Straight Blade Devices
15 and 20 Ampere, 125 Volts
2 Pole, 3 Wire Grounding
Insulgrip® Flanged Inlets and Receptacles
G
2.56"
(65.0)
2.19"
(55.6)
Flanged Inlets
.16" (4.1)
Dia.
1.72"
(43.7)
1.72"
(43.7)
HBL5278C
2.25"
(57.2)
.39"(9.9)
Dia.
2.88"
(73.2)
1.88"
(47.8)
2.66"
(67.6)
G
W
.19" (4.8) Dia.
4 Holes
W
15A 125V
NEMA 5-15P
UL CSA
20A 125V
NEMA 5-20P
UL CSA
Description
Catalog Numbers
Nylon casing, back wired.
HBL5278C
Weatherproof, gray, with lift cover and multiple
drive screws.
HBL61CM64
Weatherproof, black, with lift cover and boot,
multiple drive screws.
HBL61CM64BK
Stainless steel flange, phenolic body,
miniature style, for molded on connectors only,
HBL5240*
HBL5378C
Notes: *Specially designed to accept “molded-on" connector bodies. Catalog number HBL5240
will not accept re-wireable size connector bodies listed in this catalog or molded
connectors having a “rejection obstruction" as required by Underwriters Laboratories Inc.
standard #817 cord sets and power supply cords" effective 7/1/81.
See page A-45 for accessories.
1.56"
(39.6)
HBL61CM64
G
G
W
W
2.56"
(65.0)
15A 125V
NEMA 5-15R
UL CSA
0.5 HP
2.19"
(55.6)
Flanged Receptacles
.16" (4.1)
Dia.
1.72"
(43.7)
1.72"
(43.7)
HBL5279C
1.47"
(37.3)
2.06"
(52.3)
Description
Catalog Numbers
HBL5279C
covered terminals, multiple drive screws.
HBL5279
Stainless steel flange, brown phenolic
(mounting screws packed separately).
HBL5256
Weatherproof, gray nylon, with lift cover and boot,
.20" Dia.
(5.1)
20A 125V
NEMA 5-20R
UL CSA
1 HP
HBL5379C
HBL61CM65*
Notes: *Not CSA Certified.
1.09"
(27.7)
HBL5256
2.25"
(57.2)
.39"(9.9)
Dia.
2.88"
(73.2)
1.88"
(47.8)
.19" (4.8) Dia.
4 Holes
2.66"
(67.6)
1.56"
(39.6)
HBL61CM65
A-28
www.hubbell-wiring.com
Dimensions in Inches (mm)
很抱歉,暂时无法提供与“HBL5379C”相匹配的价格&库存,您可以联系我们找货
