信息: 适用于需要高电流和电压的工业和商业应用。 - 封装信息: 产品符合UL标准,具有2000V的耐电压性能,并且具有过载保护功能。
HBL5284 价格&库存
很抱歉,暂时无法提供与“HBL5284”相匹配的价格&库存,您可以联系我们找货
