HBL5362
HBL5362
    HUBBELL(哈伯尔公司)
HBL5362 数据手册
Straight Blade Devices 20A, 125V, 2 Pole, 3 Wire Grounding HBL® Extra Heavy Duty Specification Grade Duplex Receptacle Features Back wired ground terminal allows faster, easier installation One-piece brass integral ground strap Finder Groove Face Deep body design with circuit ID face Ordering Information Description Device Color UPC Catalog Number Deep body design with Brown 783585435220 HBL5362 Listings UL Listed to UL498 File No. E2186 Certified to CSA 22.2, No. 42 File 285 Fed. Spec. W-C-596 NEMA® WD-6 Compliant Specifications Face Base By-Pass Power Contacts Ground Contacts Clamping Plate Terminal Screws Mounting Strap Automatic Self-grounding Clip Mounting Screws Nylon PBT .036 in. (.9) Brass .031 in. (.8) Brass Nickel plated brass Plated brass .050 in. (1.3) Brass Stainless steel Zinc plated steel Performance Electrical Current Interrupting Dielectric Voltage Certified for current interrupting at full rated current Withstands 2,000V minimum Mechanical Product Identification Ratings are a permanent part of the device Terminal Accommodation #14-#10 AWG copper stranded or solid conductor only Terminal Identification Terminals identified in accordance with UL 498 and CSA Environmental Flammability Operating Temperatures Online Resources Customer Use Drawing eCatalog Installation Instructions Top: UL 94V-2, Base: UL 94V-0 Maximum continuous 75°C; minimum -40°C (w/o impact) Accessories Wallplate or Weatherproof Cover Dimensions in Inches (mm) Hubbell Wiring Device-Kellems • Hubbell Incorporated (Delaware) • 40 Waterview Drive • Shelton, CT 06484 Phone (800) 288-6000 • Fax (800) 255-1031 • Specifications subject to change without notice. Duplex Openin
HBL5362 价格&库存
很抱歉,暂时无法提供与“HBL5362”相匹配的价格&库存,您可以联系我们找货
