HBL5965VY
HBL5965VY
    HUBBELL(哈伯尔公司)
HBL5965VY 数据手册
Valise Plugs and Connector Bodies ® A Configuration for Every OEM and Contractor Need ISO 9002 CERTIFIED World Wide Web URL: http://www.hubbell-wiring.com Valise Plugs and Connector Bodies Have it all with the Valise line of plugs and connector bodies Virtually all commercial equipment applications from Hubbell, Inc. With Valise devices, OEMs and contractors will get the speed, ease and economy they want while being able to offer their customers and end-users excellence in performance, durability and reliability. Unique Design Valise devices offer superior Medical areas where space is at a premium cord gripping, strain relief and abuse-resistance. The unique Valise design was developed by Hubbell to speed wiring and simplify assembly of plugs and connector bodies. Full Line Hubbell now offers a full line Large to small office equipment of Valise devices – meaning there’s an exact configuration, rating, size, feature, color and accessory combination that’s ideal for your application. And every Valise device is UL and CSA listed, and meets NEC dead-front requirements. Superior Performance Ideal for theatrical applications The way these devices are designed makes wiring and assembly a breeze; the way they’re built assures superior performance and durability, even in demanding applications. Valise plugs and connector bodies from Hubbell: an open and shut case for speed, ease and performance every time. Specifications meet I.E.C. applications for electronics With Valise Plugs and Connector Bodies, Speed and Economy Go Hand-in-Hand With Superior Performance Straight Blade Valise Plugs and Connector Bodies Hubbell Valise plugs go together in seconds but stay together securely for reliable long-term operation. Eight loadbearing, locking lugs in the impact- and crush-resistant nylon body assure a positive grip. Devices feature patented “wire bundling” terminals that are easy to wire and provide positive, reliable terminations. See pages 3 and 4 Valise Twist-Lock® Plugs and Connector Bodies Get all the outstanding features of Hubbell’s Valise line plus the security of locking configurations. Valise Twist-Lock devices assure a secure connection for uninterrupted power together with the same fast wiring and positive cord gripping found in every Valise device. The line includes 15, 20, and 30 amp devices in 3-wire NEMA configurations. See pages 5 and 6 Insulation Displacement Valise Plugs and Connector Bodies Save time, save labor: Hubbell’s straight blade Valise insulation displacement plug is provided in an open position that’s ready for wiring. Cord preparation is simplified because only the outer jacket needs to be cut back – there’s no need to strip insulation from the individual conductors. See page 7 Midget Valise Twist-Lock® Plugs and Connector Bodies Small in size, but big in features: that’s Midget Twist-Lock Valise. Unique two-screw design allows Midget Twist-Lock Valise plugs to go together in seconds. Insulation displacement feature means terminations are made automatically when the device is closed. Screw terminals are also available for these compact 15 amp devices. See page 8 IEC Valise Connector Bodies and Panel Mount Inlets Hubbell’s IEC Valise connector bodies are ideal for any electrical equipment sold in domestic and export markets. Built to IEC 320 specifications, these connector bodies are built of high-impact thermoplastic and feature binding screw terminals with a “wire bundling” feature for reliable electrical connections. See page 9 Accessories and Technical Information See page 10 and back cover 2 Straight Blade Valise Plugs and Connector Bodies Totally insulated impact- and crush-resistant nylon body. Nylon hinges make wiring quick and easy by joining three sections during assembly. 8 load-bearing lugs assure positive fit as the blade holder and sides are closed. Combination Phillips/slotted head screws provide screwdriver versatility. Unique, patented clamp-type terminals provide superior electrical connection by “bundling” conductor strands when clamps are tightened. Powerful cord grips prevent slippage and strain on wiring terminals. Removable cord inserts accommodate cords from .220" to .660" (5.6mm to 16.8mm). 3 * Robertson/slotted drive screws available on certain configurations and are indicated with “CN” suffixes in the catalog. Hubbell straight blade Valise plugs and connector bodies are ideal for OEMs because their superior performance will help your own products perform better. Valise devices are designed to be easy to wire and quick to assemble. Yet, they provide superior cord gripping, impact- and crushresistance, and a totally insulated body for added safety. Plugs Description Connector Bodies NEMA Config. Rating Catalog Number Description NEMA Config. Rating 2 Pole, 2 Wire Non-Grounding 2 Pole, 2 Wire Non-Grounding Plug, Yellow, Non-Polarized Plug, Yellow, Robertson Drive, Non-Polarized Plug, Yellow, Polarized Plug, Yellow, Robertson Drive, Polarized Connector Body, Yellow, Connector Body, Yellow, Robertson Drive – – 1-15P 15A 125V HBL5865VY 1-15P 15A 125V HBL5865VYCN 1-15P 15A 125V HBL5866VY 1-15P 15A 125V HBL5866VYCN Catalog Number 1-15R 15A 125V HBL5869VY 1-15R 15A 125V HBL5869VYCN – – 2 Pole, 3 Wire Grounding 2 Pole, 3 Wire Grounding Connector Body, Yellow 5-15R Connector Body, Yellow, 5-15R Robertson Drive Connector Body, Yellow, 5-15R Robertson Drive, Bulk Pkg. Connector Body,Yellow, Bulk Pkg. 5-15R Connector Body, Gray 5-15R Connector Body,Yellow, Bulk Pkg.5-15R Connector Body, Yellow 5-15R Connector Body, Yellow, 5-15R Robertson Drive, Bulk Pkg. Connector Body, Black, 5-15R Robertson Drive 15A 125V HBL5969VY 15A 125V HBL5969VYCN Plug, Yellow Plug, Yellow, Robertson Drive Plug, Yellow, Robertson Drive, Bulk Pkg. Plug, Yellow, Bulk Pkg. 5-15P 15A 125V HBL5965VY 5-15P 15A 125V HBL5965VYCN Plug, Gray Plug, Black Plug, Black, Bulk Pkg. Plug, Black, Robertson Drive, Bulk Pkg. Plug, Black, Robertson Drive 5-15P 5-15P 5-15P 5-15P Plug, Yellow Plug, Yellow, Bulk Pkg. 5-20P 20A 125V HBL5364VY 5-20P 20A 125V HBL5364VYB Plug, Yellow, Robertson Drive Plug, Black 5-20P 20A 125V HBL5364VYCN Connector Body, Yellow, Robertson Drive 5-20P 20A 125V HBL5364VBK Connector Body, Black 5-20R 20A 125V HBL5369VBK Connector Body, Black, Bulk Pkg. 5-20R 20A 125V HBL5369VBKB Plug, Black, Bulk Pkg. 5-20P 20A 125V HBL5364VBKB Plug, Yellow 6-15P 15A 250V HBL5666VY Plug, Yellow, Robertson Drive 6-15P 15A 250V HBL5666VYCN Plug, Yellow 6-20P 20A 250V HBL5464VY Plug, Yellow, Robertson Drive 6-20P 20A 250V HBL5464VYCN 5-15P 15A 125V HBL5965VYCNB 5-15P 15A 125V HBL5965VYB 15A 15A 15A 15A 125V 125V 125V 125V HBL5965VGY HBL5965VBK HBL5965VBKB HBL5965VBKCNB 5-15P 15A 125V HBL5965VBKCN 2 Pole, 3 Wire Grounding – Hospital Grade Plug, White Plug, White, Bulk Pkg. Plug, White, Robertson Drive 5-15P 15A 125V HBL8115V 5-15P 15A 125V HBL8115VB 5-15P 15A 125V HBL8115VCN Plug, White 5-20P 20A 125V HBL8364V Plug, White Plug, White 6-20P 20A 250V HBL8464V 6-15P 15A 250V HBL8666V 15A 125V HBL5969VYCNB 15A 125V 15A 125V 15A 125V 15A 125V 15A 125V HBL5969VYB HBL5969VGY HBL5969VBK HBL5969VBKB HBL5969VBKCNB 15A 125V HBL5969VBKCN Connector Body, Yellow 5-20R 20A 125V HBL5369VY Connector Body,Yellow, Bulk Pkg. 5-20R 20A 125V HBL5369VYB 5-20R 20A 125V HBL5369VYCN Connector Body, Yellow Connector Body, Yellow, Robertson Drive 6-15R 15A 250V HBL5669VY 6-15R 15A 250V HBL5669VYCN Connector Body, Yellow Connector Body, Yellow, Robertson Drive 6-20R 20A 250V HBL5469VY 6-20R 20A 250V HBL5469VYCN 2 Pole, 3 Wire Grounding – Hospital Grade Connector Body, White 5-15R 15A 125V HBL8119V Connector Body, White, Bulk Pkg. 5-15R 15A 125V HBL8119VB Connector Body, White, 5-15R 15A 125V HBL8119VCN Robertson Drive – Connector Body, White – – 6-20P 20A 250V HBL8469V – 4 Valise Twist-Lock® Plugs and Connector Bodies One-piece Valise body. As the cord grip screws are tightened, a unique locking lug design fastens the device together to provide body strength, even in rough use. The security and reliability of a locking device combined with all the benefits of Valise design and construction. Available in black and high-visibility yellow. Insulated thermoplastic body design provides maximum safety in the face of abuse. Unique, patented clamp-type terminals provide superior electrical connection by “bundling” conductor strands when clamps are tightened. Offset cord grip design puts an unrelenting hold on the cable to prevent strain on the conductors. Cord grip inserts accommodate a wide range of cord diameters. 5 Wire the terminals, fold the Valise shut and tighten two captive assembly screws. That’s the beauty of Valise Twist-Lock plugs: the speed and ease of Valise design and the security of a locking configuration for uninterrupted power. It’s not only economical to wire these devices, they’re economical to buy. Plus, black and high-visibility yellow color choices make them ideal for use in industrial, entertainment and construction applications. Textured surface emphasizes tough, industrial design. Plugs Description Connector Bodies NEMA Config. Rating Catalog Number 15 Amp, 2 Pole, 3 Wire Grounding Plug, Plug, Plug, Plug, Black Yellow Yellow, Robertson Drive Black, Robertson Drive L5-15P L5-15P L5-15P L5-15P 15A 15A 15A 15A Description NEMA Config. Rating Catalog Number 15 Amp, 2 Pole, 3 Wire Grounding 125V 125V 125V 125V HBL4723VBK 4723VY 4723VYCN HBL4723VBKCN Connector Body, Black Connector Body, Yellow – – L5-15R 15A 125V HBL4729VBK L5-15R 15A 125V 4729VY – – Plug, Black Plug, Yellow L6-15P 15A 250V HBL4573VBK L6-15P 15A 250V 4573VY Connector Body, Black Connector Body, Yellow L6-15R 15A 250V HBL4579VBK L6-15R 15A 250V 4579VY Plug, Black Plug, Yellow L7-15P 15A 277V HBL4773VBK L7-15P 15A 277V 4773VY Connector Body, Black Connector Body, Yellow L7-15R 15A 277V HBL4779VBK L7-15R 15A 277V 4779VY 20 Amp, 2 Pole, 3 Wire Grounding 20 Amp, 2 Pole, 3 Wire Grounding Plug, Black Plug, Yellow Plug, Corrosion Resistant Yellow L5-20P 20A 125V HBL2311VBK L5-20P 20A 125V 2311VY L5-20P 20A 125V 23CM11V Connector Body, Black Connector Body, Yellow – L5-20R 20A 125V HBL2313VBK L5-20R 20A 125V 2313VY – Plug, Black Plug, Yellow L6-20P 20A 250V HBL2321VBK L6-20P 20A 250V 2321VY Connector Body, Black Connector Body, Yellow L6-20R 20A 250V HBL2323VBK L6-20R 20A 250V 2323VY Plug, Black Plug, Yellow L7-20P 20A 277V HBL2331VBK L7-20P 20A 277V 2331VY – – – – 30 Amp, 2 Pole, 3 Wire Grounding 30 Amp, 2 Pole, 3 Wire Grounding Plug, Black Plug, Yellow L5-30P 30A 125V HBL2611VBK L5-30P 30A 125V 2611VY Connector Body, Black Connector Body, Yellow L5-30R 30A 125V HBL2613VBK L5-30R 30A 125V 2613VY Plug, Corrosion Resistant Yellow L5-30P 30A 125V 26CM11V Connector Body, Corrosion Resistant Yellow L5-30R 30A 125V 26CM13V Plug, Corrosion Resistant, Black L5-30P 30A 125V 26CM11VBK – – Plug, Black L6-30P 30A 250V HBL2621VBK Connector Body, Black L6-30R 30A 250V HBL2623VBK Plug, Yellow L6-30P 30A 250V 2621VY Connector Body, Yellow L6-30R 30A 250V 2623VY 6 Insulation Displacement Straight Blade Valise Plugs and Connector Bodies Two captive tri-drive assembly screws accepts straight blade, Phillips and Robertson drivers. 7 load-bearing lugs assure positive fit as the blade holder and sides are closed. Totally insulated impact- and crush-resistant nylon body. Powerful cord grips prevent slippage and strain on wiring terminals. Nylon hinges make wiring quick and easy by joining three sections during assembly. Accommodates cords from .230" to .360" (5.8mm to 9.1mm). Insulation displacement feature eliminates the need to strip insulation on individual conductors, saving time yet assuring quality terminations. Hubbell’s insulation displacement Valise plugs and connector bodies are the right choice for economy, wiring speed and long life. With Valise plugs, assembly time is reduced by 30 to 50 percent because the insulation does not have to be stripped from individual conductors– only the outer jacket needs to be cut back. Yet, these devices deliver all the strength and reliability inherent in Hubbell’s Valise design and construction. Plugs Description Connector Bodies NEMA Config. Rating Catalog Number 2 Pole, 3 Wire Grounding Plug, Plug, Plug, Plug, 7 Black Black, Bulk Pkg. Yellow Yellow, Bulk Pkg. NEMA Config. Description Rating 2 Pole, 3 Wire Grounding 5-15P 5-15P 5-15P 5-15P 15A 15A 15A 15A 125V 125V 125V 125V HBL5966VBK HBL5966VBKB HBL5966VY HBL5966VYB Connector Connector Connector Connector Body, Body, Body, Body, Black Black, Bulk Pkg. Yellow Yellow, Bulk Pkg. 5-15R 5-15R 5-15R 5-15R 15A 15A 15A 15A 125V 125V 125V 125V 2 Pole, 3 Wire Grounding – Hospital Grade 2 Pole, 3 Wire Grounding – Hospital Grade Plug, White 5-15P 15A 125V HBL8013V Connector Body, White Plug, White, Bulk Pkg. 5-15P 15A 125V HBL8013VB Connector Body, White, Bulk Pkg. 5-15R * Available 2nd Quarter 1998 Catalog Number 5-15R HBL5963VBK* HBL5963VBKB* HBL5963VY* HBL5963VYB* 15A 125V HBL8019V* 15A 125V HBL8019VB* Midget Valise Twist-Lock® Plugs and Connector Bodies Two captive assembly screws. The security of locking devices in a compact package. Totally insulated impact- and crush-resistant nylon body. Powerful cord gripping jaws prevent slippage and strain on wiring terminals. Accommodates cord diameters from .218" to .375" (5.5mm to 9.5mm) – 2W and .300" to .430" (7.6mm to 10.9mm) – 3W. Nylon hinges join two sections together, which makes assembly quick and easy. Insulation displacement feature eliminates the need to strip insulation on individual conductors, saving time yet assuring quality terminations. “TURN & PULL” marking is highly visible, reducing possible damage to equipment by attempting disconnection prior to unlocking. Two-wire Midget Valise TwistLock plugs and connector bodies feature bundling terminals that eliminate the need to bend the wire around the terminals – just insert the stripped conductor wire into a clamp-type terminal and tighten. Three-wire models offer built-in insulation displacement terminal compartments, eliminating the need to strip insulation on individual conductors. Accessories include Seal-Tite® boots and inlet closure plug. Devices are also available in angled versions. Plugs Description Connector Bodies NEMA Config. Rating Catalog Number Description NEMA Config. 2 Pole, 2 Wire Non-Grounding 2 Pole, 2 Wire Non-Grounding Plug, Black Plug, Black, Robertson Drive – Connector Body, Black Connector Body, Black, Robertson Drive – ML-1P 15A 125V 7465V ML-1P 15A 125V 7465VCN – 2 Pole, 3 Wire Grounding Insulation Displacement Plug, Black Rating Catalog Number ML-1R 15A 125A 7464V ML-1R 15A 125A 7464VCN – 2 Pole, 3 Wire Grounding ML-2P 15A 125V 7494V Insulation Displacement Connector Body, Black ML-2R 15A 125V 7593V 8 IEC 320 Valise Connector Bodies and Panel Mount Inlets Detachable connector body allows the greatest flexibility in providing cordsets. High impact, engineered thermoplastic construction withstands severe abuse. UL Listed; CSA and TUV Certified. Black pebbled finished is attractive in any environment. Binding screw terminals with “wire bundling” feature provide reliable electrical connections. Hubbell IEC 320 panel mount inlets and detachable connector bodies are built to international standards and are approved by all of the proper agencies to speed approval for OEMs. Ideal applications include workstations, desktop publishing systems, CAD/CAM systems, professional sound equipment, medical equipment, industrial lasers, stage and specialty lighting, and cooking equipment. Plugs and Flanged Inlets Description Connector Bodies and Receptacles Rating Catalog Number 2 Pole, 3 Wire Grounding 9 Description Rating Catalog Number 20/16A 250V 20/16A 250V H320C H320R 2 Pole, 3 Wire Grounding Flanged Inlet 20/16A 250V Flanged Inlet, w/Retention Clamp 20/16A 250V H320B H320BL Plug H320P 20/16A 250V Connector Body Receptacle Valise Accessories PLUGOUT® Lockout Devices Description Catalog Number Electrical plug lockout devices for 15 Amp molded on plugs. Electrical plug lockout device for 15-30 Amp wired on plugs. HLDMP HLD Twist-Lock® Weatherproofing Accessories IP55* Suitability Catalog Description Number Yellow Seal-Tite® elastomer triple-seal cover for use with Valise plugs 60CM31V* when used in cord set and Valise connector bodies when used with flanged inlet. Yellow Seal-Tite elastomer triple seal cover for use with 60CM31V* connector bodies. *IP55 Suitability when installed and used properly with plug cover and connector body combination. Midget Twist-Lock® Weatherproofing Accessories Catalog Description Number 7490V* Seal-Tite® cover, black elastomer, for use with a 7465V when used with a 7464V connector body, or a 7464V connector body when used with a flanged inlet. Seal-Tite cover, black elastomer, for use with a 7464V connector body 7459V* and combination of 7465V plug and 7490V cover. Closure cover for use with 7466 or 7467. Bead chain is nickel-plated. 4890 Seal-Tite® cover, black elastomer, for use with a 7593V connector body 7440V* and a combination of 7594V plug and 7495V cover. Closure cover for use with 7595 or 7595N. 4889 *IP55 Suitability when installed and used properly with plug cover and connector body combination. 10 Technical Information Valise Product Specifications Electrical Other Information Screws Dielectric Voltage: 2000V Min. Max. Working Voltage: Temperature Rise: 250V 30° Max. at Full Rated Current Current Interrupting: Certified at Full Rated Current Std St. Blade/Slot/Phillips Combo I.D. Sr Blade/ Tri-Drive Midget TL, ID (CN) Slot/Robertson Combo Twist-Lock – Slotted Cord Ranges Mechanical Terminal Identification: Cable Grip Accommodation: Terminal Accommodation: Product Identification: Screw color Round Cord .220" to .660" (5.6mm to 16.8mm) 18/3 thru 12/3 Molded rating on device face 3 Wire Std. St. Blade (15 & 20A): Hospital Grade: .220" to .660" (5.6mm to 16.8mm) 18/3 12/3 .300" to 660" (7.6mm to 16.8mm) 2 Wire St. Blade (15A): St. Blade ID Valise: IEC 320 Devices (16/20A): .218" to 385" (5.5mm to 9.8mm) .230" to .360" (5.8mm to 9.1mm) .325" to .475" (8.26mm to 12mm) 16/3 12/3 .218" to .375" (5.5mm to 9.5mm) 2W Midget TL: Environmental Operating Temperatures: Max. continuous 60° C. Min. – 40° C (w/o impact). IP20 Suitability 3W Midget TL: TL Valise: .300" to .430" (7.6mm to 10.9mm) 15A .220" to .660" (5.6mm to 16.8mm) 20A .325" to .720" (8.26mm to 18.3mm) 30A .590" to .930" (15.0mm to 23.6mm) Materials Housing: Blades: Contacts: Terminal Screw: Cable Inserts: Terminal Clamps: Body Holding Screw: Toughened (high-impact) Type 66 Nylon 260 Alloy Brass 688 Alloy Brass Steel Poly Phenylene Oxide (PPO) CR Steel Steel Standards NEMA Configuration Listed to UL Standard #: UL498 Certified to CSA Standard #: CSA C22.2 No. 42 Certified to TUV: IEC Devices only at 16A 250VAC ISO 9002 CERTIFIED Hubbell Incorporated (Delaware) • 185 Plains Road • Milford, CT 06460-2420 • (203) 882-4800 • FAX (800) 255-1031 • In CT (203) 882-4849 World Wide Web URL: http://www.hubbell-wiring.com In Canada: Hubbell Canada, Inc. • 870 Brock Road South • Pickering, Ontario L1W 1Z8 • (905) 839-1138 • FAX (905) 839-9108 Hubbell De Mexico, S.A. De C.V. • Ave. Coyoacan 1051 • Col. Del Valle • 03100 Mexico D.F. • 011(525) 575-2022 • FAX 011(525) 559-8626 ® Registered trademark of Hubbell Incorporated ™Trademark of Hubbell Incorporated H4610 Printed in U.S.A. Copyright 1997, Hubbell Incorporated Specifications Subject to Change Without Notice.
HBL5965VY 价格&库存
很抱歉,暂时无法提供与“HBL5965VY”相匹配的价格&库存,您可以联系我们找货
